W5100S-L
W5100S-L
    WIZNET
    LQFP48_7X7MM
    以太网芯片,LQFP48_7X7MM,3.3KV
W5100S-L 数据手册
W5100S (W5100S-L & W5100S-Q) Version 1.0.0 http://www.wiznet.io/ © Copyright 2018 WIZnet Co., Ltd. All rights reserved. W5100S W5100S designed with Hardwired TCP/IP, WIZnet technology, is an embedded Internet Controller Chip. W5100S supporting Full Hardwired, Ethernet MAC (Media Access Control), and 10Base-T/100Base-TX Ethernet PHY is Internet Connectivity One-chip Solution for Internet Protocol (TCP/IP). With W5100S, Host (User MCU) simply handles variety Internet Protocol such as IPv4, TCP, UDP, ICMP, IGMP, ARP, PPPoE and etc. And W5100S supports each 8KB Memory for Transmit and Receive to minimize using memory on Low-end level Host. Host also independently uses 4 Hardwired SOCKETs to develop vary Internet Applications in each Hardwired SOCKETs. W5100S supports SPI and Parallel System BUS Interface for Host Interface. It also provides Low Power / Low Heat design, WOL (Wake On LAN), Ethernet PHY Power Down Mode and etc. W5100S is Low-cost chip that improves on W5100. Any Firmware using on W5100 can be used on W5100S without any modification. Also, W5100S has 48 Pin LQFP & QFN Lead-Free Package, smaller than W5100 for product miniaturization. 2 / 109 W5100S Datasheet Version1.0.0 Features - Support Hardwired Internet protocols : TCP, UDP, WOL over UDP, ICMP, IGMPv1/v2, IPv4, ARP, PPPoE - Support 4 independent SOCKETs simultaneously - Support SOCKET-less command : ARP-Request, PING-Request - Support Ethernet Power down mode & Main Clock gating for power save - Support Wake on LAN over UDP - Support Serial & Parallel Host Interface : High Speed SPI (MODE 0/3), System Bus with 2 Address signal & 8bit Data - Internal 16Kbytes Memory for TX/ RX Buffers - 10BaseT/100BaseTX Ethernet PHY Integrated - Support Auto Negotiation (Full and half duplex, 10 and 100-based ) - Support Auto-MDIX only when Auto-Negotiation mode - Not support IP Fragmentation - 3.3V operation with 5V I/O signal tolerance - Network Indicator LEDs (Full/Half duplex, Link, 10/100 Speed, Active) - 48 Pin LQFP & QFN Lead-Free Package (7x7mm, 0.5mm pitch) Target Applications W5100S is well-suited for many embedded applications, including: - User product based on W5100 : No modify firmware - Home Network Devices: Set-Top Boxes, PVRs, Digital Media Adapters - Serial-to-Ethernet: Access Controls, LED displays, Wireless AP relays, etc. - Parallel-to-Ethernet: POS / Mini Printers, Copiers - USB-to-Ethernet: Storage Devices, Network Printers - GPIO-to-Ethernet: Home Network Sensors - Security Systems: DVRs, Network Cameras, Kiosks - Factory, Building, Home Automations - Medical Monitoring Equipment - Embedded Servers - Internet of Thing (IoT) Devices - IoT Cloud Devices W5100S Datasheet Version1.0.0 3 / 109 Block Diagram Figure 1 Block Diagram 4 / 109 W5100S Datasheet Version1.0.0 Contents 1 PIN Description ........................................................................................ 11 1.1 PIN Description ............................................................................. 12 2 Memory Map ............................................................................................ 16 2.1 W5100S Registers........................................................................... 18 2.1.1 Common registers .................................................................... 18 2.1.2 SOCKET Registers .................................................................... 20 3 Register Descriptions ................................................................................. 22 3.1 Common Registers ......................................................................... 24 3.1.1 MR (Mode Register) .................................................................. 24 3.1.2 GWR (Gateway IP Address Register) .............................................. 24 3.1.3 SUBR (Subnet Mask Register) ...................................................... 24 3.1.4 SHAR (Source Hardware Address Register) ...................................... 25 3.1.5 SIPR (Source IP Address Register) ................................................. 25 3.1.6 INTPTMR (Interrupt Pending Time Register) .................................... 25 3.1.7 IR (Interrupt Register)............................................................... 25 3.1.8 IMR (Interrupt Mask Register) ...................................................... 26 3.1.9 RTR (Retransmission Time Register) .............................................. 27 3.1.10 RCR (Retransmission Count Register) ............................................. 27 3.1.11 RMSR (RX Memory Size Register) .................................................. 27 3.1.12 TMSR (TX Memory Size Register) .................................................. 28 3.1.13 IR2 (Interrupt Register 2) ........................................................... 28 3.1.14 IMR2 (Interrupt Mask Register 2) .................................................. 29 3.1.15 PTIMER (PPP Link Control Protocol Request Timer Register) ................ 29 3.1.16 PMAGIC (PPP Link Control Protocol Magic number Register) ................. 29 3.1.17 UIPR (Unreachable IP Address Register) ......................................... 30 3.1.18 UPORTR (Unreachable Port Register) ............................................ 30 3.1.19 MR2 (Mode Register 2) .............................................................. 30 3.1.20 PHAR (Destination Hardware Address Register on PPPoE) .................... 32 3.1.21 PSIDR (Session ID Register on PPPoE) ............................................. 32 3.1.22 PMRUR (PPPoE Maximum Receive Unit Register) ............................... 32 3.1.23 PHYSR (PHY Status Register) ....................................................... 32 3.1.24 PHYRAR (PHY Register Address Register) ........................................ 33 3.1.25 PHYDIR (PHY Data Input Register) ................................................ 34 3.1.26 PHYDOR (PHY Data Output Register) ............................................. 34 3.1.27 PHYACR (PHY Access Control Register) .......................................... 34 3.1.28 PHYDIVR (PHY Division Register) .................................................. 34 3.1.29 PHYCR0 (PHY Control Register 0) ................................................. 34 W5100S Datasheet Version1.0.0 5 / 109 3.2 6 / 109 3.1.30 PHYCR1 (PHY Control Register 1) ................................................. 35 3.1.31 SLCR (SOCKET-less Command Register) .......................................... 36 3.1.32 SLRTR (SOCKET-less Retransmission Time Register) ........................... 36 3.1.33 SLRCR (SOCKET-less Retransmission Count Register) .......................... 37 3.1.34 SLPIPR (SOCKET-less Peer IP Address Register) ................................. 37 3.1.35 SLPHAR (SOCKET-less Peer Hardware Address Register) ...................... 37 3.1.36 PINGSEQR (PING Sequence-number Register) ................................... 37 3.1.37 PINGIDR (PING ID Register) ......................................................... 38 3.1.38 SLIMR (SOCKET-less Interrupt Mask Register) ................................... 38 3.1.39 SLIR (SOCKET-less Interrupt Register) ............................................ 38 3.1.40 CLKLCKR (Clock Lock Register) .................................................... 39 3.1.41 NETLCKR (Network Lock Register) ................................................ 39 3.1.42 PHYLCKR (PHY Lock Register) ..................................................... 39 3.1.43 VERR (Version Register) ............................................................. 39 3.1.44 TCNTR (Ticker Counter Register) ................................................. 39 3.1.45 TCNTCLR (Ticker Counter Clear Register) ....................................... 40 SOCKET Register ............................................................................ 41 3.2.1 Sn_MR (SOCKET n Mode Register) ................................................. 41 3.2.2 Sn_CR (SOCKET n Command Register)............................................ 42 3.2.3 Sn_IR (SOCKET n Interrupt Register) ............................................. 44 3.2.4 Sn_SR (SOCKET n Status Register) ................................................ 45 3.2.5 Sn_PORTR (SOCKET n Source Port Register) .................................... 46 3.2.6 Sn_DHAR (SOCKET n Destination Hardware Address Register) ............... 46 3.2.7 Sn_DIPR (SOCKET n Destination IP Address Register) .......................... 47 3.2.8 Sn_DPORTR (SOCKET n Destination Port Register) ............................. 47 3.2.9 Sn_MSS (SOCKET n Maximum Segment Size Register) ......................... 47 3.2.10 Sn_PROTOR (SOCKET n IP Protocol Register) ................................... 48 3.2.11 Sn_TOS (SOCKET n IP Type Of Service Register) ............................... 48 3.2.12 Sn_TTL (SOCKET n IP Time To Live Register) ................................... 48 3.2.13 Sn_RXBUF_SIZE (SOCKET n RX Buffer Size Register) ........................... 48 3.2.14 Sn_TXBUF_SIZE (SOCKET n TX Buffer Size Register) ........................... 49 3.2.15 Sn_TX_FSR (SOCKET n TX Free Size Register) ................................... 49 3.2.16 Sn_TX_RD (SOCKET n TX Read Pointer Register) ............................... 49 3.2.17 Sn_TX_WR (SOCKET n TX Write Pointer Register) .............................. 50 3.2.18 Sn_RX_RSR (SOCKET n RX Received Size Register) ............................. 50 3.2.19 Sn_RX_RD (SOCKET n RX Read Pointer Register) ............................... 50 3.2.20 Sn_RX_WR (SOCKET n RX Write Pointer Register) .............................. 51 3.2.21 Sn_IMR (SOCKET n Interrupt Mask Register) ..................................... 51 3.2.22 Sn_FRAGR (SOCKET n Fragment Offset in IP Header Register) .............. 51 W5100S Datasheet Version1.0.0 3.2.23 Sn_MR2 (SOCKET n Mode register 2) .............................................. 51 3.2.24 Sn_KPALVTR (SOCKET n Keep Alive Timer Register) ........................... 53 3.2.25 Sn_RTR (SOCKET n Retransmission Time Register) ............................. 53 3.2.26 Sn_RCR (SOCKET n Retransmission Count Register) ........................... 53 4 Functional Description ............................................................................... 54 4.1 W5100S RESET .............................................................................. 54 4.2 Initialization ................................................................................ 54 4.3 4.4 4.2.1 Basic Setting .......................................................................... 54 4.2.2 Network Information Setting....................................................... 54 4.2.3 SOCKET TX/RX Buffer Setting ...................................................... 55 TCP ........................................................................................... 