ES1E
ES1E
    HOTTECH(合科泰)
    SMA(DO214AC)
ES1E 数据手册
ES1A- ES1M SURFACE MOUNT SUPER FAST RECTIFIER FEATURES  Glass Passivated Die Construction  Super-Fast Recovery Time For High Efficiency  Low Forward Voltage Drop and High Current Capability  Ideally Suited for Automated Assembly  Plastic Material: UL Flammability Classification Rating 94V-0 DO-214AC (SMA) MECHANICAL DATA  Case: DO-214AC Molded plastic 10  Terminals: Pure tin plated, lead free  Polarity: Indicated by cathode band  Weight: 70mg (approx.) Cathode MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. ES1A ES1B ES1C ES1D ES1E ES1G ES1J ES1K ES1M Unit V RRM 50 100 150 200 300 400 600 800 1000 V Maximum RMS Voltage V RMS 35 70 105 140 210 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 150 200 300 400 600 800 1000 V Maximum Average Forward Rectified Current at T A =75 °C I F(AV) 1.0 A Peak Forward Surge Current 8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC) I FSM 50.0 A Maximum Instantaneous Forward Voltage at 1 A VF Maximum DC Reverse Current at Rated DC Blocking Voltage IR Parameter Symbol Maximum Repetitive Peak Reverse Voltage T A = 25 °C T A =100 °C 0.975 1.25 1.7 5.0 150.0 50 V µA Maximum reverse recovery time (NOTE1) t rr 60 100 nS Typical Junction Capacitance (NOTE2) CJ 25.0 pF Maximum Thermal Resistance (NOTE3) R θJL 20.0 °C/W Operating and Storage Temperature Range T J, T S -50 to +150 °C Note: 1.Reverse recovery condition I F =0.5A,I R =1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 1/3 ES1A- ES1M SURFACE MOUNT SUPER FAST RECTIFIER FIG. 1- FORWARD CURRENT DERATING CURVE 1.0 0.8 0.6 Single Phase Half Wave 60Hz Resistive or inductive Load 0.4 0.2 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES Typical Characteristics FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 30 25 20 15 10 175 5.0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 AMBIENT TEMPERATURE, C 20 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 1 0.1 ES1A-ES1D ES1E-ES1G ES1J 0.01 0 0.4 0.8 1.2 1.6 1.8 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 10 1,000 100 10 TJ=100 C 1 0.1 TJ=25 C 0.01 INSTANTANEOUS FORWARD VOLTAGE, VOLTS TJ=25 C 10 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% TRANSIENT THERMAL IMPEDANCE, C/W JUNCTION CAPACITANCE, pF FIG. 5-TYPICAL JUNCTION CAPACITANCE 200 100 100 NUMBER OF CYCLES AT 60 Hz FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 100 1 0.1 1.0 10 REVERSE VOLTAGE,VOLTS ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD 100 t,PULSE DURATION,sec. E-mail:hkt@heketai.com 2/3 ES1A- ES1M SURFACE MOUNT SUPER FAST RECTIFIER SMA Package Outline Dimensions 10 52 0 32 4.50 7 ( DIMENSIONS ARE IN MILLIMETER ) SMA Embossed Carrier Tape P0 P1 d E MAX.3° A MAX.3° T F W C B R A P DIMENSIONS ARE IN MILLIMETER TYPE A B C d E F P P0 P1 T W SMA 3.0 5.4 2.4 1.5 1.5 5.65 4 4 2 0.3 12 TOLERANCE ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.05 ±0.1 ±0.1 ±0.1 ±0.05 ±0.2 SMA Reel D2 D W1 DIMENSIONS REEL OPTION D1 ARE IN MILLIMETER D D1 D2 W1 7’’ DIA 178 50 min. 13 16.8 TOLERANCE ±2 ±0.1 ±0.5 ±2 ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 3/3
很抱歉,暂时无法提供与“ES1E”相匹配的价格&库存,您可以联系我们找货
