H7605
300mA Low Power LDO
Features
Low power consumption
Low Quiescent Current: 1.5uA at 6V
Low voltage drop
Output voltage accuracy: tolerance ±2%
Low temperature coefficient
Applications
Battery-powered equipment
Portable AV systems
Reference voltage sources
Mobile phones
Cameras,video cameras
Portable games
General Description
compatible with low ESR ceramic capacitors. The
consumption,
voltage
current limiter’s fold back circuit operates as a
regulators manufactured using CMOS and laser
short circuit protection as well as the output
trimming technologies. The series provides large
current limiter for the output pin. Output voltages
currents with a significantly small dropout voltage.
are internally by laser trimming technologies. It is
3
terminal,
positive
The H7605 consists of a current limiter circuit, a
driver transistor, a precision reference voltage
The series is
selectable in 0.1V increments within a range of
1.2V to 5.0V.
H7605 series are available in
SOT-23,SOT23-3 and SOT-89 packages.
PR
O
and an error correction circuit.
IN
H7605 series are a highly precise, lower
SI
Typical Application
Order Information
H7605-①②③④
Designator
Symbol
Description
① ②
Integer
Output Voltage(1.2V~5.0V)
③
④
N
Package:SOT23
M
Package:SOT23-3
P
Package:SOT89-3
R
RoHS / Pb Free
G
Halogen Free
Note:”①②” stands for output voltages. Other voltages can be specially customized
Ver1.3
1
Shanghai Siproin Microelectronics Co.
H7605
300mA Low Power LDO
Block Diagram
SI
PR
O
IN
Pin Assignment
Absolute Maximum Ratings
Parameter
Symbol
Ratings
Units
Input Voltage
VIN
10
V
Output Current
IOUT
300
Output Voltage
VOUT
VSS-0.3~VIN+0.3
V
0.20
W
W
W
SOT-23
Power Dissipation
Pd
SOT-89
SOT23-3
Operating Temperature Range
Topr
0.50
0.20
-40~+85
Storage Temperature Range
Tstg
-55~+125
mA
*IOUT=Pd/(VIN-VOUT)
Ver1.3
2
H7605
300mA Low Power LDO
Electrical Characteristics
H7605 for any output voltage
(Ta=25℃)
Parameter
Symbol
Conditions
Output Voltage
Vout
Output Current*1
Iout
Low dropout*2
Vdrop
Line Regulation
△Vout1/(Vin·Vout)
Load Regulation
△Vout /ΔIout
Vin=Vout+1V
1.0mA≤Iout≤30mA
Unit
Vout×0.98
Vout×1.02
V
300
mA
1.6V≤Vin≤6.5V
Iout=40mA
Vin= Vout+1V
△Vout/(Ta·Vout)
0.05
0.2
%/V
12
30
mV
±75
Ppm/℃
IN
1.0mA≤Iout≤80mA
Iout=30mA
0℃≤Ta≤70℃
PR
O
Input Voltage
Max.
Refer to the next table
Coefficiency
Supply Current
Typ.
Vin-Vout=1V
Output voltage
Temperature
Min.
Iss
1.5
2
uA
Vin
6
8
V
Electrical Characteristics by Output Voltage:
Dropout Voltage Vdif(V)
SI
Output Voltage Vout(V)
Conditions
Typ.
Max.
Vout≤1.5V
0.35
0.57
Vout=1.6V
0.32
0.50
0.30
0.45
0.28
0.42
2.1 ≤ Vout ≤ 2.7
0.25
0.38
2.8 ≤ Vout ≤ 5.0
0.19
0.35
Vout=1.7V
1.8 ≤ Vout ≤ 2
Ver1.3
Iout=100 mA
3
H7605
300mA Low Power LDO
Package Information
SI
PR
O
IN
3-pin SOT23 Outline Dimensions
Ver1.3
4
H7605
300mA Low Power LDO
SI
PR
O
IN
3-pin SOT23-3 Outline Dimensions
Ver1.3
5
H7605
300mA Low Power LDO
SI
PR
O
IN
3-pin SOT89 Outline Dimensions
Ver1.3
6
很抱歉,暂时无法提供与“H7605-33NR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.25070
- 20+0.24610
- 100+0.23690
