LTC8551XT5/R6
LTC8551XT5/R6
    LINEARIN(先积)
    SOT23-5L
    单、零漂、微功率1.5MHz、RRIO运算放大器
LTC8551XT5/R6 数据手册
LTC8551, LTC8552, LTC8553 P-1 General Description The LTC855x family of amplifiers provides input offset voltage correction for very low offset and drift through the use of patented fast step response chopper stabilized techniques. This method constantly measures and compensates the input offset, eliminating drift over time and temperature and the effect of 1/f noise. This design breakthrough allows the combination of a gain bandwidth product of 1.5 MHz and a high slew rate of 1.2 V/μs, while only drawing 125 μA supply current. These devices are unity gain stable and have good Power Supply Rejection Ratio (PSRR) and Common Mode Rejection Ratio (CMRR). The LTC855x series are perfectly suited for applications that require precision amplification of low level signals, in which error sources cannot be tolerated, even in which high bandwidth and fast transition are needed. The rail-to-rail input and output swings make both high-side and low-side sensing easy. The LTC855x series can operate with a single supply voltage as low as 1.8 V for 2-cell battery applications. The LTC855x op-amps have enhanced EMI protection to minimize any electromagnetic interference from external sources, and have high electro-static discharge (ESD) protection (5-kV HBM). All models are specified over the extended industrial temperature range of −40 ℃ to +125 ℃. Features and Benefits  High DC Precision: – ±8 μV (maximum) VOS with a Drift of ±40 nV/℃ (maximum) – AVOL: 112 dB (minimum, VDD = 5.5V) – PSRR: 112 dB (minimum, VDD = 5.5V) – CMRR: 112 dB (minimum, VDD = 5.5V) – Vn: 0.45 μVPP (typical, f = 0.1 to 10 Hz)  1.5 MHz Bandwidth and 1.2 V/μs Slew Rate  Settling Time to 0.1% with 1V Step: 1.2 μs  Overload Recovery Time to 0.1%: 35 μs  Micro-Power 125 μA per Amplifier and 1.8 V to 5.5 V Wide Supply Voltage Range  Operating Temperature Range: −40℃ to +125℃ Applications         Precision current sensing Resistor thermal detectors Temperature, position and pressure sensors Medical equipment Electronic scales Strain gage amplifiers Thermocouple amplifiers Driving A/D Converters Pin Configurations (Top View) LTC8551 LTC8551 LTC8552 LTC8552 LTC8553 SOT23-5L SOIC-8L / MSOP-8L DFN2x2-8L SOIC-8L / MSOP-8L SOT23-5L / SC70-5L OUT 1 5 +VS –VS 2 +IN 3 4 –IN OUTA 1 NC 1 –IN 2 8 7 8 +VS NC –INA 2 7 OUTB OUT A 1 +VS +INA 3 6 –INB –IN A 2 –VS 4 5 +INB +IN A 3 –VS 4 +IN 3 6 OUT –VS 4 5 NC CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 8 A B +VS 7 OUT B 6 –IN B 5 +IN B +IN 1 5 +VS –VS 2 –IN 3 4 OUT FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-2 Pin Description Symbol Description Symbol Description –IN Inverting input of the amplifier. –VS Negative (lowest) power supply. +IN Non-inverting input of the amplifier. OUT Amplifier output. +VS Positive (highest) power supply. NC No internal connection. Ordering Information Orderable Type Number Package Name Package Quantity Eco Class(1) Operating Temperature Marking Code LTC8551XT5/R6 SOT23-5L 3 000 Green (RoHS & no Sb/Br) –40℃ to +125℃ AZ1 LTC8551XS8/R8 SOIC-8L 4 000 Green (RoHS & no Sb/Br) –40℃ to +125℃ AZ1 X LTC8552XF8/R6 DFN2x2-8L 3 000 Green (RoHS & no Sb/Br) –40℃ to +125℃ AZ2 LTC8552XS8/R8 SOIC-8L 4 000 Green (RoHS & no Sb/Br) –40℃ to +125℃ AZ2 X LTC8552XV8/R6 MSOP-8L 3 000 Green (RoHS & no Sb/Br) –40℃ to +125℃ AZ2X LTC8553XT5/R6 SOT23-5L 3 000 Green (RoHS & no Sb/Br) –40℃ to +125℃ AZ3 LTC8553XC5/R6 SC70-5L 3 000 Green (RoHS & no Sb/Br) –40℃ to +125℃ AZ3 (1) Eco Class - The planned eco-friendly classification: Pb-Free (RoHS) or Green (RoHS & Halogen Free). (2) Please contact to your Linearin representative for the latest availability information and product content details. Limiting Value In accordance with the Absolute Maximum Rating System (IEC 60134). Parameter Absolute Maximum Rating Supply Voltage, VS+ to VS– 10.0 V Signal Input Terminals: Voltage, Current VS– – 0.5 V to VS+ + 0.5 V, ±20 mA Output Short-Circuit Continuous Storage Temperature Range, Tstg –65 ℃ to +150 ℃ Junction Temperature, TJ 150 ℃ Lead Temperature Range (Soldering 10 sec) 260 ℃ ESD Rating Parameter Electrostatic Discharge Voltage Item Value Human body model (HBM), per MIL-STD-883J / Method 3015.9 ±5 000 Charged device model (CDM), per ESDA/JEDEC JS-002-2014 ±2 000 Machine model (MM), per JESD22-A115C ±250 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. Unit V FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-3 Electrical Characteristics VS = 5.0V, TA = +25℃, VCM = VS /2, VO = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol Parameter Conditions Min. Typ. Max. Unit ±2 ±8 μV ±5 ±40 nV/℃ OFFSET VOLTAGE VOS Input offset voltage VOS TC Offset voltage drift TA = −40 to +125 ℃ Power supply rejection ratio VS = 2.0 to 5.5 V, VCM < VS+ − 2V 112 TA = −40 to +125 ℃ 106 PSRR 126 dB INPUT BIAS CURRENT ±70 IB Input bias current IOS Input offset current TA = +85 ℃ ±150 TA = +125 ℃ ±700 