TLP404
TLP404
    TRIPPLITE
    TLP404
TLP404 数据手册
Protect It! 4-Outlet Home Computer Surge Protector Strip, 4 ft. (1.22 m) Cord, 450 Joules Highlights ● 4 outlets / 4-ft. (1.22 m) cord ● 450 joule rating MODEL NUMBER: TLP404 Package Includes Description Tripp Lite's TLP404 offers economical AC surge suppression for protection of workstations, desktop PCs, telecom systems and other sensitive electronics. Built-in AC surge suppression shields connected equipment from damage and performance problems due to transient surges. TLP404 offers 4 total outlets, 4-ft. (1.22 m) cord and diagnostic LED to warn of suppressor damage. AC suppression rated at 450 joules shields equipment from surges and line noise. Attractive light gray suppressor housing with keyhole mounting tabs and 1 designated transformer plug outlet offers convenient protection of desktop computer equipment and accessories. $1,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). PLUG/OUTLETS: Input: NEMA5-15P/Output: 4 NEMA5-15R/4-ft. (1.22 m) AC line cord ELECTRICAL: 120V AC, 50/60Hz, 15A (Requires NEMA5-15R wall receptacle) FORMAT: Corded multi-outlet strip with 1 transformer spaced outlet SUPPRESSION: AC: 150V RMS Clamping/450 joules/500V UL1449 3rd Edition Features ● 4 outlets ● 4-ft. (1.22 m) cord ● Surge suppression rating: 450 joules ● EMI/RFI noise filtering ● 15 amp resettable circuit breaker ● Diagnostic LED confirms surge protection status ● Includes full normal mode (H-N) and common mode (N-G/H-G) line surge suppression ● Can accommodate 1 large transformer plug without covering remaining outlets, 2 total transformers ● Keyhole supports for wall mounting ● Non-Lighted power switch ● $1,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) ● Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required Specifications 1/4 ● TLP404 surge suppressor ● Instruction manual with warranty information OVERVIEW UPC Code 037332119131 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Cord Gauge Type 14 gauge; SJT Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 22500 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 4 Right-Angle Plug No Input Cord Length (m) 1.22 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output (Watts) 1800 Output Receptacles (4) 5-15R Circuit Breaker (amps) 15 Overload Protection 15A resettable combo switch / circuit breaker Transformer Accommodation (2) Yes Outlet Orientation Single row of 4 outlets Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Combination AC circuit breaker and 2 position on/off power switch Diagnostic LED Details Built-in LED confirms suppressor "protection present" (green) status SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 450 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression 2/4 UL1449 Let Through Rating 500V - UL Verified EMI / RFI Filtering Yes Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Light Gray Housing Color Light Gray Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) Distance between slots = 57.5 mm; Distance between slot height = 26 mm Outlets Measurement (Center to Center) 28.6mm Receptacle Color Gray Shipping Dimensions (hwd / in.) 11.90 x 2.00 x 5.00 Shipping Dimensions (hwd / cm) 30.23 x 5.08 x 12.70 Shipping Weight (lbs.) 0.88 Shipping Weight (kg) 0.40 Unit Dimensions (hwd / in.) 1.2 x 1.85 x 8.1 Unit Dimensions (hwd / cm) 3 x 4.7 x 20.6 Unit Weight (lbs.) 1 Unit Weight (kg) 0.45 FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); cUL Listed; UL 1449; UL 1363; UL Listed Product Compliance RoHS WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 Connected Equipment Insurance (U.S., Canada & Puerto Rico) $1,000 Ultimate Lifetime Insurance  © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
TLP404 价格&库存
很抱歉,暂时无法提供与“TLP404”相匹配的价格&库存,您可以联系我们找货
TLP404
    • 1+121.40820
