3406
    ADAFRUIT
3406 数据手册
Bluefruit nRF52 Feather Learning Guide Created by Kevin Townsend https://learn.adafruit.com/bluefruit-nrf52-feather-learning-guide Last updated on 2022-03-28 05:00:51 AM EDT ©Adafruit Industries Page 1 of 177 Table of Contents Introduction 7 • nRF52832 Technical Details • nRF51 or nRF52 Bluefruit Devices? 7 8 Device Pinout 9 • • • • • 10 11 11 12 12 Special Notes Power Pins Analog Inputs PWM Outputs I2C Pins Assembly 12 • • • • • • • • • 12 16 16 17 17 19 19 20 21 Header Options! Soldering in Plain Headers Prepare the header strip: Add the breakout board: And Solder! Soldering on Female Header Tape In Place Flip & Tack Solder And Solder! Power Management • • • • Battery + USB Power Power supplies ENable pin Alternative Power Options Arduino Support Setup • • • • 1. BSP Installation 2. LINUX ONLY: adafruit-nrfutil Tool Installation 3. Update the bootloader (nRF52832 ONLY) Advanced Option: Manually Install the BSP via 'git' Arduino Board Testing • • • • • • 1. Select the Board Target 2. Select the USB CDC Serial Port 2.1 Download & Install CP2104 Driver (nRF52832) 2.2 Download & Install Adafruit Driver (nRF52840 Windows) 3. Update the bootloader (nRF52832 Feather Only) 4. Run a Test Sketch Using the Bootloader 22 22 23 23 24 25 25 27 28 28 29 29 29 30 31 31 31 33 • Forcing Serial Boot Mode • Factory Reset • Advanced: OTA DFU Bootloader 33 34 35 Updating the Bootloader 35 • Upgrading an Existing Bootloader ©Adafruit Industries 35 Page 2 of 177 Flashing the Bootloader • 1. Updating the Bootloader with a Segger J-Link and Arduino IDE • 2. Manually Burning the Bootloader via nrfjprog • 3. Manually Burning the Bootloader via AdaLink Arduino BLE Examples 37 37 38 39 40 • Example Source Code • Documented Examples 40 40 Advertising: Beacon 41 • Complete Code • Output 41 42 BLE UART: Controller 43 • Setup • Complete Code 43 45 Custom: HRM 50 • • • • HRM Service Definition Implementing the HRM Service and Characteristics Service + Characteristic Setup Code Analysis Full Sample Code BLE Pin I/O • Setup • Complete Code Central BLEUART • • • • Client Services Scanner Central Role Full Sample Code Dual Roles BLEUART • • • • • Server & Client Service Setup Peripheral Role Central Role Advertising and Scanner Full Sample Code Custom: Central HRM • • • • HRM Service Definition Implementing the HRM Service and Characteristics Client Service + Characteristic Code Analysis Full Sample Code 50 50 52 54 57 57 58 72 72 73 74 75 78 79 80 80 80 81 85 85 85 86 89 Arduino Bluefruit nRF52 API 92 AdafruitBluefruit 93 • API • Examples 93 95 BLEGap 95 ©Adafruit Industries Page 3 of 177 BLEAdvertising 96 • API • Related Information • Example 96 97 98 BLEScanner 98 • API • setRxCallback(rx_callback_t fp) • void useActiveScan(bool enable); • void filterRssi(int8_t min_rssi);void filterMSD(uint16_t manuf_id);void filterUuid(BLEUuid ble_uuid);void filterUuid(BLEUuid ble_uuid1, BLEUuid ble_uuid2);void filterUuid(BLEUuid ble_uuid1, BLEUuid ble_uuid2, BLEUuid ble_uuid3);void filterUuid(BLEUuid ble_uuid1, BLEUuid ble_uuid2, BLEUuid ble_uuid3, BLEUuid ble_uuid4);void filterUuid(BLEUuid ble_uuid[], uint8_t count); • void clearFilters(void); • bool start(uint16_t timeout = 0); bool stop(void); • void restartOnDisconnect(bool enable); • Examples 99 100 101 BLEService • • • • Basic Usage Order of Operations (Important!) API Example BLECharacteristic • • • • Basic Usage Order of Operations (Important!) API Example BLEClientService • Basic Usage • API • Example BLEClientCharacteristic • Basic Usage • API • Example BLEDiscovery • API 102 102 103 103 103 103 104 104 104 105 107 107 108 108 110 112 112 112 113 116 117 117 118 122 122 BLEDis 122 • API • Example • Output 124 124 125 BLEUart 125 • API • Example 125 126 BLEClientUart • API • Examples ©Adafruit Industries 128 128 128 Page 4 of 177 BLEBeacon 131 • API • Example • Testing 132 132 133 BLEMidi 134 • • • • API Installing the Arduino MIDI Library Example Usage BLEHidAdafruit • • • • • • API Example Sketches Bonding