56 4.3.1 TCP Server ............................................................................ 57 4.3.2 TCP Client ............................................................................. 65 4.3.3 Other Functions ...................................................................... 67 UDP ........................................................................................... 68 4.4.1 UDP Unicast ........................................................................... 68 4.4.2 UDP Broadcast ........................................................................ 71 4.4.3 UDP Multicast ......................................................................... 72 4.4.4 Other Functions ...................................................................... 74 4.5 IPRAW ........................................................................................ 75 4.6 MACRAW ..................................................................................... 78 4.7 SOCKET-less Command (SLCR) ........................................................... 81 4.8 4.9 4.7.1 ARP Request (SLCR [ARP] = ‘1’) ................................................... 81 4.7.2 PING Command (SLCR [PING] = ‘1’)............................................... 83 Retransmission .............................................................................. 86 4.8.1 ARP & PING Retransmission ........................................................ 86 4.8.2 TCP Retransmission .................................................................. 86 Others Function ............................................................................ 88 4.9.1 System Clock(SYS_CLK) Switching ................................................ 88 4.9.2 Ethernet PHY Operation Mode Configuration ................................... 88 4.9.3 Ethernet PHY Parallel Detection .................................................. 89 4.9.4 Ethernet PHY Auto MDIX ............................................................ 89 4.9.5 Ethernet PHY Power Down Mode .................................................. 90 4.9.6 Ethernet PHY’s Registers Control ................................................. 91 5 HOST Interface Mode ................................................................................. 92 5.1 SPI Mode ..................................................................................... 92 5.1.1 SPI Frame .............................................................................. 93 5.1.2 SPI Write ............................................................................... 93 5.1.3 SPI Read ............................................................................... 94 W5100S Datasheet Version1.0.0 7 / 109 5.2 Parallel Bus Mode .......................................................................... 95 5.2.1 Parallel Bus Data Write ............................................................. 95 5.2.2 Parallel Bus Data Write ............................................................. 96 6 Clock & Transformer Requirements ............................................................... 97 6.1 Quartz Crystal requirements. ............................................................ 97 6.2 Oscillator requirements. .................................................................. 98 6.3 Transformer Characteristics ............................................................. 98 7 Electrical Specification .............................................................................. 99 7.1 Absolute Maximum ratings................................................................ 99 7.2 Absolute Maximum ratings (Electrical Sensitivity) ................................... 99 7.3 DC Characteristics ......................................................................... 99 7.4 AC Characteristics ........................................................................ 100 7.5 7.4.1 Reset Timing ......................................................................... 100 7.4.2 BUS ACCESS TIMING ................................................................. 102 7.4.3 SPI ACCESS TIMING .................................................................. 103 7.4.4 Transformer Characteristics ...................................................... 104 7.4.5 MDIX ................................................................................... 104 POWER DISSPATION ....................................................................... 104 8 Package Information ................................................................................ 106 8.1 LQFP48 ...................................................................................... 106 8.2 QFN48 ....................................................................................... 107 9 Document Revision History ....................................................................... 109 8 / 109 W5100S Datasheet Version1.0.0 List of Figures Figure 1 Block Diagram ...........................................................................4 Figure 2 W5100S Pin Layout .................................................................. 11 Figure 3 Memory Map ........................................................................... 16 Figure 4 State Diagram ......................................................................... 46 Figure 5 TCP SERVER and TCP CLIENT ...................................................... 56 Figure 6 TCP Server Operation Flow ........................................................ 57 Figure 7 TCP Client Operation Flow ......................................................... 65 Figure 8 UDP Operation Flow ................................................................. 68 Figure 9 Received UDP DATA in SOCKETn RX Buffer Block ............................. 69 Figure 10 IPRAW Operation Flow ............................................................ 75 Figure 11 Received Data in IPRAW Mode SOCKET RX Buffer Block ................... 76 Figure 12 MACRAW Operation Flow ......................................................... 78 Figure 13 Received DATA Format in MACRAW ............................................ 79 Figure 14 SOCKET-less Command Operation Flow ....................................... 81 Figure 15 SCSn controlled by Host ........................................................... 92 Figure 16 SPI Mode 0 & Mode 3 ............................................................... 92 Figure 17 SPI Frame ............................................................................. 93 Figure 18 W5100 Mode Write SPI Frame ................................................... 94 Figure 19 W5100 Mode Read SPI Frame .................................................... 94 Figure 20 Direct & Indirect Mode Control by Host ....................................... 95 Figure 21 Parallel Bus N-Bytes Data Write ................................................. 96 Figure 22 Indirect Mode Continuous Read Access ........................................ 96 Figure 23 Quartz Crystal Model .............................................................. 97 Figure 24 Transformer Type .................................................................. 98 Figure 25 Reset Timing ....................................................................... 101 Figure 26 Bus Read Timing .................................................................. 102 Figure 27 BUS Write Timing ................................................................. 102 Figure 28 SPI Read Timing ................................................................... 103 Figure 29 SPI Write Timing .................................................................. 103 Figure 30 Transformer Type ................................................................ 104 W5100S Datasheet Version1.0.0 9 / 109 List of Tables Table 1 Pin Type Notation ..................................................................... 11 Table 2 PIN Description ........................................................................ 12 Table 3 Common Registers .................................................................... 18 Table 4 Socket Registers ....................................................................... 20 Table 5 Internet Protocol Supported In IPRAW Mode .................................... 75 Table 6 W5100 Mode SPI Command ......................................................... 93 Table 7 Indirect Mode Address Value ....................................................... 95 Table 8 Quartz Crystal .......................................................................... 97 Table 9 Crystal Recommendation Characteristics ........................................ 97 Table 10 Oscillator Characteristics .......................................................... 98 Table 11 Transformer Characteristics ...................................................... 98 Table 12 Absolute Maximum ratings......................................................... 99 Table 13 Electro Static Discharge (ESD) .................................................... 99 Table 14 Latch up Test ......................................................................... 99 Table 15 DC Characteristics ................................................................... 99 Table 16 Reset Table ......................................................................... 101 Table 17 BUS Read Timing ................................................................... 102 Table 18 BUS Write timing ................................................................... 103 Table 19 SPI Read Timing .................................................................... 103 Table 20 SPI Write Timing ................................................................... 104 Table 21 Transformer Characteristics .................................................... 104 Table 22 Power Dissipation .................................................................. 104 Table 23 LQFP48 VARIATIONS (ALL DEMINSIONS SHOWN IN MM) ................... 106 Table 24 QFN48 VARIATIONS (ALL DEMINSIONS SHOWN IN MM) ..................... 107 10 / 109 W5100S Datasheet Version1.0.0 MISO MOSI 1V2D SCLK CSn MOD3 MOD2 MOD1 33 32 31 30 29 28 27 26 MOD0 RDn 34 25 WRn DAT1 35 37 3V3D DAT0 36 PIN Description 24 3V3D 38 23 GND DAT2 39 22 1V2D DAT3 40 21 COLn DAT4 41 20 ACTn DAT5 42 19 DPXn DAT6 43 18 SPDn DAT7 44 17 LNKn 1V2D 45 16 GNDA GND 46 15 3V3A INTn 47 14 1V2O RSTn 48 13 1V2D W5100S 5 6 7 8 9 10 11 12 RXIN RXIP GNDA 3V3A RSET_BG GND XSCO XSCI 3 TXOP 4 2 TXON 1V2A 1 LOT Number Weekly Code GNDA 1 Figure 2 W5100S Pin Layout Table 1 Pin Type Notation Type Description I Input O Output M Alternate (Multi-function) Signal U Internal pulled-up 75KΩ resistor D Internal pulled-down 75KΩ resistor A Analog P Power & Ground W5100S Datasheet Version1.0.0 11 / 109 1.1 PIN Description Table 2 PIN Description PIN # Symbol Type Description 1 GNDA AP Analog Ground 2 TXON AO Differential Transmitted Signal Pair 3 TXOP AO 4 1V2A AP 5 RXIN AI 6 RXIP AI 7 GNDA AP Analog Ground 8 3V3A AP Analog 3.3V Power Differential Data is transmitted to Media via TXOP/TXON signal pair on MDI Mode. Analog 1.2V Power Supplied from 1V20 voltage source Differential Received Signal Pair Differential Data is received from Media via RXIP/RXIN signal pair on MDI Mode. Off-chip Bias Resistor 9 RSET_BG AO Must be connected to analog Ground through external 12.3KΩ, error 1% Resistance. 