KFSON
ALUMINUM ELECTROLYTIC CAPACITORS
KN
series
Load life 2000 Hrs at 105℃
RoHS Compliant
Specifications
規格表
Ltem 項目
Operating Temperature
Range
工作溫度範圍
Rated Voltage Range
額定電壓範圍
Capacitance Range
容量範圍
Performance Characteristics
-40 to +105℃
-25 to +105℃
16 to 100 VDC
160 to 500 VDC
68 to 56000 μF
Capacitance Tolerance
靜電容量偏差
Leakage Current
漏電流
±20%(120Hz,+20℃)
After 5 minutes at 20°C application of rated voltage, leakage
current is not more than 0.01CV or 1.5mA, whichever is smaller
C: Nominal Capacitance(μF) V: Rated Voltage(V)
rated voltage(V) 16
Dissipation Factor
tanδ(Max)
50
損耗角正切值 tanδ(%)
Low Temperature
Characteristics
低溫特性
Load Life
使用壽命
特性參數
25
40
35
40
50
30
63 100 160-400 450-500
20 20
15
impedance ratio max 電容器最大阻抗比值
rated voltage(V) 16 25 35 50 63 100 160-400 450-500
Z(-25℃)/Z(+20℃) 4
4
4
4
4
4
4
8
Z(-40℃)/Z(+20℃) 15 15 15 15 15 15
105℃施加額定工作電壓2000小時,經恢復後,產品性能應滿足以下要求
The following specifications shall be satisfied when the capacitors are restored
to 20℃ after subjected to DC voltage with the rated ripple current is applied
for 2000H at 105℃
Capacitance change
≦±20% of the initial value
D.F.(tanδ)
≦200% of the specified value
Leakage current
≦The specified value
105℃放置1000小時,經恢復後20℃后,產品性能應滿足以下要求
Shelf Life
存儲特性
to 20℃ after exposing them for 1000 hours at 105℃ without voltage applied.
Capacitance change
D.F.(tanδ)
Leakage current
Diagram of Dimensions 外形尺寸圖 (mm)
≦150% of the specified value
KFSON
KN series
Frequency Coefficient
Frequency
Voltage(v)
≤100V
160-250V
≥350
50/60
120
300
1K
10K
≥50K
Hz
Hz
Hz
Hz
Hz
Hz
0.95
0.87
0.80
1.00
1.00
1.00
1.07
1.17
1.16
1.13
1.32
1.30
1.19
1.45
1.41
1.20
1.50
1.43
Rated Voltage
Rated
Capacity
V
μF
Standard Ratings
Rated Voltage
V
Rated
Capacity
Size Rated ripple
φD*L
current
μF
mm
A
3300
22*26
22*26
25*26
22*31
25*26
30*26
22*31
22*31
25*26
30*26
22*36
30*26
22*41
25*36
30*26
35*32
22*51
25*46
30*36
35*32
25*51
30*36
35*32
25*51
30*41
35*32
30*46
35*37
30*51
35*42
35*45
35*47
1.17
1.53
1.55
2.02
2.02
2.02
2.20
2.79
2.79
2.81
3.06
3.06
3.24
3.24
3.24
3.24
3.54
3.51
3.51
3.54
4.25
4.08
4.08
4.30
4.30
4.30
4.83
4.83
5.78
5.78
6.32
6.48
4700
6800
8200
10000
12000
15000
16V
18000
22000
27000
33000
39000
47000
56000
3300
4700
6800
8200
10000
25V
12000
15000
18000
22000
27000
33000
39000
47000
Size Rated ripple
φD*L
current
mm
A
22*26
25*26
22*26
25*26
22*31
25*26
30*26
22*36
25*31
30*26
22*41
25*36
30*31
35*27
22*46
25*41
30*31
35*27
25*46
30*36
35*32
25*51
30*41
35*32
30*46
35*37
35*42
35*52
35*52
35*52
1.48
1.48
1.88
1.90
2.60
2.60
2.60
3.14
3.14
3.14
3.50
3.50
3.50
3.50
4.02
4.02
4.02
4.02
4.58
4.58
4.58
4.82
4.82
4.79
5.12
5.12
5.30
6.09
6.20
6.30
Rated ripple current(A,rms)at 105℃,120Hz
KFSON
KN series
Standard Ratings
Rated Voltage
V
Rated
Capacity
Size Rated ripple
φD*L
current
μF
mm
A
1500
22*26
22*26
25*26
22*26
25*26
22*26
25*26
22*36
25*26
30*26
22*41
25*36
30*26
35*27
25*46
30*36
35*27
25*51
30*41
35*32
30*46
35*37
35*52
35*52
35*45
35*52
1.26
1.35
1.45
1.55
1.65
1.80
1.90
2.42
2.30
