4423
    ADAFRUIT
4423 数据手册
        JST-XH 2.54mm Pitch Connector Kit 560 Piece Kit PRODUCT ID: 4423 Totaling 560 pieces, this JST-XH Connector Kit is a must-have for your workstation. You'll have enough sockets and headers to fuel your maker tendencies for days on end! These connectors are really common in electronics, we use the 2 pin ones for our arcade quick-connects. Since they are 0.1" they match nicely with perfboards, breadboards, plain header, etc. We recommend you own a set of crimping pliers as well, such as these nice ones from Engineer - they're easier to use than trying to crimp with pliers. Since they are nylon, they don't conduct electricity or interfere with antennas/magnetometers. Set contains the following parts in a nice reusable storage container:  20 x JST XH 2.54mm 2-pin connector  20 x JST XH 2.54mm 3-pin connector  20 x JST XH 2.54mm 4-pin connector  20 x JST XH 2.54mm 5-pin connector  20 x JST B2B-XH-A 2.54mm TH shrouded header  20 x JST B3B-XH-A 2.54mm TH shrouded header  20 x JST B4B-XH-A 2.54mm TH shrouded header  20 x JST B5B-XH-A 2.54mm TH shrouded header  200 x JST-XH 2.5mm female crimp pin  200 x JST-XH 2.5mm male crimp pin For more information on JST XH, plus specs and datasheet, check out the official JST webs         https://www.adafruit.com/product/4423/1‐6‐20
很抱歉,暂时无法提供与“4423”相匹配的价格&库存,您可以联系我们找货
