DB3W
Silicon Bidirectional Trigger Diodes
PINNING
FEATURES
These diacs are intended for use in thyristor phase control.
circuits for lamp-dimming. universal-motor speed controls.
and heat controls.
PIN
MECHANICAL DATA
▪Case: SOD-123FL
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪Approx. Weight:15mg 0.00048oz
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: DB3W / DC34W / DB4W
Simplified outline SOD-123FL and symbol
Absolute Maximum Ratings (Ta = 25°C )
Symbol
Value
Unit
Power Dissipation (T C = 100°C )
P tot
150
mW
Repetitive Peak On-state Current (tp = 20 µs, f = 100 Hz)
I TRM
2
A
T j , T stg
- 40 to + 125
°C
Parameter
Operating Junction and Storage Temperature Range
Characteristics at T a = 25°C
Symbol
Parameter
DB3W
Min.
Max.
Unit
28
36
V
30
38
V
35
45
V
3
V
Breakover Voltage
at C = 22 nF, see diagram 1
V BO
DC34W
DB4W
Breakover Voltage Symmetry
[|+V BO |-|- V BO |]
Dynamic Breakover Voltage
at △I = [I BO to I F = 10 mA]
| △V ± |
Output Voltage
See diagram 2
VO
Breakover Current
at C = 22 nF
I BO
Leakage Current
at V B =0.5V BO max
IB
Rise Time
See diagram 3
tr
www.slkormicro.com
1
5
5
V
V
50
μA
10
μA
2
μs
DB3W
Diagram2: Test circuit for output voltage
Diagram1: current-voltage characteristice
10KΩ
+I F
500KΩ
220V
50Hz
IO
R=20Ω
0.1μF
(10mA)
VO
I BO
IB
-V
D.U.T
+V
0. 5V BO
Diagram3 : Test circuit see Fig.2 . Adjust R for lp=0.5A
△V
VO
V BO
90%
-I F
10%
tr
Fig.2: Power dissipation versus ambient
temperapture(maximum values)
VBO[Tj]
VBO[Tj=25°C ]
150
120
90
60
30
50
75
100
125
150
CASE TEMPERATURE,°C
I TRM,PEAK PULSE CURRENT,A
10
1
0.1
0.01
100
1000
10000
tp,PULSE DURATION,µs
www.slkormicro.com
1.08
1.06
1.04
1.02
1.00
25
T J (°C)
50
75
100
T j,JUNCTION TEMPERATURE, °C
Fig.3: Power dissipation versus ambient
10
RELATIVE VARIATION OF V BO
P,POWER DISSIPATION,mW
Fig.1: Power dissipation versus ambient
2
125
DB3W
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123FL
∠ALL ROUND
C
A
∠ALL ROUND
VM
D
E
A
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.1
0.20
2.9
1.9
1.1
0.9
3.8
min
0.9
0.12
2.6
1.7
0.8
0.7
3.5
max
43
7.9
114
75
43
35
150
min
35
4.7
102
67
31
28
138
UNIT
mm
1.2
(47)
1.2
(47)
2.0
(79)
Unit: mm
(mil)
www.slkormicro.com
7°
The recommended mounting pad size
1.2
(47)
g
pad
e
E
A
pad
HE
3
很抱歉,暂时无法提供与“DB3W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.06480
- 10+0.06240
- 100+0.05664
- 500+0.05376