10 GND AP Digital Ground 11 XSCO AO 25MHz Clock 25MHz Crystal Oscillator (TXAL) or Oscillator (OSC) are used for Internal oscillator stabilization. W5100S uses 25MHz (Low Frequency Mode) or 100MHz 12 XSCI AI (Normal Mode) as Internal Clock from External 25MHz Clock Source. If OSC is used, 25MHz@1.2V must be used and only XSCI must be connected and XSCO must be floated. For more information, refer to Clock Selection Guide. 13 1V2D P Digital 1.2V Power Supplied from 1V20 voltage source Internal Regulator 1.2V Power Output Internal Regulator for W5100S needs Max 150mA for 1.2V Power Output. Make sure to supply 1V2D and 1V2A for External 14 1V2O PO Capacitor 3.3uF stabilization. 1V2O must use Ferrite Bead. 1V2D and 1V2A must be separated and be supplied. This power is only for W5100S. It must not be used for other device. 12 / 109 W5100S Datasheet Version1.0.0 15 3V3A AP Analog 3.3V Power 16 GNDA AP Analog Ground Link Status LED It is valid on SPI and Parallel Bus Mode. 17 LNKn OU Low : Link up High : Link down Link Speed LEDIt is valid on SPI and Parallel Bus Mode. 18 SPDn OU Low : 100Mbps High : 10Mbps Link Duplex LED It is valid on SPI and Parallel Bus Mode. 19 DPXn OU Low : Full-Duplex High : Half-Duplex Link Activity LED It is valid on SPI and Parallel Bus Mode. 20 ACTn OU No Flash : Link up state without TX/RX Flash : Link up state with TX/RX data High : Link-down state Link Collision Detect LED It is valid on SPI and Parallel Bus Mode. 21 COLn OU It indicates a collision during Data transmission. Low : Collision Detected High : No Collision Digital 1.2V Power 22 1V2D P 23 GND P Digital Ground 24 3V3D P Digital 3.3V power 25 MOD[0] ID W5100S Interface Mode Selection 26 MOD[1] ID Interface Mode is selected by MOD [3:0]. 27 MOD[2] ID 28 MOD[3] ID 29 CSn IU W5100S Datasheet Version1.0.0 Supplied from 1V20 voltage source. “0000” : SPI Mode “010X” : Parallel Bus Mode W5100S Chip Select 13 / 109 Low : Select High : No Select SPI Clock 30 SCLK ID On SPI Mode, it is used to SPI Clock. But on Parallel Bus Mode, it must be connected to GND or be floated. 31 32 33 1V2D MOSI /ADDR0 MISO /ADDR1 P Digital 1.2V Power Supplied from 1V20 voltage source. SPI Master Output Slave Input / Address 0 IDM MOSI : On SPI Mode, SPI Data is received from HOST. ADDR0 : On Parallel Bus Mode, it is used to Address 0. SPI Master Input Slave Output / Address 1 IOPM MISO : On SPI Mode, SPI Data is transmitted to HOST. ADDR1 : On Parallel Bus Mode, It is used to Address 1. Read Strobe 34 RDn IU On Parallel Bus Mode, it indicates Read Operation. On SPI Mode, it must be connected to 3V3D or be floated. Write Strobe 35 WRn IU 36 3V3D P 37 DAT0 IOU 8 Bits Data Bus 38 DAT1 IOU On Parallel Bus Mode, DAT [7:0] receives Data from HOST 39 DAT2 IOU or W5100S. 40 DAT3 IOU 41 DAT4 IOU 42 DAT5 IOU 43 DAT6 IOU 44 DAT7 IOU 45 1V2D P Digital 1.2V Power 46 GND P Digital Ground On Parallel Bus Mode, it indicates Write Operation. Digital 3.3V Power On SPI Mode, DAT [7:0] must be floated. Interrupt When the event occurs during W5100S Ethernet Communication, INTn notices to HOST. 47 INTn OP Low : Interrupt Occurred High : No Interrupt Refer to IEN (Interrupt pin Enable) in MR2 (Mode Register 2), INTPTMR (Interrupt Pending Time Register), IMR 14 / 109 W5100S Datasheet Version1.0.0 (Interrupt Mask Register), IMR2 (Interrupt Mask Register 2), SLIMR (SOCKET-less Interrupt Mask Register) Reset RSTn initializes W5100S. RSTn must be asserted to Low longer than 500ns. After asserted RSTn, W5100S spends 48 RSTn IP 60.3ms for initialization. (Ref 7.4.1 Reset Timing) Low : W5100S initialized. High : Normal Operation. W5100S Datasheet Version1.0.0 15 / 109 2 Memory Map W5100S has the same Memory Map as W5100 for compatibility and additional Common Register for improved functionality. The below Figure 3 shows W5100S Memory Map. Figure 3 Memory Map 16 / 109 W5100S Datasheet Version1.0.0 Figure 3 shows the Address Offset of Common & SOCKET Register Block and TX/RX Memory Block. At W5100S Reset, each SOCKET n TX/RX Buffer are assigned with 2KB/2KB from TX/RX Memory Block. After W5100S Reset, each SOCKET n TX/RX Buffer Size are set by TMSR (TX Memory Size Register) and RMSR (RX Memory Size Register) or by SOCKET n TX/RX Buffer Size Register (Sn_TXBUF_SIZE / Sn_RXBUF_SIZE). The total Buffer Size of SOCKET n TX/RX must not be exceeded by 8 Kbytes. W5100S Datasheet Version1.0.0 17 / 109 2.1 W5100S Registers 2.1.1 Common registers Table 3 Common Registers Address Address 0x0000 0x0001 0x0002 0x0003 0x0004 0x0005 0x0006 0x0007 0x0008 0x0009 0x000A 0x000B 0x000C 0x000D 0x000E 0x000F 0x0010 0x0011 0x0012 0x0013 0x0014 Register Mode (MR) Gateway Address Interrupt2 (IR2) (GAR1) Interrupt2 Mask (IMR2) (GAR2) 0x0022 (GAR3) ~ Subnet Mask Address (SUBR0) (SUBR1) (SUBR2) (SUBR3) Source Hardware Address (SHAR0) (SHAR1) (SHAR2) (SHAR4) (SHAR5) Source IP Address 0x001B 18 / 109 Reserved 0x0027 0x0028 0x0029 0x002A 0x002B 0x002C 0x002D (SHAR3) 0x002E 0x002F PPP LCP Request Timer (PTIMER) PPP LCP Magic Number (PMAGIC) Unreachable IP Address (UIPR0) (UIPR1) (UIPR2) (UIPR3) Unreachable Port (UPORTR0) (UPORTR1) (SIPR0) 0x0030 Mode2 (MR2) (SIPR1) 0x0031 Reserved (SIPR2) Destination Hardware Address (SIPR3) 0x0032 on PPPoE Interrupt Pending Time 0x0033 (PHAR0) (INTPTMR0) 0x0034 (PHAR1) (INTPTMR1) 0x0035 (PHAR2) 0x0036 (PHAR3) 0x0037 (PHAR4) Interrupt Mask (IMR) 0x001A Reserved 0x0021 0x0016 0x0019 ~ 0x001F 0x0020 Interrupt (IR) 0x0018 0x001C (GAR0) 0x0015 0x0017 Register (PHAR5) Retransmission Time (RTR0) (RTR0) 0x0038 0x0039 Retransmission Time (RCR) RX Memory Size 0x003A 0x003B (RMSR) TX Memory Size (TMSR) 0x003C Session ID on PPPoE (PSIDR0) (PSIDR1) Maximum Receive Unit on PPPoE (PMRUR0) (PMRUR1) PHY Status (PHYSR0) W5100S Datasheet Version1.0.0 Address Register 0x003E PHY Address Value (PHYAR) 0x003F PHY Register Address (PHYRAR) 0x0040 0x0041 PHY Data Input (PHYDIR0) (PHYDIR1) PHY Data Output Address 0x005E 0x005F Register SOCKET-less Interrupt Mask (SLIMR) SOCKET-less Interrupt (SLIR) 0x0060 ~ Reserved 0x006A 0x0070 Clock Lock (CLKLCKR) 0x0071 Network Lock (NETLCKR) (PHYDOR1) 0x0072 PHY Lock (PHYLCKR) 0x0044 PHY Access (PHYACR) 0x0073 0x0045 PHY Division (PHYDIVR) 0x0042 0x0043 0x0046 0x0047 (PHYDOR0) 0x007F (PHYCR0) 0x0080 Chip Version (VERR) (PHYCR1) 0x0081 Reserved Reserved 0x0082 0x0083 0x004B 0x004C 0x004D 0x004E 0x004F 0x0050 0x0051 0x0052 0x0053 0x0054 0x0055 0x0056 0x0057 0x0058 0x0059 0x005A 0x005B 0x005C 0x005D Reserved PHY Control 0x0048 ~ ~ SOCKET-less Command (SLCR) SOCKET-less Retransmission Time (SLRTR0) (SLRTR1) 100us Tick Counter (TCNTR0) (TCNTR1) 0x0084 ~ Reserved 0x0087 0x0088 TCNTCLR SOCKET-less Retransmission Count (SLRCR) SOCKET-less Peer IP Address (SLPIPR0) (SLPIPR1) (SLPIPR2) (SLPIPR3) SOCKET-less Peer Hardware Address (SLPHAR0) (SLPHAR1) (SLPHAR2) (SLPHAR3) (SLPHAR4) (SLPHAR5) PING Sequence Number (PINGSEQR0) (PINGSEQR1) PING ID (PINGIDR0) (PINGIDR1) W5100S Datasheet Version1.0.0 19 / 109 2.1.2 SOCKET Registers Table 4 Socket Registers Symbol Sn_MR Sn_CR Sn_IR Sn_SR Description SOCKET n Mode SOCKET n Command SOCKET n Interrupt SOCKET n Status Address Sn_ S0_ S1_ S2_ S3_ 0x0400+(0x0100 x n) 0x0400 0x0500 0x0600 0x0700 0x0401+(0x0100 x n) 0x0401 0x0501 0x0601 0x0701 0x0402+(0x0100 x n) 0x0402 0x0502 0x0602 0x0702 0x0403+(0x0100 x n) 0x0403 0x0503 0x0603 0x0703 Sn_PORTR0 SOCKET n 0x0404+(0x0100 x n) 0x0404 0x0504 0x0604 0x0704 Sn_PORTR1 Source Port 0x0405+(0x0100 x n) 0x0405 0x0505 0x0605 0x0705 Sn_DHAR0 0x0406+(0x0100 x n) 0x0406 0x0506 0x0606 0x0706 Sn_DHAR1 0x0407+(0x0100 x n) 0x0407 0x0507 0x0607 0x0707 0x0408+(0x0100 x n) 0x0408 0x0508 0x0608 0x0708 0x0409+(0x0100 x n) 0x0409 0x0509 0x0609 0x0709 Sn_DHAR4 0x040A+(0x0100 x n) 0x040A 0x050A 0x060A 0x070A Sn_DHAR5 0x040B+(0x0100 x n) 0x040B 0x050B 0x060B 0x070B Sn_DIPR0 0x040C+(0x0100 x n) 0x040C 0x050C 0x060C 0x070C 0x040D+(0x0100 x n) 0x040D 0x050D 0x060D 0x070D 0x040E+(0x0100 x n) 0x040E 0x050E 0x060E 0x070E 0x040F+(0x0100 x n) 0x040F 0x050F 0x060F 0x070F Sn_DHAR2 Sn_DHAR3 Sn_DIPR1 Sn_DIPR2 SOCKET n Destination Hardware Address SOCKET n Destination IP Address Sn_DIPR3 Sn_DPORTR0 SOCKET n 0x0410+(0x0100 x n) 0x0410 0x0510 0x0610 0x0710 Sn_DPORTR0 Destination Port 0x0411+(0x0100 x n) 0x0411 0x0511 0x0611 0x0711 SOCKET n 0x0412+(0x0100 x n) 0x0412 0x0512 0x0612 0x0712 0x0413+(0x0100 x n) 0x0413 0x0513 0x0613 0x0713 0x0414+(0x0100 x n) 0x0414 0x0514 0x0614 0x0714 0x0415+(0x0100 x n) 0x0415 0x0515 0x0615 0x0715 0x0416+(0x0100 x n) 0x0416 0x0516 0x0616 0x0716 Sn_MSS0 Sn_MSS1 Sn_PROTOR Sn_TOS Sn_TTL Maximum Segment Size SOCKET n IP Protocol SOCKET n IP Type Of Service SOCKET n IP Time To Live Reserved Reserved 0x0417+(0x0100 x n) 0x0417 0x0517 0x0617 0x0717 Reserved Reserved 0x041D+(0x0100 x n) 0x041D 0x051D 0x061D 0x071D 0x041E+(0x0100 x n) 0x041E 0x051E 0x061E 0x071E 0x041F+(0x0100 x n) 0x041F 0x051F 0x061F 0x071F 0x0420+(0x0100 x n) 0x0420 0x0520 0x0620 0x0720 Sn_RXBUF_SIZE Sn_TXBUF_SIZE Sn_TX_FSR0 20 / 109 SOCKET n RX Buffer Size SOCKET n TX Buffer Size SOCKET n W5100S Datasheet Version1.0.0 Sn_TX_FSR1 TX Free Size 0x0421+(0x0100 x n) 0x0421 0x0521 0x0621 0x0721 Sn_TX_RD0 SOCKET n 0x0422+(0x0100 x n) 0x0422 0x0522 0x0622 0x0722 Sn_TX_RD1 TX Read Pointer 0x0423+(0x0100 x n) 0x0423 0x0523 0x0623 0x0723 Sn_TX_WR0 SOCKET n 0x0424+(0x0100 x n) 0x0424 0x0524 0x0624 0x0724 Sn_TX_WR1 TX Write Pointer 0x0425+(0x0100 x n) 0x0425 0x0525 0x0625 0x0725 Sn_RX_RSR0 SOCKET n 0x0426+(0x0100 x n) 0x0426 0x0526 0x0626 0x0726 Sn_RX_RSR1 RX Received Size 0x0427+(0x0100 x n) 0x0427 0x0527 0x0627 0x0727 Sn_RX_RD0 SOCKET n 0x0428+(0x0100 x n) 0x0428 0x0528 0x0628 0x0728 Sn_RX_RD1 RX Read Pointer 0x0429+(0x0100 x n) 0x0429 0x0529 0x0629 0x0729 Sn_RX_WR0 SOCKET n 0x042A+(0x0100 x n) 0x042A 0x052A 0x062A 0x072A Sn_RX_WR1 RX Write Pointer 0x042B+(0x0100 x n) 0x042B 0x052B 0x062B 0x072B 0x042C+(0x0100 x n) 0x042C 0x052C 0x062C 0x072C 0x042D+(0x0100 x n) 0x042D 0x052D 0x062D 0x072D 0x042E+(0x0100 x n) 0x042E 0x052E 0x062E 0x072E 0x042F+(0x0100 x n) 0x042F 0x052F 0x062F 0x072F 0x0430+(0x0100 x n) 0x0430 0x0530 0x0630 0x0730 0x0432+(0x0100 x n) 0x0432 0x0532 0x0632 0x0732 0x0433+(0x0100 x n) 0x0433 0x0533 0x0633 0x0733 0x0434+(0x0100 x n) 0x0434 0x0534 0x0634 0x0734 Sn_IMR Sn_FRAGR0 Sn_FRAGR1 Sn_MR2 Sn_KPALVTR Sn_RTR0 Sn_RTR1 SOCKET n Interrupt Mask SOCKET n Fragment Offset in IP Header SOCKET n Mode 2 SOCKET n Keep-alive Timer SOCKET n Retransmission Time SOCKET n Sn_RCR Retransmission Count W5100S Datasheet Version1.0.0 21 / 109 3 Register Descriptions Register Notation * Register Symbol (Register full Name) - [Register Type][Address Offset][Reset Value] Register Description…. 