Application Notes: AN_SY8368
High Efficiency Fast Response
8A Continuous, 16A Peak, 28V Input
Synchronous Step Down Regulator
General Description
Features
The SY8368 develops a high efficiency synchronous
step-down DC-DC regulator capable of delivering 8A
continuous, 16A peak current. The SY8368 operates
over a wide input voltage range from 4V to 28V and
integrates main switch and synchronous switch with
very low RDS(ON) to minimize the conduction loss.
• Low RDS(ON) for internal switches (top/bottom):
20/10 mΩ
• Wide input voltage range: 4-28V
• Instant PWM architecture to achieve fast transient
responses
• Internal 400uS softstart limits the inrush current
• Pseudo-constant frequency: 800kHz.
• 8A continuous/16A peak output current capability
• ±1.5% 0.6V reference
• Programmable peak current limit
• Power good indicator
• Output discharge function
• Short circuit latch off protection
• Over voltage latch off protection
• Input UVLO
• Over temperature protection
• RoHS Compliant and Halogen Free
• Compact package: QFN3x3-10
ar
ed
fo
r
The SY8368 adopts the instant PWM architecture to
achieve fast transient responses for high step down
applications and high efficiency at light loads. In
addition, it operates at pseudo-constant frequency of
800kHz under continuous conduction mode to
minimize the size of inductor and capacitor.
SY8368 □ (□□)□
Tempera ture Code
Packa ge Code
Optional Spec Code
Note
Applications
en
Package type
QFN3x3-10
.C
on
fid
Ordering Number
SY8368QNC
tia
l-P
re
p
Ordering Information
LCD-TV/Net-TV/3DTV
Set Top Box
Notebook
High Power AP
VIN
Co
rp
Typical Applications
IN
PG
PG (Open Drain Output)
BS
er
gy
CIN
10uF
CBS
100nF
High/Floating/Low
ILMT
Sil
GND
EN
ON/OFF
CVCC
2.2uF
VCC
VOUT=5V
LX
L 1.5uH
C1
220pF
R1
100k
COUT
22uF×3
R3
1k
FB
R2
13.7k
Figure 1 Schematic
AN_SY8368 Rev. 0.9B
Figure 2. Efficiency
Silergy Corp. Confidential- Prepared for Customer Use Only
1
AN_SY8368
r
Pinout (top view)
fo
(QFN3x3-10)
Pin Number
1
PG
2
ILMT
3
FB
4
VC
5
BS
6
IN
GND
LX
7,8
9
10
Pin Description
Enable control. Pull this pin high to turn on the IC. Do not leave this pin floating.
Power good Indicator. Open drain output when the output voltage is within 90% to
120% of regulation point.
tia
l-P
re
p
Pin Name
EN
ar
ed
Top Mark: YWxyz, (Device code: YW, x=year code, y=week code, z= lot number code)
Sil
er
gy
Co
rp
.C
on
fid
en
Current limit setting pin. The current limit is set to 8A, 12A or 16A when this pin
is pull low, floating or pull high respectively.
Output Feedback Pin. Connect this pin to the center point of the output resistor
divider (as shown in Figure 1) to program the output voltage:
Vout=0.6*(1+R1/R2)
Internal 3.3V LDO output. Power supply for internal analog circuits and driving
circuit. Bypass a capacitor to GND.
Boot-Strap Pin. Supply high side gate driver. Decouple this pin to LX pin with
0.1uF ceramic cap.