pA ±100 pA NOISE Vn Input voltage noise en Input voltage noise density In Input current noise density f = 0.01 to 1 Hz 0.1 f = 0.1 to 10 Hz 0.45 f = 10 kHz 15 f = 1 kHz 19 f = 1 kHz 10 μVP-P nV/√Hz fA/√Hz INPUT VOLTAGE VCM CMRR Common-mode voltage range Common-mode rejection ratio VS––0.1 VS = 5.5 V, VCM = −0.1 to 5.5 V 112 VCM = 0 to 5.3 V, TA = −40 to +125 ℃ 106 VS = 2.0 V, VCM = −0.1 to 2.0 V 102 VCM = 0 to 1.8 V, TA = −40 to +125 ℃ 96 VS++0.1 V 130 122 dB INPUT IMPEDANCE RIN Input resistance CIN Input capacitance 100 GΩ Differential 2.0 Common mode 3.5 pF OPEN-LOOP GAIN AVOL Open-loop voltage gain RL = 20 kΩ, VO = 0.05 to 3.5 V 112 TA = −40 to +125 ℃ 106 RL = 2 kΩ, VO = 0.15 to 3.5 V 101 TA = −40 to +125 ℃ 95 132 120 dB FREQUENCY RESPONSE SR Gain bandwidth product Slew rate tS Settling time tOR Overload recovery time GBW f = 1 kHz 1.5 MHz G = +1, CL = 100 pF, VO = 1.5 to 3.5 V 1.2 V/μs To 0.1%, G = +1, 1V step 1.2 To 0.01%, G = +1, 1V step 1.5 To 0.1%, VIN * Gain > VS 35 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. μs μs FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-4 Electrical Characteristics (continued) VS = 5.0V, TA = +25℃, VCM = VS /2, VO = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol Parameter Conditions Min. Typ. Max. Unit OUTPUT VOH High output voltage swing RL = 20 kΩ VOL Low output voltage swing RL = 20 kΩ VS–+4 RL = 2 kΩ VS–+40 ZOUT Open-loop output impedance ISC Short-circuit current RL = 2 kΩ VS+–6 VS+–100 f = 350 kHz, IO = 0 mV VS+–60 VS–+66 2 Source current through 10Ω 40 Sink current through 10Ω 50 mV kΩ mA POWER SUPPLY VS Operating supply voltage IQ Quiescent current (per amplifier) TA = 0 to +70 ℃ 1.8 5.5 TA = −40 to +125 ℃ 2.0 5.5 80 125 V 190 μA +125 ℃ THERMAL CHARACTERISTICS TA θJA Operating temperature range Package Thermal Resistance -40 SC70-5L 333 SOT23-5L 190 DFN2x2-8L 80 MSOP-8L 216 SOIC-8L 125 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. ℃/W FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-5 Typical Performance Characteristics 5,000 Sampels VS = 5V VCM = –VS 600 AOL (dB) 500 400 300 125 100 100 75 75 50 50 25 25 0 200 0 -25 100 -25 -50 0 -50 10 -8 -7 -6 -5 -4 -3 -2 -1 0 1 2 3 4 5 6 7 8 Number of Amplifiers 700 1k Input Offset Voltage (μV) Open-loop Gain and Phase as a function of Frequency. 140 140 120 120 100 100 PSRR (dB) CMRR (dB) -75 10M 100k Frequency (Hz) Input Offset Voltage Production Distribution. 80 60 80 60 40 40 20 20 0 0 1 100 10k 1M 1 100 Frequency (Hz) 10k 1M Frequency (Hz) Common-mode Rejection Ratio as a function of Frequency. Power Supply Rejection Ratio as a function of Frequency. 200 Quiescent Current (μA) 200 Quiescent Current (μA) Phase (deg) At TA=+25℃, VS=±2.5V, VCM=VS /2, RL=10kΩ connected to VS /2, and CL=100pF, unless otherwise noted. 175 150 125 100 75 50 175 150 125 100 75 50 25 25 0 0 1.5 2 2.5 3 3.5 4 4.5 5 5.5 -50 0 25 50 75 100 125 Temperature (℃) Supply Voltage (V) Quiescent Current as a function of Supply Voltage. -25 Quiescent Current as a function of Temperature. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-6 Typical Performance Characteristics (continued) At TA = +25℃, VCM = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. 60 Sourcing Current Output Voltage (V) 4 3 –40℃ +125℃ +25℃ 2 1 Sinking Current Short-circuit Current (mA) 5 0 50 40 –ISC 30 +ISC 20 10 0 0 10 20 30 40 50 60 2 2.5 3 3.5 4 4.5 5 Supply Voltage (V) Output Current (mA) Output Voltage Swing as a function of Output Current. Short-circuit Current as a function of Supply Voltage. 1V/div 20 mV/div CL=100pF CL = 100pF AV = +1 2.5μs/div Large Signal Step Response (4V Step). 5.5 0.25 µs/div Small Signal Step Response (100mV Step). CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers P-7 LTC8551, LTC8552, LTC8553 Application Notes The LTC855x operational amplifiers are unity-gain stable and free from unexpected output phase reversal. These devices use a proprietary autocalibration technique to provide low offset voltage and very low drift over time and temperature. For lowest offset voltage and precision performance, optimize circuit layout and mechanical conditions. Avoid temperature gradients that create thermoelectric (Seebeck) effects in the thermocouple junctions formed from connecting dissimilar conductors. Cancel these thermallygenerated potentials by assuring they are equal on both input terminals. Other layout and design considerations include: • Use low thermoelectric-coefficient conditions (avoid dissimilar metals). • Thermally isolate components from power supplies or other heat sources. • Shield operational amplifier and input circuitry from air currents, such as cooling fans. Following these guidelines reduces the likelihood of junctions being at different temperatures, which can cause thermoelectric voltages of 0.1μV/℃ or higher, depending on materials used. OPERATING VOLTAGE The LTC855x family is fully specified and ensured for operation from 2.0V to 5.5V (±1.0V to ±2.75V). In