LC1117
1A Bipolar Linear Regulator
DESCRIPTION
FEATURES
LC1117 is a series of low dropout three-terminal
regulators with a dropout of 1.3V at 1A load current.
LC1117 features a low standby current 2mA.
Other than a fixed version (Vout = 1.2V, 1.5V, 1.8V,
2.5V, 3.3V, 5V, and 12V), LC1117 has an adjustable
version, which can provide an output voltage from
1.25 to 12V with only two external resistors.
LC1117 offers thermal shut down and current limit
functions, to assure stability of chip and power
system. Trimming technique is used to guarantee
output voltage accuracy within 2%. Other output
voltage accuracy such as 1% can be customized on
demand.
LC1117 is available in SOT-223, TO-252 power
packages.
Other than a fixed version and an adjustable
version, output value can be customized on
demand.
Maximum output current is 1A
Range of operation input voltage: Max 18V
Standby current: 2mA (typ.)
Line regulation: 0.1%/V (typ.)
Load regulation: 10mV (typ.)
Environment Temperature: -40C~85C
Compatible with tantalum capacitor,
electrolytic capacitor and MLCC.
APPLICATIONS
Power Management for Computer Mother
Board, Graphic Card
LCD Monitor and LCD TV
DVD Decode Board
ADSL Modem
Post Regulators for Switching Supplies
TYPICAL APPLICATION
TYPICAL ELECTRICAL CHARACTERISTIC
LC1117
Vin
10uF
Gnd
LC1117-ADJ Vout Vs. Temp
Vout
Vout
1.5
10uF
Vout (V)
Vin
Application circuit of LC1117 fixed version
1.0
0.5
0.0
-50
50
150
250
Temperature (C)
www.leadchip.com
1
Your final power solution
LC1117
ORDERING INFORMATION
PIN CONFIGURATION
LC1117 □
1□
2□
3□
4□
5
Code
Product Classification
Marking
1117:
Product Code
B: Fab Code
1117 B
XX:
XXYYZZ
Output Voltage
YY: Lot No.
ZZ: Date Code
1117:
Product Code
B:Fab Code
1117 B XX:
XXYYZZ Output Voltage
YY:Lot No.
□1
□2
□3
□4
□5
Description
Temperature&Rohs:
C:-40~85C ,Pb Free Rohs Std.
Package type:
L:SOT-223
O:TO-252
Packing type:
TR:Tape&Reel (Standard)
Output voltage:
e.g. 12=1.2V 15=1.5V
18=1.8V 25=2.5V
33=3.3V 50=5.0V
120=12V
AD=Output adjustable
Voltage accuracy:
1=±1%(Customized)
Blank(default)=±2%
LC1117CLTR□
4□
4
LC1117COTR□
4□
4
ZZ:Date Code
Vss/Adj
Vin
Vout
TO-252
1 Vss/ADJ
2 Vout
3 Vin
1117 B
XX YYZZ
2
1
3
Ground Pin/Adjustable
Supply Voltage Input
Output Voltage
ABSOLUTE MAXIMUM RATING
Parameter
Value
18V
150C
-40C – 85C
20C / W
12.5C / W
-40C - 150C
260C, 10S
Max Input Voltage
Max Operating Junction Temperature(Tj)
Ambient Temperature(Ta)
SOT-223
Package Thermal Resistance(jc)
TO-252
Storage Temperature(Ts)
Lead Temperature & Time
Note: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect
device reliability.
RECOMMENDED WORK CONDITIONS
Parameter
Value
Max. 16V
-40C –125C
Input Voltage Range
Exceptional for LC1117-12V, the maximum input voltage for LC1117-12V is 20V.
