ESD36VB25-1006
1-Line Bi-directional TVS Diode
www.sot23.com.tw
Features
Mechanical Characteristics
⚫ Package: DFN1006-2 (0402)
⚫ Lead Finish: Matte Tin
⚫ Ultra small package: 1.0x0.6x0.5mm
⚫ Ultra low capacitance: 30pF (Max)
⚫ Case Material: “Green” Molding Compound.
⚫ Moisture Sensitivity: Level 3 per J-STD-020
⚫ Ultra low leakage: nA level
⚫ Low operating voltage: ±36V
⚫ Terminal Connections: See Diagram Below
⚫ Low clamping voltage
⚫ 2-pin leadless package
Applications
IC
⚫ Complies with following standards:
⚫ – IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
- - (Lightning) 6A (8/20μs)
μs)
⚫ – IEC61000-4-5
⚫ RoHS Compliant
BL
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
Digital Cameras
Peripherals
PU
⚫ Lead Finish: NiPdAu
Ordering Information
Qty per Reel
Reel Size
ESD36VB25-1006
3000
10000
7”
TE
CH
Part Number
Dimensions and Pin Configuration
ESD36VB25-1006
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
350
W
Peak Pulse Current (8/20µs)
Ipp
6
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Operating Temperature Range
kV
±30
BL
Storage Temperature Range
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
Reverse Working Voltage
VBR
Clamping Voltage
Junction Capacitance
Max
36
40
Unit
Test Condition
V
V
IT = 1mA
IR
0.05
uA
VC
50
V
Ipp=1A(8x 20us pulse)
VC
60
V
Ipp=6A(8x 20us pulse)
CJ
30
pF
VR = 0V, f = 1MHz
TE
Reverse Leakage Current
Clamping Voltage
VRWM
Typ
CH
Breakdown Voltage
Min
PU
Parameter
2
VRWM = 24V
WWW.TECHPUBLIC.COM.TW
ESD36VB25-1006
www.sot23.com.tw
TE
CH
UB
LI
C
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
3
ESD36VB25-1006
www.sot23.com.tw
DFN1006-2 Package Outline Drawing (0402)
h
h
A
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.45
0.50
0.55
0.018
0.020
0.022
c
0.12
0.15
0.18
0.005
0.006
0.007
D
0.95
1.00
1.05
0.037
0.039
0.041
SYM
b
E
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.45
0.50
0.55
0.018
0.020
0.022
L
A1
c
A
Bottom View
0.65 BSC
BL
e
IC
e
D
0.026 BSC
0.55
0.60
0.65
0.022
0.024
0.026
L
0.20
0.25
0.30
0.008
0.010
0.012
h
0.07
0.12
0.17
0.003
0.005
0.007
Y3
Y2
TE
Suggested Land Pattern
CH
PU
E
Y1
SYM
Z
DIMENSIONS
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
X
4
很抱歉,暂时无法提供与“ESD36VB25-1006”相匹配的价格&库存,您可以联系我们找货