7 6 5 4 3 2 1 0 Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 Bit Type Bit Type Bit Type Bit Type Bit Type Bit Type Bit Type Bit Type Sn_IR [3: 0] indicates a Register Symbol [Upper Bit: Lower Bit]. Sn_IR [3: 0] = '0001' indicates Sn_IR [3] = '0', Sn_IR [2] = '0', Sn_IR [1] = '0', Sn_IR [0] = '1'. [Register/Bit Type]: Type of Register and Bit. - [RW] : Both reading and writing are possible. - [R=W] : The value read and written are the same. - [RO] : Read Only - [WO] : Write Only - [W] : Write Only - [WC] : Cleared by written ‘1’. - [W0] : Must be written only ‘0’. - [W1] : Must be written only ‘1’. - [AC] : Auto Clear - [1] : Always read ‘1’ - [0] : Always read ‘0’ - [-] : Not available [Address Offset]: Register Address Offset [Reset Value]: Default Value. Ex1) 3.1.1 MR ( Mode Register) [RW][0x0000][0x03] MR is abbreviation for Mode Register. This Register is possible to be read and written. The Register Address Offset is ‘0x0000’ and it is set to ‘0x03’ after Reset. 7 6 5 4 3 2 1 0 RST - - PB PPPoE - AI IND AC W0 W0 R=W R=W - 1 1 22 / 109 W5100S Datasheet Version1.0.0 Ex2) MR [RST] MR [RST] means RST Bit in MR. Ex3) MR [7:0] MR [7:0] means the Bits from 7th to 0th bit in MR. W5100S Datasheet Version1.0.0 23 / 109 3.1 Common Registers 3.1.1 MR (Mode Register) [RW][0x0000] [0x03] MR is used for Reset, PING Block and PPPoE Enable 7 6 5 4 3 2 1 0 RST - - PB PPPoE - - - Bit Symbol Description Reset 7 RST If this Bit is ‘1’, All W5100S Registers will be initialized. It will be automatically cleared as ‘0’ after 3 SYS_CLK [6:5] - Reserved PING Response Block 4 PB If this Bit is ‘1’, it blocks the Response to a ping request. 1 : Disable PING Response 0 : Enable PING Response PPPoE Enable 3 PPPoE 1 : Enable PPPoE 0 : Disable PPPoE [2:0] - Reserved 3.1.2 GWR (Gateway IP Address Register) [R=W] [0x0001-0x0004] [0x00] GWR configures the Gateway Address when NETLCKR (Network Lock Register) is on Unlock Mode. Ex) GWR = “192.168.0.1” GWR0(0x0001) GWR1(0x0002) GWR2(0x0003) GWR3(0x0004) 192 (0xC0) 168 (0xA8) 0 (0x00) 1 (0x01) 3.1.3 SUBR (Subnet Mask Register) [R=W] [0x0005–0x0008] [0x00] SUBR configures the Subnet Mask Address when NETLCKR (Network Lock Register) is on Unlock Mode. Ex) SUBR = “255.255.255.255” 24 / 109 W5100S Datasheet Version1.0.0 SUBR0(0x0005) SUBR0(0x0006) SUBR0(0x0007) SUBR0(0x0008) 255 (0xFF) 255 (0xFF) 255 (0xFF) 255 (0xFF) 3.1.4 SHAR (Source Hardware Address Register) [R=W] [0x0009-0x000E] [0x00] SHAR configures the Source MAC Address when NETLCKR (Network Lock Register) is on Unlock Mode. Ex) SHAR = “11:22:33:AA:BB:CC” SHAR0(0x0009) SHAR1(0x000A) SHAR2(0x000B) 0x11 0x22 0x33 SHAR3(0x000C) SHAR4(0x000D) SHAR5(0x000E) 0xAA 0xBB 0xCC 3.1.5 SIPR (Source IP Address Register) [R=W] [0x000F-0x0012] [0x00] SIPR configures the Source IP Address when NETLCKR (Network Lock Register) is on Unlock Mode. Ex) SIPR = “192.168.0.100” SIPR0(x000F) SIPR1(0x0010) SIPR2(0x0011) SIPR3(0x0012) 192 (0xC0) 168 (0xA8) 0 (0x00) 100(0x64) 3.1.6 INTPTMR (Interrupt Pending Time Register) [RW][0x0013-0x0014][0x0000] INTPTMR sets internal Interrupt Pending Timer Count. When INTn is de-asserted to High, Timer Count is initialized to INTPTMR and decreased by 1 from initial value to ‘0’ every SYS_CLK x 4. When Interrupt occurs and the corresponding Interrupt Mask is set and INTPTMR is ‘0’, INTn is asserted to Low. Ex) INTPTMR = 1000(0x03EB) INTPTMR0(0x0013) INTPTMR1(0x0014) 0x03 0xEB 3.1.7 IR (Interrupt Register) [RW] [0x0015] [0x00] When W5100S or SOCKET n Event occurs, the corresponding Bit in IR is set to ‘1’. If the Event occurs and the corresponded Interrupt Mask Bit in IMR is set to ‘1’ and internal Interrupt W5100S Datasheet Version1.0.0 25 / 109 Pending Timer Counter is ‘0’, INTn is asserted to Low. When the Event is cleared or the corresponding Mask Bit is set to ‘0’, INTn is de-asserted to High. 7 6 5 4 3 2 1 0 CONFLICT UNREACH PPPTERM - S3_INT S2_INT S1_INT S0_INT WC WC WC - AC AC AC AC Bit Symbol Description IP Conflict 7 CONFLICT Read 1 : IP Conflict Read 0 : Destination Port Unreachable When receiving the ICMP (Destination port unreachable) packet, this Bit is set as ‘1’. And Destination Information, IP Address and Port 6 UNREACH Number, is written on UIPR & UPORTR. Read 1 : Unreachable Packet receive Read 0 : PPPoE Terminated 5 PPPTERM Read 1 : Received PPPT or LCPT Packet only on PPPoE Read 0 : - 4 - Reserved SOCKET n Interrupt [3:0] Sn_INT Read 1 : Each n-th Bit describes SOCKET n-th Interrupt. Read 0 : When Sn_IR is 0x00, Sn_INT bit is Auto-Clear as ‘0’ 3.1.8 IMR (Interrupt Mask Register) [R=W] [0x0016] [0x00] IMR is used for the corresponding IR Bit Mask. 7 6 5 4 3 CNFT UNREACH PPPTERM - S3_INT R=W R=W R=W R=W Bit Symbol 2 1 0 S2_INT S1_INT S0_INT R=W R=W R=W Description IP Conflict Interrupt Mask 7 CNFT 1 : Enable IP Conflict Interrupt 0 : Disable IP Conflict Interrupt 6 26 / 109 UNREACH Destination Port Unreachable Interrupt Mask W5100S Datasheet Version1.0.0 1 : Enable Destination Port Unreachable Interrupt 0 : Disable Destination Port Unreachable Interrupt PADT/LCPT Interrupt Mask 5 PPPTERM 1 : Enable PADT/LCPT Interrupt 0 : Disable PADT/LCPT Interrupt 4 - Reserved SOCKET 3 Interrupt Mask 3 S3_INT 1 : Enable SOCKET 3 Interrupt 0 : Disable SOCKET 3 Interrupt SOCKET 2 Interrupt Mask 2 S2_INT 1 : Enable SOCKET 2 Interrupt 0 : Disable SOCKET 2 Interrupt SOCKET 1 Interrupt Mask 1 S1_INT 1 : Enable SOCKET 1 Interrupt 0 : Disable SOCKET 1 Interrupt SOCKET 0 Interrupt Mask 0 S0_INT 1 : Enable SOCKET 0 Interrupt 0 : Disable SOCKET 0 Interrupt 3.1.9 RTR (Retransmission Time Register) [R=W] [0x0017-0x0018] [0x07D0] RTR sets initial value of Sn_RTR (SOCKET n Retransmission Time Register). The unit is 100us. RTR and RCR (Retransmission Counter Register) set ARP & TCP Retransmission. (Ref 4.8 Retransmission) Ex) RTR = 5000 (0x1388) 5000*100us = 0.5s RTR0(0x0017) RTR1(0x0018) 0x13 0x88 3.1.10 RCR (Retransmission Count Register) [R=W] [0x0019] [0x08] RCR sets initial value of Sn_RCR (SOCKET n Retransmission Count Register). RTR and RCR set ARP & TCP Retransmission. (Ref 4.8 Retransmission) 3.1.11 RMSR (RX Memory Size Register) [R=W] [0x001A] [0x55] RMSR configures each SOCKET n RX Buffer Size. And the Sum of SOCKET n RX Buffer Size must not exceeded 8 Kbytes. (Ref Sn_RXBUF_SIZE (SOCKET n RX Buffer Size Register)) W5100S Datasheet Version1.0.0 27 / 109 7 6 5 SOCKET 3 S1 4 3 SOCKET 2 S0 S1 2 1 SOCKET 1 S0 S1 0 SOCKET 0 S0 S1 S0 Each SOCKET n RX Buffer Size is set by S0 and S1. Buffer Size S1 S0 1 KB 0 0 2 KB 0 1 4 KB 1 0 8 KB 1 1 3.1.12 TMSR (TX Memory Size Register) [R=W] [0x001B] [0x55] TMSR configures each SOCKET n TX Buffer Block Size. And the sum of SOCKET n TX Buffer Block Size must not be exceeded 8 Kbytes. (Ref Sn_TXBUF_SIZE (SOCKET n TX Buffer Size Register)) 7 6 5 SOCKET 3 S1 4 3 SOCKET 2 S0 S1 2 1 SOCKET 1 S0 S1 0 SOCKET 0 S0 S1 S0 Each SOCKET n TX Buffer Block Size is set by S0 and S1. Buffer Size S1 S0 1 KB 0 0 2 KB 0 1 4 KB 1 0 8 KB 1 1 3.1.13 IR2 (Interrupt Register 2) [RW] [0x0020] [0x00] When WOL Event occurs, IR2 [WOL] is set to ‘1’. If the Event occurs and IMR2 [WOL] is set to ‘1’ and internal Interrupt Pending Timer Counter is ‘0’, INTn is asserted to Low. When the Event is cleared or IMR2 [WOL] is set to ‘0’, INTn is de-asserted to High. 7 28 / 109 6 5 4 3 2 1 0 W5100S Datasheet Version1.0.0 - - - - - - - WOL - - - - - - - WC Bit Symbol [7:1] - Description Reserved WOL MAGIC Packet Interrupt 0 WOL 1 : Received UDP based WOL Magic Packet. 0:- 3.1.14 IMR2 (Interrupt Mask Register 2) [R=W] [0x0021] [0x00] IMR2 is used for the corresponding IR2 Bit Mask. 7 6 5 4 3 2 1 0 - - - - - - - WOL - - - - - - - R=W Bit Symbol [7:1] - Description Reserved WOL MAGIC Packet Interrupt Mask 0 WOL 1 : Enable WOL MAGIC Packet Interrupt 0 : Disable WOL MAGIC Packet Interrupt 3.1.15 PTIMER (PPP Link Control Protocol Request Timer Register) [R=W] [0x0028] [0x28] PTIMER configures the sending period for LCP Echo Request. The unit is 25ms. Ex) PTIMER = 200 (0xC8), 200 * 25ms = 5s 3.1.16 PMAGIC (PPP Link Control Protocol Magic number Register) [R=W] [0x0029] [0x00] PMAGIC configures 4 Bytes Magic Number for LCP Echo Request. Ex) PMAGIC = 0x01 PMAGIC(0x0029) W5100S Datasheet Version1.0.0 29 / 109 0x01 LCP Magic Number = 0x01010101 3.1.17 UIPR (Unreachable IP Address Register) [RO] [0x002A-0x002D] [0x0000] When W5100S received Unreachable Packet (IR [UNR] = ‘1’), Peer IP Address in the Packet is written on UIPR. Ex) UIPR = “192.169.0.21” UIPR0(0x002A) UIPR1(0x002B) UIPR2(0x002C) UIPR3(0x002D) 192(0xC0) 168(0xA8) 0(0x00) 21(0x15) 3.1.18 UPORTR (Unreachable Port Register) [RO] [0x002E-0x002F] [0x0000] When W5100S received Unreachable Packet (IR [UNR] = ‘1’), Peer PORT Number in the Packet is written on UPORTR. Ex) UPORTR = 3000 (0x0BB8) UPORTR0(0x002E) UPORTR1(0x002F) 0x0B 0xB8 3.1.19 MR2 (Mode Register 2) [R=W] [0x0030] [0x40] MR2 configures System Operation Clock (SYS_CLK), Interrupt Activation, TCP & UDP Scan Prevention, WOL (Wake On LAN) and Force ARP. 7 6 5 4 3 2 1 0 CLKSEL IEN NOTCPRST UDPURB WOL - FARP - R=W R=W R=W R=W R=W W0 R=W W0 Bit Symbol Description System Operation Clock(SYS_CLK) Select When CLKLCKR (Clock Lock Register) is Unlock, this bit can only set. 7 CLKSEL (Ref to 3.1.40 CLKLCKR (Clock Lock Register) [WO] [0x0070] [0x00]) 1 : 25MHz 30 / 109 W5100S Datasheet Version1.0.0 0 : Depends on PHYCR1[PWDN] SYS_CLK selected by PHCR1 configuration. PHYCR1[PWDN] SYS_CLK 0 100 MHz 1 25 MHz INTn Enable / Disable 6 IEN 1 : INTn Enable 0 : INTn Disable (INTn is Always High) TCP RST Packet Block If Peer transmits TCP Packet to a Port that does not exist on W5100S. W5100S automatically transmits RST Packet. But it could be the target for Port Scan Attack. 5 NOTCPRST But if this Bit is set as ‘1’, W5100S does not transmit RST Packet against Peer TCP Packet having wrong port. 1 : Block sending RST Packet 0 : Normal UDP Port Unreachable Packet Block If Peer transmits UDP Packet to a Port that does not exist on W5100S. W5100S automatically transmits ICMP Packet (Destination Port Unreachable) to Peer. But it could be the target for Port Scan Attack. 4 UDPURB But if this Bit is set as ‘1’, W5100S does not transmit ICMP Packet (Destination Port Unreachable). 1 : Block sending ICMP Packet (Destination Port Unreachable Message) 0 : Normal Wake On LAN This Bit decides receiving WOL Packet. 3 WOL 1 : Receive WOL 0 : No Receive WOL 2 - Reserved Force ARP UDP Mode SOCKET transmits ARP Request once before the first UDP Data Packet when it sends Data continuously to the same Peer. But if 1 FARP this Bit is set to ‘1’, it sends ARP Request for every UDP Data Packet. 