Advance Info
TF1503U
Half-Bridge Gate Driver
Features
Description
Floating
high-side driver in bootstrap operation to 600V
Drives
two N-channel MOSFETs or IGBTs in a half bridge
configuration
Designed for enhanced performance in noisy motor
applications
300mA source/550mA sink output current capability
Outputs tolerant to negative transients
Internal dead time of 420ns to protect MOSFETs
Wide low side gate driver supply voltage: 10V to 20V
Logic input (HIN and LIN*) 3.3V capability
Schmitt triggered logic inputs
Undervoltage lockout for VCC (logic and low side supply)
Extended temperature range: -40°C to +125°C
The TF1503U is a high voltage, high speed gate
driver capable of driving N-channel MOSFETs and IGBTs
in a half bridge configuration. TF Semiconductors’s
high voltage process enables the TF2103U high side to
switch to 250V in a bootstrap operation.
The TF1503U logic inputs are compatible with
standard TTL and CMOS levels (down to 3.3V) to
interface easily with controlling devices. The driver
outputs feature high pulse current buffers designed for
minimum driver cross conduction. TF1503U has a
fixed internal deadtime of 420ns (typical).
The TF1503U is offered in a SOIC-8(N) package and
operates over an extended -40 °C to +125 °C temperature
range.
Applications
Motor Controls
DC-DC Converters
AC-DC Inverters
Motor Drives
SOIC-8(N)
Ordering Information
Typical Application
Up to 600V
PART NUMBER PACKAGE
SOIC-8(N)
TF1503U-TAU
PACK / Qty
Tube / 100
MARK
YYWW
SOIC-8(N)
T&R / 2500
Lot ID
TF1503U-TAH
VCC
VCC
VB
HIN
HIN
HO
LIN*
LIN*
R4
COM
www.tfsemi.com
April 2020
TF1503U
Year Year Week Week
TF1503U
TO
LOAD
VS
LO
Rev 1.0
1
Advance Info
TF1503U
Pin Diagrams
VCC
1
8
VB
HIN
2
7
HO
LIN*
3
6
VS
COM
4
5
LO
Top View: SOIC-8
TF1503U
Pin Descriptions
PIN NAME
PIN NUMBER
PIN DESCRIPTION
VCC
1
Logic and low side supply
HIN
2
Logic input for high-side gate driver output in phase with HO
LIN*
3
Logic input for low-side gate driver output out of phase with LO
COM
4
Low-side and logic return
LO
5
Low-side gate drive output
VS
6
High-side floating supply return
HO
7
High-side gate drive output
VB
8
Functional Block Diagram
VCC
Vcc
TF1503U
UV
Detect
HIN
Pulse
Gen
HV Level
Shift
Dead
time
R
Q
HO
R
S
High Voltage Well
Vs
VCC
+5V
LIN*
VB
UV UV
Detect
Detect
Delay
LO
COM
April 2020
2
Advance Info
TF1503U
Absolute Maximum Ratings (NOTE1)
A
VB - High side floating supply voltage.....................-0.3V to +274V
VS - High side floating supply offset voltage....VB -24V to VB+0.3V
VHO - High side floating output voltage...................VS-0.3V to VB+0.3V
dVS / dt - Offset supply voltage transient...................................50 V/ns
PD - Package power dissipation at TA ≤ 25 °C
SOIC-8.............................................................................................0.625W
VCC - Low-side fixed supply voltage...............................-0.3V to +24V
VLO - Low-side output voltage....................................-0.3V to VCC +0.3V
VIN - Logic input voltage (HIN and LIN*)..................-0.3V to VCC +0.3V
NOTE1 Stresses beyond those listed under “Absolute Maximum Ratings” may cause
permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational
sections of the specifications is not implied. Exposure to absolute maximum rating
conditions for extended periods may affect device reliability.
SOIC-8(N) Thermal Resistance (NOTE2)
qJA ...............................................................................................200 °C/W
TJ - Junction operating temperature........................................+150 °C
TL - Lead Temperature (soldering, 10 seconds).......................+300 °C
Tstg - Storage temerature ......................................................-55 to 150 °C
NOTE2 When mounted on a standard JEDEC 2-layer FR-4 board.
Recommended Operating Conditions
Symbol
Parameter
MIN
MAX
Unit
VB
High side floating supply absolute voltage
VS + 10
VS + 20
V
VS
NOTE3
250
V
VHO
VS
VB
V
VCC
Low side fixed supply voltage
10
V
VLO
Low side output voltage
VCC
V
VIN
V
TA
Ambient temperature
-40
125
°C
NOTE3 Logic operational for VS of -5V to +600V.
April 2020
3
Advance Info
TF1503U
DC Electrical Characteristics (NOTE4)
VBIAS (VCC, VBS ) = 15V, TA = 25 °C , unless otherwise specified.
