P4SMA6.8A(CA) - P4SMA440A(CA)
SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR DIODE
VOLTAGE RANGE: 6.8 - 440 V
POWER: 400Wa t t s
Features
Glass Passivated Die Construction
Uni- and Bi-Directional Versions Available
Excellent Clamping Capability
Fast Response Time
Plastic Material: UL Flammability
Classification Rating 94V-0
B
SMA(DO-214AC)
Mechanical Data
A
Case: SMA/DO-214AC, Molded Plastic
Terminals: Solder Plated, Solderable
per MIL-STD-750, Method 2026
Polarity: Cathode Band or Cathode Notch
Marking: Type Number
C
D
J
Weight: 0.064 grams (approx.)
H
Maximum Ratings
Min
Max
A
2.29
2.92
B
4.00
4.60
C
1.27
1.63
D
0.15
0.31
E
4.80
5.59
G
0.10
0.20
H
0.76
1.52
J
2.01
2.62
All Dimensions in mm
@ TA = 25°C unless otherwise specified
Characteristic
Symbol
Peak Pulse Power Dissipation
(Non repetitive current pulse derated above TA = 25°C)
(Note 1)
Peak Forward Surge Current, 8.3ms Single Half Sine
Wave Superimposed on Rated Load (JEDEC Method)
(Notes 1, 2, & 3)
Instantaneous Forward Voltage
@ IPP = 35A
(Notes 1, 2, & 3)
Operating and Storage Temperature Range
Notes:
G
E
Dim
Value
Unit
PPK
400
W
IFSM
40
A
VF
3.5
V
Tj, TSTG
-55 to +150
°C
1. Valid provided that terminals are kept at ambient temperature.
2. Measured with 8.3ms single half sine-wave. Duty cycle = 4 pulses per minute maximum.
3. Unidirectional units only.
1 of 4
www.sunmate.tw
TYPE
(UNI)
P4SMA6.8
P4SMA6.8A
P4SMA7.5
P4SMA7.5A
P4SMA8.2
P4SMA8.2A
P4SMA9.1
P4SMA9.1A
P4SMA10
P4SMA10A
P4SMA11
P4SMA11A
P4SMA12
P4SMA12A
P4SMA13
P4SMA13A
P4SMA15
P4SMA15A
P4SMA16
P4SMA16A
P4SMA18
P4SMA18A
P4SMA20
P4SMA20A
P4SMA22
P4SMA22A
P4SMA24
P4SMA24A
P4SMA27
P4SMA27A
P4SMA30
P4SMA30A
P4SMA33
P4SMA33A
P4SMA36
P4SMA36A
P4SMA39
P4SMA39A
P4SMA43
P4SMA43A
P4SMA47
P4SMA47A
P4SMA51
P4SMA51A
(BI)
P4SMA6.8C
P4SMA6.8CA
P4SMA7.5C
P4SMA7.5CA
P4SMA8.2C
P4SMA8.2CA
P4SMA9.1C
P4SMA9.1CA
P4SMA10C
P4SMA10CA
P4SMA11C
P4SMA11CA
P4SMA12C
P4SMA12CA
P4SMA13C
P4SMA13CA
P4SMA15C
P4SMA15CA
P4SMA16C
P4SMA16CA
P4SMA18C
P4SMA18CA
P4SMA20C
P4SMA20CA
P4SMA22C
P4SMA22CA
P4SMA24C
P4SMA24CA
P4SMA27C
P4SMA27CA
P4SMA30C
P4SMA30CA
P4SMA33C
P4SMA33CA
P4SMA36C
P4SMA36CA
P4SMA39C
P4SMA39CA
P4SMA43C
P4SMA43CA
P4SMA47C
P4SMA47CA
P4SMA51C
P4SMA51CA
Reverse
Stand-Off
Voltage
Breakdown
Voltage
Min. @IT
Breakdown
Voltage
Max. @ IT
VRWM (V)
VBR MIN(V)
VBR MAX(V)
5.50
5.80
6.05
6.40
6.63
7.02
7.37
7.78
8.10
8.55
8.92
9.40
9.72
10.2
10.5
11.1
12.1
12.8
12.9
13.6
14.5
15.3
16.2
17.1
17.8
18.8
19.4
20.5
21.8
23.1
24.3
25.6
26.8
28.2
29.1
30.8
31.6
33.3
34.8
36.8
38.1
40.8
41.3
43.6
6.12
6.45
6.75
7.13
7.38
7.79
8.19
8.65
9.00
9.50
9.90
10.5
10.8
11.4
11.7
12.4
13.5
14.3
14.4
15.2
16.2
17.1
18.0
19.0
19.8
20.9
21.6
22.8
24.3
25.7
27.0
28.5
29.7
31.4
32.4
34.2
35.1
37.1
38.7
40.9
42.3
44.7
45.9
48.5
2 of 4
7.48
7.14
8.25
7.88
9.02
8.61
10.0
9.55
11.0
10.5
12.1
11.6
13.2
12.6
14.3
13.7
16.5
15.8
17.6
16.8
19.8
18.9
22.0
21.0
24.2
23.1
26.4
25.2
29.7
28.4
33.0
31.5
36.3
34.7
39.6
37.8
42.9
41.0
47.3
45.2
51.7
49.4
56.1
53.6
Maximum
Peak Reverse
Test Clamping Pulse Leakage
Current Voltage Current @VRWM
@IPP
IPP(A)
IR(uA)
VC(V)
IT (mA)
10
10
10
10
10
10
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