Input pin. Decouple this pin to GND pin with at least 10uF ceramic cap
Ground pin
Inductor pin. Connect this pin to the switching node of inductor
AN_SY8368 Rev. 0.9B
2
AN_SY8368
Absolute Maximum Ratings
(Note 1)
IN, LX, PG, EN ------------------------------------------------------------------------------------------------------ -0.3V to 30V
BS-LX, FB, ILMT, VCC ------------------------------------------------------------------------------------------- -0.3V to 4V
Power Dissipation, PD @ TA = 25°C QFN3x3-10 -----------------------------------------------------------------------3.3W
Package Thermal Resistance (Note 2)
θ JA -----------------------------------------------------------------------------------------------------------------30°C/W
θ JC ---------------------------------------------------------------------------------------------------------------- 4°C/W
Junction Temperature Range ------------------------------------------------------------------------------------------------ 125°C
Lead Temperature (Soldering, 10 sec.) ------------------------------------------------------------------------------------ 260°C
Storage Temperature Range -------------------------------------------------------------------------------------- -65°C to 150°C
Dynamic LX voltage in 50ns duration --------------------------------------------------------------------- IN+3V to GND-4V
Recommended Operating Conditions (Note 3)
fo
r
Supply Input Voltage ---------------------------------------------------------------------------------------------------- 4V to 28V
Junction Temperature Range ------------------------------------------------------------------------------------- -40°C to 125°C
Ambient Temperature Range -------------------------------------------------------------------------------------- -40°C to 85°C
Sil
er
gy
Co
rp
.C
on
fid
en
tia
l-P
re
p
ar
ed
Block Diagram
AN_SY8368 Rev. 0.9B
3
AN_SY8368
Electrical Characteristics
(VIN = 12V, VOUT =5V, COUT = 100uF, TA = 25°C, IOUT = 2A unless otherwise specified)
Parameter
Input Voltage Range
Quiescent Current
Symbol
VIN
IQ
Shutdown Current
Feedback Reference
Voltage
FB Input Current
Top FET RON
Bottom FET RON
Discharge FET RON
Bottom FET Current
Limit
ISHDN
VREF
Test Conditions
Min
4.0
IOUT=0,
VFB=VREF*105%
EN=0
0.591
VFB=4V
Max
28
100
Unit
V
µA
3
0.6
10
0.609
µA
V
50
nA
mΩ
mΩ
Ω
-50
50
ILMT=’0’
ILMT=Floating
ILMT=’1’
8
12
16
Vcc-0.8
A
r
IFB
Rds(on)1
Rds(on)2
Rdis
ILIM
Typ
Sil
er
gy
Co
rp
.C
on
fid
en
tia
l-P
re
p
ar
ed
fo
ILMT Rising Threshold
VILMTH
VCC
V
ILMT Falling Threshold
VILMTL
0.8
V
ILMT Floating Threshold VILMIF
1.3
2
V
Soft Start Time
TSS
400
µS
EN Rising Threshold
VENH
0.8
V
EN Falling Threshold
VENL
0.4
V
Input UVLO Threshold
3.9
V
VUVLO
UVLO hysteresis
VHYS
0.3
V
Oscillator Frequency
FOSC
Vo=5V
0.68
0.8
0.92
MHz
Min ON Time
TON,MIN
VIN=VINMAX
50
ns
Min OFF Time
TOFF,MIN
80
ns
VCC Output
VCC
VIN=4V
3.2
3.3
3.4
V
Output Over Voltage
VFB Rising
115
120
125
%VREF
Threshold
Output Over Voltage
2
%VREF
Hysteresis
Output Over Voltage
us
Delay Time
Power Good Threshold
VFB Rising (Good)
88
90
92
%VREF
Power Good Hysteresis
2
%VREF
Power Good Delay Time
10
us
Thermal Shutdown
TSD
150
°C
Temperature
Thermal Shutdown
THYS
15
°C
hysteresis
Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are
stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the
operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for
extended periods may affect device reliability
Note 2:
θ JA is measured in the natural convection at TA = 25°C on a four-layer Silergy Evaluation Board..
Note 3: The device is not guaranteed to function outside its operating conditions.
