SMD1812 HF Series Surface Mount PTC Devices
Description
The 1812 series provides surface mount resettable overcurrent protection with
holding current from 0.1A to 3.0A. This series offers complete portfolio in terms of holding
current and working voltage, and is suitable for wide range of applications.
Features
y RoHS compliant and lead-free
y Low profile
y Halogen-free
y Fast response to fault current
y Compact design saves board space
y Compatible with high temperature solders
Applications
y USB hubs, ports and peripherals
y Motherboard USB & IEEE 1394 protection
y Set-top-box and HDMI
y Optical disk drives
y Game console port protection
y General electronics
Agency Approval and Environmental Compliance
Agency
File Number
Regulation
Standard
E201431
2011/65/EU
R50099121
IEC 61249-2-21:2003
Electrical Characteristics
Maximum
Time To Trip
Current
Time
(A)
(Sec.)
Ihold
(A)
Itrip
(A)
Vmax
(Vdc)
Imax
(A)
Pd typ
(W)
SMD1812P010TF
0.10
0.30
30
100
0.8
0.50
SMD1812P010TF/60
0.10
0.30
60
10
0.8
0.50
SMD1812P014TF
0.14
0.34
60
10
0.8
1.50
SMD1812P020TF
0.20
0.40
30
100
0.8
8.00
SMD1812P020TF-J
0.20
0.40
60
40
0.8
1.00
SMD1812P035TF/30
0.35
0.75
30
40
0.8
SMD1812P035TF/60
0.35
0.70
60
10
1.0
SMD1812P050TF
0.50
1.00
15
100
SMD1812P050TF/30
0.50
1.00
30
100
SMD1812P050TF/60
0.50
1.00
60
SMD1812P075TF
0.75
1.50
SMD1812P075TF/24
0.75
1.50
SMD1812P075TF/33
0.75
1.50
SMD1812P110TF
1.10
SMD1812P110TF/16
1.10
SMD1812P110TF/24
1.10
SMD1812P110TF/33
1.10
SMD1812P125TF/16
SMD1812P150TF/8
Part Number
Resistance
Agency
Approval
Rmin
(Ω)
R1max
(Ω)
1.50
1.600
15.000
3
3
1.50
1.600
15.000
3
3
0.15
1.500
6.000
3
3
0.02
0.800
5.000
3
3
2.00
1.400
4.400
3
3
8.00
0.15
0.400
1.700
3
3
8.00
0.15
0.400
1.700
3
3
0.8
8.00
0.15
0.150
1.000
3
3
0.8
8.00
0.15
0.150
1.000
3
3
10
1.5
8.00
0.15
0.150
1.000
3
3
13.2
100
0.8
8.00
0.20
0.100
0.450
3
3
24
100
0.8
8.00
0.20
0.110
0.290
3
3
33
8.00
0.20
0.110
0.400
3
3
2.20
8
100
0.8
8.00
0.30
0.040
0.210
3
3
1.95
16
100
0.8
8.00
0.30
0.060
0.180
3
3
1.95
24
8.00
0.50
0.060
0.200
3
3
1.95
33
8.00
0.50
0.060
0.200
3
3
1.25
2.50
16
100
0.8
8.00
0.40
0.050
0.140
3
3
1.50
3.00
8
100
0.8
8.00
0.30
0.040
0.110
3
3
㖗䫠ⷩ䦸⭟ⷌ㥔⛹⌧ⷌ㥔㝘⛂巖 24-1 噆
No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan.
TEL: +886-3-5643931 FAX: +886-3-5644624
http://www.pttc.com.tw
Page: 2 of 15
2017/06/22 Revision: R
Cont’d
Maximum
Time To Trip
Current
Time
(A)
(Sec.)