addition, many specifications apply from –40℃ to +125℃. Parameters that vary significantly with operating voltages or temperature are illustrated in the Typical Characteristics graphs. NOTE: Supply voltages (VS+ to VS–) higher than +10V can permanently damage the device. INPUT VOLTAGE The input common-mode voltage range of the LTC855x series extends 100mV beyond the negative supply rail and reaches the positive supply rail. This performance is achieved with a complementary input stage: an N-channel input differential pair in parallel with a P-channel differential pair. The N-channel pair is active for input voltages close to the positive rail, typically VS+–1.4V to the positive supply, whereas the P-channel pair is active for inputs from 200mV below the negative supply to approximately VS+–1.4V. There is a small transition region, typically VS+–1.2V to VS+– 1V, in which both pairs are on. This 200mV transition region can vary up to 200mV with process variation. Thus, the transition region (both stages on) can range from VS+–1.4V to VS+–1.2V on the low end, up to VS+–1V to VS+–0.8V on the high end. Within this transition region, PSRR, CMRR, offset voltage, offset drift, and THD can be degraded compared to device operation outside this region. The typical input bias current of the LTC855x during normal operation is approximately 70pA. In overdriven conditions, the bias current can increase significantly. The most common cause of an overdriven condition occurs when the operational amplifier is outside of the linear range of operation. When the output of the operational amplifier is driven to one of the supply rails, the feedback loop requirements cannot be satisfied and a differential input voltage develops across the input pins. This differential input voltage results in activation of parasitic diodes inside the front-end input chopping switches that combine with electromagnetic interference (EMI) filter resistors to create the equivalent circuit. Notice that the input bias current remains within specification in the linear region. INPUT EMI FILTER AND CLAMP CIRCUIT Figure 1 shows the input EMI filter and clamp circuit. The LTC855x op-amps have internal ESD protection diodes (D1, D2, D3, and D4) that are connected between the inputs and each supply rail. These diodes protect the input transistors in the event of electrostatic discharge and are reverse biased during normal operation. This protection scheme allows voltages as high as approximately 500mV beyond the rails to be applied at the input of either terminal without causing permanent damage. See the table of Absolute Maximum Ratings for more information. Operational amplifiers vary in susceptibility to EMI. If conducted EMI enters the operational amplifier, the dc offset at the amplifier output can shift from its nominal value when EMI is present. This shift is a result of signal rectification associated with the internal semiconductor junctions. Although all operational amplifier pin functions can be affected by EMI, the input pins are likely to be the most susceptible. The EMI filter of the LTC855x family is composed of two 5-kΩ input series resistors (RS1 and RS2), two common-mode capacitors (CCM1 and CCM2), and a differential capacitor (CDM). These RC networks set the −3dB low-pass cutoff frequencies at 35-MHz for common-mode signals, and at 22-MHz for differential signals. VS+ D1 RS1 500Ω IN+ D2 D3 CCM1 RS2 CDM 500Ω IN– D4 CCM2 VS– Figure 1. Input EMI Filter and Clamp Circuit CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-8 Application Notes (continued) INTERNAL OFFSET CORRECTION The LTC855x operational amplifiers use an autocalibration technique with a time-continuous 500kHz operational amplifier in the signal path. This amplifier is zero-corrected every 2μs using a proprietary technique. Upon power up, the amplifier requires approximately 100μs to achieve specified VOS accuracy. This design has no aliasing or flicker noise. parallel with the feedback resistor to counteract the parasitic capacitance associated with inverting node. CF RF RISO CL CAPACITIVE LOAD AND STABILITY The LTC855x family can safely drive capacitive loads of up to 500pF in any configuration. As with most amplifiers, driving larger capacitive loads than specified may cause excessive overshoot and ringing, or even oscillation. A heavy capacitive load reduces the phase margin and causes the amplifier frequency response to peak. Peaking corresponds to overshooting or ringing in the time domain. Therefore, it is recommended that external compensation be used if the LTC855x op-amps must drive a load exceeding 500pF. This compensation is particularly important in the unity-gain configuration, which is the worst case for stability. A quick and easy way to stabilize the op-amp for capacitive load drive is by adding a series resistor, RISO, between the amplifier output terminal and the load capacitance, as shown in Figure 2. RISO isolates the amplifier