Powerpole® Connector
PP180 - Up to 350 Amps
PP180 are the largest of the Powerpole® series
housings. They are designed to accommodate up to
3/0 (70 mm²) wires and handle high currents up to 350
amps. Busbar contacts are also available for power
inputs and takeoffs. Color-coded housings minimize
user confusion and the potential of cross mating circuits.
POWERPOLE® PP180
Busbar
• Low Resistance Silver Plated Copper Contacts
Allows currents up to 350 amps
• UL Rated for Hot Plugging up to 75 Amps
Great for battery or other applications where the ability to
interrupt circuits is required
Housing & Wire Contact
• Busbar Contacts Work with Standard Housings
Provides a hot swappable quick disconnect system for
busbar power distribution
PP180 ORDERING INFORMATION
PP180 Housings
The largest Powerpole® housing can be used with wire
contacts for up to 3/0 AWG (85 mm²) or busbar contacts.
Description
Minimum Quantity
Red
Green
Black
White
Blue
Part Numbers
250
50
1381G3-BK 1381G3
1381G4-BK 1381G4
1381G1-BK 1381G1
1381G2-BK 1381G2
1381-BK 1381
[ 28.6 ]
1.13
[ 82.6 ]
3.25
[ 28.6 ]
1.13
[ 30.0 ]
1.18
[ 129.7 ]
5.5
Front View
Mated Length
PP180 Silver Plated Wire Contacts
Silver plated contacts offer superior electrical performance and durability up to 10,000 mating cycles. New contacts for 2/0 to 3/0 AWG
(70 to 85 mm²) offer extended capability in the same housings. See Reducing bushings in accessory section for smaller wires.
Mating
AWG mm² Force
Loose Piece Part Numbers
Minimum Quantity
500
300
250
3/0
85
Low
1328G2-BK
2/0
67.4 Low
1328G1-BK -
1/0
53.5 High
1382-BK -
1
42.4 High
1347-BK -
2
33.6 High
1383-BK -
4
21.1 High
1384-BK -
6
13.3 High
1348-BK -
50
1328G2 *
1328G1 *
1382
1347
1383
1384
1348
- A -
inches mm
Dimensions
- B -
- C -
inches mm
inches mm
-Dinches mm
2.35
2.35
2.35
2.35
2.35
2.35
2.10
0.70
0.64
0.52
0.52
0.52
0.52
0.37
1.04
1.04
1.04
1.04
1.04
1.04
0.80
* Extended range
D
59.69
59.69
59.69
59.69
59.69
59.69
53.34
17.78
16.26
13.21
13.21
13.21
13.21
9.40
0.58
0.49
0.44
0.39
0.35
0.30
0.22
14.73
12.45
11.18
9.91
8.89
7.62
5.59
26.42
26.42
26.42
26.42
26.42
26.42
20.32
A
C
B
- 52 -
www.andersonpower.com
[ 12.70 ]
050
All Data Subject To Change Without Notice
PP180 Silver Plated Busbar Contacts
Use 1 busbar contacts per housing to provide a quick disconnect input or
output busbar connection. Busbar contacts are for mating with wire contacts
only. Part number 180BBS includes lock nuts. Locknuts must be ordered
separately for 180BBS-BK.
See Busbar contact drawing on
website for further detail.
[ 109.7 ]
4.3
Mating
Thread
Force
Minimum Quantity
1,000
120
10
High
180BBS-BK 180BBS Busbar 1/4-20
Lock Nut 1/4-20
N/A
H1216P7
110G56 110G55
[ N/A ]
1/4-20
[ 25.4 ]
1.0
[ 2.7 ]
0.50
[ 4.6 ]
0.18
POWERPOLE® PP180
PP180 CONNECTOR TEMPERATURE CHARTS - Temperature rise charts are based on a 25°C
ambient temperature.
Current - Temperature Derating per IEC 60512-5-2 Test 5B
PP180 Singlepole
Temperature Rise at Constant Current
60
60
50
Temperature Rise
Above Ambient (°C)
Temperature Rise
Above Ambient (°C)
50
40
30
PP180 Multipole
100
150
200
250
40
30
100
3/0 AWG
1 AWG
1/0 AWG
4 AWG
75
50
50
100 150 200 250 300 350 400
2/0 AWG
2 AWG
300 350
2/0 AWG
2 AWG
1/0 AWG
4 AWG
75
50
Amperes Applied
Amperes Applied
3/0 AWG
1 AWG
250
100
25
PP180 Multipole
Derating vs. Ambient Temperature
125
Ambient Temperature (°C)
100
25
3/0 AWG
1 AWG
PP180 Singlepole
125
2/0 AWG
2 AWG
150
Amperes Applied
Amperes Applied
1/0 AWG
4 AWG
3/0 AWG
1 AWG
2/0 AWG
2 AWG
1/0 AWG
4 AWG
- 53 -
PP180 SPECIFICATIONS
ELECTRICAL
MECHANICAL
Current Rating Amperes ¹
UL 1977
CSA
Singlepole (Wire-to-Wire) (3/0 AWG)
350
230
2x2 Block (Wire-to-Wire) (3/0 AWG)
350
Singlepole (Wire-to-Busbar) (1/0 AWG)
180
Wire Contacts with Bushings
Max. Wire Insulation Diameter
Voltage Rating AC/DC
Operating Temperature ²
UL 1977
600
Dielectric Withstanding Voltage
POWERPOLE® PP180
Wire Size Range
Mating Cycles No Load by Plating
Volts AC
2,200
Avg. Mated Contact Resistance Milliohms ¹
Wire and Busbar Contacts
Avg. Mating / Unmating Force
0.100
Wire & Busbar Contacts
6” of 1/0 AWG Wire
UL Hot Plug Current Rating Amperes
Min. Contact / Spring Retention Force
4
250 Cycles at 120V DC
75A
AWG
mm²
10 to 3/0
5.3 to 85
in.
