序号Serial No.2022-04-22-04
TAE雅晶
日期Date:2022-04-22
致TO:
华秋
产品ITEM:
石英晶体谐振器
型号TYPE:
HC-49SMD-2PIN
QUARTZ CRYSTAL UNITS
标称频率NOMINAL FREQUENCY: 8.000MHz/20PF/±30ppm/70Ω
请收到我们的规格书后,签字回传。
Please confirm you received this specification,sign and fax it to us.
接收确认RECEIVING CONFIRMATION
日期DATA
接收RECEIVED
浙江雅晶電子有限公司
ZheJiang ABEL Electron Co.,Ltd.
浙江省台州市椒江区枫南东路757号
NO.757 Fengnan East Road,Jiaojiang District,
Taizhou,Zhejiang,China
電話/Tel:0086-576-89025257
傳真/Fax:0086-576-8501860
URL:www.taecn.com
Email: 13306567515@163.com
Post Code:318000
擬制Prepared by:
应金会
批准Confirmed by:
王琴飞
ABEL ELECTRO
CRYSTAL UNITS(Metal-can Type) 石英晶体谐振器(HC-49SSMD) 浙江雅晶电子有限公司
RoHS Compliant Standard
HC-49SMD-2PIN
Features 特性
标称频率
Nominal Frequency
适用于卓越的CPU时钟信号发生器
Excellent clock signal generator for CPU's
适用于宽广的温度范围
Available in extended temperature range
STANDARD SPECIFICATIONS 标准规格
Model
Item
HC-49SMD-2PIN
Conditions
标称频率
8MHz(Fund)
Need to specify
Frequency Tolerance
调整频差
±30ppm
at 25℃
Freq. Tol. Over Temp.
温度频差
±30ppm
–40~+85℃
Nominal Frequency
Operating Temp. Range 工作温度范围
Series Resistance
谐振电阻
70ΩMax.
at 25℃
Load Capacitance
负载电容
20pF
Need to specify
Shunt Capacitance
静态电容
7.0pF Max.
Drive Level
激励电平
100μw Max.
±5ppm Max.
25±3℃
500Mohm Min.
DC100V±15V
Aging[first year]
Insulation Resistance
第一年老化率
绝缘阻抗
OUTLINE DRAWING OF HC-49SMD-2PIN(mm)
http://www.taecn.com
FREQUENCY VS.TEMPERATURE
可靠性1Reliability(Mechanical and Environmental Endura
ABEL ELECTRON
浙江雅晶电子有限公司
Page 1 of 2
No.
Test Items
1 振动
Vibration
2 冲击
Shock
Test Method and Condition
Requirements
(1)振动频率Vibration Frequency 10 to 55Hz
频率变化最大:±5ppm
(2)振动幅度Vibration Amplitude 1.5mm
Frequency Change:±5ppm Max.
(3)周期 Cycle Time 1-2min(10-55-10Hz)
电阻变化最大:±15%或5ohm
(4)振动方向Direction
Resistance Change:±15% or
X.Y.Z
(5)振动时间Duration 2h/each direction
5ohm Max.
从75cm高的地方自由跌落3次到30mm厚的硬木板上
频率变化最大:±5ppm
3 Times free drop from 75cm height to hard wooden
board of thickness more than 30mm
电阻变化最大:±15%或5ohm
5ohm Max.
3 气密性
Leakage
晶体放入氦加压罐内,充入氦气压力0.5-0.6Mpa保持1小时,
漏气率小于:1x10¯8mbar.l/s
然后使用氦质谱检漏仪测试。
Leakage:1x10¯8mbar.l/s Max.
Put crystal units into a hermetic container and Helium for 0.5-0.6
Mpa,and keep it for 1h;Check the leakage by a Helium leak detector
4 可焊性
Solderability
将引线浸入完全熔化的焊锡锅内3-5s,焊锡温度245℃±5℃
浸过引线面积的95%以上被新焊锡
Put the leads of crystal units into solder melted tank for 3 to 5s
覆盖The dipped surface of the
Temperature of solder melted tank is 245℃±5℃
leads should be at least 95% covered
with continuous new solder coating.
5 回流焊接
Reflow soldering
推荐使用如下图所示的回流焊曲线.
频率变化最大:±5ppm
The recommended reflow soldering profile
电阻变化最大:±15%或5ohm
5ohm Max.
ABEL ELECTRON
可靠性2Reliability(Mechanical and Environmental Endurance) 浙江雅晶电子有限公司
Page 2 of 2
No.
Test Items
6 耐高温能力
Requirements
晶体放置于85℃±2℃环境中 2小时后,常温放置1-2小时
频率变化最大:±5ppm
High Temperature
The crystal units shall be put in somewhere for 2 hours at
Endurance
temperature of 85℃±2℃,then keep it for 1 to 2 hours under room
电阻变化最大:±15%或5ohm
temperature
Resistance Change:±15% or 5ohm Max
晶体放置于-25℃ 环境中2小时后,常温放置1-2小时
频率变化最大:±5ppm
Low Temperature
Endurance
temperature of -25℃,then keep it for 1 to 2 hours under room
电阻变化最大:±15%或5ohm
temperature
晶体放置于40℃ 、相对湿度90-95%环境中48小时后,常温放
频率变化最大:±5ppm
7 耐低温能力
8 耐湿性
Humidity Endurance 置1-2小时The crystal units shall be put in somewhere
at 40℃ in relative humidity of 90-95% for 48 hours,then keep it for 电阻变化最大:±15%或5ohm
9 高低温循环
Temperature Cycle
one or two hours under room temperature
温度从-40℃(保持30分钟)升高到100℃(保持30分钟),
频率变化最大:±5ppm
再降到-40℃(保持30分钟)然后回到室温25℃完成一个循环, Frequency Change:±5ppm Max.