output and feedback network from the capacitive load. The bigger the RISO resistor value, the more stable VOUT will be. Note that this method results in a loss of gain accuracy because RISO forms a voltage divider with the RL. RISO LTC855x VOUT LTC855x VIN VOUT VIN CL Figure 2. Indirectly Driving Heavy Capacitive Load An improvement circuit is shown in Figure 3. It provides DC accuracy as well as AC stability. The RF provides the DC accuracy by connecting the inverting signal with the output. The CF and RISO serve to counteract the loss of phase margin by feeding the high frequency component of the output signal back to the amplifier’s inverting input, thereby preserving phase margin in the overall feedback loop. For no-buffer configuration, there are two others ways to increase the phase margin: (a) by increasing the amplifier’s gain, or (b) by placing a capacitor in RL Figure 3. Indirectly Driving Heavy Capacitive Load with DC Accuracy OVERLOAD RECOVERY Overload recovery is defined as the time required for the operational amplifier output to recover from a saturated state to a linear state. The output devices of the operational amplifier enter a saturation region when the output voltage exceeds the rated operating voltage, either because of the high input voltage or the high gain. After the device enters the saturation region, the charge carriers in the output devices require time to return back to the linear state. After the charge carriers return back to the linear state, the device begins to slew at the specified slew rate. Thus, the propagation delay in case of an overload condition is the sum of the overload recovery time and the slew time. The overload recovery time for the LTC855x family is approximately 35μs. EMI REJECTION RATIO Circuit performance is often adversely affected by high frequency EMI. When the signal strength is low and transmission lines are long, an op-amp must accurately amplify the input signals. However, all opamp pins — the non-inverting input, inverting input, positive supply, negative supply, and output pins — are susceptible to EMI signals. These high frequency signals are coupled into an op-amp by various means, such as conduction, near field radiation, or far field radiation. For example, wires and printed circuit board (PCB) traces can act as antennas and pick up high frequency EMI signals. Amplifiers do not amplify EMI or RF signals due to their relatively low bandwidth. However, due to the nonlinearities of the input devices, op-amps can rectify these out of band signals. When these high frequency signals are rectified, they appear as a dc offset at the output. The LTC855x op-amps have integrated EMI filters at their input stage. A mathematical method of measuring EMIRR is defined as follows: EMIRR = 20 log (VIN_PEAK / ΔVOS) CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-9 Application Notes (continued) MAXIMIZING PERFORMANCE THROUGH PROPER LAYOUT To achieve the maximum performance of the extremely high input impedance and low offset voltage of the LTC855x op-amps, care is needed in laying out the circuit board. The PCB surface must remain clean and free of moisture to avoid leakage currents between adjacent traces. Surface coating of the circuit board reduces surface moisture and provides a humidity barrier, reducing parasitic resistance on the board. The use of guard rings around the amplifier inputs further reduces leakage currents. Figure 4 shows proper guard ring configuration and the top view of a surface-mount layout. The guard ring does not need to be a specific width, but it should form a continuous loop around both inputs. By setting the guard ring voltage equal to the voltage at the non-inverting input, parasitic capacitance is minimized as well. For further reduction of leakage currents, components can be mounted to the PCB using Teflon standoff insulators. Guard Ring +IN –IN +VS Figure 4. Use a guard ring around sensitive pins Other potential sources of offset error are thermoelectric voltages on the circuit board. This voltage, also called Seebeck voltage, occurs at the junction of two dissimilar metals and is proportional to the temperature of the junction. The most common metallic junctions on a circuit board are solder-toboard trace and solder-to-component lead. If the temperature of the PCB at one end of the component is different from the temperature at the other end, the resulting Seebeck voltages are not equal, resulting in a thermal voltage error. This thermocouple error can be reduced by using dummy components to match the thermoelectric error source. Placing the dummy component as close as possible to its partner ensures both Seebeck voltages are equal, thus canceling the thermocouple error. Maintaining a constant ambient temperature on the circuit board further reduces this error. The use of a ground plane helps distribute heat throughout the board and reduces EMI noise pickup. INPUT-TO-OUTPUT COUPLING To minimize capacitive coupling, the input and output signal traces should not be parallel. This helps reduce unwanted positive feedback. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-10 Typical Application Circuits PRECISION LOW-SIDE CURRENT SHUNT SENSING Many applications require the sensing of signals near the positive or negative rails. Current shunt sensing is one such application and is mostly used for feedback control systems. It is also used in a variety of other applications, including power metering, battery fuel gauging, and feedback controls in industrial applications. In such applications, it is desirable to use a shunt with very low resistance to minimize series voltage drop. This configuration not only minimizes wasted power, but also allows the measurement of high currents while saving power. A typical shunt may be 100mΩ. At a measured current of 1A, the voltage produced from the shunt is 100mV, and the amplifier error sources are not critical. However, at low measured current in the 1mA range, the 100μV generated across the shunt demands a very low offset voltage and drift amplifier to maintain absolute accuracy. The unique attributes of a zero drift amplifier provide a solution. Figure 5 shows a low-side current sensing circuit using the LTC8551/LTC8552. The LTC8551/LTC8552 are configured as difference amplifiers with a gain of 1000. Although the LTC8551/LTC8552 have high CMRR, the CMRR of the system is limited by the external resistors. Therefore, the key to high CMRR for the system is resistors that are well matched from both the resistive ratio and relative drift, where R1/R2 = R3/R4. The transfer function is given by: VOUT = VSHUNT × GainDiff_Amp = (RSHUNT × ILOAD) × (R2 / R1) = 100 × ILOAD VBUS ILOAD 100Ω R3 VSHUNT 0.1Ω RSHUNT 100kΩ R2 LTC8551 100Ω R1 VOUT VDD 100kΩ R2 Figure 5. Low-Side Current Sensing Circuit Any unused channel of the LTC8551/LTC8552 must be configured in unity gain with the input common-mode voltage tied to the midpoint of the power supplies. BIDIRECTIONAL CURRENT-SENSING This single-supply, low-side, bidirectional current-sensing solution detects load currents from –1A to +1A. The single-ended output spans from 110mV to 3.19V. This design uses the LTC855x because of its low offset voltage and rail-to-rail input and output. One of the amplifiers is configured as a difference amplifier and the other amplifier provides the reference voltage. Figure 6 shows the solution. This solution has the following requirements: • Supply voltage: 3.3V • Input: –1A to +1A • Output: 1.65V±1.54V (110mV to 3.19V) There are two types of errors in this design: offset and gain. Gain errors are introduced by the tolerance of the shunt resistor and the ratios of R4 to R3 and, similarly, R2 to R1. Offset errors are introduced by the voltage divider (R5 and R6) and how closely the ratio of R4/R3 matches R2/R1. The latter value affects the CMRR of the difference amplifier, ultimately translating to an offset error. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-11 Typical Application Circuits VDD VBUS VREF U1B LTC8552 ILOAD R2 VDD VDD R5 R6 R1 VSHUNT RSHUNT R3 U1A LTC8552 VOUT R4 Figure 6. Bidirectional Current-Sensing Schematic The load current, ILOAD, flows through the shunt resistor (RSHUNT) to develop the shunt voltage, VSHUNT. The shunt voltage is then amplified by the difference amplifier consisting of U1A and R1 through R4. The gain of the difference amplifier is set by the ratio of R4 to R3. To minimize errors, set R2 = R4 and R1 = R3. The reference voltage, VREF, is supplied by buffering a resistor divider using U1B. The transfer function is given by Equation 1. VOUT = VSHUNT × GainDiff_Amp + VREF Where • VSHUNT = ILOAD × RSHUNT • GainDiff_Amp = R4 / R3 • VREF = VDD × [R6 / (R5 + R6)] (1) There are two types of errors in this design: offset and gain. Gain errors are introduced by the tolerance of the shunt resistor and the ratios of R4 to R3 and, similarly, R2 to R1. Offset errors are introduced by the voltage divider (R5 and R6) and how closely the ratio of R4/R3 matches R2/R1. The latter value affects the CMRR of the difference amplifier, ultimately translating to an offset error. The value of VSHUNT is the ground potential for the system load because VSHUNT is a low-side measurement. Therefore, a maximum value must be placed on VSHUNT. In this design, the maximum value for VSHUNT is set to 100mV. Equation 2 calculates the maximum value of the shunt resistor given a maximum shunt voltage of 100mV and maximum load current of 1A. RSHUNT(MAX) = VSHUNT(MAX) / ILOAD(MAX) = 100mV / 1A = 100 mΩ (2) The tolerance of RSHUNT is directly proportional to cost. For this design, a shunt resistor with a tolerance of 0.5% was selected. If greater accuracy is required, select a 0.1% resistor or better. The load current is bidirectional; therefore, the shunt voltage range is –100mV to +100mV. This voltage is divided down by R1 and R2 before reaching the operational amplifier, U1A. Take care to ensure that the voltage present at the non-inverting node of U1A is within the common-mode range of the device. Therefore, use an operational amplifier, such as the LTC8551, that has a common-mode range that extends below the negative supply voltage. Finally, to minimize offset error, note that the LTC8551 has a typical offset voltage of merely ±2μV (±8μV maximum). Given a symmetric load current of –1A to +1A, the voltage divider resistors (R5 and R6) must be equal. To be consistent with the shunt resistor, a tolerance of 0.5% was selected. To minimize power consumption, 10kΩ resistors were used. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-12 Typical Application Circuits To set the gain of the difference amplifier, the common-mode range and output swing of the LTC8551 must be considered. Equation 3 and Equation 4 depict the typical common-mode range and maximum output swing, respectively, of the LTC8551 given a 3.3V supply. • –100mV < VCM < 3.4V (3) • 100mV < VOUT < 3.2V (4) The gain of the difference amplifier can now be calculated as shown in Equation 5. GainDiff_Amp = (VOUT_MAX – VOUT_MIN) / [RSHUNT × (IMAX – IMIN)] GainDiff_Amp = (3.2V – 100mV) / 100mΩ × [1A – (–1A)] = 15.5 V/V (5) The resistor value selected for R1 and R3 was 1kΩ. 15.4kΩ was selected for R2 and R4 because this number is the nearest standard value. Therefore, the ideal gain of the difference amplifier is 15.4V/V. The gain error of the circuit primarily depends on R1 through R4. As a result of this dependence, 0.1% resistors were selected. This configuration reduces the likelihood that the design requires a two-point calibration. A simple one-point calibration, if desired, removes the offset errors introduced by the 0.5% resistors. Output Voltage (V) 3.3 1.65 0 -1 -0.5 0 0.5 Input Current (A) 1 Figure 7. Bidirectional Current-Sensing Circuit Performance: Output Voltage vs. Input Current HIGH-SIDE VOLTAGE-TO-CURRENT (V-I) CONVERTER The circuit shown in Figure 8 is a high-side voltage-to-current (V-I) converter. It translates in input voltage of 0V to 2V to and output current of 0mA to 100mA. V+ RS2 470Ω VRS2 RS3 4.7Ω IRS2 C7 R3 200Ω VRS3 2200pF U1B LTC8552 V+ U1A LTC8552 IRS3 R4 10kΩ Q2 R5 330Ω Q1 VIN VDD C6 1000pF VRS1 R2 10kΩ RS1 2kΩ IRS1 Figure 8. Bidirectional Current-Sensing Schematic CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. VLOAD RLOAD ILOAD FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-13 Typical Application Circuits The design requirements are as follows: • Supply Voltage: 5V DC • Input: 0V to 2V DC • Output: 0mA to 100mA DC The V-I transfer function of the circuit is based on the relationship between the input voltage, VIN, and the three current sensing resistors, RS1, RS2, and RS3. The relationship between VIN and RS1 determines the current that flows through the first stage of the design. The current gain from the first stage to the second stage is based on the relationship between RS2 and RS3. For a successful design, pay close attention to the dc characteristics of the operational amplifier chosen for the application. To meet the performance goals, this application benefits from an operational amplifier with low offset voltage, low temperature drift, and rail-to-rail output. The LTC8552 CMOS operational amplifier is a high-precision, typically 2μV offset, 5nV/℃ drift amplifier optimized for low-voltage, single-supply operation with an output swing to within 15mV (at RL = 10kΩ) of the positive rail. The LTC8552 family uses chopping techniques to provide low initial offset voltage and near-zero drift over time and temperature. Low offset voltage and low drift reduce the offset error in the system, making these devices appropriate for precise dc control. The rail-to-rail output stage of the LTC8552 ensures that the output swing of the operational amplifier is able to fully control the gate of the MOSFET devices within the supply rails. Figure 9 shows the measured transfer function for this circuit. The low offset voltage and offset drift of the LTC8552 facilitate excellent dc accuracy for the circuit. Output Current (mA) 100 75 50 25 0 0 0.5 1 1.5 2 Input Voltage (V) Figure 9. Measured Transfer Function for High-Side V-I Converter SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER The extremely low offset voltage and drift, high open-loop gain, high common-mode rejection, and high power supply rejection of the LTC8551/LTC8552 make them excellent op-amp choices as discrete, single-supply instrumentation amplifiers. Figure 10 shows the classic 3-op-amp instrumentation amplifier using the LTC8551/LTC8552. The key to high CMRR for the instrumentation amplifier are resistors that are well matched for both the resistive ratio and relative drift. For true difference amplification, matching of the resistor ratio is very important, where: • R5/R2 = R6/R4 • RG1 = RG2, R1 = R3, R2 = R4, R5 = R6 • VOUT = (VIN1 – VIN2) × (1 + R1 / RG1) × (R5 / R2) The resistors