7.15
H
PCB Mount Orientation
Designed to comply with
physical, electrical and
environmental requirements of
Micro USB Standard (USB2.0).
G
Pin 1
Pin 1
2.60
Pin 5
0.65
Pin 5
7.40
4.75
1.02
0.40
1.15
Specifications 规格
E
1.40
Materials 材料
Plastic Housing 塑胶外壳: LCP, UL94V-0, Black
Contact Terminal 接触端子: Copper Alloy
Metallic Shell 金属外壳: Stainless Steel
SUS304 T = 0.25mm
Plating电镀:
Underplating 底层电镀: 50µ" Nickel
Contact Area 接触面积: 30µ" Gold plating
Solder Tails 焊接末端: Gold Flash
Metallic Shell 金属外壳: Matte Tin
1.45
1.25
1.85
1.9
5.55
2.23
3.35
1.45
F
PCB Edge
0.50
0.45
1.05
4.00
Solder Area
2.35
D
Recommended PCB Layout
Viewed from Component Side
General Tolerance: ±0.05
Component Outline
Electrical 电气
Voltage Rating 电压额定值: 30 V AC
Current Rating 电流额定值: Signal(Pins 2,3,4):1.0 A.
Power (Pins1,5):1.8A.
Operating Temperature 工作温度: -30°C to +85°C
Contact Resistance 接触电阻值: 30mΩ max.
Insulating Resistance 绝缘电阻值: 1000MΩ min.
Dielectric Withstand Voltage 耐电压: 500V AC/Minute
1.00
6.90+0.04
-0.02
0.31
1.85+0.04
-0.02
7.15
0.08
C
Pin 1
Pin 5
0.90
2.75
2.80
Mechanical & Environmental 机械 & 环境
Mating Force 插入力: 35N max.
Unmating Force 拨出力: Initial 10N min.
Final 8N min after durability test.
Durability 耐久性: 10,000 Cycles
Ordering Grid
B
USB3076
30
A
Contact Plating
30 = 30u" Gold
Request Samples
and Quotation
Packing Options
A = Tape & Reel
(1.5K per Reel)
Part Number
Product Description
USB3076
Micro USB Receptacle, Type B, SMT, Horizontal, Bottom Mount
w/out Peg, w/Outer Shell Stakes, w/out Mating Face Lead-In
Drawing Date
A
26th August 2011
1.30
Pin 1
1
By
Pin 5
2.60
2
Detail
3
4
Revision
Date
5
CC
Tolerances (Except as Noted)
USB3076
C PCN
C5
14/02/17
X.X° ± 2°
X.X ± 0.30
X.XX ± 0.20 X.XX° ± 1°
X.XXX ± 0.10 X.XXX° ± 0.5°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
ASE
8
Sheet No.
1/2
FIRST APPROXIMATELY
15PCS EMPTY CARRIER
H
4.0
FIRST APPROXIMATELY
15PCS EMPTY CARRIER
12.0
4.0
G
Products P/N
I/O Direction
卷盘绕逆时针方向转动
4
6000
10°
Carrier Tape
载带
Notes注意:
1. Peeling off force of top tape: 0.1-1.3N
2. Part Conforms to EIA-481-C Standards产品符合EIA-481-C标准
3. All dimensions in millimeters 所有尺寸均是毫米
4. 10 sprocket hole pitch cumulative tolerance±0.2mm
120
Ø2
3
ø330
1500
Peel off Angle
剥离角度
Cover Tape
盖带
F
PCS/Reel Reels/Carton PCS/Carton
USB3076
Ø13.5
120°
E
Detail F
6
P S
Detail F
Cardboard
纸板
Reel 卷筒
D
Label
标签
Waterproof bag
防水袋
Protection Tape
保护胶带
Triangle Liner
三角形班轮
Carton
纸箱
160mm
C
1500 pieces/reel
1500 件/卷
4 Reels
4 卷轴
35
0m
m
700x600x0.08
B
Part Number
Product Description
USB3076
Drawing Date
A
26th August 2011
By
Detail
1
2
3
4
m
0m
35
Revision
Date
5
CC
USB3076
C PCN
C5
14/02/17
X.X° ± 2°
X.X ± 0.30
Length
Angle
6
Units:
Metric (mm)
C
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
ASE
8
Sheet No.
2/2
很抱歉,暂时无法提供与“USB3076-30-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.961911+0.72151
- 10+5.2267810+0.63254
- 25+4.7803125+0.57851
- 50+4.4976750+0.54431
- 100+4.31041100+0.52165
- 250+3.93557250+0.47628
- 500+3.74829500+0.45362