Ihold
(A)
Itrip
(A)
Vmax
(Vdc)
Imax
(A)
Pd typ
(W)
SMD1812P150TF/12
1.50
3.00
12
100
0.8
8.00
SMD1812P150TF/16
1.50
2.80
16
100
0.8
8.00
SMD1812P150TF/24
1.50
3.00
24
SMD1812P160TF/8(4L)
1.60
2.80
8
100
0.8
SMD1812P200TFT
2.00
3.50
8
100
SMD1812P200TF/12
2.00
3.50
12
SMD1812P200TF/16
2.00
3.50
16
SMD1812P260TFT
2.60
5.00
SMD1812P260TF/12
2.60
SMD1812P260TF/16
2.60
SMD1812P300TFT
3.00
Part Number
Resistance
Agency
Approval
Rmin
(Ω)
R1max
(Ω)
0.50
0.040
0.110
3
3
0.50
0.040
0.110
3
3
8.00
1.50
0.040
0.120
3
3
8.00
1.00
0.030
0.100
3
3
0.8
8.00
2.00
0.020
0.070
3
3
100
1.0
8.00
2.00
0.020
0.070
3
3
100
1.0
8.00
2.00
0.020
0.070
3
3
8
100
0.8
8.00
2.50
0.015
0.047
3
3
5.00
12
100
0.8
8.00
5.00
0.015
0.055
3
3
5.00
16
100
1.2
8.00
5.00
0.015
0.050
3
3
5.00
6
100
0.8
8.00
4.00
0.012
0.040
3
3
Page: 3 of 15
Note on Electrical Characteristics
Vocabulary
Ihold = Hold current: maximum current device will pass without tripping in 23ºC still air.
Itrip = Trip current: minimum current at which the device will trip in 23 ºC still air.
Vmax = Maximum voltage device can withstand without damage at rated current (I max)
Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax)
Pd typ = Typical power dissipated from device when in the tripped state at 23 ºC still air.
Rmin = Minimum resistance of device in initial (un-soldered) state.
R1max = Maximum resistance of device at 23 ºC measured one hour after tripping or reflow soldering of 260 ºC for 20 sec.
Value specified is determined by using the PWB with 0.030”*1.5oz copper traces.
Caution: Operation beyond the specified rating may result in damage and possible arcing and flame.
Specifications are subject to change without notice.
Polymeric PTC Selecting Guide
Determine the following operating parameters for the circuits:
y Normal operating current (Ihold)
Ɂ Maximum interrupt current (Imax)
y Maximum circuit voltage (Vmax)
Ɂ Normal operating temperature surrounding device (minºC/maxºC)
Select the device form factor and dimension suitable for the application:
y Surface Mount Device (SMD)
Ɂ Axial Leaded Device (ALD)
y Radial Leaded Device (RLD)
Ɂ DISC Device
Ɂ Other Customized Form Factors
Compare the maximum rating for Vmax and Imax of the PPTC device with the circuit in application and make
sure the circuit’s requirement does not exceed the device rating.
Check that PPTC device’s trip time (time-to-trip) will protect the circuit.
Verify that the circuit operating temperature is within the PPTC device’s normal operating temperature range.
Verify the performance and suitability of the chosen PPTC device in the application.
Mechanical Stress
y PPTC devices will undergo a thermal expansion during fault condition. If PPTC devices are installed or placed in an application where
the space between PPTC devices and the surrounding materials (e.g., covering materials, packaging materials, encapsulate materials
and the like) is insufficient, it will cause an inhibiting effect upon the thermal expansion. Pressing, twisting, bending and other kinds of
mechanical stress will also adversely affect the performance of the PPTC devices, and shall not be used or applied.
Chemical Pollutants
y Silicone-based oils, oils, solvents, gels, electrolytes, fuels, acids, and the like will adversely affect the properties of PPTC devices, and
Electronic and Thermal Effect
y PPTC devices are secondary protection devices and are used solely for sporadic, accidental over-current or over-temperature error
condition, and shall NOT be used if or when constant or repeated fault conditions (such fault conditions may be caused by, among
others, incorrect pin-connection of a connector) or over-extensive trip events may occur.
y PTTC devices are different from fuses and, when a fault condition occurs, will go into high-resistance state and do not open circuit, in
which case the voltage at such PPTC devices may reach a hazardous level.
y Operation over the maximum rating or other forms of improper use may cause failure, arcing, flame and/or other damage to the PPTC
devices.
y Conductive material contamination, such as metal particle, may induce shortage, flame or arcing.
y Due to the inductance, the operation circuits may generate a circuit voltage (Ldi/dt) above the rated voltage of PPTC devices, which
shall not be used under such circumstances.
General
y Customers shall evaluate and test the properties of PPTC devices independently to verify and ensure that their individual applications
will be met.
y The performance of PPTC devices will be adversely affected if they are improperly used under electronic, thermal and/or mechanical
procedures and/or conditions non-conformant to those recommended by manufacturer.
y Customers shall be responsible for determining whether it is necessary to have back-up, failsafe and/or fool-proof protection to avoid or
minimize damage that may result from extra-ordinary, irregular function or failure of PPTC devices.
y Any and all responsibilities and liabilities are disclaimed if any item under this notice of warning is not complied with.