HID Devices Setting up your Bluefruit device for bonding Bonding on iOS Testing the HID Keyboard and Bonding BLEAncs • • • • • • 139 139 140 140 141 142 143 143 API ANCS OLED Example Sketch Requirements Loading the Sketch Pairing to your Mobile Device Wait for Alerts BLEClientCts • • • • • • 134 135 135 138 API Client CTS OLED Example Sketch Requirements Loading the Sketch Pairing to your Mobile Device Wait for Time Data 143 144 144 144 145 147 148 148 149 149 149 150 151 BLECentral 152 nRF52 ADC 153 • • • • Analog Reference Voltage Analog Resolution Default ADC Example (10-bit, 3.6V Reference) Advanced Example (12-bit, 3.0V Reference) Memory Map • • • • BSP release & Bootloader version Flash Memory SRAM Layout Functions affecting SoftDevice SRAM usage Software Resources • • • • • Bluefruit Bluefruit Bluefruit Bluefruit Bluefruit LE LE LE LE LE Client Apps and Libraries Connect (Android/Java) Connect  (iOS/Swift) Connect for OS X (Swift) Command Line Updater for OS X (Swift) ©Adafruit Industries 153 153 154 154 156 156 156 158 158 160 160 160 160 161 162 Page 5 of 177 • • • • • • Deprecated: Bluefruit Buddy (OS X) ABLE (Cross Platform/Node+Electron) Bluefruit LE Python Wrapper Debug Tools AdaLink (Python) Adafruit nRF51822 Flasher (Python) Downloads • • • • MyNewt Bootloader Module Details Schematic Schematic (pre March 16 2018) FAQs ©Adafruit Industries 163 163 164 164 165 165 166 167 167 168 168 168 Page 6 of 177 Introduction The Adafruit Feather nRF52 Bluefruit is our latest easy-to-use all-in-one Bluetooth Low Energy board, with a native-bluetooth chip, the nRF52832!  It's our take on an 'all-in-one' Arduino-compatible + Bluetooth Low Energy with built in USB and battery charging. This chip has twice the flash, SRAM and performance of the earlier nRF51-based Bluefruit modules. Best of all it has Arduino IDE support so there is no 'helper' chip like the ATmega32u4 or ATSAMD21. Instead, this chip is programmed directly! It's got tons of awesome peripherals: plenty of GPIO, analog inputs, PWM, timers, etc. Leaving out the extra microcontroller means the price, complexity and power-usage are all lower/better. It allows you to run code directly on the nRF52832, straight from the Arduino IDE as you would with any other MCU or Arduino compatible device. A single MCU means better performance, lower overall power consumption, and lower production costs if you ever want to design your own hardware based on your Bluefruit nRF52 Feather project! The chips are pre-programed with an auto-resetting bootloader so you can upload quickly in the Arduino IDE with no button-pressing. Want to program the chip directly? You can use our command line tools with your favorite editor and toolchain. And to get you up and running quickly, we've done all the heavy lifting of getting the low level BLE stack into shape so that you can focus on your project from day one! nRF52832 Technical Details • ARM Cortex M4F (with HW floating point acceleration) running at 64MHz • 512KB flash and 64KB SRAM • Built in USB Serial converter for fast and efficient programming and debugging • Bluetooth Low Energy compatible 2.4GHz radio (Details available in the nRF528 32 (https://adafru.it/vaJ) product specification) • FCC / IC / TELEC certified module • Up to +4dBm output power • 1.7v to 3.3v operation with internal linear and DC/DC voltage regulators • 19 GPIO, 8 x 12-bit ADC pins, up to 12 PWM outputs (3 PWM modules with 4 outputs each) • Pin #17 red LED for general purpose blinking • Power/enable pin ©Adafruit Industries Page 7 of 177 • Measures 2.0" x 0.9" x 0.28" (51mm x 23mm x 8mm) without headers soldered in • Light as a (large?) feather - 5.7 grams • 4 mounting holes • Reset button • Optional SWD connector for debugging • Works out of the box with just about all of our Adafruit FeatherWings! (https:// adafru.it/vby) (Wings that require the UART like the GPS FeatherWing won't work) Further technical details available in the nRF52832 (https://adafru.it/vaJ) product specification. Like