OP07C/OP07D
Very low offset single bipolar operational amplifier
Features
Extremely low offset: 150µV/ max.
Low input bias current: 1.8nA
LOW Vio drift: 0.5µV/°C
Ultra stable with time: 2µV/month max.
Wide supply voltage range: ±3V to ± 22V
Temperature range: 0°C to -105°C
Description
The OP07 is a very high precision op-amp with an
offset voltage maximum of 150µV.
Offering also low input current (1.8nA) and high
gain (400V/mV), the OP07 is particularly
suitable for instrumentation applications.
ORDERING INFORMATION
DEVICE
Package Type
MARKING
Packing
Packing Qty
OP07CPG
DIP8
OP07C
TUBE
2000/box
OP07DPG
DIP8
OP07D
TUBE
2000/box
OP07CDRG
SOP8
OP07C
REEL
2500/reel
OP07DDRG
SOP8
OP07D
REEL
2500/reel
Offset Null 1
1
8
Inverting Input
2
7
V CC
Non-inverting Input
3
6
Output
4
5
N.C.
V CC
深圳市汉芯半导体有限公司
http://www.hanschip.com
1
Offset Null 2
2022 JAN
OP07C/OP07D
1
Schematic diagram
Figure 1.
Schematic diagram
VCC
R2A
R2B
Offset
Null
R1A
N2
R7
C1
R1B
N4
T15
T9
T10
T18
D8
T5
Non-inverting
input
Inverting
input
D9
T3
T6
T4
R3
T7
Output
C3
D6
D1
D4
D3
R9
D7
T1
R4 D2
T8
C2
D11
R10
D5
T12
T17
R5
T2
T16
T13
T11
D10
T14
R6
R8
VCC
Figure 2.
Input offset voltage nulling circuit
Offset Null 1
20kΩ
Offset Null 2
VCC
深圳市汉芯半导体有限公司
2
2022 JAN
OP07C/OP07D
2
Absolute maximum ratings
Table 1.
Symbol
Parameter
Value
Unit
VCC
Supply voltage
± 22
V
Vid
Differential input voltage
± 30
V
Vi
Input voltage
± 22
V
Toper
Operating temperature
-40 to 85
°C
Tstg
Storage temperature
-65 to 150
°C
Rthja
Thermal resistance junction to ambient(1) (2)
DIP8
85
°C/W
Rthjc
Thermal resistance junction to case(1) (2)
DIP8
41
°C/W
HBM: human body model(3)
1.5
kV
200
V
1.5
kV
ESD
MM: machine
model(4)
CDM: charged device model
(5)
1. Short-circuits can cause excessive heating and destructive dissipation.
2. Rth are typical values.
3. Human body model: 100pF discharged through a 1.5kΩ resistor between two pins of the device, done for
all couples of pin combinations with other pins floating.
4. Machine model: a 200pF cap is charged to the specified voltage, then discharged directly between two pins
of the device with no external series resistor (internal resistor < 5Ω). Done for all couples of pin
5. Charged device model: all pins plus package are charged together to the specified voltage and then
discharged directly to the ground.
深圳市汉芯半导体有限公司
3
2022 JAN
OP07C/OP07D
3
Electrical characteristics
Table 2.
VCC+ = 15 V, VCC- = Ground, Tamb = 25° C (unless otherwise specified)
Symbol
OP07C
Parameter
Min.
Vio
DVio
Iio
Typ.
0°C ≤ Tamb ≤ +105°C
60
85
Long term input offset - voltage stability (1)
0.4
Input offset voltage drift
OP07D
Max.
Min.
Typ.
Unit
150
250
µV
uV/Mo
0.5
Input offset current (Vic = 0V)
0°C ≤ Tamb ≤ +105°C
Max.
2.5
uV/°C
0.8
6
7
0.8
6
7
nA
DIio
Input offset current drift
15
50
15
50
pA/°C
DIib
Input bias current drift
15
50
15
50
pA/°C
Ro
Open loop output resistance
60
60
Ω
Rid
Differential input resistance
33
33
MW
Ric
Common mode input resistance
120
120
GW
Vicm
Input common mode voltage range
0°C ≤ Tamb ≤ +105°C
±13
±13
±13.5
±13
±13
±13.5
CMR
Common-mode rejection ratio (Vic = Vicm -min)
0°C ≤ Tamb ≤ +105°C
100
97
120
94
94
110
106
SVR
Supply voltage rejection ratio (VCC = ±3 to ±18V)
0°C ≤ Tamb ≤ +105°C
90
86
104
90
86
104
Avd
Large signal voltage gain
VCC = ±15, RL = 2kΩ, VO = ±10V
0°C ≤ Tamb ≤ +105°C
VCC = ±3, RL = 500Ω, VO = ±0.5V
120
100
100
400
120
100
100
400
±12
±11.5
±13
±12.8
±12
±12
±11.5
±13
±12.8
±12
V
0.17
0.17
V/us
0.5
0.5
MHz
Vopp
SR
GBP
Output voltage swing
RL = 10kΩ
RL = 2kΩ
RL = 1kΩ
0°C ≤ Tamb ≤ +105°C RL = 2kΩ
Slew rate ( LR= 2kΩ, CL
±11
= 100pF)
Gain bandwidth product
(RL = 2kΩ, CL = 100pF, f = 100kHz)
dB
dB
V/mV
400
±11
0.67
5
6
1.3
0.67
5
6
1.3
en
Equivalent input noise voltage
f = 10Hz
f = 100Hz
f = 1kHz
11
10.5
10
11.5
11
10.5
10
11.5
nV
-----------Hz
in
Equivalent input noise current
f = 10Hz
f = 100Hz
f = 1kHz
0.3
0.2
0.1
0.9
0.3
0.2
0.3
0.2
0.1
0.9
0.3
0.2
pA
-----------Hz
ICC
Supply current - no load
0°C ≤ Tamb ≤ +105°C
VCC = ±3V
400
V
2.7
2.7
mA
1. Long term input offset voltage stability refers to the average trend line of Vio vs time over extended periods after the first 30
days of operation.
深圳市汉芯半导体有限公司
4
2022 JAN
OP07C/OP07D
PACKAGE
SOP8
Dimensions In Millimeters
Symbol
Min
Max
Symbol
Min
Max
A
1.225
1.570
D
A1
Q
B
a
C
b
C1
DIP8
深圳市汉芯半导体有限公司
5
2022 JAN
OP07C/OP07D
Important statement:
Huaguan Semiconductor Co,Ltd. reserves the right to change
the products and services provided without notice. Customers
should obtain the latest relevant information before ordering,
and verify the timeliness and accuracy of this information.
Customers are responsible for complying with safety
standards and taking safety measures when using our
products for system design and machine manufacturing to
avoid potential risks that may result in personal injury or
property damage.
Our products are not licensed for applications in life support,
military, aerospace, etc., so we do not bear the consequences
of the application of these products in these fields.
Our documentation is only permitted to be copied without
any tampering with the content, so we do not accept any
responsibility or liability for the altered documents.
深圳市汉芯半导体有限公司
6
2022 JAN
很抱歉,暂时无法提供与“OP07CDRG”相匹配的价格&库存,您可以联系我们找货