Page: 4 of 15
Thermal Derating Curve
Percentage of Rated Current
200.00
150.00
100.00
50.00
0.00
-40.00
0.00
40.00
80.00
120.00
Device's Ambient Temperature (ij )
Thermal Derating Chart
Recommended Hold Current (A) at Ambient Temperature (ºC)
Part Number
Ambient Operation Temperature
-40 ºC
-20 ºC
0 ºC
23 ºC
40 ºC
50 ºC
60 ºC
70 ºC
85 ºC
SMD1812P010TF
0.16
0.14
0.12
0.10
0.08
0.07
0.06
0.05
0.03
SMD1812P010TF/60
0.16
0.14
0.12
0.10
0.08
0.07
0.06
0.05
0.03
SMD1812P014TF
0.23
0.19
0.17
0.14
0.12
0.10
0.09
0.08
0.06
SMD1812P020TF
0.29
0.26
0.23
0.20
0.17
0.15
0.14
0.12
0.10
SMD1812P020TF-J
0.29
0.26
0.23
0.20
0.17
0.15
0.14
0.12
0.10
SMD1812P035TF/30
0.50
0.45
0.40
0.35
0.30
0.26
0.24
0.20
0.16
SMD1812P035TF/60
0.50
0.45
0.40
0.35
0.30
0.26
0.24
0.20
0.16
SMD1812P050TF
0.77
0.68
0.59
0.50
0.44
0.40
0.37
0.33
0.29
SMD1812P050TF/30
0.77
0.68
0.59
0.50
0.44
0.40
0.37
0.33
0.29
SMD1812P050TF/60
0.77
0.68
0.59
0.50
0.44
0.40
0.37
0.33
0.29
SMD1812P075TF
1.15
1.01
0.88
0.75
0.65
0.60
0.55
0.49
0.43
SMD1812P075TF/24
1.06
0.95
0.84
0.75
0.60
0.55
0.50
0.45
0.37
SMD1812P075TF/33
1.10
1.00
0.88
0.75
0.66
0.60
0.56
0.47
0.36
SMD1812P110TF
1.59
1.43
1.26
1.10
0.95
0.87
0.80
0.71
0.60
SMD1812P110TF/16
1.58
1.43
1.27
1.10
0.95
0.85
0.77
0.71
0.58
SMD1812P110TF/24
1.55
1.40
1.25
1.10
0.93
0.83
0.73
0.63
0.50
SMD1812P110TF/33
1.55
1.40
1.25
1.10
0.93
0.83
0.73
0.63
0.50
SMD1812P125TF/16
2.00
1.75
1.52
1.25
1.00
0.95
0.90
0.75
0.53
SMD1812P150TF/8
2.06
1.93
1.79
1.50
1.28
1.10
1.02
0.80
0.68
SMD1812P150TF/12
2.04
1.88
1.68
1.50
1.25
1.10
1.00
0.80
0.60
Page: 5 of 15
Cont’d
Part Number
-40 ºC
-20 ºC
0 ºC
23 ºC
40 ºC
50 ºC
60 ºC
70 ºC
85 ºC
SMD1812P150TF/16
2.04
1.88
1.68
1.50
1.25
1.10
1.00
0.80
0.60
SMD1812P150TF/24
2.05
1.87
1.67
1.50
1.25
1.08
0.95
0.77
0.60
SMD1812P160TF/8(4L)
2.20
2.06
1.91
1.60
1.36
1.17
1.09
0.85
0.72
SMD1812P200TFT
2.60
2.44
2.22
2.00
1.78
1.67
1.50
1.45
1.29
SMD1812P200TF/12
2.60
2.44
2.22
2.00
1.78
1.67
1.50
1.45
1.29
SMD1812P200TF/16
2.60
2.44
2.22
2.00
1.78
1.67
1.50
1.45
1.29
SMD1812P260TFT
3.40
3.16
3.00
2.60
2.30
2.15
2.00
1.85
1.63
SMD1812P260TF/12
3.40
3.16
3.00
2.60
2.30
2.15
2.00
1.85
1.63
SMD1812P260TF/16
3.40
3.16
3.00
2.60
2.30
2.15
2.00
1.85
1.63
SMD1812P300TFT
4.13
3.75
3.30
3.00
2.62
2.43
2.25
2.00
1.78
Page: 6 of 15
Average Time-Current Curve
A
100.00
BC
D
EF
A 炼SMD1812P110TF
B 炼SMD1812P150TF/8
C 炼SMD1812P160TF/8(4L)
D 炼SMD1812P200TFT
10.00
Time to Trip (Sec.)