are important in determining the performance over manufacturing tolerances, time, and temperature. Assuming a perfect unity-gain difference amplifier with infinite common-mode rejection, a 1% tolerance resistor matching results in only 34dB of common-mode rejection. Therefore, at least 0.01% or better resistors are recommended. To build a discrete instrumentation amplifier with external resistors without compromising on noise, pay close attention to the resistor values chosen. RG1 and RG2 each have thermal noise that is amplified by the total noise gain of the instrumentation amplifier and, therefore, a sufficiently low value must be chosen to reduce thermal noise contribution at the output while still providing an accurate measurement. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-14 Typical Application Circuits VIN1 A1 R5 RG1 R1 R2 A3 RG2 R3 VOUT R4 A2 R6 VIN2 Figure 10. Discrete 3-Op-amp Instrumentation Amplifier Figure 11 shows the external resistors noise contribution referred to the output . Resistor Value Resistor Thermal Noise Thermal Noise Referred to Output RG1 RG2 R1 R2 R3 R4 R5 R6 0.4 kΩ 0.4 kΩ 10 kΩ 10 kΩ 10 kΩ 10 kΩ 20 kΩ 20 kΩ 2.57 nV/√Hz 2.57 nV/√Hz 12.83 nV/√Hz 12.83 nV/√Hz 12.83 nV/√Hz 12.83 nV/√Hz 18.14 nV/√Hz 18.14 nV/√Hz 128.30 nV/√Hz 128.30 nV/√Hz 25.66 nV/√Hz 25.66 nV/√Hz 25.66 nV/√Hz 25.66 nV/√Hz 18.14 nV/√Hz 18.14 nV/√Hz Figure 11. Thermal Noise Contribution Example Note that A1 and A2 have a high gain of 1 + R1/RG1. Therefore, use a high precision, low offset voltage and low noise amplifier for A1 and A2, such as the LTC8551/LTC8552. Conversely, A3 operates at a much lower gain and has a different set of op-amp requirements. Its input noise, referred to the overall instrumentation amplifier input, is divided by the first stage gain and is not as important. Note that the input offset voltage and the input voltage noise of the amplifiers are also amplified by the overall noise gain. Any unused channel of the LTC8551/LTC8552 must be configured in unity gain with the input common-mode voltage tied to the midpoint of the power supplies. Understanding how noise impacts a discrete instrumentation amplifier or a difference amplifier (the second stage of a 3-op-amp instrumentation amplifier) is important, because they are commonly used in many different applications. LOAD CELL (STRAIN GAGE) SENSOR SIGNAL CONDITIONING The LTC8552, with its ultralow offset, drift, and noise, is well suited to signal condition a low level sensor output with high gain and accuracy. A weigh scale (load cell) is an example of an application with such requirements. Figure 12 shows a configuration for a single-supply, precision, weigh scale measurement system. The LTC8552 is used at the front end for amplification of the low level signal from the load cell. Current flowing through a PCB trace produces an IR voltage drop; with longer traces, this voltage drop can be several millivolts or more, introducing a considerable error. A 1 inch long, 0.005 inch wide trace of 1 oz copper has a resistance of approximately 100mΩ at room temperature. With a load current of 10mA, the resistance can introduce a 1mV error. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-15 Typical Application Circuits Therefore, a 6-wire load cell is used in the circuit. The load cell has two sense pins, in addition to excitation, ground, and two output connections. The sense pins are connected to the high side (excitation pin) and low side (ground pin) of the Wheatstone bridge. The voltage across the bridge can then be accurately measured regardless of voltage drop due to wire resistance. The two sense pins are also connected to the analog-todigital converter (ADC) reference inputs for a ratio-metric configuration that is immune to low frequency changes in the power supply excitation voltage. The LTC8552 is configured as the first stage of a 3-op-amp instrumentation amplifier to amplify the low level amplitude signal from the load cell by a factor of 1 + 2R1/RG. Capacitors C1 and C2 are placed in the feedback loops of the amplifiers and interact with R1 and R2 to perform low-pass filtering. This filtering limits the amount of noise entering the Σ-Δ ADC. In addition, C3, C4, C5, R3 and R4 provide further common-mode and differential mode filtering to reduce noise and unwanted signals. VIN1 U1A LTC8552 REF+ REF– VEXC LOAD CELL OUT– R1 11.3kΩ SENSE+ C1 OUT+ R3 1kΩ R2 RG 60.4Ω C2 AIN+ 3.3μF 3.3μF R4 1kΩ SENSE– R2 11.3kΩ C5 10μF AIN– C4 C3 1μF 1μF U1B LTC8552 Figure 12. Precision Weigh Scale Measurement System CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. A/D Converter FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-16 Tape and Reel Information REEL DIMENSIONS TAPE DIMENSIONS K0 P1 B0 W Reel Diameter A0 Cavity A0 B0 K0 W P1 Reel Width (W1) Dimension designed to accommodate the component width Dimension designed to accommodate the component length Dimension designed to accommodate the component