BZV55C2V4 - BZV55C75
Taiwan Semiconductor
500mW, 5% Tolerance SMD Zener Diodes
FEATURES
KEY PARAMETERS
● Wide Zener voltage range selection: 2.4V to 75V
● VZ tolerance selection of ± 5%
● Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VZ
2.4-75
V
Test current IZT
5
mA
PD
500
mW
VF at IF=10mA
1
V
TJ Max.
175
°C
APPLICATIONS
● Low voltage stabilizers or voltage references
● Adapters
● On-board DC/DC converter
Package
Mini-MELF
Configuration
Single die
MECHANICAL DATA
Case: Mini-MELF
Terminal: Matte tin plated leads, solderable per J-STD-002
Polarity: Indicated by cathode band
Weight: 31mg (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage @ IF=10mA
SYMBOL
VALUE
UNIT
VF
1
V
Power dissipation
PD
500
mW
Junction temperature range
TJ
-65 to +175
°C
Storage temperature range
TSTG
-65 to +175
°C
SYMBOL
TYP
UNIT
RӨJA
300
°C/W
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
Version: G1804
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
ZENER VOLTAGE
PART NUMBER
Min.
TEST
REGULAR
TEST
LEAKAGE
CURRENT
IMPEDANCE
CURRENT
CURRENT
IR @ V R
VZ @ IZT
IZT
ZZT @ IZT
ZZK @ IZK
IZK
V
mA
Ω
Ω
mA
µA
V
Nom.
Max.
Max.
Max.
BZV55C2V4
2.28
2.4
2.56
5
85
600
1.0
50
1.0
BZV55C2V7
2.51
2.7
2.89
5
85
600
1.0
10
1.0
BZV55C3V0
2.8
3.0
3.2
5
85
600
1.0
4
1.0
BZV55C3V3
3.1
3.3
3.5
5
85
600
1.0
2
1.0
BZV55C3V6
3.4
3.6
3.8
5
85
600
1.0
2
1.0
BZV55C3V9
3.7
3.9
4.1
5
85
600
1.0
2
1.0
BZV55C4V3
4.0
4.3
4.6
5
75
600
1.0
1
1.0
BZV55C4V7
4.4
4.7
5.0
5
60
600
1.0
0.5
1.0
BZV55C5V1
4.8
5.1
5.4
5
35
550
1.0
0.1
1.0
BZV55C5V6
5.2
5.6
6.0
5
25
450
1.0
0.1
1.0
BZV55C6V2
5.8
6.2
6.6
5
10
200
1.0
0.1
2.0
BZV55C6V8
6.4
6.8
7.2
5
8
150
1.0
0.1
3.0
BZV55C7V5
7.0
7.5
7.9
5
7
50
1.0
0.1
5.0
BZV55C8V2
7.7
8.2
8.7
5
7
50
1.0
0.1
6.2
BZV55C9V1
8.5
9.1
9.6
5
10
50
1.0
0.1
6.8
BZV55C10
9.4
10
10.6
5
15
70
1.0
0.1
7.5
BZV55C11
10.4
11
11.6
5
1.0
0.1
8.2
BZV55C12
11.4
12
12.7
5
1.0
0.1
9.1
BZV55C13
12.4
13
14.1
5
26
110
1.0
0.1
10
BZV55C15
13.8
15
15.6
5
30
110
1.0
0.1
11
BZV55C16
15.3
16
17.1
5
40
170
1.0
0.1
12
BZV55C18
16.8
18
19.1
5
50
170
1.0
0.1
13
BZV55C20
18.8
5
55
220
1.0
0.1
15
BZV55C22
20.8
22
23.3
5
55
220
1.0
0.1
16
BZV55C24
22.8
24
25.6
5
80
220
1.0
0.1
18
BZV55C27
25.1
27
28.9
5
80
220
1.0
0.1
BZV55C30
28
30
32
5
80
220
1.0
0.1
22
BZV55C33
31
33
35
5
80
220
1.0
0.1
24
BZV55C36
34
36
38
5
80
220
1.0
0.1
27
BZV55C39
37
39
41
2.5
90
500
0.5
0.1
28
BZV55C43
40
43
46
2.5
90
600
0.5
0.1
32
BZV55C47
44
47
50
2.5
110
700
0.5
0.1
35
BZV55C51
48
51
54
2.5
125
700
0.5
0.1
38
BZV55C56
52
56
60
2.5
135
1,000
0.5
0.1
42
BZV55C62
58
62
66
2.5
150
1,000
0.5
0.1
47
BZV55C68
64
68
72
2.5
160
1,000
0.5
0.1
51
BZV55C75
70
75
80
2.5
170
1,000
0.5
0.1
56
2
Max.
Version: G1804
Notes:
1. The zener voltage (VZ) is tested under pulse condition of 30ms.
2. The device numbers listed have a standard tolerance on the normal zener voltage of ±5%.
3. For detailed information on price, availability and delivery of normal zener voltages between the voltages
shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative.
4. The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current
having an rms value equal to 10% of the DC zener current(IZT or IZK) is superimposed to IZT or IZK.
ORDERING INFORMATION
PART NO.
(Note 1)
PACKAGE
PACKING
BZV55Cxxx L0
MINI MELF
10K / 13" Reel
BZV55Cxxx L0G
MINI MELF
10K / 13" Reel
BZV55Cxxx L1
MINI MELF
2.5K / 7" Reel
BZV55Cxxx L1G
MINI MELF
2.5K / 7" Reel
Notes:
"xxx" defines voltage from 2.4V (BZV55C2V4) to 75V (BZV55C75)
3
Version: G1804
CHARACTERISTICS CURVES
Fig.1 Power Dissipation VS.
Fig. 2 Total Capacitance
Ambient Temperature
1000
600
Total Capacitance (pF)
PD-Power dissipation (mW)
f=1MHz
500
400
300
200
VR=0V
VR=2V
100
VR=5V
10
100
VR=20V
80
120
160
200
60
VZ - Reverse Voltage (V)
Temperature (oC)
Fig. 3 Differential Impedance VS. Zener Voltage
80
Fig.4 Forward Current VS. Forward Voltage
1000
1000
IZ=1mA
IZ=2mA
100
Forward Current (mA)
Differential Zener Impedance(Ohm)
VR=25V
IZ=5mA
10
IZ=10mA
100
10
1
1
0.1
10
0.0
100
0.2
0.4
0.6
0.8
1.0
1.2
VF - Forward Voltage (mV)
4
Version: G1804
PACKAGE OUTLINE DIMENSION
Mini-MELF
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
3.30
3.70
0.130
0.146
B
1.40
1.60
0.055
0.063
C
0.20
0.50
0.008
0.020
SUGGEST PAD LAYOUT
Unit (mm)
Unit (inch)
Typ
Typ
A
1.25
0.049
DIM.
5
B
2.00
0.079
C
2.50
0.098
D
5.00
0.197
Version: G1804
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: G1804
很抱歉,暂时无法提供与“BZV55C4V7 L0G”相匹配的价格&库存,您可以联系我们找货