SMD1812P200TF/12
SMD1812P200TF/16
E 炼SMD1812P260TFT
1.00
SMD1812P260TF/12
SMD1812P260TF/16
F 炼SMD1812P300TFT
0.10
0.01
1.00
10.00
100.00
Fault Current (Amp.)
AB
100.00
CD E
A 炼SMD1812P050TF
B 炼SMD1812P075TF
C 炼SMD1812P110TF/16
D 炼SMD1812P125TF/16
Time to Trip (Sec.)
10.00
E 炼SMD1812P150TF/12
SMD1812P150TF/16
1.00
0.10
0.01
0.10
1.00
10.00
100.00
Page: 7 of 15
A
100.00
BC
D
E FGHI J
A 炼SMD1812P010TF
SMD1812P010TF/60
B 炼SMD1812P014TF
C 炼SMD1812P020TF
10.00
Time to Trip (Sec.)
SMD1812P020TF-J
D 炼SMD1812P035TF/30
SMD1812P035TF/60
1.00
E 炼SMD1812P050TF/30
SMD1812P050TF/60
F 炼SMD1812P075TF/33
G 炼SMD1812P075TF/24
0.10
H 炼SMD1812P110TF/33
I 炼SMD1812P110TF/24
J 炼SMD1812P150TF/24
0.01
0.10
1.00
10.00
100.00
Page: 8 of 15
Soldering Parameters
Profile Feature
Average Ramp-Up Rate (Tsmax to TP)
Preheat
-Temperature Min (Tsmin)
-Temperature Max (Tsmax)
-Time (Tsmin to Tsmax)
Time maintained above:
-Temperature (TL)
-Time (tL)
Peak Temperature (TP)
Time within 5ºC of actual Peak
Temperature (tP)
Ramp-Down Rate
Time 25ºC to Peak Temperature
Storage Condition
Pb-Free Assembly
3ºC/second max.
150ºC
200ºC
60-180 seconds
217ºC
60-150 seconds
260ºC
20-40 seconds
6 ºC /second max.
8 minutes max.
0ºC ~35ºC, ʀ70%RH
y Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free
y Recommended maximum paste thickness is 0.25mm (0.010 inch)
y Devices can be cleaned using standard industry methods and solvents.
Note 1: All temperature refer to topside of the package, measured on the package body surface.
Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements.
Page: 9 of 15
Physical Dimensions (mm.)
P : Polytronics/ Polystar Logo
Part identification
Part Number
A
B
C
D
E
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
SMD1812P010TF
4.37
4.73
3.07
3.41
0.75
1.25
0.30
1.20
0.15
0.65
SMD1812P010TF/60
4.37
4.73
3.07
3.41
0.75
1.25
0.30
1.20
0.15
0.65
SMD1812P014TF
4.37
4.73
3.07
3.41
0.75
1.95
0.30
1.20
0.15
0.65
SMD1812P020TF
4.37
4.73
3.07
3.41
0.55
1.00
0.30
1.20
0.15
0.65
SMD1812P020TF-J
4.37
4.73
3.07
3.41
0.75
1.25
0.30
1.20
0.15
0.65
SMD1812P035TF/30
4.37
4.73
3.07
3.41
0.65
1.25
0.30
1.20
0.15
0.65
0.65
SMD1812P035TF/60
4.37
4.73
3.07
3.41
1.20
1.80
0.30
1.20
0.15
SMD1812P050TF
4.37
4.73
3.07
3.41
0.50
0.75
0.30
1.20
0.15
0.50
0.65
SMD1812P050TF/30
4.37
4.73
3.07
3.41
0.50
1.00
0.30
1.20
0.15
SMD1812P050TF/60
4.37
4.73
3.07
3.41
1.20
1.80
0.30
1.20
0.15
0.65
SMD1812P075TF
4.37
4.73
3.07
3.41
0.50
0.75
0.30
1.20
0.15
0.50
SMD1812P075TF/24
4.37
4.73
3.07
3.41
0.75
1.55
0.30
1.20
0.15
0.65
SMD1812P075TF/33
4.37
4.73
3.07
3.41
0.75
1.55
0.30
1.20
0.15
0.65
SMD1812P110TF
4.37
4.73
3.07
3.41
0.30
0.71
0.30
1.20
0.15
0.65
SMD1812P110TF/16
4.37
4.73
3.07
3.41
