TMI3359
1.5MHz, 30V, 1.2A FPWM Synchronous Step-Down Converter
Features
Description
Wide Input Range: 4.5V to 30V
The TMI3359 is a high efficiency 1.5MHz,
Feedback Voltage: 0.8V±2%
synchronous step-down DC-DC converter capable
1.5MHz Switch Frequency
of delivering up to 1.2A current with force PWM
Up to 1.2A Output Current
Force Constant Current PWM Operation
COT control to achieve fast transient
operation and adopts COT control with fast
transient
response
performance.
TMI3359
integrates both high and low side switch with low
RDS(ON) to minimize the conduction loss. Low output
responses
voltage ripple and small external inductor and
Integrated internal compensation
capacitor size are achieved with 1.5MHz switching
Stable with Low ESR Ceramic Output
frequency.
Capacitors
The TMI3359 requires a minimum number of
Over Current Protection with Hiccup Mode
readily available standard external components
Thermal Shutdown
and is available in a 6-pin SOT23-6 RoHS
Inrush Current Limit and Soft Start
compliant package.
Build in Input Over Voltage Protection
Available in SOT23-6 Package
Application
⚫ Security Equipment
⚫ Distributed Power Systems
⚫ Flat Panel Television and Monitors
⚫ Smart Home
⚫ Industrial Power Systems
Typical Application
Efficiency
VOUT=3.3V, IOUT=0.001A to 1.2A, TA=25°C
0.1µF
VIN= 4.5V-30V
CIN1
CIN2
10µF
100nF
L
BS
IN
4.7µH
VOUT= 3.3V
LX
R3
100kΩ
R1
39kΩ
Cfb
27pF
EN
FB
GND
CO1
R2
12.5kΩ
22µF
TMI3359 Typical Application Circuits (VREF=0.8V)
TMI and SUNTO are the brands of TOLL microelectronic
TMI3359 V1.0 – 2021.04
100%
90%
80%
70%
60%
50%
40%
30%
20%
10%
0%
Efficiency
C4
5V-3.3V
12V-3.3V
24V-3.3V
0.4
0.6
0.8
Output Current (A)
1
1.2
www.toll-semi.com
1
TMI3359
Absolute Maximum Ratings (Note 1)
Parameter
Min
Max
Unit
Input Supply Voltage
Enable pin, EN
LX Voltages
LX Voltages (
很抱歉,暂时无法提供与“TMI3359”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.85399
- 20+0.77864
- 100+0.70328
- 500+0.62793
- 1000+0.59277
- 2000+0.56765
