SL1550
Low vf
15.0A Surface Mount Trench Schottky Rectifier
VOLTAGE RANGE
50 Volts
CURRENT
15.0 Ampere
0.264 (6.70)
0.248 (6.30)
• Low forward voltage drop.
• Excellent high temperature stability.
• Fast switching capability.
• Suffix "G" indicates Halogen-free part, ex.CP10S45SG.
• Lead-free parts meet environmental standards of
MIL-STD-19500 /228
1
0.073 (1.85)
0.069 (1.75)
2
3
0.028 (0.71)
0.016 (0.41)
PIN 1
PIN 3
PIN 2
0.216 (5.48)
0.208 (5.28)
■ Mechanical data
0.163 (4.13)
0.151 (3.83)
TO-277
■ Features
0.077 (1.96)
0.069 (1.76)
0.028 (0.71)
0.016 (0.41)
0.037 (0.95)
0.033 (0.85)
• Epoxy : UL94-V0 rated flame retardant.
• Case : Molded plastic, TO-277 .
• Lead : Solder plated, solderable per MIL-STD-750,
Method 2026.
• Polarity: Indicated by cathode band .
• Mounting Position : Any.
• Weight : Approximated 0.093 grams .
0.124 (3.15)
0.112 (2.85)
0.037 (0.95)
0.033 (0.85)
0.145 (3.69)
0.133 (3.39)
0.014 (0.35)
0.010 (0.25)
0.069 (1.74)
0.057 (1.44)
0.049 (1.25)
0.037 (0.95)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
SL1550 LOWVF
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
See Fig. 1
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 15.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Typical Junction Capacitance (Note1)
Typical Thermal Resistance RqJA (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
V
V
V
15.0
A
175
A
V
mA
0.53
0.2
Ta=100 C
UNITS
50
35
50
-65
31
+150
-65
+150
mA
pF
C/W
C
C
Note : 1.FR-4 PCB, 2oz.Copper.
2.Polymide PCB, 2oz.Copper.Cathode pad dimensions 18.8mm x 14.4mm.Anode pad dimensions 5.6mm x 14.4mm.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (SL1550 LOWVF)
Fig. 1 - Forward Power Dissipation
Fig. 2 - Instantaneous Forward
Characteristics
100
Instantaneous Forward Current,I F (A)
5
Power Dissipation,P D (W)
4
3
2
1
1 0
T A =150°C
T A =125°C
1
T A =100°C
T A =75°C
0 .1
T A =50°C
T A =25°C
10
15
Average Forward Current,I F ( AV ) (A)
0.1
0.2
0.3
0.4
0.5
Instantaneous Forward Voltage,V F (Volts)
Fig. 3 - Reverse Characteristics
Fig.4 - Forward Current Derating Curve
Instantaneous Reverse Current,I R (mA)
100
T A =150 O C
T A =125 O C
10
O
T A =100 C
1
O
T A =75 C
O
T A =50 C
0.1
15
Based on Lead Temp(T L )
10
Note 2
5
Note 1
50
75
100
125
150
175
O
T A =25 C
0.01
Ambient Temperature,T A ( O C)
40
50
Reverse Voltage,V R (V)
Fig. 5 - Total Capacitance VS.
Reverse Voltage
Fig. 6 - Maximum Avalanche Power Curve
1000000
Maximum Avalanche Power,P M (W)
Total Capacitance,C T (pF)
1000000
10000
f = 1MHz
1000
100
10
1 0.1
10000
1000
1
10
100
1
10
100
1000
10000
Pulse Duration,T P (us)
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“SL1550”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.06109
- 30+1.02059
- 100+0.98009
- 500+0.89909
- 1000+0.85859
- 2000+0.83429