thickness Overall width of the carrier tape Pitch between successive cavity centers QUADRANT ASSIGNMENTS FOR PIN 1 ORIETATION IN TAPE Sprocket Holes Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 User Direction of Feed Pocket Quadrants * All dimensions are nominal Device LTC8551XT5/R6 Package Pins Type SOT23 5 SPQ 3 000 Reel Reel Diameter Width W1 (mm) (mm) 178 9.0 A0 (mm) B0 (mm) K0 (mm) P1 (mm) W (mm) Pin 1 Quadrant 3.3 3.2 1.5 4.0 8.0 Q3 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-17 Package Outlines DIMENSIONS, SOT23-5L A2 A A1 D e1 Symbol A A1 A2 b c D E1 E e e1 L L1 θ θ L E E1 L1 e b Dimensions In Millimeters Min Max 1.25 0.04 0.10 1.00 1.20 0.33 0.41 0.15 0.19 2.820 3.02 1.50 1.70 2.60 3.00 0.95 BSC 1.90 BSC 0.60 REF 0.30 0.60 0° 8° Dimensions In Inches Min Max 0.049 0.002 0.004 0.039 0.047 0.013 0.016 0.006 0.007 0.111 0.119 0.059 0.067 0.102 0.118 0.037 BSC 0.075 BSC 0.024 REF 0.012 0.024 0° 8° c RECOMMENDED SOLDERING FOOTPRINT, SOT23-5L 1.0 0.039 0.95 0.037 0.95 0.037 0.7 0.028 2.4 0.094 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-18 Package Outlines (continued) DIMENSIONS, SC70-5L (SOT353) A2 A Symbol A1 D e1 A A1 A2 b C D E E1 e e1 L L1 θ θ e L E1 E L1 b Dimensions In Millimeters Min Max 0.90 1.10 0.00 0.10 0.90 1.00 0.15 0.35 0.08 0.15 2.00 2.20 1.15 1.35 2.15 2.45 0.65 TYP 1.20 1.40 0.525 REF 0.26 0.46 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SC70-5L (SOT353) 0.50 0.0197 0.65 0.0256 0.65 0.0256 0.40 0.0157 1.9 0.0748 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) Dimensions In Inches Min Max 0.035 0.043 0.000 0.004 0.035 0.039 0.006 0.014 0.003 0.006 0.079 0.087 0.045 0.053 0.085 0.096 0.026 TYP 0.047 0.055 0.021 REF 0.010 0.018 0° 8° FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-19 Package Outlines (continued) DIMENSIONS, DFN2x2-8L E A c A1 1 Nd D1 2 D b1 Exposed Thermal Pad Zone L h E1 h 2 e Symbol Min. 0.70 A A1 b b1 c D D1 Nd E E1 e L h 0.20 0.18 1.90 1.10 1.90 0.60 0.30 0.15 Millimeters Nom. 0.75 0.02 0.25 0.18 REF 0.20 2.00 1.20 1.50BSC 2.00 0.70 0.50BSC 0.35 0.20 1 b BOTTOM VIEW RECOMMENDED SOLDERING FOOTPRINT, DFN2x2-8L 1.60 0.0630 PACKAGE OUTLINE 8X 0.50 0.0197 1.00 0.0394 2.30 0.0906 1 0.50 PITCH 0.0197 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 0.30 8X 0.0118 mm ( inches ) Max. 0.80 0.05 0.30 0.25 2.10 1.30 2.10 0.80 0.40 0.25 FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-20 Package Outlines (continued) DIMENSIONS, MSOP-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E1 E Dimensions In Millimeters Min Max 0.800 1.100 Dimensions In Inches Min Max 0.031 0.043 0.050 0.150 0.750 0.950 0.290 0.380 0.150 0.200 2.900 3.100 2.900 3.100 4.700 5.100 0.650 TYP. 0.400 0.700 0° 8° 0.002 0.006 0.030 0.037 0.011 0.015 0.006 0.008 0.114 0.122 0.114 0.122 0.185 0.201 0.026 TYP. 0.016 0.028 0° 8° θ C RECOMMENDED SOLDERING FOOTPRINT, MSOP-8L 8X (0.45) MAX (0.018) (1.45) MAX (0.057) 8X 4.40 (5.85) MAX 0.173 (0.230) (2.95) MIN (0.116) 0.65 PITCH 0.026 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers LTC8551, LTC8552, LTC8553 P-21 Package Outlines (continued) DIMENSIONS, SOIC-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E E1 θ Dimensions In Millimeters Min Max 1.370 1.670 0.070 0.170 1.300 1.500 0.306 0.506 0.203 TYP. 4.700 5.100 3.820 4.020 5.800 6.200 1.270 TYP. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.054 0.066 0.003 0.007 0.051 0.059 0.012 0.020 0.008 TYP. 0.185 0.201 0.150 0.158 0.228 0.244 0.050 TYP. 0.018 0.030 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SOIC-8L 8X 5.40 0.213 (1.55) MAX (0.061) (3.90) MIN (0.154) 1 (0.60) MAX 8X (0.024) PITCH 1.270 0.050 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers P-22 LTC8551, LTC8552, LTC8553 IMPORTANT NOTICE Linearin is a global fabless semiconductor company specializing in advanced high-performance high- quality analog/mixed-signal IC products and sensor solutions. The company is devoted to the innovation of high performance, analog-intensive sensor front-end products and modular sensor solutions, applied in multi-market of medical & wearable devices, smart home, sensing of IoT, and intelligent industrial & smart factory (industrie 4.0). Linearin’s product families include widely-used standard catalog products, solution-based application specific standard products (ASSPs) and sensor modules that help customers achieve faster time-to-market products. Go to http://www.linearin.com for a complete list of Linearin product families. For additional product information, or full datasheet, please contact with the Linearin’s Sales Department or Representatives. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-21.1b — Data Sheet Zero-Drift, Micro-Power 1.5MHz, RRIO Operational Amplifiers
LTC8551XT5/R6 价格&库存
很抱歉,暂时无法提供与“LTC8551XT5/R6”相匹配的价格&库存,您可以联系我们找货
LTC8551XT5/R6
  • 1+1.98000
库存:495
LTC8551XT5/R6
    • 1+3.86640
    • 10+3.30480
    • 30+3.02400
    • 100+2.77560
    • 500+2.71080
    • 1000+2.66760
    库存:2042
