KBL406
KBL406
    GOODWORK(固得沃克)
    KBL
    单相4.0安培桥式整流器 VR=600V IR=5μA KBL
KBL406 数据手册
KBL406 THRU KBL410 SINGLE PHASE 4.0 AMP BRIDGE RECTIFIERS VOLTAGE RANGE 50 to 1000 Volts CURRENT FEATURES 4.0 Amperes * Ideal for printed circuit board * Low forward voltage 0.768(19.5) 0.728(18.5) * Low leakage current * Polarity: marked on body 0.580(14.7) 0.640(16.3) 0.540(13.7) 0.600(15.2) * Mounting position: Any AC + - 0.750 (19.0) MIN. 0.052(1.3) 0.048(1.2) 0.083 (2.1) 0.220(5.6) 0.180(4.6) 0.256(6.5) 0.236(6.0) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. KBL406 TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current KBL408 600 420 600 800 560 800 KBL410 UNITS 1000 700 1000 V V V .375"(9.5mm) Lead Length at Ta=50 C Peak Forward Surge Current, 8.3 ms single half sine-wave 4.0 A superimposed on rated load (JEDEC method) Maximum Forward Voltage Drop per Bridge Element at 4.0A D.C. Maximum DC Reverse Current Ta=25 C 150 1.0 5 A V A 500 +150 +150 C C at Rated DC Blocking Voltage Operating Temperature Range, TJ Storage Temperature Range, TSTG Ta=100 C -65 -65 A REV 1.0 2017 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (KBL406 THRU KBL410) FIG.2-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 6 5 4 Single Phase 3 Half Wave 60Hz Resistive Or Inductive Load 2 1 0 0 25 50 75 100 125 150 175 AMBIENT TEMPERATURE,( C) PEAK FORWARD SURGE CURRENT,(A) AVERAGE FORWARD CURRENT,(A) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE 250 200 150 8.3ms Single Half Tj=25 C Sine Wave 100 JEDEC method 50 0 1 5 50 10 100 FIG.3-TYPICAL FORWARD FIG.4-TYPICAL REVERSE CHARACTERISTICS CHARACTERISTICS 50 50 10 10 REVERSE LEAKAGE CURRENT, ( A) INSTANTANEOUS FORWARD CURRENT,(A) NUMBER OF CYCLES AT 60Hz 3.0 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 3.0 Tj=100 C 1.0 0.1 Tj=25 C .01 0 .2 .4 .6 .8 1.0 FORWARD VOLTAGE,(V) 1.2 1.4 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE, (%) REV 1.0 2017 JAN PAGE:2/2
KBL406 价格&库存
很抱歉,暂时无法提供与“KBL406”相匹配的价格&库存,您可以联系我们找货
KBL406
  • 1+0.77001
  • 30+0.74251
  • 100+0.71501
  • 500+0.66001
  • 1000+0.63251
  • 2000+0.61601
库存:450
