S9014
BIPOLAR TRANSISTOR (NPN)
FEATURES
Complementary to S9015
Excellent hFE Linearity
Surface Mount device
SOT-23
MECHANICAL DATA
Case: SOT-23
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Moisture Sensitivity: Level 1 per J-STD-020
Weight: 0.008 grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Symbol
Value
Unit
Collector-Base Voltage
VCBO
50
V
Collector-Emitter Voltage
VCEO
45
V
Emitter-Base Voltage
VEBO
5
V
Collector Current
Collector Power Dissipation
IC
100
mA
PC
200
mW
Thermal Resistance From Junction To Ambient
RθJA
625
°C/W
Junction Temperature
TJ
150
°C
Storage Temperature
TSTG
-55 ~+150
°C
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Symbol
Min
Typ
Max
Unit
Conditions
Collector-base breakdown voltage
V(BR)CBO
50
V
IC=100uA,IE=0
Collector-emitter breakdown voltage
V(BR)CEO
45
V
IC=0.1mA,IB=0
Emitter-base breakdown voltage
V(BR)EBO
5
V
IE=100uA,IC=0
Collector cut-off current
ICBO
0.1
uA
VCB=50V, IE=0
ICEO
1
uA
VCE=35V, IB=0
Emitter cut-off current
IEBO
0.1
uA
VEB=3V, IC=0
DC current gain
hFE1
200
VCE=1V, IC=50mA
1000
Collector-emitter saturation voltage
VCE(sat)
0.3
V
IC=100mA,IB=5mA
Base-emitter saturation voltage
VBE(sat)
1
V
IC=100mA,IB=50mA
Transition frequency
fT
150
MHz
VCE=5V, IC=10mA, f=30MHz
CLASSIFICATION OF hFE
Rank
L
H
Range
200-450
450-1000
Marking
©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
J6
E-mail:hkt@heketai.com
1/4
S9014
Typical Characteristics
hFE
Static Characteristic
1000
COMMON
EMITTER
Ta=25℃
20uA
6
18uA
16uA
14uA
4
12uA
10uA
8uA
2
IC
Ta=100℃
DC CURRENT GAIN hFE
COLLECTOR CURRENT IC (mA)
8
6uA
Ta=25℃
100
4uA
COMMON EMITTER
VCE= 5V
IB=2uA
6
4
COLLECTOR-EMITTER VOLTAGE
VCEsat
10
0.1
8
1
(V)
10
COLLECTOR CURRENT
IC
VBEsat
IC
100
(mA)
IC
2
1
0.1
Ta=25℃
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
1
VCE
Ta=100℃
Ta=25℃
Ta=100℃
β=20
β=20
1
10
COLLECTOR CURRENT
IC
100
IC
—— VBE
fT
1000
1
COMMON EMITTER
VCE= 5V
0.6
0.3
0.9
Cob/ Cib
IC
100
(mA)
IC
100
10
COMMON EMITTER
VCE=5V
Ta=25℃
1
0.1
1.2
1
BASE-EMMITER VOLTAGE VBE (V)
100
10
COLLECTOR CURRENT
Ta=25℃
0.1
0.0
1
(mA)
Ta=100℃
10
0.1
0.1
100
TRANSITION FREQUENCY fT (MHz)
0.01
0.1
10
COLLECTOR CURRENT
VCB/ VEB
PC
250
IC
100
(mA)
Ta
f=1MHz
IE=0/IC=0
COLLECTOR POWER DISSIPATION
PC (mW)
CAPACITANCE C (pF)
Ta=25 ℃
Cib
10
Cob
1
0.1
0.1
1
REVERSE VOLTAGE
10
VR
(V)
150
100
50
50
75
AMBIENT TEMPERATURE
125
100
Ta
150
2/4
S9014
SOT-23 Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
1.200
1.400
0.047
0.055
E1
2.250
2.550
0.089
0.100
e
e1
0.950 TYP
1.800
L
0.037 TYP
2.000
0.071
0.550 RE F
0.079
0.022 REF
L1
0.300
0.500
0.012
0.020
θ
0°
8°
0°
8°
SOT-23 Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
3/4
S9014
SOT-23 Tape and Reel
SOT-23 Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SOT-23
3.15
2.77
1.22
Ø1.50
1.75
3.50
4.00
4.00
2.00
8.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SOT-23 Tape Leader and Trailer
SOT-23 Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
9.50
12.30
±2
±1
±1
±1
±1
±1
±1
±1
4/4
很抱歉,暂时无法提供与“S9014”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.03224
- 100+0.03014
- 300+0.02804
- 500+0.02594
- 2000+0.02489
- 5000+0.02426
