MMBT4403
MMBT3904
AO3400
SI2305
MMBT4403
TRANSISTOR (PNP)
FEATURES
Epitaxial Planar Die Construction
Complementary NPN Type Available
(MMBT4401)
Ideal for Medium Power Amplification and
Switching
SOT-23
1.BASE
2.EMITTER
3.COLLECTOR
MARKING:2T
MAXIMUM RATINGS (TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Units
VCBO
Collector-Base Voltage
-40
V
VCEO
Collector-Emitter Voltage
-40
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current -Continuous
-0.6
A
PC
Collector Power Dissipation
0.3
W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55-150
ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified)
Parameter
Symbol
Test
conditions
MIN
MAX
UNIT
Collector-base breakdown voltage
V(BR)CBO
IC=-100μA , IE=0
-40
V
Collector-emitter breakdown voltage
V(BR)CEO
IC= -1mA , IB=0
-40
V
Emitter-base breakdown voltage
V(BR)EBO
IE=-100μA, IC=0
-5
V
Collector cut-off current
ICBO
VCB=-35V, IE=0
-0.1
μA
ICEO
VCE=-35 V, IB=0
-0.1
μA
Emitter cut-off current
IEBO
VEB=-4V,IC=0
-0.1
μA
hFE
DC current gain
VCE=-2V, IC= -150mA
100
300
Collector-emitter saturation voltage
VCE(sat)
IC=-150mA, IB=-15mA
-0.4
V
Base-emitter saturation voltage
VBE(sat)
IC=- 150mA, IB=-15mA
-0.95
V
fT
Transition frequency
www.tw-gmc.com
1
3
2
VCE= -10V, IC= -20mA
f = 100MHz
200
MHz
MMBT4403
MMBT3904
AO3400
SI2305
Typical Characteristics
Static Characteristic
-200
COMMON
EMITTER
Ta=25℃
-1mA
-0.9mA
-0.8mA
-0.7mA
-150
hFE
1000
-0.6mA
-0.4mA
-0.3mA
-50
COMMON EMITTER
VCE=-2V
Ta=25℃
100
-0.5mA
-100
IC
Ta=100℃
DC CURRENT GAIN
hFE
COLLECTOR CURRENT
(mA)
IC
-250
-0.2mA
IB=-0.1mA
-0
-0
-2
COLLECTOR-EMITTER VOLTAGE
VCEsat
-700
10
-6
-4
VCE
-1
IC
COLLECTOR-EMITTER
SATURATION VOLTAGE VCEsat
(mV)
-600
-100
VBEsat
-1.2
(mA)
IC
IC
β=10
β=10
BASE-EMITTER
SATURATION VOLTAGE
VBEsat (V)
-300
Ta=25℃
-0.8
Ta=100℃
-100
Ta=25℃
Ta=100℃
-0.4
-30
-10
-10
COLLECTOR CURRENT
(V)
-1
-3
-10
-30
-100
COLLECTOR CURRENT
-600
IC
IC
-0.0
-600
-1
-3
(mA)
-10
-100
-30
COLLECTOR CURRENT
—— VBE
Cob/ Cib
50
COMMON EMITTER
VCE=-2V
-600
(mA)
IC
VCB/ VEB
f=1MHz
IE=0/IC=0
Ta=25℃
Cib
Cob
C
Ta=100℃
-10
CAPACITANCE
(pF)
COLLECTOR CURRENT
(mA)
IC
-100
Ta=25℃
-1
-0.1
-0.0
-0.4
-0.8
10
1
1-0.1
-1.2
fT
-600
-10
-1
REVERSE VOLTAGE
BASE-EMMITER VOLTAGE VBE (V)
—— IC
PC
400
V
-30
(V)
Ta
300
COLLECTOR POWER
DISSIPATION P
C
(mW)
TRANSITION FREQUENCY
(MHz)
fT
VCE=-10V
Ta=25℃
-100
200
100
-10
-1
COLLECTOR CURRENT
www.tw-gmc.com
-10
-3
IC
(mA)
50
75
AMBIENT TEMPERATURE
1
3
2
100
Ta
125
150
MMBT4403
MMBT3904
AO3400
SI2305
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
www.tw-gmc.com
SOT-23
1
3
2
很抱歉,暂时无法提供与“MMBT4403”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.05700
- 100+0.05320
- 300+0.04940
- 500+0.04560
- 2000+0.04370
- 5000+0.04256