共计5个循环
电阻变化最大:±15%或5ohm
Temperature shift from low(-40℃) to high(100℃,keep 30 minutes), Resistance Change:±15% or 5ohm Max
satisfy high(100℃) to low(-40℃,keep 30 minutes),then
go up to room temperature for 5 cycles
ABEL ELECTRON
使用说明Processing Instructions
浙江雅晶电子有限公司
下面的说明和信息供用户正确理解和使用我们公司的石英晶体系列产品 ,预防不当的加工方式
对石英晶体的损坏 ,确保用户设备的可靠性
The following instructions and information are provided for the purpose of having the user understand
the proper way to process our crystal products to prevent problems prior to use and enhance the reliability
of the equipment to which they are applied.
PROCESSING INSTRUCTIONS
No.
1
石英晶体意外跌落 When dropped by mistake
设计和制造的石英晶体本身具有耐冲击能力 ,但是当石英晶体组件经受剧烈的机械冲击 ,如跌落到地板上或安装期间剧烈震
动时,在使用之前需要进行电性能确认
The crystal units are designed and manufactured to resist physical shocks.However,when the crystal units are subjected to excessive
impact such as being dropped onto the floor or giving shocks during processing,need to make sure its satisfactory performance
before using it.
2
回流炉焊接曲线Soldering
250℃
The REFLOW SOLDERING PROFILE
as below is recommended for HC-49SM
3
石英晶体组件的清洗 CLEANING
(1)恶劣的超声波清洗或超声波焊接可能会影响和损坏石英晶体组件 。如果您对晶体组件进行了超声波清洗 ,请一定在使用前
确认晶体组件是否受到了影响和损坏
Crystal units may be sffected and destroyed at worst by supersonic cleaning or supersonic welding.Please be sure to check if your
cleaning and welding process sffects any damage to crystal units before using.
(2)有些清洗液也可能造成晶体组件的损坏 ,请在使用清洗液前确认该清洗液是否适用
Some kinds of cleaning fluid may cause any damage to crystal units.Please be sure to check suitability of the cleaning fluid in advance.
4
贮存STORAGE
石英晶体组件长时间贮存在高温或高湿环境中 ,可能会影响频率的稳定性或可焊性 。请将晶体组件贮存在正常的温度和湿度
环境中,避免阳光直射和露水凝结 ,避免贮存6个月以上再使用,拆封后尽快装配使用。
Storage of crystal units under higher temperature or high humidity for a long term may affects frequency stability or solderability.
Please store the crystal units under the normal temperature and humidity without exposing to direct sunlight and dew condensation
,and avoid the storage of crystal units for more than 6 months,and mount them as soon as possible after unpacking.
ABEL ELECTRON
编带带头带尾规格CARRIER TAPE LEADER AND TRAILER SPECIFICATIONS 浙江雅晶电子有限公司
编带带头带尾规格符合美国电子工业协会EIA-481-B电子组件编带标准
Carrier tape leader and trailer form conform to EIA-481-B
ψ1.50
1.75
±0.1
4.00±0.10
2.00±0.01
A'
24.00±0.
-0
5°
ψ2.10Min
0.40±0.0
B
+ 0.10
15.05±0.10
12.00±0.10
11.50±
0.10
载带带头带尾示意图CARRIER TAPE LEADER AND TRAILER SKETCH
B
User Direction of Feed
A0
2.90±0.10
K0
Unit:mm
2.5
25.4±1.0
B'
A
SEC A-A'
A0=4.85±0.10
B0=13.70±0.10
SEC B-B'
K0=4.10±0.10
Unit:mm
Center Hole
1.5
ψ100
ψ330
ψ13.2±0.2
Center Hole(Enlarge)
1000pcs/per reel
rubber
PCBadhesive
PCB
rubber adhesive
ABEL ELECTRON
编带带头带尾规格符合美国电子工业协会EIA-481-B电子组件编带标准Carrier tape leader and trailer
form conform t
E
-4
带头
Leader
带尾
Trailer
盖带
Cover tape
空白带头最少要留400-450mm,其中最少留240mm长的盖带The length of cover tape is m
than 400mm to 450mm including empty embossed area and thelength of pure cover tape is
more than 240mm
载带
Carrier tape
当所有的组件编完后,必须最少留20只空位或160mm-180mm长空位,这些空位全部用
盖带密封After all products were packaged,must remain more than 20pcs or 160
empty area,which should be sealed by cover tape.
盖带
Cover tape
盖带的前端先用纸胶带固定,然后在载带盘中心轴上绕一圈The tip of cover tape sh
be fixed temporary by paper tape and roll the core of reel one round
载带
Carrier tape
封好盖带的空载带最少余留160mm-200mm. The empty embossed area which are seal
top cover tape must remain more than 160mm-200mm.
t
b
1
ABEL ELECTRON
包装 PACKING
浙江雅晶电子有限公司
Label
a
Label a
360MM
Label a
450MM
360MM
很抱歉,暂时无法提供与“T4M800003211”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.45001
- 100+0.42001
- 300+0.39001
- 500+0.36000
- 2000+0.34500
- 5000+0.33600
