UMW
R
UMW SMCJ5.0A(CA) THRU SMCJ188A(CA)
5V-188V 1500W
SMC(DO-214AB)
FEATURES
Cathode Band
* 1500W surge capability at 1ms
* Excellent clamping capability
* Low zener impedance
* Fast response time : typically less
then 1.0 ps from 0 volt to VBR(min.)
* Typical IR less then 1µA above 10V
0.155(3.94)
0.246(6.22)
0.130(3.30)
0.220(5.59)
0.280(7.11)
0.260(6.60)
0.012(0.305)
0.006(0.152)
0.103(2.62)
0.079(2.06)
MECHANICAL DATA
0.060(1.52)
0.030(0.76)
0.008(0.2)
* Case : SMC Molded plastic
* Epoxy : UL94V-O rate flame retardant
* Lead : Lead Formed for Surface Mount
* Polarity : Color band denotes cathode end
except Bipolar.
* Mounting position : Any
* Weight : 0.21 gram
0(0)
0.320(8.13)
0.305(7.75)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating at 25°C ambient temperature unless otherwise specified.
Rating
Symbol
Value
Unit
Peak Pulse Power Dissipation (1) (2)
PPPM
Minimum 1500
W
Peak Forward Surge Current per Fig. 5 (2)
IFSM
200
A
Maximum Instantaneous Forward Voltage at
50.0A for Unidirectional Only
VF
3.5
Volts
Typical Thermal Resistance , Junction to Ambient (3)
RθJA
75
°C/W
Operating Junction and Storage Temperature Range
TJ, TSTG
- 55 to + 150
°C
Notes :
(1) Non-repetitive Current pulse, per Fig. 3 and derated above Ta = 25 °C per Fig. 1
(2) Mounted on 0.31x 0.31" (8.0 x 8.0mm) copper pads to each terminal.
(3) Mounted on minimum recommended pad layout
www.umw-ic.com
1
友台半导体有限公司
UMW
R
5V-188V 1500W
ELECTRICAL CHARACTERISTICS (Rating at 25°C ambient temperature unless otherwise specified)
DEVICE MARKING
CODE
IT
(mA)
VWM
(V)
Maximum
Reverse
Leakage
@ VWM
ID
(µA)
10
10
10
10
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
5.0
6.0
6.5
7.0
7.5
8.0
8.5
9.0
10
11
12
13
14
15
16
17
18
24
26
28
30
33
36
40
43
45
48
51
54
58
60
64
70
75
78
85
90
100
110
120
130
150
160
170
188
1000
1000
500
200
100
50
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
Breakdown Voltage @ IT (1)
DEVICE TYPE
SMCJ5.0A(CA)
SMCJ6.0A(CA)
SMCJ6.5A(CA)
SMCJ7.0A(CA)
SMCJ7.5A(CA)
SMCJ8.0A(CA)
SMCJ8.5A(CA)
SMCJ9.0A(CA)
SMCJ10A(CA)
SMCJ11A(CA)
SMCJ12A(CA)
SMCJ13A(CA)
SMCJ14A(CA)
SMCJ15A(CA)
SMCJ16A(CA)
SMCJ17A(CA)
SMCJ18A(CA)
SMCJ20A(CA)
SMCJ22A(CA)
SMCJ24A(CA)
SMCJ26A(CA)
SMCJ28A(CA)
SMCJ30A(CA)
SMCJ33A(CA)
SMCJ36A(CA)
SMCJ40A(CA)
SMCJ43A(CA)
SMCJ45A(CA)
SMCJ48A(CA)
SMCJ51A(CA)
SMCJ54A(CA)
SMCJ58A(CA)
SMCJ60A(CA)
SMCJ64A(CA)
SMCJ70A(CA)
SMCJ75A(CA)
SMCJ78A(CA)
SMCJ85A(CA)
SMCJ90A(CA)
SMCJ100A(CA)
SMCJ110A(CA)
SMCJ120A(CA)
SMCJ130A(CA)
SMCJ150A(CA)
SMCJ160A(CA)
SMCJ170A(CA)
SMCJ188A(CA)
UNI
BI
GDE
G
GDG
GDK
GDM
GDP
GDR
GDT
GDV
GDX
GDZ
GEE
GEG
GEK
GDE
GDG
BDK
GDM
BDP
BDR
BDT
BDV
BDX
GDZ
BEE
GEG
BEK
BEM
GEP
GER
BET
BEV
BEX
BEZ
BFE
BFG
BFK
BFM
BFP
BFR
BFT
GFV
GFX
GFZ
GGE
GGG
GGK
GGM
GGP
GGR
GGT
GGV
GGX
GGZ
GHE
GHG
GHK
GHM
GHP
GHR
GHS
GEM
GEP
GER
GET
GEV
GEX
GEZ
GFE
GFG
GFK
GFM
GFP
GFR
GFT
GFV
GFX
GFZ
GGE
GGG
GGK
GGM
GGP
GGR
GGT
GGV
GGX
GGZ
GHE
GHG
GHK
GHM
GHP
GHR
GHS
VBR (V)
Min.