1 : Transmit ARP Request for every UDP Data Packet 0 : Normal W5100S Datasheet Version1.0.0 31 / 109 0 - Reserved 3.1.20 PHAR (Destination Hardware Address Register on PPPoE) [R=W] [0x0032-0x0037] [0x0000] PHAR configures PPPoE Server Hardware Address only on PPPoE. Ex) PHAR = “11:22:33:AA:BB:CC” PHAR0(0x0032) PHAR1(0x0033) PHAR2(0x0034) 0x11 0x22 0x33 PHAR3(0x0035) PHAR4(0x0036) PHAR5(0x0037) 0xAA 0xBB 0xCC 3.1.21 PSIDR (Session ID Register on PPPoE) [R=W] [0x0038-0x0039] [0x0000] PSID configures PPPoE Sever Session ID on PPPoE. Ex) PSIDR = 0x1234 PSIDR0(0x0038) PSIDR1(0x0039) 0x12 0x34 3.1.22 PMRUR (PPPoE Maximum Receive Unit Register) [R=W] [0x003A-0x003B] [0xFFFF] PMRUR configures MRU (Maximum Receive Unit) on PPPoE and the value must not be exceeded 1472. If it is set bigger than 1472, it is configured 1472. And also PMRUR must be configured before SOCKET OPEN (Sn_CR [OPEN] = ’1’). Ex) PMUR = 1000 (0x03E8) PMUR0(0x0038) PMUR1(0x0039) 0x03 0xE8 3.1.23 PHYSR (PHY Status Register) [RO] [0x003C] [0x00] PHYSR indicates PHY Operation Mode and LINK status configured by PHYCR0 (PHY Control Register 0) 7 6 5 4 3 2 1 0 CABOFF - AUTO SPD DPX FDPX FSPD LINK RO RO RO RO RO RO RO 32 / 109 W5100S Datasheet Version1.0.0 Bit Symbol Description Cable OFF Bit 7 CABOFF 1 : Cable Unplugged 0 : Cable Plugged 6 - Reserved Auto Negotiation Bit configured by PHYCR0[2] 5 AUTO 1 : Disable Auto Negotiation 0 : Enable Auto Negotiation Speed Bit configured by PHYCR0[1] 4 SPD 1 : 10Mbps 0 : 100Mbps Duplex Bit configured by PHYCR0[0] 3 DPX 1 : Half Duplex 0 : Full Duplex Flag Duplex Bit (When Link up) 2 FDPX 1 : Half Duplex 0 : Full Duplex Flag Speed Bit (When Link up) 1 FSPD 1 : 10Mbps 0 : 100Mbps Flag Link Bit 0 LNK 1 : Link Up 0 : Link Down 3.1.24 PHYRAR (PHY Register Address Register) [R=W] [0x003F] [0x00] PHYRAR configures PHY Register Address of Internal Ethernet PHY. 7 6 5 4 3 2 1 0 - - - A4 A3 A2 A1 A0 R=W R=W R=W R=W R=W Bit Symbol Description 7 - Reserved 6 - Reserved 5 - Reserved [4:0] A[4:0] PHY Register Address W5100S Datasheet Version1.0.0 33 / 109 3.1.25 PHYDIR (PHY Data Input Register) [R=W] [0x0040-0x0041] [0x0000] PHTDIR writes PHY Register specified by PHYAR. Ex) PHYDIR = 0x1234 PHYDIR0(0x0040) PHYDIR1(0x0041) 0x34 0x12 3.1.26 PHYDOR (PHY Data Output Register) [RO] [0x0042-0x0043] [0x0000] PHYDOR reads the PHY Register specified by PHYAR Ex) PHYDOR = 0x1234 PHYDOR0(0x0042) PHYDPR1(0x0043) 0x34 0x12 3.1.27 PHYACR (PHY Access Control Register) [AC] [0x0044] [0x00] PHYACR configures Access Type of PHY Register specified by PHYAR Access Type Value Write 0x01 Read 0x02 3.1.28 PHYDIVR (PHY Division Register) [R=W] [0x0045] [0x01] Internal Ethernet PHY uses the divided Clock of System Operation Clock (SYS_CLK). And this divided Clock must not be exceeded 2.5MHz. Value Divider SYS_CLK=100MHz SYS_CLK=25MH 0x00 1/32 3.125MHz (N/A) 781.25KHz 0x01 1/64 1.5625MHz 390.625KHz others 1/128 781.25KHz 195.3125KHz 3.1.29 PHYCR0 (PHY Control Register 0) [WO] [0x0046] [0x00] PHYCR configures Ethernet PHY Operation Mode such as Auto Negotiation, Speed and Duplex. 34 / 109 W5100S Datasheet Version1.0.0 Before set PHYCR, PHYLCKR (PHY Lock Register) must be on Unlock Mode. 7 6 5 4 3 2 1 0 - - - - - AUTO SPD DPX WO WO WO Bit Symbol [7:3] - Description Reserved Auto Negotiation If AUTO is set to ‘1’, SPD and DPX are ignored. 2 AUTO 1 : Disable Auto Negotiation 0 : Enable Auto Negotiation 10/100 Speed When AUTO is ‘0’ , it can configures 10Mbps or 100Mbps 1 SPD 1 : 10 Mbps 0 : 100 Mbps Full/Half Duplex When AUTO is ‘0’ , it can configures Half Duplex or Full Duplex 0 DPX 1 : HDX 0 : FDX 3.1.30 PHYCR1 (PHY Control Register 1) [R=W] [0x0047] [0x41] PHYCR configures Ethernet PHY Operation Mode such as PHY Power Down Mode, PHY Reset. Before set PHYCR, PHYLCKR (PHY Lock Register) must be on Unlock Mode. 7 6 5 4 3 2 1 0 - - PWDN - - - - Reset W0 W0 R=W W0 W0 W0 W0 AC Bit Symbol [7:6] - Description Reserved PHY Power Down 5 PWDN 1 : Enable Power Down Mode and SYS_CLK switching 25MHz 0 : Disable Power Down Mode and SYS_CLK selected by MR2[CLKSEL] W5100S Datasheet Version1.0.0 35 / 109 MR2[CLKSEL] SYS_CLK 0 100 MHz 1 25 MHz (Ref 7.4.1 Reset Timing) [4:1] - Reserved PHY Reset When PHY Reset Bit is set to ‘0’, SYS_CLK is switched to 25MHz. After PHY Reset completed, this Bit is automatically cleared and SYS_CLK is 0 RST turn back to the previous clock. (Ref 7.4.1 Reset Timing) 1 : Normal 0 : PHY H/W Reset 3.1.31 SLCR (SOCKET-less Command Register) [RW] [0x004C] [0x00] SLCR configures ARP and PING Request Transmission Command. Each Command must not be executed at the same time and not configured before SLCR cleared. The results of each Command is shown via SLIR (SOCKET-less Interrupt Register) 7 6 5 4 3 2 1 0 - - - - - - ARP PING - - - - - - AC AC Bit Symbol [7:2] - Description Reserved ARP Request Transmission Command 1 ARP 1 :Transmit ARP packet 0 : Ready PING Request Transmission Command 0 PING 1: Transmit PING Request 0 : Ready 3.1.32 SLRTR (SOCKET-less Retransmission Time Register) [R=W] [0x004D-0x004E] [0x07D0] SLRTR sets SLCR Retransmission Time. The unit is 100us. If there is no Response for ARP or PING Request Packet transmitted by SLCR, W5100S automatically retransmits Request Packet every SLRTR. (Ref 4.8 Retransmission) 36 / 109 W5100S Datasheet Version1.0.0 Ex) SLRTR = 5000 (0x1388), 5000 * 100us = 0.5s SLRTR0(0x004D) SLRTR1(0x004E) 0x013 0x88 3.1.33 SLRCR (SOCKET-less Retransmission Count Register) [R=W] [0x004F] [0x00] SLRCR sets SLCR Retransmission Number. If the number of Retransmission exceeds SLRCR, SOCKET-less Timeout (SLIR [TIMEOUT] = ‘1’) occurs. (Ref 4.8 Retransmission) 3.1.34 SLPIPR (SOCKET-less Peer IP Address Register) [R=W] [0x0050-0x0053] [0x00000000] SLPIPR configures Peer IP Address for ARP or Ping Request Packet transmitted by SLCR. Ex) SLPIPR = “192.169.0.21” SLPIPR0(0x0050) SLPIPR1(0x0051) SLPIPR2(0x0052) SLPIPR3(0x0053) 192(0xC0) 168(0xA8) 0(0x00) 21(0x15) 3.1.35 SLPHAR (SOCKET-less Peer Hardware Address Register) [RO] [0x0054-0x0059] [0x000000000000] If W5100S received ARP Reply against SLCR [ARP] and SLIPR [ARP] is set to ‘1’, Peer Hardware Address from ARP Reply is written on SLPHAR. Ex) SLPHAR = “11:22:33:AA:BB:CC” SLPHAR0(0x0054) SLPHAR1(0x0055) SLPHAR2(0x0056) 0x11 0x22 0x33 SLPHAR3(0x0057) SLPHAR4(0x0058) SLPHAR5(0x0059) 0xAA 0xBB 0xCC 3.1.36 PINGSEQR (PING Sequence-number Register) [R=W] [0x005A-0x005B] [0x0000] PINGSEQR configures Sequence Number for PING Request Packet and it is not automatically increased. Ex) PINGSEQR = 1000 (0x03E8) PINGSEQR0(0x005A) PINGSEQR1(0x005B) 0x03 0xE8 W5100S Datasheet Version1.0.0 37 / 109 3.1.37 PINGIDR (PING ID Register) [R=W] [0x005C-0x005D] [0x0000] PINGIDR configures ID for PING Request Packet. Ex) PINGIDR = 256 (0x0100) PINGIDR0(0x005C) PINGIDR1(0x005D) 0x01 0x00 3.1.38 SLIMR (SOCKET-less Interrupt Mask Register) [R=W] [0x005E] [0x00] SLIMR is used for corresponding SLIR (SOCKET-less Interrupt Register) Bit Mask. 7 6 5 4 3 2 1 0 - - - - - TIMEOUT ARP PING - - - - - R=W R=W R=W Bit Symbol [7:3] - Description Reserved TIMEOUT Interrupt Mask 2 TIMEOUT 1 : Enable TIMEOUT Interrupt 0 : Disable TIMEOUT Interrupt ARP Interrupt Mask 1 ARP 1 : Enable ARP Interrupt 0 : Disable ARP Interrupt PING Interrupt Mask 0 PING 1 : Enable PING Interrupt 0 : Disable PING Interrupt 3.1.39 SLIR (SOCKET-less Interrupt Register) [RW] [0x005F] [0x00] When SOCKET-less Event occurs, the corresponding Bit in SLIR is set to ‘1’. If the Event occurs and the corresponded Interrupt Mask Bit in SLIMR is set to ‘1’ and internal Interrupt Pending Timer Counter is ‘0’, INTn is asserted to Low. When the Event is cleared or the corresponding Mask Bit is set to ‘0’, INTn is de-asserted to High. 7 6 5 4 3 2 1 0 - - - - - TIMEOUT ARP PING - - - - - WC WC WC 38 / 109 W5100S Datasheet Version1.0.0 Bit Symbol [7:3] - 2 TIMEOUT 1 ARP 0 PING Description Reserved TIMEOUT Interrupt When TIMEOUT occurs, this Bit is set to ‘1’. ARP Interrupt When ARP Reply received, this Bit is set to ‘1’. PING Interrupt When PING Reply received, this Bit is set to ‘1’. 3.1.40 CLKLCKR (Clock Lock Register) [WO] [0x0070] [0x00] CLKLCKR status must be Unlock to set MR2 [CLKSEL]. Before HOST changes CLKLCKR status, CLKLCKR has the previous status. Unlock Lock 0xCE Others 3.1.41 NETLCKR (Network Lock Register) [WO] [0x0071] [0x00] NETLCKR status must be Unlock to set GWR, SUBR, SHAR and SIPR. Before HOST changes NETLCKR status, LETLCKR has the previous status. Unlock Lock 0xC5 0x3A 3.1.42 PHYLCKR (PHY Lock Register) [WO] [0x0072] [0x00] PHYLCKR status must be Unlock to set PHYCR0 and PHYCR1. Before HOST changes PHYLCKR status, PHYLCKR has the previous status. Unlock Lock 0x53 Others 3.1.43 VERR (Version Register) - [RO] [0x0080] [0x51] VERR shows W5100S Version. 3.1.44 TCNTR (Ticker Counter Register) [RO][0x0082-0x0083][0x0000] W5100S Datasheet Version1.0.0 39 / 109 TCNTR is W5100S Internal Counter, it has automatically increased since SYS_CLK operating. The unit is 100us. 3.1.45 TCNTCLR (Ticker Counter Clear Register) [WO][0x0088][0x00] With TCNTCLR Write Access, TCNTR Counter value is initialized. 40 / 109 W5100S Datasheet Version1.0.0 3.2 SOCKET Register 3.2.1 Sn_MR (SOCKET n Mode Register) [R=W] [0x0000+0x0100*(n+4)] [0x00] Sn_MR configures SOCKET Mode and Option. Sn_MR must be set before SOCKET OPEN (Sn_CR [OPEN] = ‘1’). 7 6 5 4 3 2 1 0 MULTI MF ND / MC - P3 P2 P1 P0 R=W R=W R=W - R=W R=W R=W R=W Bit Symbol Description UDP Multicast This Bit is valid only on UDP Mode. (Ref 4.4.3 UDP Multicast) 7 MULTI 1 : Enable UDP Multicast 0 : Disable UDP Multicast MAC Filter Enable This Bit is valid only on MACRAW Mode. If This Bit is set to ‘1’, W5100S block all Packets without Multicast, 6 MF Broadcast and the Packets no having Source MAC (SHAR). 1 : Enable MAC Filter. 0 : Disable MAC Filter No Delayed ACK (ND) This Bit is valid only on TCP Mode. If this Bit is set to ‘1’, TCP Mode SOCKET transmits ACK Packet without waiting RTR after receiving Data Packet from Peer. 1 : Enable No Delayed ACK 0 : Disable No Delayed ACK 5 ND / MC Ref) After Sn_CR[RECV] Command operating, If TCP Mode SOCKET Window Size is smaller than MSS, it sends ACK packet immediately. (no concerned with ND Bit) Multicast IGMP Version (MC) This Bit is valid only on UDP Multicast Mode (Sn_MR[3:0] = ‘UDP’ & Sn_MR[MULTI] = ‘1’) W5100S Datasheet Version1.0.0 41 / 109 0 : Using IGMP version 2 1 : Using IGMP version 1 4 - Reserved Protocol Mode This Bits set SOCKET Protocol Mode. MACRAW Mode is used only with SOCKET 0. [3:0] P[3:0] P3 P2 P1 P0 Protocol Mode 0 0 0 0 SOCKET Closed 0 0 0 1 TCP 0 0 1 0 UDP 0 0 1 1 IPRAW 0 1 0 0 MACRAW 3.2.2 Sn_CR (SOCKET n Command Register) [RW][AC] [0x0001+0x0100*(n+4)] [0x00] Sn_CR configures SOCKET n Command. After W5100S executes SOCKET Command, the corresponding Sn_CR Bit is automatically cleared. Next SOCKET Command must be configured after previous SOCKET Command Bit cleared. Value Symbol Description SOCKET OPEN Command Before OPEN Command, HOST must be set SOCKET Mode with Sn_MR. After OPEN Command done, Sn_SR shows SOCKET Status. 