all of our Feather boards, the Bluefruit nRF52 Feather includes on board USB-based LIPO charging, and has a standard LIPO battery connector to make your wireless projects genuinely 'wireless' at no additional cost (aside from the LIPO cell itself). nRF51 or nRF52 Bluefruit Devices? The Bluefruit nRF52 Feather (based on the nRF52832 (https://adafru.it/vaJ) SoC) is quite different from the earlier nRF51822 based Bluefruit products (Bluefruit M0 Feather (https://adafru.it/t6a), etc.), both of which will continue to exist. From a hardware perspective, the nRF52 Feather is based on a much more powerful ARM Cortex M4F processor, with 512KB flash, 64KB SRAM and hardware floating point acceleration ... whereas the earlier nRF51822 is based on the smaller ARM Cortex M0 core (fewer internal instructions), with 256KB flash and either 16KB or 32KB SRAM. ©Adafruit Industries Page 8 of 177 More importantly, the design approach that we took with the nRF52 is completely different: • nRF51 based Bluefruit boards run as modules that you connect to via an external MCU (typically an Atmel 32u4 or a SAMD21), sending AT style commands over SPI or UART. • With the nRF52, you run all of your code directly on the nRF52832 and no external MCU is used or required! This change of design helps keep the overall costs lower, allows for far better performance since you aren't limited by the SPI or UART transport channel, and can help improve overall power consumption. As a tradeoff, it also means a completely different API and development process, though! nRF51 Bluefruit sketches won't run on nRF52 Bluefruit hardware without modification! The two device families have different APIs and programming models, and aim to solve your wireless problems in two different ways. Device Pinout ©Adafruit Industries Page 9 of 177 Please note that the nRF52832 uses a USB serial adapter to RXD/TXD are with respect to the nRF52 Special Notes The following pins have some restrictions that need to be taken into account when using them: • PIN_DFU / P0.20: If this pin is detected to be at GND level at startup, the board will enter a special serial bootloader mode and will not execute any user code, going straight into bootloader mode. If you wish to use this pin as a standard GPIO, make sure that it is pulled high with a pullup resistor so that your code will execute normally when the MCU starts up. • P0.31 / A7: This pin is hard wired to a voltage-divider on the LIPO battery input, allow you to safely measure the LIPO battery level on your device. If possible, you should avoid using this pin as an input because you will lose the ability to read the battery voltage. You can use it as an output just make sure to switch ©Adafruit Industries Page 10 of 177 the pin to analog input when you want to do the battery read, then back to output when toggling pins • FRST/P0.22: Setting this pin to GND at startup will cause the device to perform a factory reset at startup, erasing and config data as well as the user sketch. At the next reset, you should enter serial bootloader mode by default, since no user sketch will be present. You can use this to recover 'bricked' boards, but if you don't wish to do this be careful not to have FRST low at startup. By default, a weak internal pull-up resistor is enabled on this pin during the bootloader phase. FRST does not work with Mynewt bootloader !! Power Pins • 3.3V Output: This two pins are connected to the output of the on board 3.3V regulator. They can be used to supply 3.3V power to external sensors, breakouts or Feather Wings. • LIPO Input (VBAT): This is the voltage supply off the optional LIPO cell that can be connected via the JST PH connector. It is nominally ~3.5-4.2V. • VREG Enable: This pin can be set to GND to disable the 3.3V output from the on board voltage regulator. By default it is set high via a pullup resistor. • USB Power (VBUS): This is the voltage supply off USB connector, nominally 4.5-5.2V. Analog Inputs The 8 available analog inputs can be configured