mm
0.900
22.860
°F
°C
-4° to 221°
-20° to 105°
Silver (Ag)
N
10,000
44
Lbf.
N
10
44
Lbf.
N
120
534
MATERIALS
Housing
Plastic Resin
Polycarbonate
Contact Retention Spring
Stainless Steel
Housing Flammability Rating
UL94
V-0
Glow Wire
960°C (GWFI) / 850°C (GWIT)
Contact
Base
Copper Alloy
Plating
Silver
Contact Termination Methods
Crimp ³
Hand Solder
NOTE 1: See IEC 60664-1 for working voltage.
NOTE 2: Amp ratings are stated per position and based on all positions being
fully loaded.
1 - Based on: 105°C rated or better cable of the largest size, Properly
calibrated APP® recommended tooling, and a 25°C ambient temperature.
UL rating not to exceed the maximum operating temperature. CSA rating
below a 30°C temperature rise.
2 - Limited by the thermal properties of the connector plastic housing.
3 - Use APP® recommended tooling only. Alternate tools may adversely affect
the performance of our connectors along with UL and CSA recognition.
4 - Based on 2 housings blocked together.
Wrench / Socket *
* Busbar Contacts Only
IEC INFORMATION
Connector
Series
Configurations
Single Pole
PP180
Creepage /
Clearance Material
per IEC
Group
60950-1
Stacked
Powerpole®
Unmated
6.02 mm
Mated
6.02 mm
Unmated
6.02 mm
Mated
PROTECTION
Touch Safety with Wire Contacts
IEC 60529
IP10
6.02 mm
IIIa
ATTRIBUTES
PP180
AMP Rating AC/DC
180
Voltage Rating AC/DC (Steady State)
500 V AC/DC (Operational)
Breaking Capacity - AMP Rating / Cycles
180 Amp / 10 Cycles
Voltage Rating (Breaking Capacity)
220 VDC
FINGER Safety - Mated Only
IEC 60529 - IP20
Wire Size Tested
70 mm²
Contact Series Tested
1382G2
Climatic Testing (Cold, Heat & MFG)
IEC 60512 Test -11j, 11i & 11g
Cycle Life
IEC 60512 Test 9a - 5,000
Cycles
Mechanical Strength Impact
IEC 60512-5 @ 29.5 Inches Dropped 8 times
Temperature Range
-20°C to 105°C
-4°F to 221°F
- 54 -
POWERPOLE® PP180 ACCESSORIES
Mounting Clamp
Mounting clamps can be used for fastening a block of
Powerpole® 180 series housings to a panel. Connector
blocks must be a complete square for the clamps to work
properly. Fastening hardware not included.
Description
Minimum Quantity
2 Pole
3 Pole
Part Numbers
20 sets of 2
1465G1
1465G2
Mounting Clamp
Panel
2 Pole
3 Pole
POWERPOLE® PP180
Retaining Pins
Retaining pins are used to keep stacked Powerpole® 180 series housings from separating.
Retaining pins are inserted in the circular opening between two housings stacked side by side.
Dimension “B” is +/- .015 in or .38 mm.
Dimensions
- A -
-Binches
mm
Description
Part Numbers
Minimum Quantity 1,000
100
1 Block High
111812P6 110G18
0.196 / 0.207 4.98 / 5.26
1.000 25.400
2 Block High
111812P8 110G20
1.500 38.100
B
A
Reducing Bushings
Use with contact part number 1382-BK to allow a smaller wire to be used with the connector. Electrical
capability is derated with smaller wire.
Contact Barrel Size
Wire Size
AWG
mm²
AWG
mm²
Part Numbers
Minimum Quantity
1,500
1,000
500
1/0
53.5
1
42.4
5687-BK
1/0
53.5
2
33.6
5690-BK
1/0
53.5
4
21.2
5693-BK
1/0
53.5
6
13.3
5663-BK
1/0
53.5
10 to 8
5.3 to 8.4
5648-BK
NOTE: Combination of a bushing and contact is not UL approved.