Max.
6.40
6.67
7.22
7.78
8.33
8.89
9.44
10.0
11.1
12.2
13.3
14.4
15.6
16.7
17.8
18.9
20.0
22.2
24.4
26.7
28.9
31.1
33.3
36.7
40.0
44.4
47.8
50.0
53.3
56.7
60.0
64.4
66.7
71.1
77.8
83.3
86.7
94.4
100
111
122
133
144
167
178
189
209
7.07
7.37
7.98
8.6
9.21
9.83
10.4
11.1
12.3
13.5
14.7
15.9
17.2
18.5
19.7
20.9
22.1
24.5
26.9
29.5
31.9
34.4
36.8
40.6
44.2
49.1
52.8
55.3
58.9
62.7
66.3
71.2
73.7
78.6
86
92.1
95.8
104
111
123
135
147
159
185
197
209
231
Working Peak
Reverse
Voltage
Maximum
Peak Pulse
Surge Current
Maximum
Clamping
Voltage @ IPPM
IPPM
(A)
VC
(V)
163.0
145.6
133.9
125.0
116.3
110.3
104.2
97.4
88.2
82.4
75.4
69.8
64.7
61.5
57.7
54.3
51.4
46.3
42.3
38.6
35.6
33.0
31.0
28.1
25.8
23.3
21.6
20.6
19.4
18.2
17.2
16.0
15.5
14.6
13.3
12.4
11.9
10.9
10.3
9.3
8.5
7.8
7.2
6.2
5.8
5.50
4.60
9.2
10.3
11.2
12.0
12.9
13.6
14.4
15.4
17.0
18.2
19.9
21.5
23.2
24.4
26.0
27.6
29.2
32.4
35.5
38.9
42.1
45.4
48.4
53.3
58.1
64.5
69.4
72.7
77.4
82.4
87.1
93.6
96
103
113
121
126
137
146
162
177
193
209
243
259
275
328
Notes :
(1) Pulse test : tp < 50ms.
(2) Surge Current Waveform per Figure 5 and Derate per Figure 1
(3) For bi-directional types have VWM of 10 Volts and less , the ID limit is doubled
(4) For the bi-directional SMBJ5.0CA, the maximum VBR is 7.25V
(5) "SMCJ" will be omitted in marking on the diode.
www.umw-ic.com
2
友台半导体有限公司
UMW
R
5V-188V 1500W
FIG.1 - PULSE DERATING CURVE
FIG.2 - TYPICAL JUNCTION CAPACITANCE
PEAK PULSE POWER OR CURRENT
DERATING IN PERCENTAGE
6,000
CJ, CAPACITANCE, pF
120
100
80
60
40
TJ = 25°C
f = 1.0 MHz
Vsig = 50 mVP-P
100
50
75
100
125
150
10
175
1
Ta, AMBIENT TEMPERATURE, ( °C)
Peak Value
IPPM
Half Value - IPPM
2
50
100
100
PPPM,PEAK POWER (kW)
100
10
FIG.4 - PEAK PULSE POWER RATING CURVE
Ta=25 °C
Pulse Width (td) is defined
as that point where the peak
current decays to 50%
of IPPM
tr = 10µs
2
VWM, REVERSE STAND-OFF VOLTAGE, (V)
FIG.3 - PULSE WAVEFORM
IPPM, PEAK PULSE CURRENT, %
Measured at
Stand-off Voltage
Voltage VWM
1,000
10/1000 µs. Waveform as
defined by R.E.A.
10
1.0
td
2.0
3.0
0.1
0.1µs
4.0
t, TIME(ms)
1.0µs
10µs
100µs
1.0ms
10ms
td, PULSE WIDTH, SEC
PEAK FORWARD CURRENT,
AMPERES
FIG.5 - MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
400
TJ = TJ max
8.3 ms Single half sine-wave
JEDEC Method
100
10
1
5
10
50
100
NUMBER OF CYCLES AT 60 Hz
www.umw-ic.com
3
友台半导体有限公司
UMW
R
5V-188V 1500W
ORDERING INFORMATION
Order Code
Package
Baseqty
Deliverymode
UMW SMCJxxA
SMC
850
Tape and reel
UMW SMCJxxCA
SMC
850
Tape and reel
www.umw-ic.com
4
友台半导体有限公司
很抱歉,暂时无法提供与“SMCJ188A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.36960
- 20+0.33810
- 100+0.30660
- 500+0.27510
- 1000+0.26040
- 2000+0.24990
