NPN Silicon Epitaxial Transistor
for switching and amplifier applications
As complementary types the PNP transistors
BC856...BC860 is recommended.
1.Base 2.Emitter 3.Collector
SOT-23 Plastic Package
Absolute Maximum Ratings (Ta = 25 C)
O
Parameter
Symbol
Value
Units
Collector Base Voltage
BC846
BC847, BC850
BC848, BC849
VCBO
VCBO
VCBO
80
50
30
V
V
V
Collector Emitter Voltage
BC846
BC847, BC850
BC848, BC849
VCEO
VCEO
VCEO
65
45
30
V
V
V
Emitter Base Voltage
BC846, BC847
BC848, BC849, BC850
VEBO
VEBO
6
5
V
V
Collector Current
IC
100
mA
Peak Collector Current
ICM
200
mA
Power Dissipation
Ptot
200
mW
Junction Temperature
TJ
150
O
C
Storage Temperature Range
TS
- 65 to + 150
O
C
1 of 4
Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
Characteristics at Tamb = 25 C
O
Parameter
Symbol
Min.
Typ.
Max.
Units
hFE
hFE
hFE
110
200
420
220
450
800
Collector Emitter Saturation Voltage
at IC = 10 mA, IB = 0.5 mA
at IC = 100 mA, IB = 5 mA
VCEsat
VCEsat
250
600
mV
mV
Base Emitter On Voltage
at IC = 2 mA, VCE = 5 V
at IC = 10 mA, VCE = 5 V
VBE(on)
VBE(on)
580
700
720
mV
mV
ICBO
15
nA
fT
300
MHz
Cob
6
pF
Cib
9
pF
NF
NF
NF
NF
10
4
4
3
dB
dB
dB
dB
DC Current Gain
at VCE = 5 V, IC = 2 mA
A
B
C
Collector Cutoff Current
at VCB = 30 V
Current Gain Bandwidth Product
at VCE = 5 V, IC = 10 mA, f = 100 MHz
Output Capacitance
at VCB = 10 V, f = 1 MHz
Input Capacitance
at VEB = 0.5 V, f = 1 MHz
Noise Figure
at IC = 200 µA, VCE = 5 V,
RG = 2 KΩ, f = 1 KHz
at IC = 200 µA,VCE = 5 V,
RG = 2 KΩ, f = 30 ~15 KHz
BC846, BC847, BC848
BC849, BC850
BC849
BC850
2 of 4
CURRENT GAIN BANDWIDTH PRODUCT
DC CURRENT GAIN
fT(MHz), CURRENT GAIN-BANDWIDTH PRODUCT
10000
h FE DC CURRENT GAIN
VCE=5V
1000
100
10
1
10
100
1000
I C(mA),COLLECTOR CURRENT
VCE=5V
100
10
1
0.1
100
COLLECTOR OUTPUT CAPACITANCE
f=1MHz
1000
VBE(sat)
100
VCE(sat)
1
10
I C=10IB
10
1
100
Cob(pF), CAPACITANCE
VBE(sat),VCE(sat),(V) SATURATION VOLTAGE
BASE-EMITTER SATURATION VOLTAGE
COLLECTOR-EMITTER SATURATION VOLTAGE
10000
1000
10
100
10
1
0.1
1000
1
10
100
1000
VCB(V),COLLECTOR-BASE VOLTAGE
3 of 4
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
SOT-23
Dimension in Millimeters
Symbol
Min
Max
A
0.90
1.10
A1
0.013
0.100
B
1.80
2.00
bp
0.35
0.50
C
0.09
0.150
D
2.80
3.00
E
1.20
1.40
HE
2.20
2.80
Lp
0.20
0.50
θ
0º
5º
4 of 4
很抱歉,暂时无法提供与“BC848A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.04160
- 50+0.03848
- 200+0.03588
- 600+0.03328
- 1500+0.03120
- 3000+0.02990
- 国内价格
- 50+0.05273
- 500+0.04223
- 3000+0.03290
- 6000+0.02940
- 24000+0.02637
- 51000+0.02474