2.54
3.24
3.24
3.21
3.24
3.96
3.96
3.75
4.21
4.21
4.21
4.69
4.69
5.50
5.80
5.60
5.90
2200
2700
3300
4700
6800
35V
10000
12000
15000
22000
27000
33000
Rated Voltage
Rated
Capacity
V
μF
1500
2200
2700
3300
4700
50V
6800
8200
10000
15000
18000
22000
Size Rated ripple
φD*L
current
mm
A
22*26
25*26
22*31
25*26
22*31
25*26
30*26
22*36
25*31
30*26
22*46
25*36
30*31
35*27
25*46
30*41
35*32
30*46
35*37
30*51
30*45
35*42
30*40
25*50
35*30
35*52
35*52
35*60
1.10
1.02
1.65
1.65
1.85
1.85
1.95
2.24
2.24
2.24
2.95
2.80
2.95
2.95
3.23
3.20
3.26
3.58
3.58
4.11
4.01
4.11
4.00
3.90
3.86
5.05
5.30
5.50
KFSON
KN series
Standard Ratings
Rated Voltage
Rated
Capacity
V
μF
mm
A
820
22*26
22*26
25*26
22*26
25*26
30*26
22*31
25*26
22*36
25*31
30*26
22*41
25*36
30*26
22*46
25*36
30*31
35*27
25*41
30*36
35*27
25*51
30*41
35*32
30*46
35*37
30*51
35*42
35*47
35*52
30*60
30*50
35*52
35*60
0.75
0.85
0.85
1.10
1.12
1.14
1.40
1.40
1.65
1.65
1.65
2.07
2.07
2.07
2.46
2.40
2.48
2.48
2.92
3.05
3.05
3.43
3.43
3.43
3.86
3.86
4.64
4.64
5.05
5.75
5.65
5.35
5.40
5.56
1000
1500
1800
2200
2700
3300
63V
3900
4700
5600
6800
8200
10000
15000
Size Rated ripple
φD*L
current
Rated Voltage
Rated
Capacity
V
μF
mm
A
330
22*26
22*26
25*26
22*26
25*26
22*31
25*26
30*26
22*31
25*26
30*26
22*36
25*31
30*26
22*41
25*36
30*31
22*46
25*41
30*31
35*27
25*41
30*36
35*32
25*51
30*41
35*32
30*46
35*37
30*56
35*47
35*47
35*52
35*40
30*50
35*60
35*52
35*60
0.54
0.79
0.81
0.90
0.95
1.02
1.02
1.14
1.26
1.26
1.32
1.38
1.38
1.38
1.65
1.65
1.65
1.83
1.83
1.83
1.83
2.52
2.52
2.52
3.03
3.03
3.03
4.10
4.10
4.59
4.59
4.98
5.03
4.80
4.65
5.10
5.09
5.20
470
560
680
820
1000
1200
100V
1500
1800
2200
2700
3300
3900
4700
5600
5600
6800
Size Rated ripple
φD*L
current
KFSON
KN series
Standard Ratings
Rated Voltage
Rated
Capacity
V
μF
mm
A
220
22*26
22*31
25*26
30*26
22*36
25*31
30*26
22*31
22*41
25*36
30*31
35*27
22*46
25*36
30*31
35*27
22*36
25*41
30*36
35*32
25*51
30*41
35*32
25*56
30*46
35*37
30*51
35*42
30*51
35*42
35*52
35*42
35*52
35*45
22*26
25*26
22*31
25*26
30*26
22*31
25*26
30*26
0.42
0.98
0.98
1.00
1.21
1.21
1.21
1.15
1.40
1.40
1.40
1.40
1.64
1.58
1.65
1.71
1.49
1.76
1.85
1.85
2.15
2.15
2.15
2.46
2.46
2.46
2.80
2.80
3.13
3.13
3.26
3.18
3.50
3.35
0.54
0.54
0.92
0.92
0.92
1.03
1.03
1.05
330
470
560
680
160V
820
1000
1200
1500
1800
2200
3300
150
200V
220
270
Size Rated ripple
φD*L
current
Rated Voltage
Rated
Capacity
V
μF
330
390
470
560
680
200V
820
1000
1200
1500
1800
2200
2700
100
250V
120
150
Size Rated ripple
φD*L
current
mm
A
22*36
25*31
30*26
22*36
25*31
30*31
22*41
25*36
30*31
35*27
22*30
22*46
25*41
30*31
35*27
22*51
25*46
30*31
35*32
25*51
30*36
35*37
30*40
35*37
25*45
25*40
35*30
25*50
30*30
30*50
35*42
35*47
35*52
35*52
30*50
35*52
35*45
22*31
25*26
22*25
22*31
25*26
22*31
25*26
30*26
1.21
1.21
1.21
1.33
1.34
1.45
1.57
1.59
1.65
1.65
1.55
1.81
1.85
1.85
1.85
2.04
2.07
2.04
2.17
2.30
2.30
2.31
2.62
2.62
2.55
2.51
2.50
2.55
2.45
3.00
3.00
3.28
4.01
4.10
3.85
4.10
3.80
0.44
0.44
0.42
0.50
0.50
0.60
0.60