to generate 8, 10 or 12-bit data (or 14bits with over-sampling), at speeds up to 200kHz (depending on the bit-width of the values generated), based on either an internal 0.6V reference or the external supply. The following default values are used: • Default voltage range: 0-3.6V (uses the internal 0.6V reference with 1/6 gain) • Default resolution: 10-bit (0..1023) Unlike digital functions, which can be remapped to any GPIO/digital pin, the ADC functionality is tied to specified pins, labelled as A* in the image above (A0, A1, etc.). ©Adafruit Industries Page 11 of 177 PWM Outputs Any GPIO pin can be configured as a PWM output, using the dedicated PWM block. Three PWM modules can provide up to 12 PWM channels with individual frequency control in groups of up to four channels. Please note that DMA based PWM output is still a work in progress in the initial release of the nR52 BSP, and further improvements are planned here. I2C Pins I2C pins on the nRF52832 require external pullup resistors to function, which are not present on the Adafruit nRF52 Feather by default. You will need to supply external pullups to use these. All Adafruit I2C breakouts have appropriate pullups on them already, so this normally won't be an issue for you. Assembly We ship Feathers fully tested but without headers attached - this gives you the most flexibility on choosing how to use and configure your Feather Header Options! Before you go gung-ho on soldering, there's a few options to consider! ©Adafruit Industries Page 12 of 177 The first option is soldering in plain male headers, this lets you plug in the Feather into a solderless breadboard ©Adafruit Industries Page 13 of 177 Another option is to go with socket female headers. This won't let you plug the Feather into a breadboard but it will let you attach featherwings very easily ©Adafruit Industries Page 14 of 177 We also  have 'slim' versions of the female headers, that are a little shorter and give a more compact shape ©Adafruit Industries Page 15 of 177 Finally, there's the "Stacking Header" option. This one is sort of the best-of-bothworlds. You get the ability to plug into a solderless breadboard and plug a featherwing on top. But its a little bulky Soldering in Plain Headers Prepare the header strip: Cut the strip to length if necessary. It will be easier to solder if you insert it into a breadboard - long pins down ©Adafruit Industries Page 16 of 177 Add the breakout board: Place the breakout board over the pins so that the short pins poke through the breakout pads And Solder! Be sure to solder all pins for reliable electrical contact. (For tips on soldering, be sure to check out our Guide to Excellent Soldering (https:// adafru.it/aTk)). ©Adafruit Industries Page 17 of 177 Solder the other strip as well. ©Adafruit Industries Page 18 of 177 You're done! Check your solder joints visually and continue onto the next steps Soldering on Female Header Tape In Place For sockets you'll want to tape them in place so when you flip over the board they don't fall out ©Adafruit Industries Page 19 of 177 Flip & Tack Solder After flipping over, solder one or two points on each strip, to 'tack' the header in place ©Adafruit Industries Page 20 of 177 And Solder! Be sure to solder all pins for reliable electrical contact. (For tips on soldering, be sure to check out our Guide to Excellent Soldering (https:// adafru.it/aTk)). ©Adafruit Industries Page 21 of 177 You're done! Check your solder joints visually and continue onto the next steps Power Management Battery + USB Power We wanted to make the Feather easy to power both when connected to a computer as well as via battery. There's two ways to power a Feather. You can connect with a MicroUSB cable (just plug into the jack) and the Feather will regulate the 5V USB down to 3.3V. You can also connect a 4.2/3.7V Lithium Polymer (Lipo/Lipoly) or Lithium Ion (LiIon) battery to the JST jack. This will let the Feather run on a rechargable battery. When the USB power is powered, it will