SMDJ58CA
SMDJ58CA
    PTTC(聚鼎)
    SMC
    SMC SMT 58V 93.6V
SMDJ58CA 数据手册
T VS Diode – SMDJ Series Features  Plastic package, excellent insulation strength.  Glass passivated chip junction in SMD package.  Excellent voltage clamping capability.  Low Zener impedance.  3000W peak pulse power capability on 10/1000s waveform.  Typical leakage current less than 1A above 13V.  Very fast response time, typically less than 1.0ps from 0 volt to  High temperature soldering guaranteed: 265°C/10 sec.  MSL: JEDEC-J-STD-020, Level 1 VBR minimum. Applications  I/O interface, VCC bus  Telecom  Industrial and consumer electronic applications.  Relay and electromagnetic valve surge absorption. Agency Approval  UL file no.: E474915 Mechanical and Physical Data  Case: JEDEC SMC molded plastic.  Surface mount device, solderable per MIL-STD-750,  Polarity: Color band denoted cathode except bidirectional. Method 2026 Maximum Ratings and Thermal Characteristics Parameter Peak Pulse Power Dissipation on 10/1000s waveform (Note 1, Fig.1). Peak Pulse Current of 10/1000s waveform (Note 1, Fig.3). Steady State Power Dissipation at TL = 75°C, Lead lengths 0.375”, (9.5mm) (Fig.5). Peak Forward Surge Current, 8.3 ms Single Half Sine Wave Superimposed on Rated Load (Note 2, Fig.6). Operating Junction and Storage Temperature Range. Symbol Value Unit PPPM Min 3000 Watt IPPM See Table Amp PM(AV) 6.5 Watt IFSM 300 Amp TJ, TSTG -55~150 °C Note: 1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig.2. 2. 8.3ms single half sine wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. Part Number Code SMDJ □□□ C A - □□□ Packaging Code (T13: Tape with 13” Reel; T7: Tape with 7”) VBR Voltage tolerance (A: 5%; Blank: 10%) C: Bi-directional; Blank: Uni-directional Reverse Stand-Off Voltage or Typical Breakdown Voltage SMDJ Series (3000W) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 1 of 6 2018/07/27 Rev: D T VS Diode – SMDJ Series I-V Curve Characteristics PPPM Peak Pulse Power Dissipation – Maximum power dissipation VR Stand-off Voltage – Maximum voltage that can be applied to the TVS without operation VBR Breakdown Voltage – Maximum voltage that flows through the TVS at a specified test current (IT) VC Clamping Voltage – Peak voltage measured across the TVS at a specified IPPM (Peak Impulse Current) IR Reverse Leakage Current – Current measured at VR VF Forward Voltage Drop for Uni-directional Electrical Characteristics Uni Bi Uni Bi Reverse Stand Off Voltage VR (V) Min. Max. Test Current IT (mA) SMDJ5.0A SMDJ5.0CA RDE DDE 5.0 6.40 7.00 10 9.2 326.09 800 SMDJ6.0A SMDJ6.0CA RDG DDG 6.0 6.67 7.37 10 10.3 291.26 800 SMDJ6.5A SMDJ6.5CA RDK DDK 6.5 7.22 7.98 10 11.2 267.86 500 SMDJ7.0A SMDJ7.0CA PDM DDM 7.0 7.78 