3146.000.00.00
    FEIGELECTRONIC
3146.000.00.00 数据手册
 Proximity Reader ID RWA02 (125 kHz) FEATURES  Multi-tag Reader for all common 125 kHz transponders  Interfaces: RS232 or RS485  Suitable for indoor- and outdoor use (IP 54)  Reader has its own local intelligence, the most important functions of the reader can be configured to support an offline operational mode  TECHNICAL DATA Dimensions (W x H x D) Reader Surface spacer Housing Color Weight Protection class Temperature range Operation Storage Relative air humidity MTBF Supply voltage Current consumption Interfaces ID RWA02.10-AD ID RWA02.10-B LED Operating frequency Antenna Beeper Relay Digital inputs Read range SHORT DESCRIPTION Order description: ID RWA02.10-AD/-B Proximity Reader 84 mm x 84 mm x 22 mm (3.33 in x 3.33 in x 0.87 in) 78 mm x 78 mm x 18 mm (3.07 in x 3.07 in x 0.71 in) Plastic (ASA) / Front: acrylic glass Corpus: white/Front panel: black approx. 150 g IP 54 –25 °C up to 70 °C –40 °C up to 85 °C 95 % (non-condensing) 307.000 h 12-24 V AC / DC max. 2,5 W RS232 RS485 (max. 32 devices / data bus) Bicolor (Red / Green / Orange) 125 kHz integrated, approx. 70 mm x 70 mm integrated 1 closer 2 (max. cable length 3 m) * maximum 7 cm 1 Supported transponders 125 kHz ReadOnly transponders 2 125 kHz Read/Write transponders Polling-Mode ID RWA02.10-AD / -B is designed as a wall-mounted device for contactless data exchange with common 125 kHz transponders for applications like access control, time attendance and payment systems. Operation modes For power supply an external power supply unit is necessary, data exchange with a computer or other equipment is carried out via a serial (RS232 or RS485) or a Data-/Clock interface. * Read ranges depend on the used transponders; here made statements relate on an inlet size of 76 mm x 45 mm (3.00 in x 1.78 in) Scope of delivery: - Reader ID RWA02.10-AD or ID RWA02.10-B - Surface spacer for surface mount installation - Installation manual STANDARD CONFORMITY 1 For example ID CTxA, H4001, H4002, H4022, H4102, Unique, Q5, e5555 etc. 2 For example ID DTxB, ID DTxC, HITAG 1, HITAG S etc. Radio approval Europe USA EMC Safety Low voltage Human Exposure Environment EN 300 330 FCC 47 CFR Part 15 EN 301 489 EN 60950 EN 50364 WEEE – 2002/96/EC RoHS – 2002/95/EC FEIG ELECTRONIC reserves the right to change specification without notice at any time. Stand of information: August 2016.
3146.000.00.00 价格&库存
很抱歉,暂时无法提供与“3146.000.00.00”相匹配的价格&库存,您可以联系我们找货