automatically switch over to USB for power, as well as start charging the battery (if attached) at 100mA. This happens 'hotswap' style so you can always keep the Lipoly connected as a 'backup' power that will only get used when USB power is lost. The JST connector polarity is matched to Adafruit LiPoly batteries. Using wrong polarity batteries can destroy your Feather ©Adafruit Industries Page 22 of 177 The above shows the Micro USB jack (left), Lipoly JST jack (top left), as well as the changeover diode (just to the right of the JST jack) and the Lipoly charging circuitry (to the right of the JST jack). There's also a CHG LED, which will light up while the battery is charging. This LED might also flicker if the battery is not connected. Power supplies You have a lot of power supply options here! We bring out the BAT pin, which is tied to the lipoly JST connector, as well as USB which is the +5V from USB if connected. We also have the 3V pin which has the output from the 3.3V regulator. We use a 500mA peak regulator. While you can get 500mA from it, you can't do it continuously from 5V as it will overheat the regulator. It's fine for, say, powering an ESP8266 WiFi chip or XBee radio though, since the current draw is 'spikey' & sporadic. ENable pin If you'd like to turn off the 3.3V regulator, you can do that with the EN(able) pin. Simply tie this pin to Ground and it will disable the 3V regulator. The BAT and USB pins will still be powered ©Adafruit Industries Page 23 of 177 Alternative Power Options The two primary ways for powering a feather are a 3.7/4.2V LiPo battery plugged into the JST port or a USB power cable. If you need other ways to power the Feather, here's what we recommend: • For permanent installations, a 5V 1A USB wall adapter (https://adafru.it/duP) will let you plug in a USB cable for reliable power • For mobile use, where you don't want a LiPoly, use a USB battery pack! (https:// adafru.it/e2q) • If you have a higher voltage power supply, use a 5V buck converter (https:// adafru.it/DHs) and wire it to a USB cable's 5V and GND input (https://adafru.it/ DHu) Here's what you cannot do: • Do not use alkaline or NiMH batteries and connect to the battery port - this will destroy the LiPoly charger and there's no way to disable the charger • Do not use 7.4V RC batteries on the battery port - this will destroy the board The Feather is not designed for external power supplies - this is a design decision to make the board compact and low cost. It is not recommended, but technically possible: • Connect an external 3.3V power supply to the 3V and GND pins. Not recommended, this may cause unexpected behavior and the EN pin will no longer. Also this doesn't provide power on BAT or USB and some Feathers/ ©Adafruit Industries Page 24 of 177 Wings use those pins for high current usages. You may end up damaging your Feather. • Connect an external 5V power supply to the USB and GND pins. Not recommended, this may cause unexpected behavior when plugging in the USB port because you will be back-powering the USB port, which could confuse or damage your computer. Arduino Support Setup You can install the Adafruit Bluefruit nRF52 BSP (Board Support Package) in two steps: nRF52 support requires at least Arduino IDE version 1.8.15! Please make sure you have an up to date version before proceeding with this guide! Please consult the FAQ section at the bottom of this page if you run into any problems installing or using this BSP! 1. BSP Installation Recommended: Installing the BSP via the Board Manager • Download and install the Arduino IDE (https://adafru.it/fvm) (At least v1.8) • Start the Arduino IDE • Go into Preferences • Add https://adafruit.github.io/arduino-board-index/ package_adafruit_index.json  as an 'Additional Board Manager URL' (see image below) ©Adafruit Industries Page 25 of 177 • Restart the Arduino IDE • Open the Boards Manager option from the Tools -> Board menu and install 'Adaf ruit nRF52 by Adafruit' (see image below) It will take up to