SD103AWS
35 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
0.35
VOLTAGE RANGE
40 Volts
CURRENT
FEATURES
0.35Ampere
Fast Switching Speed
Surface Mount Package Ideally Suited for Automatic Insertion
For General Purpose Switching Applications
High Conductance
SOD323
E
E
D
b
A1
A
C
z
z
z
z
MECHANICAL DATA
L1
* Case: Molded plastic
* Lead: Axial leads, solderable per MIL-STD-750,
method 2026
* Polarity:Polarity symbols marked on case
* Marking: S4
E1
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
63
100
9.8
7.9
UNIT
mm
8
mil
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
SD103AWS
UNITS
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
40
21
40
V
V
V
See Fig. 1
Peak Forward Surge Current, 8.3 ms single half sine-wave
0.35
A
2
A
V
mA
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 0.2A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Typical Junction Capacitance (Note1)
Typical Thermal Resistance RqJA (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
0.6
0.05
8
Ta=100 C
-65
-65
400
+125
+150
mA
pF
C/W
C
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Ambient.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (SD103AWS)
FIG.2-TYPICAL FORWARD
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
50
0.4
0.3
0.2
0.1
60
80
100
120
140
160
180
AMBIENT TEMPERATURE ( C)
FIG.3 - Power Derating Curve
POWER DISSIPATION PD (mW)
300
200
INSTANTANEOUS FORWARD CURRENT,(A)
0.5
10
3.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
250
.01
.1
200
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
150
100
50
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
100
FIG.4-TYPICAL JUNCTION CAPACITANCE
10
50
75
100
AMBIENT TEMPERATURE T (℃)
100
Ta=25℃
f=1MHz
80
60
40
REVERSE LEAKAGE CURRENT, (mA)
a
CAPACITANCE BETWEEN TERMINALS
CT (pF)
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
0.6
1.0
Tj=75 C
.1
Tj=25 C
10
15
30
60
80
100 120 140
PERCENTAGE RATED PEAK REVERSE VOLTAGE
REVERSE VOLTAGE VR (V)
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“SD103AWS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.04500
- 100+0.04200
- 300+0.03900
- 500+0.03600
- 2000+0.03450
- 5000+0.03360
