SLO0520H Series
SMD Molding Power Inductor
◆ Features
Pb
1、Magnetically shielded construction, low DC resistance;
2、The use of magnetic iron powder ensure capability
for large current;
3、Low audible core noise;
4、Ideal for DC-DC converter applications in hand held
personal computer and etc;
5、Frequency Range: up to 3.0MHz;
6、RoHS compliant。
◆ Applications
1、Smart phone、MID;
2、Next-generation mobile devices with multifunction such
as adding color TV and digital movie cameras;
3、Flat-screen TVs, blue-ray disc recorders, set top box;
4、Notebooks, desktop computers, servers, graphic cards;
5、Portable gaming devices, personal navigation systems,
personal multimedia devices;
6、Automotive systems;
7、Telecomm base stations。
◆ Lead Free Part Numbering
SLO 0520
(1)
(2)
H
(3)
2R2 M
(4) (5)
T
T
(6) (7)
(1)
(2)
(3)
(4)
Series Type
Dimension:A X C
Material Code
Inductance:2R2=2.2μH;
100=10μH;101=100μH
(5) Inductance Tolerance:M=±20%, Y=±30%
(6) Company Code
(7) Packaging:packed in embossed carrier tape
◆ Dimensions
Series
SLO0520H
Rev.01
A±0.2(mm)
5.4
B±0.2 (mm)
5.1
Page 1 of 4
C (mm)
2.0 Max
D±0.1 (mm)
2.0
E±0.1 (mm)
1.0
www.sunltech.com
SLO0520H Series
◆ Specification
Ω
Rdc
(m )
Test a
condition
HEAT RATING
CURRENT(Idc)
DC AMPS1
(Typ.)
SATURATION
CURRENT(Isat)
DC AMPS2
(Typ.)
μ
Typ.
Max
SLO0520HR68MTT
0.68
15
100KHz/1V
5.0
10.0
SLO0520H1R0MTT
1.0
15
21
100KHz/1V
5.0
8.0
SLO0520H1R2MTT
1.2
17
27
100KHz/1V
5.0
8.0
SLO0520H1R5MTT
1.5
100KHz/1V
4.0
6.0
SLO0520H2R2MTT
2.2
32
42
100KHz/1V
3.5
6.0
SLO0520H3R3MTT
3.3
44
58
100KHz/1V
3.5
5.5
SLO0520H4R7MTT
4.7
68
90
100KHz/1V
3.2
4.5
SLO0520H5R6MTT
5.6
75
97
100KHz/1V
3.0
4.0
SLO0520H6R8MTT
6.8
105
130
100KHz/1V
2.5
3.0
SLO0520H100MTT
10
170
221
100KHz/1V
2.0
3.0
Part Number
INDUCTANCE
Lo( H)
SLO0520H Series
NOTES:
1. DC current (Idc) that will cause an approximate T of 40
2. DC current (Isat) that will cause Lo to drop approximately 20%
3. All test data is referenced to 25 ambient
4. Operating Temperature Range -55 to +150
5. The part temperature (ambient + temp rise) should not exceed 150
under the worst operating conditions. Circuit design, component placement,
PWB trace size and thickness, airflow and other cooling provisions all affect
the part temperature. Part temperature should be verified in the end application.
Rev.01
Page 2 of 4
www.sunltech.com
SLO0520H Series
◆ Wave Soldering
◆ Hand soldering
Rev.01
Page 3 of 4
www.sunltech.com
SLO0520H Series
◆ Reliability Mechanical
℃ ~+125℃
-45℃ ~ + 1 2 5 ℃
-55
Rev.01
Page 4 of 4
www.sunltech.com
很抱歉,暂时无法提供与“SLO0520H2R2MTT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.63570
- 100+0.57720
- 500+0.51870
- 1000+0.46020
- 2000+0.42120
- 4000+0.40950
