Encapsulate Three terminal voltage regulators
Three-terminal negative voltage regulator
SOT-89 Plastic Package
FEATURES
Maximum output current
IOM: 0.1 A
Output voltage
Vo: -12 V
Continuous total dissipation
PD: 0. 5 W
1. GND
2. IN
3. OUT
ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified)
Symbol
Parameter
Input Voltage
Value
-35
Vl
Operating Junction Temperature Range
Storage Temperature Range
Unit
TOPR
0~+150
TSTG
-55~+150
V
ELECTRICAL CHARACTERISTICS AT SPECIFIED VIRTUAL JINCTION TEMPERATURE (Vi=19V,Io=40mA,Ci=0.33μF,Co=0.1μF, unless otherwise specified)
Parameter
Symbol
Test conditions
25℃
Output Voltage
Vo
-14.5V≤Vl≤-27V, Io=1mA~40mA
0-125℃
Io=1mA~70mA
ΔVo
Load Regulation
Line Regulation
ΔVo
Quiescent Current
Iq
Min
Typ
Max
Unit
-11.5
-12
-12.5
V
-11.4
-12
-12.6
V
-11.4
-12
-12.6
V
Io=1mA~100mA
25℃
24
100
mV
Io=1mA~40mA
25℃
15
50
mV
-14.5V≤Vl≤-27V
25℃
50
250
mV
-16V≤Vl≤-27V
25℃
40
200
mV
25℃
6.5
mA
ΔIq
-16V≤Vl≤-27V
0-125℃
1.5
mA
ΔIq
1mA≤IO≤40mA
0-125℃
0.1
mA
Output Noise Voltage
VN
10Hz≤f≤100KHz
Ripple Rejection
RR
-15V≤Vl≤-25V,f=120Hz
Dropout Voltage
Vd
Quiescent Current Change
TYPICAL APPLICATION
Vi
Ci
25℃
0-125℃
25℃
2
79 L12
1
3
37
80
μV
42
dB
1.7
V
Vo
Co
0.33μF
0.1μF
Note: Bypass capacitors are recommended for optimum stability and transient response and should be located as close as
possible to the regulators.
1 of 2
Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
SOT-89 PACKAGE OUTLINE
2 of 2
很抱歉,暂时无法提供与“79L12”相匹配的价格&库存,您可以联系我们找货