0.60
KFSON
KN series
Standard Ratings
Rated Voltage
Rated
Capacity
V
μF
220
270
330
390
470
250V
560
680
820
1000
Size
φD*L
Rated ripple
current
mm
A
1.00
1.00
1.00
0.95
1.16
1.16
1.16
1.28
1.28
1.28
1.28
1.48
1.48
1.48
1.76
1.76
1.76
1.56
1.60
1.56
1.68
1.68
1.93
1.93
1.93
2.15
2.22
2.22
2.48
2.15
2.46
2.43
2.48
2.48
2.74
2.65
2.80
2.70
3.00
3.00
3.50
3.50
5.00
5.10
5.10
22*36
25*31
30*26
22*30
22*41
25*36
30*31
22*46
25*36
30*31
35*27
22*46
30*31
35*27
25*41
30*36
35*32
25*30
25*35
22*36
30*30
22*40
25*51
30*41
35*32
25*40
30*46
35*37
30*51
22*45
25*45
30*35
30*51
35*42
30*50
30*40
35*47
30*45
1200
1500
2200
35*50
35*55
35*50
35*55
35*55
35*60
35*70
Rated Voltage
Rated
Capacity
V
μF
100
120
150
180
220
400V
270
330
390
470
Size
φD*L
Rated ripple
current
mm
A
0.82
0.82
0.70
0.80
0.90
0.90
0.80
0.85
0.98
0.98
0.95
0.95
0.90
0.90
1.05
1.21
1.21
1.21
1.21
1.21
1.10
1.10
1.10
1.40
1.30
1.30
1.57
1.57
1.50
1.50
1.50
1.60
1.68
1.71
1.94
1.80
1.80
1.80
1.85
1.85
1.85
1.98
22*36
25*31
22*25
25*25
22*36
25*31
22*25
25*25
22*41
25*36
30*31
35*27
22*30
25*25
25*36
30*30
30*41
25*40
25*35
35*32
22*40
25*30
30*25
30*40
25*40
30*35
30*40
35*30
22*45
25*40
30*35
35*35
30*40
35*42
35*45
25*50
30*40
35*35
30*50
30*45
35*40
35*50
KFSON
KN series
Standard Ratings
Rated Voltage
Rated
Capacity
V
μF
560
680
400V
820
1000
1200
82
100
450V
120
150
Size
φD*L
Rated ripple
current
mm
A
2.23
2.23
2.40
2.40
2.85
2.83
2.80
2.70
2.65
2.90
2.83
2.85
3.20
3.15
3.15
3.10
3.30
3.30
3.30
0.64
0.64
0.64
0.74
0.74
0.74
0.70
0.72
0.72
0.82
0.82
0.82
0.80
0.80
0.80
0.80
0.96
0.96
0.96
0.96
0.90
35*50
30*45
35*45
35*40
35*62
35*50
35*45
30*50
35*40
35*62
35*45
35*50
35*70
35*65
35*60
35*50
35*70
35*65
35*60
22*36
25*31
30*26
22*41
25*31
30*31
22*25
22*35
25*25
22*46
25*36
30*31
22*30
25*25
25*30
30*25
22*51
25*41
30*36
35*27
22*30
Rated Voltage
Rated
Capacity
V
μF
150
180
220
270
Size
φD*L
Rated ripple
current
mm
A
0.90
0.90
0.95
0.95
0.95
1.14
1.10
1.14
1.24
1.24
1.20
1.20
1.20
1.20
1.48
1.48
1.60
1.64
1.60
1.60
1.60
1.80
1.86
1.65
1.90
1.90
1.90
1.90
2.40
2.40
2.40
2.40
2.90
2.85
2.80
2.80
3.20
3.20
3.20
3.30
3.30
3.60
22*35
25*30
25*35
30*25
30*30
25*46
30*36
35*32
30*41
35*37
22*40
25*40
25*50
30*30
30*51
35*42
30*40
330
450V
390
470
560
680
820
1000
1200
30*50
25*50
30*35
35*30
35*40
35*52
35*35
35*50
35*45
30*50
30*60
35*50
35*45
35*40
30*50
35*60
35*50
35*45
30*55
35*70
35*65
35*60
35*70
35*65
35*80
KN series
Standard Ratings
Rated Voltage
Rated
Capacity
V
μF
100
120
150
180
500V
220
270
330
390
470
680
820
1000
Size
φD*L
Rated ripple
current
mm
A
0.90
0.94
0.94
0.94
0.94
0.94
0.94
1.10
1.13
1.13
1.39
1.40
1.50
1.60
1.60
1.60
1.70
1.70
2.10
2.10
2.10
2.50
2.47
2.60
2.65
3.10
3.80
3.80
4.70
22*40
22*45
25*40
30*30
25*40
30*30
35*25
25*40
30*35
35*30
25*50
30*40
30*40
30*45
35*35
35*40
30*50
35*40
30*55
30*60
35*50
35*55
35*50
35*55
35*60
35*70
35*80
40*70
40*80
KFSON
很抱歉,暂时无法提供与“KN122M40035*70A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+20.90000
- 10+19.95000