Dimensions
- ID inches mm
100
5687
5690
5693
5663
5648
0.39
0.34
0.27
0.22
0.19
9.91
8.64
6.86
5.59
4.83
[ 25.4 ]
1.0
ID
Wire Entrance
For environmentally sealed connector shells to hold Powerpole ®
15 to 180 connectors, see SPEC Pak ® product series on our
website www.andersonpower.com
- 55 -
Powerpole®
Tooling Information - APP® Applicators are Mechanical Feed Style and do
not Require an Air Feed Kit.
Wire Size
AWG
mm²
Tin Plating
Silver Plating
Loose Piece Contact Crimp Tools
Hand Tool
OR
Pneumatic
Bench
Tool
Die
Locator
Number
of Crimps
N/A
Single
POWERPOLE® TOOLING
PP15 / 45 Flat Wiping Power & Ground
16 to 20
1.3 to 0.52 N/A
1332
12 to 16
3.3 to 1.3
1331
16 to 20
1.3 to 0.52 262G1-LPBK
262G2-LPBK
16 to 20
1.3 to 0.52 269G2-LPBK
N/A
12 to 16
3.3 to 1.3
261G1-LPBK
N/A
10 to 14
5.3 to 2.1
261G2-LPBK
261G3-LPBK
12 to 16
3.3 to 1.3
269G1-LPBK
N/A
10 to 14
5.3 to 2.1
269G3-LPBK
N/A
10 to 14
5.3 to 2.1
200G1L-LPBK
200G3L-LPBK
10 to 14
5.3 to 2.1
201G1H-LPBK
N/A
310 to 14
5.3 to 2.1
1830G1-LPBK
1830G2-LPBK
N/A
1309G2
or
1309G8
1309G3
or
1309G8
N/A
N/A
1309G6
or
1309G8
PP75
6
13.3
8
8.4
1307
1875G1
N/A
10 to 12
1389G6
5900
5952
1875G2
1388G6
1309G4
1389G6
1387G1
1389G21
5953
5.3 to 3.3
5915
1389G21
1388G7
1875G3
Single
1389G6
1389G21
PP120
1/0
53.5
1323G2
1
42.4
1323G1
2
33.6
4
21.2
1319G4
6
13.3
1319G6
3/0
85
1328G2
2/0
53.5
1328G1
1/0
53.5
1
42.4
2
33.6
4
21.1
1384
6
13.3
1348
N/A
1319
1388G3
1368 Series
1387G1
1389G4
Single
1304G32
Double
1389G3
Single
1388G4
PP180
1303G12
1382
N/A
1347
1368 Series
1387G2
1303G13
1383
1387G1
1388G4
Insertion / Extraction Tool for PP15/45 Contacts = 111038G2
NOTE: see website for the most current information.
- 56 -
Wire Size
Reeled Part Number
AWG
mm²
Tin Plating
Silver Plating
16 to 20
1.3 to 0.52
262G1
262G2
16 to 20
1.3 to 0.52
269G2
N/A
12 to 16
3.3 to 1.3
261G1
N/A
10 to 14
5.3 to 2.1
261G2
261G3
12 to 16
3.3 to 1.3
269G1
N/A
10 to 14
5.3 to 2.1
269G3
N/A
10 to 14
5.3 to 2.1
200G1L
200G3L
10 to 14
5.3 to 2.1
201G1H
N/A
10 to 14
5.3 to 2.1
1830G1
1830G2
Reeled Contact Crimp Tools
APP®
Applicator
APP® Press
PP15/45 Flat Wiping Power & Ground
TD0101
POWERPOLE® TOOLING
115V = TE0101
230V = TE0102
TD0102
Your Best Connection™
2020-0055 DS-PP180
REV C7
Anderson™ will use reasonable efforts to include accurate and up-to-date content in the data sheet. All product information contained in the data sheet including ordering information,
illustrations, specifications, and dimensions, are believed to be reliable as of the date of publishing, but is subject to change without notice. Anderson™ makes no warranty or representation as
to its accuracy. Content in the data sheet may contain technical inaccuracies, typographical errors and may be changed or updated without notice. Anderson™ may also make improvements
and/or changes to the products and/or to the programs described in the content at any time without notice. Current sales drawings and specifications are available upon request.
©2020 Anderson Power Products, Inc. All rights reserved. APP®, A®, Anderson Power Products® , Powerpole® , SPEC Pak® and the APP Logo are registered trademarks of Anderson Power
Products, Inc. Anderson™ and Your Best Connection™ are trademarks of Anderson Power Products, Inc.
- 57 -
很抱歉,暂时无法提供与“5690-BK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+14.877941+1.80052
- 10+14.3633910+1.73825
- 25+13.4140925+1.62336
- 50+12.5890450+1.52352
- 100+11.86158100+1.43548
- 国内价格 香港价格
- 1+36.108051+4.36977
