PIANO SWITCHES (HALF PITCH)
RoHS compliant
CHP
INTERNAL STRUCTURE
⑧
⑦
②
⑤
①
⑥
Part name
③
④
Material
Flammability
■ FEATURES
①
Cover
Polyphenylenesulphide
● RoHS compliant
● High-reliability
②
Slider
Polyamide
③
Housing
④
Slider contact
⑤
Fixed contact
■ APPLICATIONS
⑥
Terminal pin
● Communication devices, AV • OA equipment and
computer peripherals
⑦
Piano lever
Polyamide
⑧
Piano cover
UL94V-0
Copper alloy, Gold-plated
UL94V-0
■ PART NUMBER DESIGNATION
C H P - 0 4 0 T B
Series name
No. of bits
02:2 bits
04:4 bits
08:8 bits
ON direction
0:Upper
1:Lower
※ Please refer to the LIST OF PART NUMBERS when placing orders.
Shape of terminal
A:J-hook
B:Gull wing
Form of packaging
T :Taping (Reel)
Blank:Bulk in plastic bag
CHP
■ LIST OF PART NUMBERS
No. of bits
ON direction
2
4
8
Upper
Lower
Upper
Lower
Upper
Lower
Form of packaging
Taping
Plastic bag
Taping
Plastic bag
Taping
Plastic bag
Taping
Plastic bag
Taping
Plastic bag
Taping
Plastic bag
Shape of terminals
Pieces in package
A(J-hook)
B(Gull wing)
CHP-020TA
CHP-020TB
500 pcs./reel
CHP-020A CHP-020B 50 pcs./pack
CHP-021TA
CHP-021TB
500 pcs./reel
CHP-021A CHP-021B 50 pcs./pack
CHP-040TA
CHP-040TB
500 pcs./reel
CHP-040A CHP-040B 50 pcs./pack
CHP-041TA
CHP-041TB
500 pcs./reel
CHP-041A CHP-041B 50 pcs./pack
CHP-080TA
CHP-080TB
500 pcs./reel
CHP-080A CHP-080B 50 pcs./pack
CHP-081TA
CHP-081TB
500 pcs./reel
CHP-081A CHP-081B 50 pcs./pack
※ Verify the above part numbers when placing orders.
Taping version can be supplied only in reel units.
■ STANDARD SPECIFICATIONS
Operating temp. range
− 40 ~ 85 °C
Storage temp. range
Sealing
Net weight
■ ELECTRICAL CHARACTERISTICS
Contact rating
Non-switching
Switching
Minimum
Non-washable
Approx. 0.16 g (CHP-02), Approx. 0.25 g (CHP-04),
Approx. 0.43 g (CHP-08)
■ MECHANICAL CHARACTERISTICS
Contact resistance
Insulation resistance
Dielectric strength
22 °
Operation force
5 N {0.51 kgf} maximum
Vibration
Solderability
Soldering heat
10 N {1.02 kgf} 60 s
245 ± 3 °C, 2 ~ 3 s
Reflow:255 °C (Peak temperature)
(Please refer to the profile below)
Manual soldering:
350 ± 10 °C, 3 ~ 4 s
Shear (Adhesion)
5 N {0.51 kgf} 10 s
Substrate bending
Width 90 mm, bend 3 mm, 5 s, 1 time
1000 M Ω (DC100 V) minimum
AC500 V, 60 s
5 N {0.51 kgf} 10 s
{ } : Reference only
(Amplitude) 1.5 mm or (Acceleration) 98 m/s2,
10-500 Hz, 3 directions for 10 cycles each
Shock
490 m/s2, 11 ms
6 directions for 3 times each
Load life
Continuous load 1000 cycles,
DC6 ± 0.5 V, 100 ± 10 mA
Humidity
−10 ~ 65 °C, Relative humidity 0 ~ 96 %,
24 h for 10 cycles
High temp. exposure
85 °C, 96 h
Low temp. exposure
− 40 °C, 96 h
Thermal shock
Pull-off strength
50 m Ω maximum
■ ENVIRONMENTAL CHARACTERISTICS
Operation angle
Stop strength
DC50 V 100 mA
DC6 V, 100 mA DC24 V, 25 mA
DC20 mV 1 μA
−40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles
CHP
〈Reflow profile for soldering heat evaluation〉
Temperature
250
200
150
Peak : 250
+5
Over 230 ℃
Pre Heating Zone
180 ℃
150 ℃
90 ± 30 s
100
30 ± 10 s
50
Soldering Zone
Heating time
Reflow : two times maximum
■ OUTLINE DIMENSIONS
3.8
0.6
0.8
0.15 +0.1
–0.05
0.75
0.75
4.6
5.9
3.8
5.6 +0.3
+0.1
–0.05
0.8
0.6
22°
22°
Producion date code
● CHP-021B
4.6
0.1±0.1
4.6
Schematic