0.75
1.25
0.30
1.20
0.15
0.65
0.65
SMD1812P110TF/24
4.37
4.73
3.07
3.41
0.55
1.07
0.30
1.20
0.15
SMD1812P110TF/33
4.37
4.73
3.07
3.41
1.20
2.00
0.30
1.20
0.15
0.65
0.65
SMD1812P125TF/16
4.37
4.73
3.07
3.41
0.75
1.25
0.30
1.20
0.15
SMD1812P150TF/8
4.37
4.73
3.07
3.41
0.40
0.71
0.30
1.20
0.15
0.65
0.65
SMD1812P150TF/12
4.37
4.73
3.07
3.41
0.75
1.25
0.30
1.20
0.15
SMD1812P150TF/16
4.37
4.73
3.07
3.41
0.75
1.25
0.30
1.20
0.15
0.65
SMD1812P150TF/24
4.37
4.73
3.07
3.41
0.80
1.80
0.30
1.20
0.15
0.65
SMD1812P160TF/8(4L)
4.37
4.73
3.07
3.41
0.40
0.75
0.30
1.20
0.15
0.65
SMD1812P200TFT
4.37
4.73
3.07
3.41
0.20
0.60
0.30
1.20
0.15
0.65
SMD1812P200TF/12
4.37
4.73
3.07
3.41
0.80
1.20
0.30
1.20
0.15
0.65
SMD1812P200TF/16
4.37
4.73
3.07
3.41
0.80
1.20
0.30
1.20
0.15
0.65
0.65
SMD1812P260TFT
4.37
4.73
3.07
3.41
0.50
1.00
0.30
1.20
0.15
SMD1812P260TF/12
4.37
4.73
3.07
3.41
0.80
1.34
0.30
1.20
0.15
0.65
SMD1812P260TF/16
4.54
4.90
3.16
3.50
1.20
2.00
0.30
1.20
0.15
0.65
SMD1812P300TFT
4.37
4.73
3.07
3.41
0.50
1.00
0.30
1.20
0.15
0.65
Page: 10 of 15
Environmental Specifications
Operating Temperature
-40ºC to +85 ºC
Maximum Device Surface
Temperature in Tripped State
125ºC
Passive Aging
+85ºC , 1000 hours
±5% typical resistance change
Humidity Aging
+85ºC , 85%R.H. 1000 hours
Thermal Shock
MIL-STD-202 Method 107G
+85ºC /-40ºC 20 times
-30% typical resistance change
Solvent Resistance
MIL-STD-202, Method 215
No change
Vibration
MIL-STD-883C, Method 2007.1, Condition A
No change
Moisture Sensitivity Level
Level 1, J-STD-020C
Page: 11 of 15
Packaging Quantity and Marking
Recommended Pad Layout (mm.)
3.45
3.15
1.78
Part Number
1.78
Marking
Quantity
SMD1812P010TF
010
1500
SMD1812P010TF/60
0160
1500
SMD1812P014TF
014
1500
SMD1812P020TF
020
2000
020ɄJ
1500
SMD1812P035TF/30
0330
1500
SMD1812P035TF/60
0360
1000
SMD1812P050TF
050
2000
SMD1812P050TF/30
0530
2000
SMD1812P050TF/60
0560
1000
SMD1812P075TF
075
2000
SMD1812P075TF/24
0724
1500
SMD1812P075TF/33
0733
1500
SMD1812P110TF
110
2000
SMD1812P110TF/16
1116
1500
SMD1812P110TF/24
1124
1500
SMD1812P110TF/33
1133
1000
SMD1812P125TF/16
125
1500
SMD1812P150TF/8
150
2000
SMD1812P150TF/12
1512
1500
SMD1812P150TF/16
1516
1500
SMD1812P150TF/24
1524
1000
SMD1812P160TF/8(4L)
160
2000
SMD1812P200TFT
SMD1812P200TF/12
2012
1500
SMD1812P200TF/16
2016
1500
SMD1812P260TFT
260
1500
SMD1812P260TF/12
2612
1000
SMD1812P260TF/16
2616
1000
30
1500
SMD1812P020TF-J
SMD1812P300TFT
˖ 12 mm tape on 7 inch reel per EIA-481 (equivalent to IEC286, part 3)
Page: 12 of 15
Physical Specifications
Terminal Material
Solder-Plated Copper (Solder Material: Matte Tin (Sn))
Lead Solderability
Meets EIA Specification RS186-9E, ANSI/J-STD-002 Category 3.