8.60 10 12.0 250.00 200 SMDJ7.5A SMDJ7.5CA PDP DDP 7.5 8.33 9.21 1 12.9 232.56 100 SMDJ8.0A SMDJ8.0CA PDR DDR 8.0 8.89 9.83 1 13.6 220.59 50 SMDJ8.5A SMDJ8.5CA PDT DDT 8.5 9.44 10.4 1 14.4 208.33 20 SMDJ9.0A SMDJ9.0CA PDV DDV 9.0 10.0 11.1 1 15.4 194.81 10 SMDJ10A SMDJ10CA PDX DDX 10.0 11.1 12.3 1 17.0 176.47 5 SMDJ11A SMDJ11CA PDZ DDZ 11.0 12.2 13.5 1 18.2 164.84 2 SMDJ12A SMDJ12CA PEE DEE 12.0 13.3 14.7 1 19.9 150.75 2 SMDJ13A SMDJ13CA PEG DEG 13.0 14.4 15.9 1 21.5 139.53 2 SMDJ14A SMDJ14CA PEK DEK 14.0 15.6 17.2 1 23.2 129.31 2 SMDJ15A SMDJ15CA PEM DEM 15.0 16.7 18.5 1 24.4 122.95 2 SMDJ16A SMDJ16CA PEP DEP 16.0 17.8 19.7 1 26.0 115.38 2 SMDJ17A SMDJ17CA PER DER 17.0 18.9 20.9 1 27.6 108.70 2 SMDJ18A SMDJ18CA PET DET 18.0 20.0 22.1 1 29.2 102.74 2 Part Number Marking Breakdown Voltage VBR (V) @ IT Maximum Clamping Voltage VC (V) @ IPP Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR (A) @ VR 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 6 2018/07/27 Rev: D T VS Diode – SMDJ Series Uni Bi Uni Bi Reverse Stand Off Voltage VR (V) SMDJ20A SMDJ20CA PEV DEV 20.0 22.2 24.5 1 32.4 92.59 2 SMDJ22A SMDJ22CA PEX DEX 22.0 24.4 26.9 1 35.5 84.51 2 Part Number Marking Breakdown Voltage VBR (V) @ IT Min. Max. Test Current IT (mA) Maximum Clamping Voltage VC (V) @ IPP Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR (A) @ VR SMDJ24A SMDJ24CA PEZ DEZ 24.0 26.7 29.5 1 38.9 77.12 2 SMDJ26A SMDJ26CA PFE DFE 26.0 28.9 31.9 1 42.1 71.26 2 SMDJ28A SMDJ28CA PFG DFG 28.0 31.1 34.4 1 45.4 66.08 2 SMDJ30A SMDJ30CA PFK DFK 30.0 33.3 36.8 1 48.4 61.98 2 SMDJ33A SMDJ33CA PFM DFM 33.0 36.7 40.6 1 53.3 56.29 2 SMDJ36A SMDJ36CA PFP DFP 36.0 40.0 44.2 1 58.1 51.64 2 SMDJ40A SMDJ40CA PFR DFR 40.0 44.4 49.1 1 64.5 46.51 2 SMDJ43A SMDJ43CA PFT DFT 43.0 47.8 52.8 1 69.4 43.23 2 SMDJ45A SMDJ45CA PFV DFV 45.0 50.0 55.3 1 72.7 41.27 2 SMDJ48A SMDJ48CA PFX DFX 48.0 53.3 58.9 1 77.4 38.76 2 SMDJ51A SMDJ51CA PFZ DFZ 51.0 56.7 62.7 1 82.4 36.41 2 SMDJ54A SMDJ54CA PGE DGE 54.0 60.0 66.3 1 87.1 34.44 2 SMDJ58A SMDJ58CA PGG DGG 58.0 64.4 71.2 1 93.6 32.05 2 SMDJ60A SMDJ60CA PGK DGK 60.0 66.7 73.7 1 96.8 30.99 2 SMDJ64A SMDJ64CA PGM DGM 64.0 71.0 78.6 1 103.0 29.13 2 SMDJ70A SMDJ70CA PGP DGP 70.0 77.8 86.0 1 113.0 26.55 2 SMDJ75A SMDJ75CA PGR DGR 75.0 83.3 92.1 1 121.0 24.79 2 SMDJ78A SMDJ78CA PGT DGT 78.0 86.7 95.8 1 126.0 23.81 2 SMDJ80A SMDJ80CA PGB DGB 80.0 88.8 97.6 1 129.6 23.15 2 SMDJ85A SMDJ85CA PGV DGV 85.0 94.4 104.0 1 137.0 21.90 2 SMDJ90A SMDJ90CA PGX DGX 90.0 100.0 111.0 1 146.0. 