a few minutes to finish installing the cross-compiling toolchain and tools associated with this BSP. The delay during the installation stage shown in the image below is normal, please be patient and let the installation terminate normally: Once the BSP is installed, select • Adafruit Bluefruit nRF52832 Feather (for the nRF52 Feather) • Adafruit Bluefruit nRF52840 Feather Express (for the nRF52840 Feather) • Adafruit ItsyBitsy nRF52840 (for the Itsy '850) • Adafruit Circuit Playground Bluefruit (for the CPB) • etc... from the Tools -> Board menu, which will update your system config to use the right compiler and settings for the nRF52: ©Adafruit Industries Page 26 of 177 2. LINUX ONLY: adafruit-nrfutil Tool Installation adafruit-nrfutil (https://adafru.it/Cau) is a modified version of Nordic's nrfutil (https:// adafru.it/vaG), which is used to flash boards using the built in serial bootloader. It is originally written for python2, but have been migrated to python3 and renamed to ada fruit-nrfutil since BSP version 0.8.5. This step is only required on Linux, pre-built binaries of adafruit-nrfutil for Windows and MacOS are already included in the BSP. That should work out of the box for most setups. Install python3 if it is not installed in your system already $ sudo apt-get install python3 Then run the following command to install the tool from PyPi $ pip3 install --user adafruit-nrfutil Add pip3 installation dir to your PATH if it is not added already. Make sure adafruitnrfutil can be executed in terminal by running $ adafruit-nrfutil version adafruit-nrfutil version 0.5.3.post12 ©Adafruit Industries Page 27 of 177 3. Update the bootloader (nRF52832 ONLY) To keep up with Nordic's SoftDevice advances, you will likely need to update your bootloader if you are using the original nRF52832 based Bluefruit nRF52 Feather boards. Follow this link for instructions on how to do that This step ISN'T required for the newer nRF52840 Feather Express, which has a different bootloader entirely! Update the nRF52832 Bootloader https://adafru.it/Dsx Advanced Option: Manually Install the BSP via 'git' If you wish to do any development against the core codebase (generate pull requests, etc.), you can also optionally install the Adafruit nRF52 BSP manually using 'git', as decribed below: Adafruit nRF52 BSP via git (for core development and PRs only) 1. Install BSP via Board Manager as above to install compiler & tools. 2. Delete the core folder nrf52 installed by Board Manager in Adruino15, depending on your OS. It could be macOS:  ~/Library/Arduino15/packages/adafruit/hardware/nrf52 Linux:  ~/.arduino15/packages/adafruit/hardware/nrf52 Windows:  %APPDATA% \Local\Arduino15\packages\adafruit\hardware\nrf52 3. Go to the sketchbook folder on your command line, which should be one of the following: macOS: ~/Documents/Arduino Linux: ~/Arduino Windows: ~/Documents/Arduino 4. Create a folder named hardware/Adafruit , if it does not exist, and change directories into it. ©Adafruit Industries Page 28 of 177 5. Clone the Adafruit_nRF52_Arduino (https://adafru.it/vaF) repo in the folder described in step 2: git clone --recurse-submodules git@github.com:adafruit/ Adafruit_nRF52_Arduino.git 6. This should result in a final folder name like ~/Documents/Arduino/hardware/ Adafruit/Adafruit_nRF52_Arduino  (macOS). 7. Restart the Arduino IDE Arduino Board Testing Once you have the Bluefruit nRF52 BSP setup on your system, you need to select the appropriate board, which will determine the compiler and expose some new menus options: 1. Select the Board Target • Go to the Tools menu • Select Tools > Board > Adafruit Bluefruit nRF52 Feather for nRF52832-based boards • Select Tools > Board > Adafruit Bluefruit nRF52840 Feather Express for nRF528 40-based boards • Select Tools > Board > Adafruit CLUE for the Adafruit CLUE 2. Select the USB CDC Serial Port Finally, you need to set the serial port used by Serial Monitor and the serial bootloader: • Go to Tools > Port and select the appropriate device ©Adafruit Industries Page 29 of 177 2.1 Download & Install CP2104 Driver (nRF52832) For Feather nRF52832 If you don't see the serial ports device listed, you may need to install the SiLabs CP2104 driver (https://adafru.it/yfA) on your system. On MacOS If you see this dialog message while installing driver On MacOS If you see this dialog message while installing driver, System Extension Blocked   And cannot find the serial port of CP2104, it is highly possible that driver is blocked. To enable it go to System Preferences -> Security & Privacy and click allow if you see Silab in the developer name. After installing cp210x driver, If feather nRF52832 appear as 2 serial ports on your macos. e.g "/dev/cu.SLAB_USBtoUART" and "/dev/cu.usbserial-1234", the correct port to use is "/dev/cu.usbserial-1234" ©Adafruit Industries Page 30 of 177 2.2 Download & Install Adafruit Driver (nRF52840 Windows) For Feather nRF52840, If you are using Windows, you will need to follows Windows Driver Installation (https://adafru.it/D0H) to download and install driver. 3. Update the bootloader (nRF52832 Feather Only) To keep up with Nordic's SoftDevice advances, you will likely need to update your bootloader Follow this link for instructions on how to do that This step is only necessary on the nRF52832-based devices, NOT on the newer nRF52840 Feather Express. Update the Bootloader https://adafru.it/Dsx 4. Run a Test Sketch At this point, you should be able to run a test sketch from the Examples folder, or just flash the following blinky code from the Arduino IDE: #include is required when using with nRF52840 based board for Serial port implementation. #if defined(USE_TINYUSB) #include // for Serial #endif void setup() { pinMode(LED_BUILTIN, OUTPUT); } void loop() { digitalWrite(LED_BUILTIN, HIGH); delay(1000); digitalWrite(LED_BUILTIN, LOW); delay(1000); } ©Adafruit Industries // // // // turn wait turn wait the for the for LED on (HIGH is the voltage level) a second LED off by making the voltage LOW a second Page 31 of 177 This will blink the red LED beside the USB port on the Feather, or the red LED labeled "LED" by the corner of the USB connector on the CLUE. If Arduino failed to upload sketch to the Feather If you get this error: Timed out waiting for acknowledgement from device. Failed to upgrade target. Error is: No data received on serial port. Not able to proceed. Traceback (most recent call last):   File "nordicsemi\__main__.py", line 294, in serial   File "nordicsemi\dfu\dfu.py", line 235, in dfu_send_images   File "nordicsemi\dfu\dfu.py", line 203, in _dfu_send_image   File "nordicsemi\dfu\dfu_transport_serial.py", line 155, in send_init_packet   File "nordicsemi\dfu\dfu_transport_serial.py", line 243, in send_packet   File "nordicsemi\dfu\dfu_transport_serial.py", line 282, in get_ack_nr nordicsemi.exceptions.NordicSemiException: No data received on serial port. Not able to proceed. This is probably caused by the bootloader version mismatched on your feather and installed BSP. Due to the difference in flash layout (more details (https://adafru.it/ Dsy)) and Softdevice API (which is bundled with bootloader), sketch built with selected bootloader can only upload to board having the same version. In short, you need to upgrade/burn bootloader to match on your Feather, follow above Update The Bootloader (https://adafru.it/Dsx) guide It only has to be done once to update your Feather On Linux I'm getting 'arm-none-eabi-g++: no such file or directory', even though 'arm-none-eabi-g++' exists in the path specified. What should I do? This is probably caused by a conflict between 32-bit and 64-bit versions of the compiler, libc and the IDE. The compiler uses 32-bit binaries, so you also need to have a 32-bit version of libc installed on your system (details (https://adafru.it/vnE)). Try running the following commands from the command line to resolve this: ©Adafruit Industries Page 32 of 177 sudo dpkg --add-architecture i386 sudo apt-get update sudo apt-get install libc6:i386 