WST3415A
P-Ch MOSFET
General Description
Product Summery
The WST3415A is the highest performance
trench P-ch MOSFET with extreme high cell
density , which provide excellent RDSON and
gate charge for most of the small power switching
and load switch applications.
BVDSS
RDSON
ID
-20V
58mΩ
-5.3A
Applications
The WST3415A meet the RoHS and Green
Product requirement , with full function reliability
approved.
z High Frequency Point-of-Load Synchronous
Buck Converter for MB/NB/UMPC/VGA
z Networking DC-DC Power System
Features
z ESD:3KV
z Advanced high cell density Trench technology
SOT-23-3L Pin Configuration
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
V
VGS
Gate-Source Voltage
-20
±12
ID@TC=25℃
Continuous Drain Current, VGS @ -4.5V1
-5.3
A
ID@TC=70℃
1
-3.0
A
-17
A
IDM
Pulsed Drain Current
2
3
V
PD@TA=25℃
Total Power Dissipation
1.0
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Thermal Resistance Junction-Case1
www.winsok.tw
Page 1
1
Typ.
Max.
Unit
110
℃/W
70
℃/W
Rev:1.0 May.2019
WST3415A
P-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-20
V
Reference to 25℃ , ID=-1mA
-0.016
V/℃
VGS=-4.5V , ID=-3A
58
64
VGS=-2.5V , ID=-2A
67
78
66
75
-0.3
-0.75
-1.0
V
3.97
mV/℃
VDS=-16V , VGS=0V , TJ=25℃
1
VDS=-16V , VGS=0V , TJ=55℃
5
VGS=-1.8V , ID=-1A
VGS(th)
Gate Threshold Voltage
VGS=VDS , ID =-250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±8V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-3A
14
S
6.2
9
2.2
2.5
Qg
Total Gate Charge (-4.5V)
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
1.8
2.6
Turn-On Delay Time
2.7
5.5
Td(on)
VDS=-15V , VGS=-4.5V , ID=-3A
uA
nC
Rise Time
VDD=-10V , VGS=-4.5V ,
8.4
15
Turn-Off Delay Time
RG=3.3Ω, ID=-3A
38
78
Fall Time
6
12
Ciss
Input Capacitance
575
810
Coss
Output Capacitance
98
135
Crss
Reverse Transfer Capacitance
75
110
Min.
Typ.
Max.
-1
A
-17
A
-1
V
28
nS
25
nC
Tr
Td(off)
Tf
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
Conditions
1,4
IS
Continuous Source Current
ISM
Pulsed Source Current2,4
VSD
Diode Forward Voltage2
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
IF=-3A , dI/dt=100A/µs , TJ=25℃
Unit
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WST3415A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.22680
- 50+0.20952
- 200+0.19512
- 600+0.18072
- 1500+0.16920
- 3000+0.16200
