6.65 [0.262]
8.34 [0.328]
A1
2.20 [0.087]
2.56 [0.101]
6.00 [0.236]
A12
B12
B1
11.00 [0.433]
AFTER MATING
8.94 [0.352]
A
A
4.80 [0.189]
ALL CONTACT
XKB
4.30 [0.169]
4.60 [0.181]
7.50 [0.295]
1.30 [0.051]
1.00 [0.039]
5.30 [0.209]
3.16 [0.124]
XKB
NOTE:
1.MATERIAL SPECIFICATION:
1.HOUSING:LCP,UL94 V-0.
2.TERMINAL: COPPER ALLOY
3.MID PLATE: STAINLESS STEEL
4.FRONT SHELL: STAINLESS STEEL
5.EMI PLATE: STAINLESS STEEL
2.PLATING SPECIFICATION:
2-1.TERMINAL:
Ni 50u" MIN. UNDER PLATED OVER ALL.
Au PLATED ON THE FUNCTIONAL AREA OF CONTACT.
(GOLD PLATING THICKNESS FOLLOW THE P/N)
PLATING SPECIFICATIONS OF THE SOLDER AREA FOLLOW THE P/N
2-2.FRONT SHELL:
PLATING SPECIFICATIONS FOLLOW THE P/N
2-3.MID PLATE&EMI PLATE:
CLEAR ONLY
3.MECHANICAL PERFORMANCE,
3-1.INSERTION FORCE: 0.5~2.0kgf.
3-2.REMOVAL FORCE: 0.8kgf~2.0kgf.
3-3.DURABILITY: 10000 CYCLES.
4.ELECTRICAL PERFORMANCE,
4-1. VOLTAGE RATING:5 V DC/AC (RMS. max)
CURRENT RATING:5 AMPS. FOR TOTAL VBUS/GND PINS;
1.25AMPS FOR CC PIN,0.25 AMPS. FOR ALL OTHER CONTACT.
4-2. LLCR:
VBUS & GND PINS AND OTHER PINS: 40mΩ/PIN MAX.
SHIELD: 50mΩ/MAX.
LLCR MAX. CHANGE OF ALL PINS: 10mΩ.
4-3.INSULATION RESISTANCE: 100MΩ MIN
4-4.DIELECTRIC WITHSTAND VOLTAGE,AC 100V FOR 1 MINUTE.
5. ENVIRONMENTAL PERFORMANCE:
OPERATING TEMPERATURE: -25°C~+85°C.
6.IR REFLOW:
THE PEAK TEMPERATURE ON THE BOARD SHALL
BE MAINTAINED FOR 10 SECONDS AT 260°C.
0.50 [0.020]
A1
A2
A3
A4
A5
A6
A7
A8
A9
A10
A11
A12
7.50 [0.295]
7.50 [0.295]
5.50 [0.217]
4.80 [0.189]
4.50 [0.177]
3.50 [0.138]
2.50 [0.098]
1.50 [0.059]
0.50 [0.020]
4XØ1.10 [Ø0.043]
4XØ0.70 [Ø0.028]
5.50 [0.217]
6.50 [0.256]
0.50 [0.020]
1.10 [0.043]
4.45 [0.175]
A12
2XØ0.66 [Ø0.026]
B12
0.41 [0.016]
24X0.30 [0.012]
W:WHITE
B:BLACK
1.26 [0.050]
1.26 [0.050]
SECTION:A-A
X
X
X
DATE
DESCRIPTION
REVISIONS
www.xk-dg.cn
www.helloxkb.com
REVISED
APPROVED
ANGLAR
L≤ 4
4
很抱歉,暂时无法提供与“U263-241N-4BQC02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.85330
- 10+3.48040
- 50+3.18208
- 150+2.98320
- 300+2.85890
- 国内价格
- 50+4.55040
- 150+4.26600
- 300+4.08830
