KIA
8A,500V
N-CHANNEL MOSFET
840S
SEMICONDUCTORS
1. Features
n
RDS(ON)=0.7Ω (typ) @VGS=10V
n
RoHS compliant
n
Low on resistance
n
Low gate charge
n
Peak current vs pulse width curve
2. Applications
n
Adaptor
n
TV main power
n
SMPS power supply
n
LCD panel power
3.Symbol
1 of 6
Pin
Function
1
Gate
2
Drain
3
Source
4
Drain
Rev 1.2 JAN 2016
KIA
8A,500V
N-CHANNEL MOSFET
840S
SEMICONDUCTORS
4. Absolute maximum ratings
(TC=25°C,unless otherwise specified)
Units
Rating
Parameter
Symbol
Drain-source voltage
Continuous drain current
Continuous drain current TC=100 ºC
Pulsed drain current
Power dissipation
Derating factor above 25℃
Gate-source voltage
Single pulse avalanche energy
Avalanche energy, repetitive
Avalanche current
Peak diode recovery dv/dt
Gate-source ESD(HBM-C=100pF,R=1.5KΩ)
VDSS
ID
IDMa1
PD
VGS
EASa2
EARa1
IAR a1
dv/dt a3
VESD(G-S)
Operating junction and storage temperature
range
Maximum temperature for soldering
TO-220
TO-252,
TO-263
500
8.0
5.5
28
160
100
1.28
0.8
+20
400
30
7.0
5.5
4000
V
A
A
A
W
W/ ºC
V
mJ
mJ
A
V/ns
V
TJ ,TSTG
150,-55 to150
ºC
TL
300
ºC
*Drain current limited by maximum junction temperature
Caution:Stresses greater than those listed in the”Absolute maximum ratings”table may cause permanent
Damage to the device
5. Thermal characteristics
Parameter
Symbol
Rating
Unit
Junction-case
RθJC
1.04
ºC/W
Junction-ambient
RθJA
100
ºC/W
Test condition
Drain lead soldered to water cooled heatsink,PD
adjusted for a peak junction temperature of +150 ºC
1 cubic foot chamber,free air
2 of 6
Rev 1.2 JAN 2016
KIA
8A,500V
N-CHANNEL MOSFET
840S
SEMICONDUCTORS
6. Electrical characteristics
Parameter
Drain-source breakdown voltage
Bvdss temperature coefficient
Symbol
BVDSS
△BVDSS/△TJ
Test Conditions
Min Typ Max Units
VGS=0V,ID=250μA
500
V
Reference 25℃
ID=250uA
0.74
25
V/ºC
Gate source breakdown voltage
VGSO
Gate-source forward leakage
IGSS(F)
VDS=500V, VGS=0V
TA=25°C
VDS=400V, VGS=0V
TA=125°C
IGS=+1mA
(open drain)
VGS=20V
Gate-source reverse leakage
IGSS(R)
VGS=-20V
-10
Drain-source on-resistance
RDS(on)
VGS=10V,ID=4A
0.7
0.9
Ω
Gate threshold voltage
VGS(TH)
VDS= VGS, ID=250uA
2
3
4
V
Forward transconductance
Input capacitance
Output capacitance
Reverse transfer capacitance
Turn-on delay time
Rise time
Turn-off delay time
Fall time
Total gate charge
Gate-source charge
Gate-drain charge
Continuous source current(body biode)
gfs
Ciss
Coss
Crss
td(on)
tr
td(off)
tf
Qg
Qgs
Qgd
IS
VDS=15V, ID=3A
8.5
960
110
10
11
17
46
22
24
4.0
10
8
S
Maximum pulsed current(body biode)
Diode forward voltage
Reverse recovery time
Reverse recovery charge
Reverse recovery current
Pulse width tp
很抱歉,暂时无法提供与“KIA840SB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.75451
- 30+1.69401
- 100+1.57301
- 500+1.45200
- 1000+1.39150
- 国内价格
- 1+2.45160
- 10+1.94400
- 30+1.73880
- 100+1.46880