AN_SY8368 Rev. 0.9B
4
AN_SY8368
Typical Performance Characteristics
Efficiency vs. Load Current
100
100
90
90
80
80
70
70
60
60
50
50
VIN=7.4V,VOUT=5.0V
VIN=12V,VOUT=5.0V
VIN=19V,VOUT=5.0V
VIN=28V,VOUT=5.0V
40
30
VIN=5.0V,VOUT=3.3V
VIN=12V,VOUT=3.3V
VIN=19V,VOUT=3.3V
VIN=28V,VOUT=3.3V
40
30
0.01
0.10
1.00
10.00
0.001
0.01
0.10
10.00
Load Current (A)
fo
r
Load Current (A)
1.00
ar
ed
95
95
85
85
75
65
tia
l-P
re
p
75
65
55
55
45
VIN=5.0V,VOUT=1.8V
VIN=12V,VOUT=1.8V
VIN=19V,VOUT=1.8V
VIN=28V,VOUT=1.8V
15
0.01
0.10
1.00
.C
on
0.001
fid
25
Load Current (A)
VIN=5.0V,VOUT=1.2V
VIN=12V,VOUT=1.2V
VIN=19V,VOUT=1.2V
VIN=28V,VOUT=1.2V
35
en
35
45
25
15
10.00
0.001
0.01
0.10
1.00
Load Current (A)
Load Transient
(VIN=12V, VOUT=5V, ILOAD=2-6A)
Co
rp
Load Transient
(VIN=12V, VOUT=5V, ILOAD=0.8-8A)
er
gy
∆VOUT
100mV/div
∆VOUT
IL
100mV/div
2A/div
5A/div
Sil
IL
10.00
Time (200µs/div)
AN_SY8368 Rev. 0.9B
Time (200µs/div)
5
AN_SY8368
Startup from Enable
Shutdown from Enable
(VIN=12V, VOUT=5V, ILOAD=8A)
EN
5V/div
VLX
10V/div
VOUT
IL
EN
5V/div
VLX
10V/div
5V/div
VOUT
5V/div
IL
5A/div
5A/div
Time (400µs/div)
Time (400µs/div)
Shutdown from VIN
VOUT
5V/div
IL
5A/div
fo
10V/div
ar
ed
VLX
tia
l-P
re
p
10V/div
en
VIN
r
Startup from VIN
10V/div
VLX
10V/div
VOUT
5V/div
IL
5A/div
Time (2ms/div)
fid
Time (4ms/div)
VIN
.C
on
Short Circuit Protection
er
gy
Co
rp
(VIN=12V, VOUT=5V, ILMT floating, Null Load to Short)
VOUT
5A/div
Sil
IL
2V/div
Time (100µs/div)
AN_SY8368 Rev. 0.9B
6
AN_SY8368
Output Ripple
20mV/div
VLX
5V/div
IL
5A/div
Frequency(kHz)
∆Vout(AC)
Sil
er
gy
Co
rp
.C
on
fid
en
tia
l-P
re
p
ar
ed
fo
r
Time (2µs/div)
AN_SY8368 Rev. 0.9B
7
AN_SY8368
Operation
Output inductor L:
There are several considerations in choosing this
inductor.
1) Choose the inductance to provide the desired
ripple current. It is suggested to choose the ripple
current to be about 40% of the maximum output
current. The inductance is calculated as:
VOUT (1 − VOUT /VIN, MAX )
FSW × I OUT, MAX × 40%
ar
ed
L=
where Fsw is the switching frequency and IOUT,MAX is
the maximum load current.
The SY8368 regulator IC is quite tolerant of different
ripple current amplitude. Consequently, the final choice
of inductance can be slightly off the calculation value
without significantly impacting the performance.
2) The saturation current rating of the inductor must
be selected to be greater than the peak inductor
current under full load conditions.
tia
l-P
re
p
Because of the high integration in the SY8368 IC, the
application circuit based on this regulator IC is rather
simple. Only input capacitor CIN, output capacitor COUT,
output inductor L and feedback resistors (R1 and R2)
need to be selected for the targeted applications
specifications.
fo
r
Applications Information
Output capacitor COUT:
The output capacitor is selected to handle the output
ripple noise requirements. Both steady state ripple and
transient requirements must be taken into consideration
when selecting this capacitor. For most applications,
an X5R or better grade ceramic capacitor greater than
66uF capacitance can work well. The capacitance
derating with DC voltage must be considered.
Co
rp
0.6V
R2 =
R1 .
VOUT − 0.6V
.C
on
fid
en
Feedback resistor dividers R1 and R2:
Choose R1 and R2 to program the proper output voltage.
To minimize the power consumption under light loads,
it is desirable to choose large resistance values for both
R1 and R2. A value of between 10kΩ and 1MΩ is
highly recommended for both resistors. If Vout is 3.3V,
R1=100k is chosen, then using following equation, R2
can be calculated to be 22.1k:
0.6VFB
GND
R1
R2
er
gy
Sil
OUT
To minimize the potential noise problem, place a
typical X5R or better grade ceramic capacitor really
close to the IN and GND pins. Care should be taken to
minimize the loop area formed by CIN, and IN/GND
pins. In this case, a 10uF low ESR ceramic capacitor is
recommended.
AN_SY8368 Rev. 0.9B
VOUT(1-VOUT/VIN,MAX)
2 ⋅ FSW ⋅ L
VOUT
Input capacitor CIN:
The ripple current through input capacitor is calculated
as:
I
= I ⋅ D(1 − D) .
CIN _ RMS
ISAT, MIN > IOUT, MAX +
3)
The DCR of the inductor and the core loss at the
switching frequency must be low enough to
achieve the desired efficiency requirement. It is
desirable to choose an inductor with DCR