0x01 OPEN Sn_MR (P[3:0]) Sn_MR_CLOSE (‘0000’) Sn_SR SOCK_CLOSED (0x00) Sn_MR_TCP (‘0001’) SOCK_INIT (0x13) Sn_MR_UDP (‘0010’) SOCK_UDP (0x22) Sn_MR_IPRAW (‘0011’) S0_MR_MACRAW (‘0100’) SOCK_IPRAW (0x32) SOCK_MACRAW (0x42) TCP LISTEN Command 0x02 LISTEN After LISTEN Command, TCP Mode SOCKET waits for SYN Packet from Peer for TCP Connection in SOCK_INIT (Sn_SR = ‘0x13’). (Ref 4.3.1 TCP Server) TCP CONNECT Command 0x04 CONNECT After CONNECT Command, TCP Mode SOCKET transmits SYN Packet to Peer for TCP Connection in SOCK_INIT (Sn_SR = ‘0x13’). 42 / 109 W5100S Datasheet Version1.0.0 (Ref 4.3.2 TCP Client) TCP DISCON Command 0x08 DISCON After DISCON Command, TCP Mode SOCKET transmits FIN Packet to Peer for TCP Disconnection in SOCK_ESTABLESHED (Sn_SR = ‘0x17’) or SOCK_CLOSE_WAIT (Sn_SR = ‘0x1C’). SOCKET CLOSE Command 0x10 CLOSE After CLOSE Command, SOCKET is closed (Sn_SR = ‘0x00’). *Caution : Sn_SR is changed to SOCK_CLOSE without FIN Packet sending in TCP Mode SOCKET SEND Command After SEND Command, SOCKET sends Data as much as the calculated size between Sn_TX_WR (SOCKET n TX Write Point Register) and Sn_TX_RD (SOCKET n RX Read Pointer Register). The Sent Data must not be exceeded Sn_RX_FSR (SOCKET n TX Free Buffer Size Register). HOST must execute next SEND Command after Sn_IR [SENDOK] is set to ‘1’. On TCP and UDP Mode, if the calculated size is over MSS (Maximum Segment Size), Data is separated by MSS and sent. 0x20 SEND On the other hands, on IPRAW and MACRAW Mode, if Data is over MSS, HOST must separate it by less than MSS. On TCP Mode, if Peer receives Data (It means TCP Mode SOCKET receives ACK Packet from Peer), Sn_RX_FSR is automatically increased by sent Data Size. But if not, Sn_IR [TIMEOUT] is set to ‘1’ and Sn_SR is changed to SOCK_CLOSED. On UDP, IPRAW and MACRAW Mode, Sn_TX_FSR is increased by sent Data Size after Sn_IR [SENDOK] is set to ‘1’. SOCKET SEND_MAC Command SEND_MAC Command is used only on UDP and IPRAW Mode. Only the 0x21 SEND_MAC different with SEND Command is that it skips ARP Process. Before using SEND_MAC Command, HOST must set Sn_DHAR (SOCKET n Destination Hardware Address Register) with Peer MAC Address. SOCKET SEND_KEEP Command SEND_KEEP Command is used only on TCP Mode. Before using SEND_KEEP 0x22 SEND_KEEP Command, TCP Mode SOCKET must send more than 1 byte Data to Peer. After SEND_KEEP Command, TCP Mode SOCKET continues to send Keep alive (KA) Packet and check the TCP connection. If there is no Peer W5100S Datasheet Version1.0.0 43 / 109 response, KA Packet is retransmitted. After Retransmission Time, Sn_IR [TIMEOUT] is set to ‘1’ and Sn_SR is changed to SOCK_CLOSED. (Ref 4.3.3.2 Keep AliveKeep ) SOCKET RECV Command After reading received Data from SOCKET n RX Buffer Block, HOST updates Sn_RX_RD (SOCKET n Read Pointer Register) with RECV Command. 0x40 RECV (Ref 오류! 참조 원본을 찾을 수 없습니다. 오류! 참조 원본을 찾을 수 없습니다., 3.2.19 Sn_RX_RD (SOCKET n RX Read Pointer Register) and 오류! 참조 원본을 찾을 수 없습니다. 오류! 참조 원본을 찾을 수 없습니다.) 3.2.3 Sn_IR (SOCKET n Interrupt Register) [RW] [0x0002+0x0100*(n+4)] [0x00] When Sn_IR Event occurs, the corresponding Interrupt Bit is set to ‘1’. 7 6 5 4 3 2 1 0 - - - SENDOK TIMEOUT RECV DISCON CON WC WC WC WC WC Bit Symbol [7:5] - Description Reserved SEND OK Interrupt 4 SENDOK 1 : When SEND Command is completed 0 : When others TIMEOUT Interrupt 3 TIMEOUT 1 : When the number of retransmission is exceeded Sn_RCR (SOCKET Retransmission Count Register) in ARP or TCP communication. 0 : When others RECEIVED Interrupt 2 RECV 1 : When SOCKET received Data or Data still remained in SOCKET n RX Buffer Block after Sn_CR [RECV] 0 : When others DISCONNECTED Interrupt 1 DISCON 1: When FIN Packet sent and disconnection completed, or When FIN Packet received or RST Packet received. 0 : When others 0 44 / 109 CON CONNECTED Interrupt W5100S Datasheet Version1.0.0 1 : When TCP Connection is successfully done. (Sn_MR [3:0]=’TCP) 0 : When others 3.2.4 Sn_SR (SOCKET n Status Register) [RO] [0x0003+0x0100*(n+4)] [0x00] Sn_SR describes the Status of SOCKET. Sn_SR is set by Sn_CR or Data transmit/receive. Value Symbol Description 0x00 SOCK_CLOSED 0x13 SOCK_INIT 0x14 SOCK_LISTEN 0x17 SOCK_ESTABLISHED SOCKET is TCP Mode and TCP Connection is done 0x1C SOCK_CLOSE_WAIT SOCKET is TCP Mode and received disconnection request 0x22 SOCK_UDP 0x32 SOCK_IPRAW 0x42 SOCK_MACRAW SOCKET Closed SOCKET Opened as TCP Mode SOCKET is TCP Mode and wait for Peer Connection SOCKET Opened as UDP Mode SOCKET Opened as IPRAW Mode SOCKET Opened as MACRAW Mode The below table shows a temporary status indicated during changing the status of SOCKET n. Value Symbol 0x15 SOCK_SYNSENT SOCKET n sent the Connect request 0x16 SOCK_SYNRECV SOCKET n received the Connect request 0x18 SOCK_FIN_WAIT 0X1B SOCK_TIME_WAIT 0X1D SOCK_LAST_ACK W5100S Datasheet Version1.0.0 Description SOCKET n is in SOCKET Closed 45 / 109 SNED/SEND_MAC/RECV SOCK_IPRAW : Status (when Sn_MR[3:0]='IPRAW') SEND/SEND_MAC/RECV : Command : SEND/RECV packet or Timeout OPEN CLOSE OPEN SOCK_UDP (when Sn_MR[3:0]='UDP') CLOSE SOCK_CLOSED CLOSE SOCK_MACRAW OPEN (START/END) (when Sn_MR[3:0]='MACRAW') RECV ACK OPEN CLOSE SOCK_INIT CLOSE SOCK_LAST_ACK (when Sn_MR[3:0]='TCP') LISTEN SOCK_LISTEN SEND SYN/ACK RECV ACK RECV FIN or Timeout CONNECT Timeout SOCK_SYNSENT RECV SYN SOCK_SYNRECV SEND/RECV Timeout RECV SYN/ACK SEND ACK CLOSE DISCON SOCK_FIN_WAIT SOCK_TIME_WAIT Timeout CLOSE SOCK_CLOSE_WAIT DISCON SOCK_ESTABLISHED SEND/RECV RECV FIN SEND/RECV Figure 4 State Diagram 3.2.5 Sn_PORTR (SOCKET n Source Port Register) [R=W] [0x0004+0x0100*(n+4), 0x0005+0x0100*(n+4)] [0x0000] Sn_PORTR configures Source Port Number of SOCKET n. Ex) S0_PORTR = 5000 (0x1388) S0_PORTR0(0x0404) S0_PORTR1(0x0405) 0x013 0x88 3.2.6 Sn_DHAR (SOCKET n Destination Hardware Address Register) [RW] [0x0006+0x0100*(n+4), 0x0007+0x0100*(n+4), 0x0008+0x0100*(n+4), 0x0009+0x0100*(n+4), 0x000A+0x0100*(n+4), 0x000B+0x0100*(n+4)] [0x000000000000] Peer MAC Address in Peer Packet is written on Sn_DHAR. On TCP Mode, Sn_DHAR is valid after CONNECT Command. On UDP and IPRAW Mode, Sn_DHAR is valid after SEND Command. If HOST uses SEND_MAC Command, Sn_DHAR must be set with Peer MAC Address before Command. On UDP Multicast Mode, Sn_DHAR must be configured with Multicast Group MAC 46 / 109 W5100S Datasheet Version1.0.0 Address. (Ref 4.4.3 UDP Multicast) Ex) S0_DHAR = “11:22:33:AA:BB:CC” S0_DHAR0(0x0406) S0_DHAR1(0x0407) S0_DHAR2(0x0408) 0x11 0x22 0x33 S0_DHAR3(0x0409) S0_DHAR4(0x040A) S0_DHAR5(0x040B) 0xAA 0xBB 0xCC 3.2.7 Sn_DIPR (SOCKET n Destination IP Address Register) [RW] [0x000C+0x0100*(n+4), 0x000D+0x0100*(n+4), 0x000E+0x0100*(n+4), 0x000F+0x0100*(n+4)] [0x00000000] Sn_DIPR is set with Peer IP Address. On TCP Mode, Sn_DIPR must be set with Peer IP Address before Connection, or indicates IP Address of connected Peer. On UDP and IPRAW Mode, Sn_DIPR must be set with Peer IP Address before sending Data. On UDP Multicast Mode, Sn_DIPR must be configured with Multicast Group IP Address. (Ref 4.4.3 UDP Multicast) On UDP, UDP Multicast and IPRAW Mode, Peer IP Address is stored with Data in SOCKET n RX Buffer. Ex) S0_DIPR = “192.168.0.11” S0_DIPR0(0x040C) S0_DIPR1(0x040D) S0_DIPR2(0x040E) S0_DIPR3(0x040F) 192 (0xC0) 168 (0xA8) 0 (0x00) 11 (0x0B) 3.2.8 Sn_DPORTR (SOCKET n Destination Port Register) [R=W] [0x0010+0x0100*(n+4), 0x0011+0x0100*(n+4)] [0x0000] Sn_DPORTR is set with Peer Port Number. On TCP Mode, Sn_DPORTR must be set with Peer Port Number before Connection, or indicates Port Number of connected Peer. On UDP and IPRAW Mode, Sn_DPORTR must be set with Peer Port Number before sending Data. On UDP Multicast Mode, Sn_DPORTR must be configured with Multicast Group Port Number. (Ref 4.4.3 UDP Multicast) On UDP, UDP Multicast and IPRAW Mode, Peer Port Number is stored with Data in SOCKET n RX Buffer. Ex) S0_DPORTR = 5000 (0x1388), S0_DPORTR0(0x0410) S0_DPORTR1(0x0411) 0x13 0x88 3.2.9 Sn_MSS (SOCKET n Maximum Segment Size Register) [R=W] [0x0012+0x0100*(n+4), 0x0013+0x0100*(n+4] [0xFFFF] W5100S Datasheet Version1.0.0 47 / 109 Sn_MSS sets SOCKET n MSS and it must be set before Sn_CR [OPEN]. Sn_MSS must not be exceeded specified size as below table. Mode Normal (MR [PPPoE]=’0’) Range PPPoE (MR [PPPoE]=’1’) Range TCP 1~1460 1~1452 UDP 1~1472 1~1464 IPRAW 1480 1472 MACRAW 1514 Ex) S0_MSS = 1460 (0x05B4), S0_MSS0(0x0412) S0_MSS1(0x0413) 0x05 0xB4 3.2.10 Sn_PROTOR (SOCKET n IP Protocol Register) [R=W] [0x0014+0x0100*(n+4)] [0x0000] Sn_PROTOR configures Protocol Number (Ref IANA_Protocol Number) of IP Header except for TCP (0x06), UDP (0x11) and IGMP (0x01). On IPRAW Mode, only the Protocol configured in Sn_PROTR can be transmitted and received. Ex) ICMP (Internet Control Message Protocol) = 0x01 3.2.11 Sn_TOS (SOCKET n IP Type Of Service Register) [R=W] [0x0015+0x0100*(n+4)] [0x00] Sn_TOS configures the TOS (Type Of Service) of IP Header. (Ref IANA_IP Parameters) 3.2.12 Sn_TTL (SOCKET n IP Time To Live Register) [R=W] [0x0016+0x0100*(n+4)] [0x80] Sn_TTL configures TTL (Time To Live) of IP header. (Ref IANA_IP Parameters) 3.2.13 Sn_RXBUF_SIZE (SOCKET n RX Buffer Size Register) [RW] [0x001E+0x0100*(n+4)] [0x02] Sn_RXBUF_SIZE configures SOCKET n RX Buffer Size as 0, 1, 2, 4 and 8 Kbytes. RX Memory is sequentially allocated from SOCKET 0 to SOCKET 3. The total sum of Sn_RXBUF_SIZE must not be exceeded 8 Kbytes. Sn_RXBUF_SIZE can also be configured by RMSR. Value (Dec) 0 1 2 4 8 Buffer size 0KB 1KB 2KB 4KB 8KB Ex) S0_RXBUF_SIZE = 8KB 48 / 109 W5100S Datasheet Version1.0.0 S0_RXBUF_SIZE(0x041E) 0x08 3.2.14 Sn_TXBUF_SIZE (SOCKET n TX Buffer Size Register) [RW] [0x001F+0x0100*(n+4)] [0x02] Sn_TXBUF_SIZE configures SOCKET n TX Buffer Size as 0, 1, 2, 4 and 8 Kbytes. TX Memory is sequentially allocated from SOCKET 0 to SOCKET 3. The total sum of Sn_TXBUF_SIZE must not be exceeded 8 Kbytes. Sn_TXBUF_SIZE can also be configured by RMSR. Value (Dec) 0 1 2 4 8 Buffer size 0KB 1KB 2KB 4KB 8KB Ex) S0_TXBUF_SIZE= 4KB S0_TXBUF_SIZE(0x041F) 0x04 3.2.15 Sn_TX_FSR (SOCKET n TX Free Size Register) [RO] [0x0020+0x0100*(n+4), 0x0021+0x0100*(n+4)] [0x0800] Sn_TX_FSR indicates SOCKET n TX Free Buffer Size. In UDP, IPRAW and MACRAW mode, Sn_TX_FSR = | Sn_TX_WR(1) – Sn_TX_RD(2) | + 1 In TCP mode, Sn_TX_FSR = | Sn_TX_WR – Internal Pointer(3) | + 1 (1) SOCKET n TX Write Pointer Register (2) SOCKET n TX Read Pointer Register (3) TCP ACK Pointer managed by W5100S Data to be stored in SOCKET n TX Buffer must not be bigger than Sn_TX_FSR. Ex) S0_TX_FSR = 1024 (0x0400) S0_TX_FSR0(0x0420) S0_TX_FSR1(0x0421) 0x04 0x00 3.2.16 Sn_TX_RD (SOCKET n TX Read Pointer Register) [RO] [0x0022+0x0100*(n+4), 0x0023+0x0100*(n+4)] [0x0000] Sn_TX_RD indicates the last Data Address in SOCKET n TX Buffer Block after transmitting. Sn_TX_RD is initialized by Sn_CR [OPEN]. On TCP Mode, Sn_TX_RD is re-configured in TCP Connection Process. By