www.leadchip.com
2
LC1117
ELECTRICAL CHARACTERISTICS
Tj=25C
Symbol
Vref
Vout
ΔVout
ΔVout
Parameter
Reference Voltage
Output Voltage
Line Regulation
Load Regulation
www.leadchip.com
Conditions
LC1117-ADJ
10mA≤Iout≤1A , Vin=3.25V
LC1117-1.2V
0≤Iout≤1A , Vin=3.2V
LC1117-1.5V
0≤Iout≤1A , Vin=3.5V
LC1117-1.8V
0≤Iout≤1A , Vin=3.8V
LC1117-2.5V
0≤Iout≤1A , Vin=4.5V
LC1117-3.3V
0≤Iout≤1A , Vin=5.3V
LC1117-5.0V
0≤Iout≤1A , Vin=7.0V
LC1117-12.0V
0≤Iout≤1A , Vin=14V
LC1117-1.2V
Iout=10mA, 2.7V≤Vin≤15V
LC1117-ADJ
Iout=10mA, 2.75V≤Vin≤16V
LC1117-1.5V
Iout=10mA, 3.0V≤Vin≤16V
LC1117-1.8V
Iout=10mA, 3.3V≤Vin≤16V
LC1117-2.5V
Iout=10mA, 4.0V≤Vin≤16V
LC1117-3.3V
Iout=10mA, 4.8V≤Vin≤16V
LC1117-5.0V
Iout=10mA, 6.5V≤Vin≤16V
LC1117-12.0V
Iout=10mA, 13.5V≤Vin≤20V
LC1117-ADJ
Vin =2.7V, 10mA≤Iout≤1A
LC1117-ADJ
Vin =2.75V, 10mA≤Iout≤1A
LC1117-1.5V
Vin=3.0V, 10mA≤Iout≤1A
LC1117-1.8V
Vin=3.3V, 10mA≤Iout≤1A
LC1117-2.5V
Vin=4.0V, 10mA≤Iout≤1A
LC1117-3.3V
Vin=4.8V, 10mA≤Iout≤1A
LC1117-5.0V
Vin=6.5V, 10mA≤Iout≤1A
LC1117-12.0V
Vin=13.5V, 10mA≤Iout≤1A
3
Min
Typ
Max
Unit
1.225
1.25
1.275
V
1.176
1.2
1.224
V
1.47
1.5
1.53
V
1.764
1.8
1.836
V
2.45
2.5
2.55
V
3.234
3.3
3.366
V
4.9
5
5.1
V
11.76
12
12.24
V
0.1
0.2
%/V
0.1
0.2
%/V
0.1
0.2
%/V
0.1
0.2
%/V
0.1
0.2
%/V
0.1
0.2
%/V
0.1
0.2
%/V
0.1
0.2
%/V
10
30
mV
10
30
mV
10
30
mV
10
30
mV
10
30
mV
10
30
mV
10
30
mV
10
30
mV
LC1117
ELECTRICAL CHARACTERISTICS continued
Tj=25C
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Iout=100mA
1.23
1.3
V
Iout=1A
1.3
1.5
V
Vdrop
Dropout Voltage
Ilimit
Current Limit
Vin-Vout=2V, Tj=25°C
Imin
Minimum Load Current
LC1117-ADJ
2
10
mA
LC1117-1.2V, Vin =10V
2
5
mA
LC1117-1.5V, Vin =12V
2
5
mA
LC1117-1.8V, Vin =12V
2
5
mA
LC1117-2.5V,Vin =12V
2
5
mA
LC1117-3.3V, Vin =12V
2
5
mA
LC1117-5.0V, Vin =12V
2
5
mA
LC1117-12.0V, Vin =20V
2
5
mA
55
120
uA
0.2
10
uA
Iq
IAdj
Quiescent Current
Adjust Pin Current
Ichange
Iadj change
ΔV/ΔT
Temperature coefficient
JC
Thermal Resistance
LC1117-ADJ
Vin =5V, 10mA≤Iout≤1A
LC1117-ADJ
1
A
±100
SOT-223
TO-252
10
TO-220
4.5
ppm
°C/W
Note1: All test are conducted under ambient temperature 25°C and within a short period of time 20ms
Note2: Load current smaller than minimum load current of LC1117-ADJ will lead to unstable or oscillation output.
BLOCK DIAGRAM
www.leadchip.com
4
LC1117
DETAILED DESCRIPTION
LC1117 is a series of low dropout voltage, three terminal regulators. Its application circuit is very simple:
the fixed version only needs two capacitors and the adjustable version only needs two resistors and two capacitors to
work. It is composed of some modules including start-up circuit, bias circuit, bandgap, thermal shutdown, current limit,
power transistors and its driver circuit and so on.
The thermal shut down modules can assure chip and its application system working safety when the junction
temperature is larger than 140°C.
The bandgap module provides stable reference voltage, whose temperature coefficient is compensated by careful design
considerations. The temperature coefficient is under 100 ppm/°C. And the accuracy of output voltage is guaranteed by
trimming technique.
TYPICAL APPLICATION
LC1117 has an adjustable version and six fixed versions (1.2V, 1.5V, 1.8V, 2.5V, 3.3V, 5V and 12V)
Fixed Output Voltage Version
LC1117
Vin
Vin
10uF
Vout
Vout
10uF
Gnd
1) Recommend using 10uF tan capacitor as bypass capacitor (C1) for all application circuit.
2) Recommend using 10uF tan capacitor to assure circuit stability.
Adjustable Output Voltage Version
LC1117-ADJ provides a 1.25V reference voltage. Any output voltage between 1.25V~12V can be achievable by
choosing two external resistors (schematic is shown below), R1 and R2
LC1117-ADJ
Vin
Vin
10uF
Vout
Vout
ADJ
R1
10uF
R2
Application Circuit of LC1117-ADJ
The output voltage of adjustable version follows the equation: Vout=1.25(1+R2/R1)+IAdjR2. We can ignore
IAdj because IAdj (about 50uA) is much less than the current of R1 (about 2~10mA).
www.leadchip.com
5
LC1117
1)
To meet the minimum load current (>10mA) requirement, R1 is recommended to be 125ohm or lower. As
LC1117-ADJ can keep itself stable at load current about 2mA, R1 is not allowed to be higher than 625ohm.
2)
Using a bypass capacitor (CADJ) between the ADJ pin and ground can improve ripple rejection. This bypass
capacitor prevents ripple from being amplified as the output voltage is increased. The impedance of CADJ
should be less than R1 to prevent ripple from being amplified. As R1 is normally in the range of
100Ω~500Ω, the value of CADJ should satisfy this equation: 1/(2frippleCADJ)