10.8
10.5
11.7
11.3
12.5
12.1
13.8
13.4
15.0
14.5
16.2
15.6
17.3
16.7
19.0
18.2
22.0
21.2
23.5
22.5
26.5
25.2
29.1
27.7
31.9
30.6
34.7
33.2
39.1
37.5
43.5
41.4
47.7
45.7
52.0
49.9
56.4
53.9
61.9
59.3
67.8
64.8
73.5
70.1
38.0
40.0
36.0
37.0
33.0
35.0
30.0
31.0
28.0
29.0
26.0
27.0
24.0
25.0
22.0
23.0
19.0
20.0
18.0
19.0
16.0
17.0
14.0
15.0
13.0
14.0
12.0
13.0
11.0
11.2
10.0
10.0
9.0
9.0
8.0
8.4
7.4
7.8
6.8
7.1
6.2
5.0
5.7
6.0
1000.0
1000.0
500.0
500.0
200.0
200.0
50.0
50.0
10.0
10.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
www.sunmate.tw
Reverse
Stand-Off
Voltage
TYPE
(UNI)
P4SMA56
P4SMA56A
P4SMA62
P4SMA62A
P4SMA68
P4SMA68A
P4SMA75
P4SMA75A
P4SMA82
P4SMA82A
P4SMA91
P4SMA91A
P4SMA100
P4SMA100A
P4SMA110
P4SMA110A
P4SMA120
P4SMA120A
P4SMA130
P4SMA130A
P4SMA150
P4SMA150A
P4SMA160
P4SMA160A
P4SMA170
P4SMA170A
P4SMA180
P4SMA180A
P4SMA200
P4SMA200A
P4SMA220
P4SMA220A
P4SMA250
P4SMA250A
P4SMA300
P4SMA300A
P4SMA350
P4SMA350A
P4SMA400
P4SMA400A
P4SMA440
P4SMA440A
(BI)
P4SMA56C
P4SMA56CA
P4SMA62C
P4SMA62CA
P4SMA68C
P4SMA68CA
P4SMA75C
P4SMA75CA
P4SMA82C
P4SMA82CA
P4SMA91C
P4SMA91CA
P4SMA100C
P4SMA100CA
P4SMA110C
P4SMA110CA
P4SMA120C
P4SMA120CA
P4SMA130C
P4SMA130CA
P4SMA150C
P4SMA150CA
P4SMA160C
P4SMA160CA
P4SMA170C
P4SMA170CA
P4SMA180C
P4SMA180CA
P4SMA200C
P4SMA200CA
P4SMA220C
P4SMA220CA
P4SMA250C
P4SMA250CA
P4SMA300C
P4SMA300CA
P4SMA350C
P4SMA350CA
P4SMA400C
P4SMA400CA
P4SMA440C
P4SMA440CA
VRWM (V)
45.4
47.8
50.2
53.0
55.1
58.1
60.7
64.1
66.4
70.4
73.7
77.8
81.0
85.5
89.2
94.0
97.2
102
105
111
121
128
130
136
138
145
146
154
162
171
175
185
202
214
243
256
284
300
324
342
356
376
Breakdown
Voltage
Min. @IT
Breakdown
Voltage
Max. @ IT
VBR MIN(V)
VBR MAX(V)
50.4
53.2
55.8
58.9
61.2
64.6
67.5
71.3
73.8
77.9
81.9
86.5
90.0
95.0
99.0
105
108
114
117
124
135
143
144
152
153
162
162
171
180
190
198
209
225
237
270
285
315
333
360
380
396
418
3 of 4
61.6
58.8
68.2
65.1
74.8
71.4
82.5
78.8
90.2
86.1
100
95.5
110
105
121
116
132
126
143
137
165
158
176
168
187
179
198
189
220
210
242
231
275
263
330
315
385
368
440
420
484
462
Maximum Peak Reverse
@IPP
IT (mA)
IR (uA)
VC(V)
IPP(A)
1.0
80.5
5.2
5.0
5.5
1.0
77.0
5.0
1.0
89.0
5.0
4.7
1.0
85.0
5.0
5.0
4.3
1.0
98.0
5.0
1.0
92.0
4.6
5.0
3.9
108
5.0
1.0
103
5.0
1.0
4.1
3.6
1.0
118
5.0
113
3.7
1.0
131
3.2
5.0
1.0
3.4
125
5.0
1.0
2.9
5.0
1.0
144
137
3.1
5.0
1.0
158
5.0
1.0
2.7
1.0
152
2.8
5.0
173
1.0
5.0
2.4
1.0
165
2.5
5.0
1.0
187
5.0
2.2
2.3
1.0
179
5.0
1.0
215
2.0
5.0
1.0
207
2.0
5.0
230
1.0
1.8
5.0
1.0
219
1.9
5.0
1.0
5.0
244
1.7
234
1.0
1.8
5.0
1.0
258
1.6
5.0
1.0
246
5.0
1.7
1.0
287
1.5
5.0
1.53
5.0
1.0
274
1.0
1.16
5.0
344
328
1.0
5.0
1.22
360
1.0
5.0
1.1
344
1.0
1.16
5.0
430
0.93
1.0
5.0
1.0
0.97
5.0
414
1.0
504
0.79
5.0
0.83
1.0
482
5.0
574
1.0
0.70
5.0
0.73
1.0
548
5.0
631
0.63
1.0
5.0
1.0
602
0.65
5.0
Test
www.sunmate.tw
Ratings and Characteristic Curves TA=25°C unless otherwise noted
4 of 4
www.sunmate.tw
很抱歉,暂时无法提供与“P4SMA18A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.18700
- 50+0.17050
- 500+0.15400
- 1000+0.13750
- 2500+0.12980
- 5000+0.12320
- 国内价格
- 10+0.20000
- 50+0.18500
- 200+0.17250
- 600+0.16000
- 1500+0.15000
- 3000+0.14375