Sn_CR [SEND] and Sn_CR [SEND_MAC], Sn_TX_WR (SOCKET n TX Write W5100S Datasheet Version1.0.0 49 / 109 Pointer Register) is increased to Data Size. After transmitting Data, Sn_TX_RD increases by Sn_TX_WR and Sn_IR [SENDOK] occurs. Ex) S0_TX_RD = 0xd4b3 S0_TX_RD0(0x0422) S0_TX_RD1(0x0423) 0xd4 0xb3 3.2.17 Sn_TX_WR (SOCKET n TX Write Pointer Register) [RW] [0x0024+0x0100*(n+4), 0x0025+0x0100*(n+4)] [0x0000] Sn_TX_WR indicates the last stored Data Address in SOCKET n TX Buffer Block. Sn_TX_RD is initialized by Sn_CR [OPEN]. On TCP Mode, Sn_TX_RD is re-configured in TCP Connection Process. Before Sn_CR [SEND] and Sn_CR [SEND_MAC], Sn_TX_WR must be set as transmitting Data Size. Ex) S0_TX_WR = 0x0800 S0_TX_WR0(0x0424) S0_TX_WR1(0x0425) 0x08 0x00 3.2.18 Sn_RX_RSR (SOCKET n RX Received Size Register) [RO] [0x0026+0x0100*(n+4), 0x0027+0x0100*(n+4)] [0x0000] Sn_RX_RSR indicates received Data Size in SOCKET n RX Buffer Block. In TCP, UDP, IPRAW and MACRAW mode, Sn_RX_RSR = | Sn_RX_WR(1) – Sn_RX_RD(2) | (1) SOCKET n RX Write Pointer Register (2) SOCKET n RX Read Pointer Register Ex) S0_RX_RSR = 2048 (0x0800) S0_RX_RSR0(0x0426) S0_RX_RSR1(0x0427) 0x08 0x00 3.2.19 Sn_RX_RD (SOCKET n RX Read Pointer Register) [RW] [0x0028+0x0100*(n+4), 0x0029+0x0100*(n+4)] [0x0000] Sn_RX_RD is the last Data Address read by HOST in SOCKET n RX Buffer Block. HOST is available to read Data from Sn_RX_RD to Sn_RX_WR in SOCKET n RX Buffer Block. After setting Sn_RX_RD as much as Data read, HOST must set Sn_CR [RECV] to update Sn_RX_RD. Ex) S0_RX_RD =1536(0x0600) S0_RX_RD0(0x0428) 50 / 109 S0_RX_RD1(0x0429) W5100S Datasheet Version1.0.0 0x06 0x00 3.2.20 Sn_RX_WR (SOCKET n RX Write Pointer Register) [RO] [0x002A+0x0100*(n+4), 0x002B+0x0100*(n+4)] [0x0000] Sn_RX_WR is the last received Data Address in SOCKET n RX Buffer Block. If received Data is smaller than Sn_RX_RSR, it is stored in SOCKET n RX Buffer Block and Sn_RX_WR increases by stored Data Size. Ex) S0_RX_WR = 1536(0x0600) S0_RW_WR0(0x042A) S0_RW_WR1(0x042B) 0x06 0x00 3.2.21 Sn_IMR (SOCKET n Interrupt Mask Register) [R=W] [0x002C+0x0100*(n+4)] [0xFF] Sn_IMR is used for the corresponding Sn_IR Bit Mask. 7 6 5 4 3 2 1 0 - - - SENDOK TIMEOUT RECV DISCON CON - - - R=W R=W R=W R=W R=W Bit Symbol Description [7:5] - 4 SENDOK Sn_IR[SENDOK] Interrupt Mask 3 TIMEOUT Sn_IR[TIMEOUT] Interrupt Mask 2 RECV 1 DISCON 0 CON Reserved Sn_IR[RECV] Interrupt Mask Sn_IR[DISCON] Interrupt Mask Sn_IR[CON] Interrupt Mask 3.2.22 Sn_FRAGR (SOCKET n Fragment Offset in IP Header Register) [R=W] [0x002D+0x0100*(n+4), 0x002E+0x0100*(n+4)] [0x4000] Sn_FRAGR configures Fragment Offset in IP Header. Ex) S0_FRAG0 = 0x0000 (Don’t Fragment) S0_FRAGR0(0x042D) S0_FRAGR1(0x042E) 0x00 0x00 3.2.23 Sn_MR2 (SOCKET n Mode register 2) [R=W] [0x002F+0x0100*(n+4)] [0x00] W5100S Datasheet Version1.0.0 51 / 109 Sn_MR2 configures SOCKET n Option. Sn_MR2 must be set before Sn_CR[OPEN] = ‘1’. 7 6 5 4 3 2 1 0 - MBBLK MMBLK IPV6BLK - - BRDB UNIB - R=W R=W R=W - - R=W R=W Bit Symbol 7 - Description Reserved Broadcast Blocking on MACRAW Mode On MACRAW Mode, this Bit is set to ‘1’ to block Broadcast Packet. 6 MBBLK 0 : Disable Broadcast Blocking 1 : Enable Broadcast Blocking Multicast Blocking on MACRAW Mode On MACRAW Mode, this Bit is set to ‘1’ to block Multicast Packet. 5 MMBLK 0 : Disable Multicast Blocking 1 : Enable Multicast Blocking IPv6 Packet Blocking on MACRAW Mode On MACRAW Mode, this Bit is set ‘1’ to block IPv6 Packet. 4 IPV6BLK 0 : Disable IPv6 Blocking 1 : Enable IPv6 Blocking [3:2] - Reserved Broadcast Blocking on UDP Mode/ Force PSH on TCP Mode *Broadcast Blocking on UDP Mode On UDP Mode, this Bit is set ‘1’ to block UDP Broadcast Packet. 0 : Disable Broadcast Blocking 1 : Enable Broadcast Blocking 1 BRDB * Force PSH on TCP Mode On TCP Mode, this Bit is set to ‘1’ to set PSH Flag in all transmitting Data Packet. 1: Force PSH Flag 0: No Force PSH Flag 0 52 / 109 UNIB Unicast Blocking on UDP Multicast Mode W5100S Datasheet Version1.0.0 On UDP Multicast Mode, this Bit is set to ‘1’ to block UDP Unicast Packet. 0 : Disable Unicast Blocking 1 : Enable Unicast Blocking 3.2.24 Sn_KPALVTR (SOCKET n Keep Alive Timer Register) [RO] [0x0030+0x0100*(n+4)] [0x00] Sn_KPALVTR sets ‘Keep Alive (KA)’ Packet transmission time. The unit is 5 sec. TCP Mode SOCKET transmits KA Packet every Sn_KPALVTR. Before transmitting KA Packet, SOCKET must transmit Data (over 1 Byte) Packet at least once. By Sn_CR [SENDKEEP], KA Packet is transmitted without Sn_KPALVTR setting. Ex) S0_KPALVTR = 10 (0x0A), 10 * 5s = 50s S0_KPALVRT(0x0430) 0x0A 3.2.25 Sn_RTR (SOCKET n Retransmission Time Register) [R=W] [0x0032+0x0100*(n+4), 0x0033+0x0100*(n+4)] [0x0000] Sn_RTR sets SOCKET n Retransmission Time. If Sn_RTR is zero, SOCKET n Retransmission Time is set by RTR. (Ref 4.8 Retransmission) Ex) S0_RTR = 5000 (0x1388), 5000 * 100us = 0.5s S0_RTR0(x0432) S0_RTR1(0x0433) 0x013 0x88 3.2.26 Sn_RCR (SOCKET n Retransmission Count Register) [R=W] [0x0034+0x0100*(n+4)] [0x00] Sn_RCR sets SOCKET n Retransmission Counter. If Sn_RCR is zero, SOCKET n Retransmission Counter is set by RCR. (Ref 4.8 Retransmission) W5100S Datasheet Version1.0.0 53 / 109 4 Functional Description W5100S provides Internet Connectivity with simple register control. In this chapter, the Initialization of W5100S, Data Communication method according to each TCP, UDP, IPRAW, MACRAW Mode and the additional functions are described step by step based on the pseudo code. 4.1 W5100S RESET  Set Hardware before Reset. (Ref 7.4.1 Reset Timing)  Set HOST Interface Mode with MOD [3:0] pin.  Supply the Reset signal longer than 500ns on RSTn pin for Hardware Reset.  Wait for TSTA (Ref 7.4.1 Reset Timing) 4.2 Initialization The Network Information and SOCKET n TX / RX buffer are set in the W5100S Initialization Process. 4.2.1 Basic Setting To operate the W5100S properly, set the following Registers according to User’s Application.  Mode Register (MR)  Interrupt Mask Register (IMR)  Retransmission Time Register (RTR)  Retransmission Count Register (RCR) More Information for the above registers can be found in each Register Descriptions. 4.2.2 Network Information Setting Set the basic Network Information for Internet Communication. NETWORK SETTING: { /* W5100S MAC Address, 11:22:33:AA:BB:CC */ SHAR[0:5] = { 0x11, 0x22, 0x33, 0xAA, 0xBB, 0xCC }; /* W5100S Gateway IP address, 192.168.0.1 */ GAR[0:3] = { 0xC0, 0xA8, 0x00, 0x01 }; 54 / 109 W5100S Datasheet Version1.0.0 /* W5100S Subnet MASK Address, 255.255.255.0 */ SUBR[0:3] = { 0xFF, 0xFF,, 0xFF, 0x00}; /* W5100S IP Address, 192.168.0.100 */ SIPR[0:3] = {0xC0, 0xA8,0x00, 0x64}; } 4.2.3 SOCKET TX/RX Buffer Setting Determine SOCKET n TX/RX Buffer Size using TMSR/RMSR or Sn_TXBUF_SIZE/Sn_RXBUF_SIZE. SOCKET n TX / RX Buffer is a RING-Buffer structure. So, calculation of the base address and MASK value for SOCKET n TX / RX Buffer control must be required. Please make sure that the Sum of SOCKET n TX / RX Buffer Size must not be exceed 8 KB. The pseudo-code for setting the SOCKET n TX/RX Buffer is described below. In case of, assign 2KB TX/RX memory per SOCKET { // set Base Address of TX/RX Memory for SOCKET n gS0_RX_BASE = 0x8000; // TX Memory Block Base Address gS0_RX_BASE = 0xC000; // RX Memory Block Base Address TxTotalSize = 0; // For check the total size of SOCKET n TX Buffer RxTotalSize = 0; // For check the total size of SOCKET n RX Buffer for (n=0; n 8 or RxTotalSize > 8 ) goto ERROR; // invalid Total Size } // end for } W5100S Datasheet Version1.0.0 55 / 109 4.3 TCP TCP (Transmission Control Protocol) is a bidirectional Data Transmission Protocol based on a 1:1 communication on Transport Layer. It also provides Communication between Applications by using Port Number. TCP 1:1 communication needs the Connection Process such as transmitting Connection Request to Peer or receiving Connection Request from Peer. In this Connection Process, the side transmitting Connection Request is ‘TCP CLIENT’ and the other side receiving Connection Request is ‘TCP SERVER’. TCP also provides reliable, ordered and error-checked delivery of a stream Data between applications running on hosts communicating by an IP network. ‘TCP SERVER’ and ‘TCP CLIENT’ are maintaining transmit and receive Data until the TCP connection is terminated. SERVER CLIENT SERVER OPEN OPEN LISTEN CLIENT Connect-Request ESTABLISHED CONNECT Connect-Request ESTABLISHED Data Communications Data Communications Disconnect-Request Disconnect-Request Or Or Disconnect-Request Disconnect-Request CLOSED CLOSED “TCP SERVER” “TCP CLIENT” Figure 5 TCP SERVER and TCP CLIENT 56 / 109 W5100S Datasheet Version1.0.0 4.3.1 TCP Server Figure 6 show ‘TCP SERVER’ Operation Flow. Figure 6 TCP Server Operation Flow  OPEN HOST configures SOCKET n to TCP Mode. { START : Sn_MR[3:0] = ‘0001’; /* set TCP Mode */ Sn_PORTR[0:1] = {0x13,0x88}; /* set PORT Number, 5000(0x1388) */ /* configure SOCKET Option when you need it. */ // Sn_MR[ND] = ‘1’; /* set No Delay ACK */ Sn_CR[OPEN] = ‘1’; /* set OPEN Command */ while(Sn_CR != 0x00); /* wait until OPEN Command is cleared*/ if(Sn_SR != SOCK_INIT) goto START; /* check SOCKET Status */ W5100S Datasheet Version1.0.0 57 / 109 }  LISTEN SOCKET n is operated as ‘TCP SERVER’ by Sn_CR [LISTEN]. ‘TCP SERVER’ waits for SYN Packet in Sn_SR (SOCK_LISTEN) { Sn_CR = LISTEN; /* set LISTEN Command */ while(Sn_CR != 0x00); /* wait until LISTEN Command is cleared*/ if(Sn_SR != SOCK_LISTEN) goto OPEN; /* check SOCKET Status */ }  ESTABLISHED? ‘TCP SERVER’ keeps Sn_SR (SOCK_LISTEN) until received SYN Packet. If ‘TCP SERVER’ receives SYN Packet from ‘TCP CLIENT’, it transmits SYN/ACK Packet to ‘TCP CLIENT’ and the Connection Process between ‘TCP SERVER’ and ‘TCP CLIENT’ is completed. If there is no response from Peer against of transmitted SYN Packet or SYN/ACK Packet within the Retransmission Time, Sn_IR [TIMEOUT] is set to ‘1’. First method : { /* check SOCKET Interrupt */ if (Sn_IR[CON] == ‘1’) { /* clear SOCKET Interrupt */ Sn_IR[CON] = ‘1’; goto Received DATA?; /* or goto Send DATA?; */ } else if(Sn_IR[TIMEOUT] == ‘1’) goto Timeout?; } Second method : { if (Sn_SR == SOCK_ESTABLISHED) { /* clear SOCKET Interrupt */ Sn_IR[CON] = ‘1’; goto Received DATA? /* or goto Send DATA?; */ } 58 / 109 W5100S Datasheet Version1.0.0 else if(Sn_IR[TIMEOUT] == ‘1’) goto Timeout?; }  Receive DATA? Whether SOCKET n Data is received is confirmed by Sn_IR [RECV] or Sn_RX_RSR. First method : { /* check SOCKET RX Memory Received Size */ if (Sn_RX_RSR > 0) goto Receiving Process; } Second method : { if (Sn_IR[RECV] == ‘1’) { /* check SOCKET Interrupt */ Sn_IR[RECV] = ‘1’; /* clear SOCKET Interrupt */ goto Receiving Process; } }  Receiving Process Received Data is read from SOCKET n RX Buffer Block. The Read Offset Address of Received Data in RX Memory Block is calculated by gSn_RX_BASE, gSn_RX_MASK and Sn_RX_RD. (Ref 4.2.3 SOCKET TX/RX Buffer Setting) After reading