Page: 13 of 15
Tape Specifications: EIA-481 (mm.)
P020TF
P010TF, P010TF/60
P035TF/60
P050TF, P050TF/30,
P014TF, P020TF-J
P050TF/60
P075TF, P110TF
P035TF/30
P110TF/33
P160TF/8(4L)
P075TF/24, P075TF/33
P150TF/24
P150TF/8
P110TF/16, P110TF/24
P260TF/12
P200TFT
P125TF/16, P150TF/12
P260TF/16
P150TF/16
P200TF/12, P200TF/16
P260TFT, P300TFT
W
F
E1
D0
D1
P0
P1
P2
A0
B0
T
K0
12.00 ± 0.30
12.00 ± 0.30
12.00 ± 0.10
5.50 ± 0.05
5.50 ± 0.05
5.50 ± 0.05
1.75 ± 0.10
1.75 ± 0.10
1.75 ± 0.10
1.55 ± 0.05
1.55 ± 0.05
1.55 ± 0.05
1.55 (MIN)
1.50 ± 0.10
1.50 (MIN)
4.00 ± 0.10
4.00 ± 0.10
4.00 ± 0.08
8.00 ± 0.10
8.00 ± 0.10
8.00 ± 0.10
2.00 ± 0.05
2.00 ± 0.05
2.00 ± 0.05
3.58 ± 0.10
3.50 ± 0.10
3.58 ± 0.10
4.93 ± 0.10
4.85 ± 0.10
4.93 ± 0.10
0.25 ± 0.10
0.25 ± 0.10
0.25 ± 0.10
0.87 ± 0.06
1.25 ± 0.10
2.10 ± 0.10
Leader
min.
390
390
390
Trailer
min.
160
160
160
Reel Dimensions: EIA-481 (mm.)
C
D
H
W
Ø178 ± 1.0
Ø60.2 ± 0.5
16.0 ± 0.5
13.2 ± 1.5
Page: 14 of 15
Part Number System
SMD 1812 P □□□ TF T /□□
Special Voltage Rating (Optional)
Thickness Version (Optional)
Lead- Free
Holding Current Rating
Polytronics Symbol
Device Dimensions: Length/Width (Unit: 1/100 inch)
Cross Reference
Cross Reference
Polytronics / EVERFUSE®
TE Connectivity / PolySwitch®
Bourns / Multifuse®
SMD1812P010TF
miniSMDC010F
MF-MSMF010
SMD1812P010TF/60
miniSMDC010F
MF-MSMF010
SMD1812P014TF
miniSMDC014F
MF-MSMF014
SMD1812P020TF
miniSMDC020F
MF-MSMF020
SMD1812P020TF-J
MF-MSMF020/60
SMD1812P035TF/30
SMD1812P035TF/60
miniSMDC050F
MF-MSMF050
SMD1812P050TF/30
SMD1812P050TF/60
miniSMDC075F
MF-MSMF075
SMD1812P075TF/24
miniSMDM075F/24
MF-MSMF075/24
SMD1812P075TF/33
miniSMDC110F
MF-MSMF110
SMD1812P110TF/16
miniSMDC110F/16
MF-MSMF110/16
SMD1812P110TF/24
miniSMDC110F/24
SMD1812P110TF/33
SMD1812P125TF/16
miniSMDC125F/16
MF-MSMF125
SMD1812P050TF
SMD1812P075TF
SMD1812P110TF
SMD1812P150TF/8
miniSMDC150F
MF-MSMF150
SMD1812P150TF/12
miniSMDC150F/12
SMD1812P150TF/16
miniSMDC150F/16
SMD1812P150TF/24
miniSMDM150F/24
SMD1812P160TF/8(4L)
miniSMDM160F
MF-MSMF160
SMD1812P200TFT
miniSMDC200F
MF-MSMF200
SMD1812P200TF/12
SMD1812P200TF/16
miniSMDC260F
MF-MSMF260
SMD1812P260TF/12
miniSMDC260F/12
SMD1812P260TF/16
miniSMDC260F/16
miniSMDC300F
SMD1812P260TFT
SMD1812P300TFT
“EVERFUSE” is a registered trademark of Polytronics Technology Corp.
“Multifuse” is a registered trademark of Bourns, Inc.
“PolySwitch” is a registered trademark of TE Connectivity Ltd.
Page: 15 of 15
