BAV21W
SWITCHING DIODE
FEATURES
High Conductance
Fast Switching
Small Surface Mount device
For General Purpose Switching Applications
SOD-123
MECHANICAL DATA
Case: SOD-123
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.005 grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Symbol
Value
Unit
Non-Repetitive Peak Reverse Voltage
VRM
250
V
DC Blocking Reverse Voltage
VR
200
V
RMS Reverse Voltage
VR(RMS)
141
V
Average Rectified Output Current
Non-Repetitive Peak Forward Surge Current @t@=8.3ms
IO
200
mA
IFSM
2.0
A
Power Dissipation
500
mW
Thermal Resistance From Junction To Ambient
PD
RθJA
250
°C/W
Junction Temperature
TJ
150
°C
Storage Temperature
TSTG
-55 ~+150
°C
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Symbol Min
Forward Voltage
V
Reverse current
Diode capacitance
IR
CD
Reverse recovery time
TRR
© SHENZHEN HOTTECH ELECTRONICS CO.,LTD
Typ
Max Unit
1.0
1.25
0.1
uA
5
pF
4
nS
Conditions
IF=100mA
IF=200mA
VR=200V
VR=0V,f=1MHz
IF=IR=30mA,Irr=0.1XIR ,RL=100Ω
E-mail:hkt@heketai.com
1/4
BAV21W
SWITCHING DIODE
Typical Characteristics
Forward
Characteristics
Reverse
Pulsed
Pulsed
Ta=100℃
100
(nA)
100
REVERSE CURRENT IR
30
T=
a 2
5℃
T=
a 1
00
FORWARD CURRENT
IF
(mA)
Characteristics
1000
400
10
10
Ta=25℃
1
3
1
0.2
0.1
0.4
0.6
0.8
FORWARD VOLTAGE
1.0
VF
1.2
(V)
40
60
REVERSE VOLTAGE
80
VR
100
120
125
150
(V)
Power Derating Curve
Capacitance Characteristics
600
1.4
Ta=25℃
f=1MHz
(mW)
PD
400
1.0
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
500
1.2
0.8
0.6
300
200
100
0.4
10
REVERSE VOLTAGE
15
VR
(V)
50
75
AMBIENT TEMPERATURE
100
Ta
2/4
BAV21W
SWITCHING DIODE
SOD-123 Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.450
0.650
0.018
0.026
c
0.080
0.150
0.003
0.006
D
1.500
1.700
0.059
0.067
E
2.600
2.800
0.102
0.110
E1
3.550
3.850
0.140
0.152
L
0.500RE F
0.020 REF
L1
0.250
0.450
0.010
0.018
θ
0°
8°
0°
8°
SOD-123 Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
3/4
BAV21W
SWITCHING DIODE
SOD-123 Tape and Reel
SOD-123 Embossed Carrier Tape
SOD-123 Tape Leader and Trailer
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SOD-123
1.85
3.95
1.57
Ø1.55
1.75
3.50
4.00
4.00
2.00
8.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SOD-123 Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
9.50
12.30
±2
±1
±1
±1
±1
±1
±1
±1
4/4
很抱歉,暂时无法提供与“BAV21W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.05395
- 150+0.04568
- 1000+0.03740
- 5000+0.03409