received Data, Sn_RX_RD must be increased by Data read Size and Sn_CR [RECV] must be set to ‘1’. If there is remain Data in SOCKET n RX Buffer Block after Sn_CR [RECV] Command, Sn_IR [RECV] is set to ‘1’. When Read Offset Address calculated, it is cautious to over the boundary Address (n=0,1,2 : gSn_RX_BASE ∼ gSn+1_RX_BASE, n=3 : gS3_RX_BASE ∼ 0xFFFF) of SOCKET n RX Buffer Block. { /* get Received Size */ get_size = Sn_RX_RSR; /* calculate SOCKET n RX Buffer Size & Offset Address */ gSn_RX_MAX = Sn_RXBUF_SIZE * 1024; get_offset = Sn_RX_RD & gSn_RX_MASK; W5100S Datasheet Version1.0.0 59 / 109 /* calculate Read Offset Address */ get_start_address = gSn_RX_BASE + get_offset; /* if overflow the upper boundary of SOCKET n RX Buffer */ If( (get_offset + get_size) > gSn_RX_MAX ) { /* copy upper_size bytes of get_start_address to destination_address - destination_address is user data memory address */ upper_size = gSn_RX_MAX – get_offset; memcpy(get_start_address, destination_address, upper_size); destination_address += upper_size; /* copy the remained size bytes of gSn_RX_BASE to destination_address */ remained_size = get_size – upper_size; memcpy(gSn_RX_BASE, destination_address, remained_size); } else { /* copy get_size of get_start_address to destination_address */ memcpy(get_start_address, destination_address, get_size); } /* increase Sn_RX_RD as get_size */ Sn_RX_RD += get_size; /* set RECV Command */ Sn_CR[RECV] = ‘1’; while(Sn_CR != 0x00); /* wait until RECV Command is cleared*/ }  Send DATA? / Sending Process Written Data in SOCKET n TX Buffer Block is transmitted. The Write Offset Address in TX Memory Block is calculated by gSn_TX_BASE, gSn_TX_MASK and Sn_TX_WD. (Ref 4.2.3 SOCKET TX/RX Buffer Setting). And Data to be transmitted form the Write Offset Address is written. After writing Data, Sn_TX_WD must be increased by written Data Size and the Data is transmitted by Sn_CR [SEND]. Before Sn_IR [SENDOK] = ‘1’, next Data Transmission Process is not executed. How long time until Sn_IR [SENDOK] = ‘1’ after transmitting Data is depending on SOCKET Count, Data Size and Network Traffic. Also Sn_IR [TIMEOUT] could be occurred. (Ref 4.8.2 TCP Retransmission) 60 / 109 W5100S Datasheet Version1.0.0 When Write Offset Address calculated, it is cautious to over the boundary Address (n=0,1,2 : gSn_TX_BASE ∼ gSn+1_TX_BASE, n=3 : gS3_TX_BASE ∼ 0xC000) of SOCKET n TX Buffer Block. If there is no response from Peer against of transmitted Data Packet within the Retransmission Time, Sn_IR [TIMEOUT] is set to ‘1’. { /* calculate SOCKETn TX Buffer Size & Offset Address */ gSn_TX_MAX = Sn_TXBUF_SIZE * 1024; get_offset = Sn_TX_WR & gSn_TX_MASK; /* check the max size of DATA(send_size) & Free Size of SOCKETn TX Buffer(Sn_TX_FSR)*/ if( send_size >gSn_TX_MAX ) send_size = gSn_TX_MAX; while(send gSn_TX_MAX ) { /* copy upper size bytes of source_address to get_start_address - source_address is the start address of user data */ upper_size = gSn_TX_MAX – get_offset; memcpy(source_address, get_start_address, upper_size); /* copy the Remained Size Bytes of source_address to gSn_TX_BASE */ source_address += upper_size; remained_size = send_size – upper_size; memcpy(source_address, gSn_TX_BASE, remained_size); } else { /* copy send_size bytes of source_address to get_start_address - source_address is the start address of user data */ W5100S Datasheet Version1.0.0 61 / 109 memcpy(source_address, get_start_address, send_size); } /* increase Sn_TX_WR as send_size */ Sn_TX_WR += send_size; /* set SEND Command */ Sn_CR = SEND; while(Sn_CR != 0x00); /* wait until SEND Command is cleared*/ /* wait until SEND Command is completed or TIMEOUT Interrupt is occurred*/ while(Sn_IR[SENDOK] == ‘0’ and Sn_IR[TIMEOUT] = ‘0’); /* clear SOCKET Interrupt*/ if(Sn_IR[SENDOK] == ‘1’) Sn_IR[SENDOK] = ‘1’; else goto Timeout?; }  Received FIN (Passive Close) When FIN Packet received from Peer. First Method: { If(Sn_SR == SOCK_CLOSE_WAIT) goto Disconnecting Process; } Second Method: { If(Sn_IR[DISCON] == ‘1’) goto Disconnecting Process; }  Disconnected (Active Close) When FIN Packet transmitted to Peer. { /* send FIN Packet */ Sn_CR[DISCON] = ‘1’; while(Sn_CR != 0x00); /* wait until DISCON Command is cleared*/ goto Disconnecting Process; } 62 / 109 W5100S Datasheet Version1.0.0  Disconnecting Process In Passive Close, if FIN Packet is received from Peer and there is no Data to be transmitted, SOCKET transmits FIN Packet and it will be closed. If there is no response from Peer against of transmitted FIN Packet within the Retransmission Time, Sn_IR [TIMEOUT] is set to ‘1’. In Active Close, if SOCKET transmits FIN Packet to Peer, SOCKET waits for Peer FIN Packet. SOCKET will be closed after receiving FIN Packet from Peer. If there is no response from Peer against of transmitted FIN Packet within the Retransmission Time, Sn_IR [TIMEOUT] is set to ‘1’. Passive Close: /* received FIN Packet from Peer */ { /* send FIN Packet */ Sn_CR = DISCON; while(Sn_CR != 0x00); /* wait until DISCON Command is cleared*/ /* wait unit ACK Packet is received*/ while(Sn_IR[DISCON] == ‘0’ and Sn_IR[TIMEOUT] == ‘0’) ; if (Sn_IR[DISCON] == ‘1’) { /* clear Interrupt */ Sn_IR[DISCON] = ‘1’; goto CLOSED; } else goto Timeout?; } Active Close : /* sent FIN Packet to Peer */ { /* wait until FIN Packet is received*/ while(Sn_IR[DISCON] == ‘0’ and Sn_IR[TIMEOUT] == ‘0’) ; if (Sn_IR[DISOCN] == ‘1’) { /* clear Interrupt */ Sn_IR[DISCON] = ‘1’; goto CLOSED; } else goto Timeout?; } W5100S Datasheet Version1.0.0 63 / 109  Timeout? If there is no response from Peer against of transmitted SYN or SYN/ACK or FIN or Data Packet within the Retransmission Time, Sn_IR [TIMEOUT] is set to ‘1’. (Ref 4.8.2 TCP Retransmission) { /* check TIMEOUT Interrupt */ if(Sn_IR[TIMEOUT] == ‘1’) { /* clear Interrupt */ Sn_IR[TIMEOUT] = ‘1’; goto CLOSE; } }  CLOSE SOCKET n is closed by the Disconnect Process, Sn_IR [TIMEOUT] = ‘1’ and Sn_CR [CLOSE] = ‘1’. { /*wait until SOCKET n is closed*/ while(Sn_SR != SOCK_CLOSED); } 64 / 109 W5100S Datasheet Version1.0.0 4.3.2 TCP Client Figure 7 shows ‘TCP CLIENT’ Operation Flow. Figure 7 TCP Client Operation Flow  OPEN Refer to 4.3.1 TCP Server : OPEN  CONNECT SOCKET n is operated as ‘TCP CLIENT’ by Sn_CR [CONNECT]. SYN Packet is transmitted to ‘TCP SERVER’ by Sn_CR [CONNECT]. { /* set Destination IP Address, 192.168.0.11 */ Sn_DIPR[0:3] ={ 0xC0, 0xA8, 0x00, 0x0B}; /* set Destination PORT Number, 5000(0x1388) */ Sn_DPORTR[0:1] = {0x13, 0x88}; W5100S Datasheet Version1.0.0 65 / 109 /* set CONNECT Command */ Sn_CR = CONNECT; while(Sn_CR != 0x00); /* wait until CONNECT Command is cleared*/ goto ESTABLISHED?; }  ESTABLISHED? ‘TCP CLIENT’ is in Sn_SR (SOCK_SYNSENT) until receiving SYN/ACK Packet from ‘TCP SERVER’ against of SYN Packet transmitted. If SYN/ACK Packet is received from ‘TCP SERVER’, the Connection Process between ‘TCP SERVER’ and ‘TCP CLIENT’ is completed. If there is no response from Peer against of transmitted SYN Packet within the Retransmission Time, Sn_IR [TIMEOUT] is set to ‘1’. (Ref 4.3.1 TCP Server : Received DATA?)  Others flow Refer to 4.3.1 TCP Server. 66 / 109 W5100S Datasheet Version1.0.0 4.3.3 Other Functions 4.3.3.1 TCP SOCKET Options Before Sn_CR [OPEN] is set to ‘1’, SOCKET Option can be set by Sn_MR and Sn_MR2.  No Delayed ACK : Sn_MR [NDACK] = ‘1’ If No Delayed ACK option is set, SOCKET sends ACK Packet against of Peer Data Packet without Delay.  Delayed ACK : Sn_MR [NDACK] = ‘0’ If No Delayed ACK option is not set, SOCKET sends ACK Packet against of Peer Data Packet after RTR or TCP Window Size increased.  Force PSH : Sn_MR2 [BRDB ]=’1’ If Force PSH option is set, SOCKET puts PSH flag in every Data Packet to be transmitted.  Auto PSH : Sn_MR2 [BRDB ]=’0’ If Force PSH option is not set, SOCKET puts PSH flag in the last Data Packet to be transmitted. 4.3.3.2 Keep Alive Keep Alive (KA) is a message sent by Peer to check that the link is operating, or to prevent the link from being broken. Keep Alive sends the last 1 Byte from the last transmitted Data. So, Data bigger than 1 Byte must be transmitted before Keep Alive. If there is no response from Peer against of KA Packet within the Retransmission Time, Sn_IR [TIMEOUT] is set to ‘1’. The period of KA Packet transmit is set by Sn_KPALVTR. If Sn_KPALVTR is zero, KA Packet is able to be transmitted by Sn_CR [SEND_KEEP]. W5100S Datasheet Version1.0.0 67 / 109 4.4 UDP UDP (User Datagram Protocol) is a Datagram Communication Protocol and doesn’t guarantee the stability in Transport Layer above the IP Layer. It also provides Communication between Applications using Port Numbers. UDP can communicate with more than one Peer and doesn’t require the Connection Process. On the other hand, UDP has Data Loss and receives Data from any Peers because UDP has no guarantee reliability. UDP Transmission Methods are Unicast, Broadcast and Multicast according to Data transmit/receive range. Figure 8 shows UDP Operation Flow. Figure 8 UDP Operation Flow 4.4.1 UDP Unicast UDP Unicast is the first Communication Method in which sender is one and receiver is one. Before Data Transmit, SOCKET performs the ARP Process. In the ARP Process, if there is no response from Peer against of ARP Request within the Retransmission Time, Sn_IR [TIMEOUT] is set to ‘1’. (Ref 4.8.1 ARP & PING Retransmission) If previous Destination and current Destination are the same, the ARP Process is skipped. Also, the ARP Process is skipped by Sn_CR [SEND_MAD] and Sn_DHAR.  OPEN SOCKET n is configured as UDP Mode by OPEN Command. { 68 / 109 W5100S Datasheet Version1.0.0 START : /* set UDP Mode */ Sn_MR[3:0] = ‘0010’; /* set Source PORT Number, 5000(0x1388) */ Sn_PORTR[0:1] = {0x13, 0x88}; /* set SOCKET Option such as Broadcast Block. */ // refer to 3.2.23 Sn_MR2 (SOCKET n Mode register 2) // Sn_MR2[BRDB] = ‘1’; /* set OPEN Command */ Sn_CR = OPEN; while(Sn_CR != 0x00); /* wait until OPEN Command is cleared*/ /* check SOCKET for UDP Mode */ if(Sn_SR != SOCK_UDP) goto START; }  Received DATA? Refer to 4.3.1 TCP Server : Received DATA?  Receiving Process UDP Mode SOCKET can receive Data Packets from more than one Peer. The received Data Packet is stored in SOCKET n RX Buffer Block with “PACKET INFO” as shown in Figure 9. If the received Data is bigger than SOCKET n RX Buffer Free Size, it is discarded. (Ref 4.3.1 TCP Server : Receiving Process) Figure 9 Received UDP DATA in SOCKETn RX Buffer Block { /* receive PACKINFO */ W5100S Datasheet Version1.0.0 69 / 109 goto 4.3.1 TCP Server : Receiving Process with get_size = 8; /* extract Destination IP, Port, Size in PACKET INFO*/ dest_ip[0:3] = destination_address[0:3]; dest_port = (destination_address[4]
W5100S-L 价格&库存
很抱歉,暂时无法提供与“W5100S-L”相匹配的价格&库存,您可以联系我们找货
W5100S-L
  • 1+14.57000
W5100S-L
  • 1+29.643801+3.59370
  • 10+25.1891010+3.05370
  • 100+21.83050100+2.64650
  • 200+20.65270200+2.50370
  • 400+18.55360400+2.24930
  • 1000+14.856901000+1.80110
