XM CONNECTOR
2.5mm pitch/Crimp style wire-to-wire connectors
Specifications –––––––––––––––––––
The retainer provides added protection
against non-insertion or disconnection.
• Inner-housing lock
• Secondary retainers
• Housing lance
• Mountable on a variety of panels
• Contacts smoothly insert into the housings
without colliding with internal obstacles
• Current rating: 3A AC, DC max.
• Voltage rating: 250V AC, DC max.
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/10m Ω max.
After environmental testing/20m Ω max.
• Insulation resistance:
500M Ω min.
• Withstanding voltage: 1,500V AC/minute
• Applicable wire: AWG #28 to #20
0.08 to 0.50mm2
• Applicable panel thickness: 0.5 to 1.8mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards–––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
Panel Layout and Assembly layout
(18 circuits)
15.5
7.9
(2 to 12 circuits)
24.4
24.4
+0.1
A 0
+0.1
B±0.05
Circuits
Receptacle housing
+0.1
B±0.05
Panel hole dimensions (mm) General tolerance
A +0.1
B±0.05
2
XMR-02V
9.3
12.6
3
XMR-03V
10.3
13.6
4
XMR-04V
12.8
16.1
5
XMR-05V
15.3
18.6
6
XMR-06V
17.8
21.1
7
XMR-07V
20.3
23.6
8
XMR-08V
22.8
26.1
9
XMR-09V
25.3
28.6
10
XMR-10V
27.8
31.1
11
XMR-11V
30.3
33.6
12
XMR-12V
32.8
36.1
18
XMR-18V
25.3
28.6
Note: 1. Punch holes in the panel according to the sketch and table shown above. Burrs must be removed.
2. The strength of the panel must be considered when punching two or more holes.
3. The connector must be inserted from the same side as the hole is punched.
1
15.8
11.6±0.05
+0.1
5.5±0.05
A 0
Applicable panel thickness (mm)
0.5∼1.8
XM CONNECTOR
Contact
Pin contact
Socket contact
6.5
1.9
1.9
12.5
2.9
2.5
1.3
3.1
2.9
1.3
2.3
2.4
6.3
0.8
0.8
Applicable wire
Model No.
Q´ty / reel
Pin contact
Socket contact
mm2
AWG #
Insulation O.D.
(mm)
Pin contact
Socket contact
SXM-001T-P0.6
SXA-001T-P0.6
0.08∼0.33
28∼22
0.8∼1.9
7,000
8,000
*SXM-01T-P0.6
SXA-01T-P0.6
0.22∼0.50
24∼20
1.5∼1.9
7,000
8,000
SXA-001T-P0.6L
0.13∼0.33
26∼22
1.3∼1.9
8,000
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
RoHS compliance
Note: 1. Contact JST for special products.
2. *Marked product is not UL/CSA approved.
Contact
Crimping
machine Crimp applicator
SXM-001T-P0.6
AP-K2N
SXM-01T-P0.6
Applicator
Dies
Crimp applicator with dies
MKS-L
MK/SXA/M-001-06 APLMK SXA/M001-06
*MKS-SC
SC/SXA/M-001-06 APLSC SXA/M001-06
MKS-L
MK/SXA/M-01-06
APLMK SXA/M01-06
*MKS-SC
SC/SXA/M-01-06
APLSC SXA/M01-06
Note: *Strip-crimp applicator
Contact
Crimping
SXA-001T-P0.6
SXA-01T-P0.6
AP-K2N
SXA-001T-P0.6L
Applicator
Dies
MKS-L
*MKS-SC
MKS-L
MK/SXA/M-01-06 APLMK SXA/M01-06
*MKS-SC
SC/SXA/M-01-06 APLSC SXA/M01-06
MKS-L
MK/SXA-001-06L APLMK SXA001-06L
*MKS-SC
SC/SXA-001-06L APLSC SXA001-06L
Contact position location numbers
Contact position numbers are stamped
Retainer
Retainer
Receptacle housing
1
2
3
4
5
6
7
8
9
10
11
12
Plug housing
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
12
11
10
9
8
7
6
5
4
3
2
1
9
8
7
6
5
4
3
2
1
18
17
16
15
14
13
12
11
10
2
XM CONNECTOR
Receptacle housing (for Pin contact)
(2 to 12 circuits)
Circuits
Model No.
2
XMR-02V
XMR-03V
XMR-04V
XMR-05V
XMR-06V
XMR-07V
XMR-08V
XMR-09V
XMR-10V
XMR-11V
XMR-12V
XMR-18V
A
2.5
B
3
4
5
6
7
10.8
8
20.2
7.9
9
10
(18 circuits)
11
12
A
10.8
15.5
20.2
Q´ty / bag
2.5
8.9
1,000
5.0
9.9
1,000
7.5
12.4
500
10.0
14.9
500
12.5
17.4
500
15.0
19.9
500
17.5
22.4
500
20.0
24.9
500
22.5
27.4
500
25.0
29.9
500
27.5
32.4
500
20.0
24.9
500
Material
2.5
B
18
Dimensions (mm)
A
B
PA 66, UL94V-0
RoHS compliance
Note: Receptacle housings without panel lock device are also available for 2,
3, 4, 6, 7, 8 and 9 circuits.
Plug housing (for Socket contact)
(2 to 12 circuits)
Circuits
Model No.
2
XMP-02V
XMP-03V
XMP-04V
XMP-05V
XMP-06V
XMP-07V
XMP-08V
XMP-09V
XMP-10V
XMP-11V
XMP-12V
XMP-18V
3
2.5
A
B
4
5
6
11.5
12.0
7
6.3
7.7
8
9
(18 circuits)
10
11
12
Q´ty / bag
2.5
8.8
1,000
5.0
9.8
1,000
7.5
12.3
1,000
10.0
14.8
500
12.5
17.3
500
15.0
19.8
500
17.5
22.3
500
20.0
24.8
500
22.5
27.3
500
25.0
29.8
500
27.5
32.3
500
20.0
24.8
500
A
B
18
Dimensions (mm)
A
B
2.5
Material
PA 66, UL94V-0
11.5
12.0
RoHS compliance
13.7
14.6
Retainer
Circuits
2
3
4
5
6
A
7
8
2.5
9・18
10
11
2.5
7.8
0.95
12
Model No.
XMS-02V
XMS-03V
XMS-04V
XMS-05V
XMS-06V
XMS-07V
XMS-08V
XMS-09V
XMS-10V
XMS-11V
XMS-12V
Dimensions A (mm)
Q´ty / bag
2.5
1,000
5.0
1,000
7.5
1,000
10.0
1,000
12.5
1,000
15.0
1,000
17.5
1,000
20.0
1,000
22.5
1,000
25.0
1,000
27.5
1,000
Material
Glass-filled PA 66, UL94V-0
RoHS compliance
Note: Commonly used for 9-circuit and 18-circuit housings.
3
很抱歉,暂时无法提供与“XMS-05V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.37162
- 100+0.31762
- 300+0.29062
- 1000+0.27037
- 国内价格
- 500+0.18110
- 1000+0.16910
- 国内价格
- 100+0.54436
- 200+0.53086
- 300+0.51736
- 400+0.50499
- 500+0.49150