Symbol
Parameter
Conditions
MIN
VIH
Logic “1” (HIN) & Logic “0” (LIN*) input voltage
2.5
VIL
Logic “0” (HIN) & Logic “1” (LIN*) input voltage
VCC = 10V to 20V
NOTE5
VOH
High level output voltage, VBIAS - VO
IO = 2mA
0.05
0.2
VOL
Low level output voltage, VO
IO = 2mA
0.02
0.1
ILK
Offset supply leakage current
VB = VS = 250V
IBSQ
Quiescent VBS supply current
VIN = 0V or 5V
7
50
ICCQ
Quiescent VCC supply current
VIN = 0V or 5V
350
500
IIN+
Logic “1” input bias current
HIN = 5V, LIN* = 0V
3
10
IIN-
Logic “0” input bias current
HIN = 0V, LIN* = 5V
VCCUV+
VCC supply under-voltage positive going
threshold
7.0
8.4
9.8
VCCUV-
VCC supply under-voltage negative going
threshold
6.5
7.8
9.3
VBSUV+
VBS supply under-voltage positive going
threshold
3.6
4.5
5.6
V
VBSUV-
VBS supply under-voltage negative going
threshold
3
3.7
4.6
V
IO+
Output high short circuit pulsed current
130
300
IO-
Output low short circuit pulsed current
VO = 0V, PW ≤ 10 ms
TYP
MAX
Unit
0.8
V
50
mA
5
V
mA
270
550
NOTE4 The VIN, VTH, and IIN parameters are applicable to the two logic input pins: HIN and LIN*. The VO and IO parameters are applicable to the respective output pins: HO and LO.
VO = 15V, PW ≤ 10 ms
NOTE5 For optimal operation, it is recommended that the input pulse (to IN and SD*) should have an amplitude of 2.5V minimum with a pulse width of 1ms minimum.
April 2020
4
Advance Info
TF1503U
AC Electrical Characteristics
VBIAS (VCC, VBS ) = 15V, CL = 1000pF, and TA = 25 °C , unless otherwise specified.
Symbol
Parameter
Conditions
ton
Turn-on propagation delay
toff
Turn-off propagation delay
tDM
Delay matching, HS & LS turn-on/turn-off
tr
Turn-on rise time
tf
Turn-off fall time
tDT
Deadtime: tDT LO-HO & tDT HO-LO
April 2020
MIN
TYP
MAX
VS = 0V
560
820
VS = 250V
150
220
70
VS = 0V
300
80
170
35
90
420
650
Unit
ns
5
Advance Info
TF1503U
Timing Waveforms
50%
50%
LIN*
tON
LO
HIN
tr
tOFF
90%
90%
tf
10%
10%
LIN*
50%
50%
HIN
HO
tON
LO
HO
Figure 1. Input / Output Timing Diagram
HIN
LIN*
50%
tr
tOFF
90%
90%
10%
tf
10%
Figure 2. Switching Time Waveform Definitions
50%
90%
HO
10%
LO 90%
tDT LO-HO
tDT HO-LO
10%
Figure 3. Deadtime Waveform Definitions
April 2020
6
Advance Info
TF1503U
Package Dimensions (SOIC-8 N)
Please contact support@telefunkensemi.com for package availability.
April 2020
7
Advance Info
TF1503U
Revision History
Rev.
Change
Owner
1.0
First release, AI datasheet
Duke Walton
Date
04/10/2020
Important Notice
TF Semiconductor Solutions (TFSS) PRODUCTS ARE NEITHER DESIGNED NOR INTENDED FOR USE IN MILITARY AND/OR
AEROSPACE, AUTOMOTIVE OR MEDICAL DEVICES OR SYSTEMS UNLESS THE SPECIFIC TFSS PRODUCTS ARE SPECIFICALLY
DESIGNATED BY TFSS FOR SUCH USE. BUYERS ACKNOWLEDGE AND AGREE THAT ANY SUCH USE OF TFSS PRODUCTS WHICH TFSS
HAS NOT DESIGNATED FOR USE IN MILITARY AND/OR AEROSPACE, AUTOMOTIVE OR MEDICAL DEVICES OR SYSTEMS IS SOLELY AT
THE BUYER’S RISK.
TFSS assumes no liability for application assistance or customer product design. Customers are responsible for their products and
applications using TFSS products.
Resale of TFSS products or services with statements different from or beyond the parameters stated by TFSS for that product or
service voids all express and any implied warranties for the associated TFSS product or service. TFSS is not responsible or liable for
any such statements.
©2020 TFSS. All Rights Reserved. Information and data in this document are owned by TFSS wholly and may not be edited
, reproduced, or redistributed in any way without the express written consent from TFSS.
For additional information please contact support@tfsemi.com or visit www.tfsemi.com
April 2020
8
很抱歉,暂时无法提供与“TF1503U-TAH”相匹配的价格&库存,您可以联系我们找货
