ZMM2V0-150
ZENER DIODES
FEATURES
Low zener impedance
Low regulation factor
Glass passivated junction
High temperature soldering guaranteed
260°C/10S at terminals
LL34 (SOD-80)
MECHANICAL DATA
Cathode indification
φ1 .5±0.1
Case: MINI MELF molded glass body
Terminals: Plated axial leads, solderable per MIL-STD 750,
method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight: 0.04 grams (approx.)
C
3.5 ±0.2
B
0.4±0.1
A
Dimensions in millimeters
Maximum Ratings (TA=25 °C unless otherwise noted)
Characteristic
Symbol
Value
Unit
Power Dissipation at Tamb=25 C(Note 1)
Ptot
500
mW
Forward voltage at IF=100mA
VF
1.0
V
Junction Temperature
Tj
200
°C
Storage Temperature Range
TSTG
-65 to + 200
°C
Thermal resistance junction ambient(Note 1)
RqJA
0.3
K/mW
Note 1: Valid provided that leads at a distance of 10mm from case are kept at ambient temperature
© GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
E-mail:hkt@heketai.com
1/ 4
ZMM2V0-150
ZENER DIODES
ELECTRICAL CHARACTERISTICS @ Ta=25°C unless otherwise specified
Nominal
Test
Device
ZenerVoltage
Current
Type
Vz@IZT
IZT
Maximum
Maximum Zener
Impedance
ZZT@IZT
ZZk@IZK
IZK
Maximu
Reverse
Typical
mRegul
Leakage Current
Temperature
atorCur
Coefficient
rent
IR
@VR
IZM
Min
Max
mA
Ohms
Ohms
mA
µA
Volts
(%/°C)
mA
ZMM2V0
1.90
2.10
5
100
600
1
150
1
-0.085
165
ZMM2V2
2.09
2.31
5
100
600
1
150
1
-0.085
165
ZMM2V4
2.28
2.56
5
85
600
1
50
1
-0.085
155
ZMM2V7
2.5
2.9
5
85
600
1
10
1
-0.08
135
ZMM3V0
2.8
3.2
5
85
600
1
4
1
-0.075
125
ZMM3V3
3.1
3.5
5
85
600
1
2
1
-0.07
115
ZMM3V6
3.4
3.8
5
85
600
1
2
1
-0.065
105
ZMM3V9
3.7
4.1
5
85
600
1
2
1
-0.06
95
ZMM4V3
4
4.6
5
75
600
1
1
1
0.055
90
ZMM4V7
4.4
5
5
60
600
1
0.5
1
0.03
85
ZMM5V1
4.8
5.4
5
35
550
1
0.1
1
0.03
80
ZMM5V6
5.2
6
5
25
450
1
0.1
1
0.038
70
ZMM6V2
5.8
6.6
5
10
200
1
0.1
2
0.045
64
ZMM6V8
6.4
7.2
5
8
150
1
0.1
3
0.05
58
ZMM7V5
7
7.9
5
7
50
1
0.1
5
0.058
53
ZMM8V2
7.7
8.7
5
7
50
1
0.1
6.2
0.062
74
ZMM9V1
8.5
9.6
5
10
50
1
0.1
6.8
0.068
43
ZMM10
9.4
10.6
5
15
70
1
0.1
7.5
0.075
40
ZMM11
10.4
11.6
5
1
0.1
8.2
0.076
36
ZMM12
11.4
12.7
5
1
0.1
9.1
0.077
32
ZMM13
12.4
14.1
5
26
110
1
0.1
10
0.079
29
ZMM15
13.8
15.6
5
30
110
1
0.1
11
0.082
27
ZMM16
15.3
17.1
5
40
170
1
0.1
12
0.083
24
ZMM18
16.8
19.1
5
50
170
1
0.1
13
0.085
21
ZMM20
18.8
21.2
5
55
220
1
0.1
15
0.086
ZMM22
20.8
23.3
5
55
220
1
0.1
16
0.087
18
ZMM24
22.8
25.6
5
80
220
1
0.1
18
0.088
16
ZMM27
25.1
28.9
5
80
220
1
0.1
14
ZMM30
28
32
5
80
220
1
0.1
22
0.091
13
ZMM33
31
35
5
80
220
1
0.1
24
0.092
12
ZMM36
34
38
5
80
220
1
0.1
27
0.093
11
ZMM39
37
41
2.5
90
500
0.5
0.1
30
0.094
10
ZMM43
40
46
2.5
90
600
0.5
0.1
33
0.095
9.2
ZMM47
44
50
2.5
110
700
0.5
0.1
36
0.095
8.5
ZMM51
48
54
2.5
125
700
0.5
0.1
39
0.096
7.8
ZMM56
52
60
2.5
135
1000
0.5
0.1
43
0.096
7
2/ 4
ZMM2V0-150
ZENER DIODES
ZMM62
58
66
2.5
150
1000
0.5
0.1
47
0.096
6.4
ZMM68
64
72
2.5
200
1000
0.5
0.1
51
0.096
5.9
ZMM75
70
80
2.5
250
1500
0.5
0.1
56
0.096
5.3
ZMM82
77
87
2.5
300
2000
0.5
0.1
62
0.096
4.8
ZMM91
85
96
1
450
5000
0.1
0.1
68
0.096
4.4
ZMM100
94
106
1
450
5000
0.1
0.1
75
0.096
4.0
ZMM110
104
116
1.0
600
5000
0.1
0.1
82
+0.096
3.6
ZMM120
114
127
1.0
800
5000
0.1
0.1
91
+0.096
3.3
ZMM130
124
141
1.0
1000
5000
0.1
0.1
100
+0.096
3.0
ZMM150
138
156
1.0
1200
5000
0.1
0.1
110
+0.096
2.6
Typical Characteristics
5
mA
10
15
30
Iz,TEST CURRENT,MILLIAMPERS
50
V
40
30
Test Current
Iz=5mA
24
22
12
11
9V1
6V8
6V2
5V6
5V1
4V7
4V3
3V9
3V3
2V4
Vz,ZENER VOLTAGE,volts
POWER ,TEMPERATURE DERATING CURVE
Pd(mW)
Power Dissipation
500
400
300
200
100
50
100
150
200
300
TA(oC)
3/ 4
ZMM2V0-150
ZENER DIODES
LL34 Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
LL34
1.6
3.9
1.6
φ1.50
1.75
3.50
4.00
4.00
2.00
8.0
±0.05
±0.05
±0.05
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
TOLERANCE
LL34 Tape Leader and Trailer
LL34 Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
φ178
54.40
13.00
R78
R25.60
R6.50
9.50
12.30
±2
±1
±1
±1
±1
±1
±1
±1
4/ 4
很抱歉,暂时无法提供与“ZMM5V1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.02587
- 10+0.02388
- 30+0.02348