20.55 2 SMDJ100A SMDJ100CA PGZ DGZ 100.0 111.0 123.0 1 162.0 18.52 2 SMDJ110A SMDJ110CA PHE DHE 110.0 122.0 135.0 1 177.0 16.95 2 SMDJ120A SMDJ120CA PHG DHG 120.0 133.0 147.0 1 193.0 15.54 2 SMDJ130A SMDJ130CA PHK DHK 130.0 144.0 159.0 1 209.0 14.35 2 SMDJ150A SMDJ150CA PHM DHM 150.0 167.0 185.0 1 243.0 12.35 2 SMDJ160A SMDJ160CA PHP DHP 160.0 178.0 197.0 1 259.0 11.58 2 SMDJ170A SMDJ170CA PHR DHR 170.0 189.0 209.0 1 275.0 10.91 2 SMDJ180A SMDJ180CA HHT IHT 180.0 201.0 222.0 1 292.0 10.29 2 SMDJ190A SMDJ190CA HHV IHV 190.0 209.0 243.0 1 308.0 9.75 2 SMDJ200A SMDJ200CA HHX IHX 200.0 224.0 247.0 1 324.0 9.26 2 SMDJ220A SMDJ220CA HHE IHE 220.0 246.0 272.0 1 356.0 8.43 2 SMDJ250A SMDJ250CA PHZ DHZ 250.0 279.0 309.0 1 405.0 7.41 2 SMDJ300A SMDJ300CA PJE DJE 300.0 335.0 371.0 1 486.0 6.17 2 SMDJ350A SMDJ350CA PJG DJG 350.0 391.0 432.0 1 567.0 5.29 2 SMDJ400A SMDJ400CA PJK DJK 400.0 447.0 494.0 1 648.0 4.63 2 SMDJ440A SMDJ440CA PJM DJM 440.0 492.0 543.0 1 713.0 4.21 2 Note: 1. For bi-directional type having VR of 10 volts and less, the IR limit is double. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 6 2018/07/27 Rev: D T VS Diode – SMDJ Series Ratings and Characteristic Curves Fig 1 - Peak Pulse Power Rating Curve Fig 2 - Pulse Derating Curve Fig 3 - Pulse Waveform Fig 4 – Typical Junction Capacitance Fig 5 – Steady State Power Dissipation Derating Curve Fig 6 – Maximum Non-Repetitive Forward Surge Current (Uni-directional Only) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 6 2018/07/27 Rev: D T VS Diode – SMDJ Series Marking Definitions PolyTrans Trade mark Lot No Marking Code Cathode Band (For Uni-directional product only) Physical Dimensions Millimeters Dimension A B C D E F G H I J K L Inches Min Max Min Max 2.90 6.60 5.59 2.20 0.76 7.75 0.15 3.30 2.40 2.40 3.20 7.11 6.22 2.80 1.52 0.20 8.13 0.31 4.20 - 0.114 0.260 0.220 0.087 0.030 0.305 0.006 0.129 0.094 0.094 0.126 0.280 0.245 0.110 0.060 0.008 0.320 0.012 0.165 - Lead Free Reflow Soldering Recommendations Preheat - Temperature Min (Ts_min) 150ºC - Temperature Max (Ts_max) 200ºC - Time (Ts_min to Ts_max) 60-180 seconds - Average Ramp-Up Rate 1~3ºC/second Peak Temperature Time within 5ºC of actual Peak Temperature (tp) Ramp-Down Rate 260ºC max. 40 seconds max. 6 ºC /second max. Note: If the soldering temperatures exceed the recommended profile, devices may not meet the performance requirements. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 5 of 6 2018/07/27 Rev: D T VS Diode – SMDJ Series Packaging Information Part Number Packaging Code Component Package Quantity SMDJ Series SMDJ Series T13 T7 DO-214AB DO-214AB 3000 500 Packaging Option Tape & Reel – 16mm tape/13” reel Tape & Reel – 16mm tape/7” reel Packaging Specification EIA STD RS-481 EIA STD RS-481 Tape and Reel Specifications 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 6 of 6 2018/07/27 Rev: D
SMDJ58CA 价格&库存
很抱歉,暂时无法提供与“SMDJ58CA”相匹配的价格&库存,您可以联系我们找货