1.65±0.2
0.6
22°
Producion date code
Producion date code
0.4 +0.1
–0.05
1.27±0.15
8
0.8
Schematic
0.4 +0.1
–0.05
1.27±0.15
1.65±0.2
0.4 min
0.75
0.75
22°
0.15 +0.1
–0.05
4.6
8
5.9
0.6
0.8
1.65±0.2
5.9
0.4 min
0.15
4.6
+0.1
–0.05
0.4 +0.1
–0.05
1.27±0.15
0.4 min
0.1±0.1
1.65 ± 0.2
0.4 min
0.1 ± 0.1
0.4 +0.1
–0.05
1.27 ± 0.15
● CHP-020B
0.1±0.1
Schematic
4.6
Schematic
4.6
Producion date code
5.6 +0.3
● CHP-021A
4.6
5.9
● CHP-020A
Unless otherwise specified, tolerance : ± 0.3 (Unit : mm)
CHP
7.1
0.75
5.9
3.8
0.75
5.9
0.6
0.8
0.15 +0.1
–0.05
3.8
0.15 +0.1
–0.05
0.8
0.6
22
22
Producion date code
Producion date code
0.4 +0.1
–0.05
0.1±0.1
0.4 +0.1
–0.05
1.65±0.2
0.8
4.6
4.6
Schematic
0.1±0.1
0.4 +0.1
–0.05
1.65±0.2
Schematic
0.4 +0.1
–0.05
1.27±0.15
1.65±0.2
● CHP-081A
12.2
12.2
3.8
0.75
0.6
0.8
0.15 +0.1
–0.05
5.9
3.8
0.75
5.9
5.6 +0.3
–0.05
0.8
0.6
22
22
Schematic
Producion date code
1.65±0.2
0.1±0.1
0.4 +0.1
–0.05
1.27±0.15
Schematic
4.6
4.6
Producion date code
0.4 +0.1
–0.05
1.27±0.15
1.65±0.2
5.6 +0.3
● CHP-080A
0.1±0.1
0.4 min
22
Producion date code
Producion date code
0.1±0.1
0.6
0.4 min
22
0.4 min
0.75
0.75
8
5.9
0.6
0.8
1.27±0.15
0.15 +0.1
–0.05
7.1
8
0.15 +0.1
–0.05
7.1
1.65±0.2
● CHP-041B
0.4 min
● CHP-040B
1.27±0.15
5.9
0.1±0.1
Schematic
4.6
4.6
Schematic
1.27±0.15
5.6 +0.3
● CHP-041A
7.1
5.6 +0.3
● CHP-040A
CHP
0.15 +0.1
–0.05
12.2
8
0.8
0.6
22
Producion date code
0.1±0.1
Schematic
4.6
4.6
Producion date code
0.1±0.1
0.4 min
22
0.4 min
0.75
0.6
0.8
0.4 +0.1
–0.05
1.27±0.15
0.4 min
● CHP-081B
0.75
8
5.9
+0.1
–0.05
5.9
0.15
12.2
0.4 min
● CHP-080B
1.65±0.2
Schematic
0.4 +0.1
–0.05
1.27±0.15
1.65±0.2
■ RECOMMENDED P.C.B. PAD DIMENSIONS
B type
● 2 bits A type
1.27
7.62
1.27
1.6
5.08
1.27
0.76
0.76
B type
● 4 bits A type
1.27 N (N = 1 ~ 3) = 3.81
7.62
1.27
1.6
5.08
0.76
0.76
B type
● 8 bits A type
1.27 N (N = 1 ~ 7) = 8.89
0.76
7.62
1.27
1.6
5.08
0.76
CHP
■ PACKAGING SPECIFICATIONS
● Taping version is packaged in 500 pcs. per reel. Orders
will be accepted for units of 500 pcs., i.e., 500, 1000,
1500 pcs., etc.
● Taping version is boxed with two reels.
Maximum number of consecutive missing pieces=2
Leader length and reel dimension are shown in the
diagrams below:
● Embossed tape dimensions
● Reel dimensions
(Unit: mm)
(Conforms to JIS C 0806-3)
(In accordance with EIAJ ET-7200A)
Empty
Filled
φ 21±0.8
End
2±0.5
Head
40 mm min.
Direction of feed
20 pitches min.
Leader
400 mm min.
φ 50 min. (2, 4 bits)
φ 100±1 (8 bits)
Empty
17.4±1 (2, 4 bits)
25.4±1 (8 bits)
φ 13±0.2
21.4±1 (2, 4 bits)
29.4±1 (8 bits)
φ 254±2
12±0.1
4±0.1
2±0.1
5.3
Direction of feed
Direction of feed
0.4±0.1
Installation example
(CHP-041A)
16
(CHP-021B)
φ 1.5 +0.1
1.75±0.1
0.4±0.1
7.5±0.1
2±0.1
16
12±0.1
4±0.1
7.5±0.1
φ 1.5 +0.1
(Unit : mm)
● 4 bits
1.75±0.1
● 2 bits
5.3
2±0.1
0.4±0.1
(CHP-081B)
24
12±0.1
4±0.1
11.5±0.1
φ 1.5 +0.1
1.75±0.1
● 8 bits
Direction of feed
5.3
〈Bulk pack specifications〉
● The smallest unit of bulk pack in a plastic bag is 10 pcs. per
pack. Orders will be accepted for unit of minimum 10
pcs., i.e., 10, 20, 30 pcs., etc.
● Boxing of bulk in a plastic bag is performed with 50 pcs.
(Standard 100 pcs.) per box.
很抱歉,暂时无法提供与“CHP-041TB”相匹配的价格&库存,您可以联系我们找货