Using the Bootloader This page is for information purposes only. Normally the bootloader will work transparently and automatically from the Arduino IDE, requiring no manual intervention on your behalf. The Bluefruit nRF52 Feather includes a customized version of the Nordic bootloader that enables serial support, over the air (OTA) DFU support, and various fail safe features like factory reset when the FRST pin is grounded at startup. The bootloader that all Bluefruit nRF52 Feathers ships with allows you to flash user sketches to the nRF52832 using only the CP2104 USB to serial adapter populated on the board. The bootloader source code can be found here Adafruit_nRF52_Bootloader (https:// adafru.it/Cnt) Forcing Serial Boot Mode The Bluefruit nRF52 Feather is designed to briefly enter serial bootloader mode for a short delay every time the device comes out of reset, and the DTR line on the CP2104 USB to Serial adapter will trigger a reset every time the Serial Monitor is opened. This means that you can normally flash a user sketch to the nRF52 with no manual intervention on your part at a HW level. If you need to force the serial bootloader mode, however, you can connect the DFU pin to GND at startup, which will force you to enter serial bootloader mode and stay in that mode until you reset or power cycle the board. This can be used to recover bricked boards where a bad user sketch has been uploaded, since you will enter serial bootloader mode without executing the user sketch, and you can flash a new sketch directly from the Arduino IDE. ©Adafruit Industries Page 33 of 177 Forcing the serial bootloader can often be used to recover bricked devices. nRF52840-based board can also use double reset trick to force into serial bootloader Factory Reset The Bluefruit nRF52 Feather has an optional FRST pad on the bottom of the PCB. If you brick your device, you can solder a wire to the FRST pad, connecting it to GND. When a GND state is detected at power up the following actions will be performed: • The user application flash section will be erased • The user 'App Data' section that stores non volatile config data will be erased This will cause the device to enter serial bootloader mode at startup, and the user sketch or config data that caused the device to stop responding should be removed. Be sure to disconnect the pin from GND after a successful factory reset! ©Adafruit Industries Page 34 of 177 Advanced: OTA DFU Bootloader While this is only recommended for advanced users, you can also force OTA (Over The Air) DFU bootloader mode to enable OTA updates using BLE and Nordic's proprietary update protocol (which is support by both Nordic mobile apps, and out own Bluefruit LE Connect). To force OTA DFU mode, set both FRST and DFU to GND at startup. Power cycling the board will cause the device to boot up into OTA DFU mode. This option is not actively support nor recommended by Adafruit, and we are still working on making this as safe as possible for users via our Bluefruit LE Connect application. Use OTA DFU at your own risk knowing you can brick your device and may need a Segger J-Link or similar device to regain control of it! Updating the Bootloader Upgrading the Bootloader is only possible from BSP release 0.8.0 and higher. Upgrading an Existing Bootloader The Adafruit Feather nRF52 Bootloader binary contains not only the DFU code, but also the Bluetooth stack (a.k.a SoftDevice) to make sure they work together reliably. To get the latest and greatest features from the stack such as Bluetooth 5.0 with higher throughput, increased broadcast capacities or larger MTU it is necessary to upgrade Bootloader to get the latest stack. Therefore latest BSP release could support newer SoftDevice version than one currently exists on your board. Due to the flash memory & API difference between SoftDevice major versions, upgrade your board's bootloader to match one supported by BSP is required to upload compiled sketch. Luckily the Bluefruit nRF52 Bootloader can be upgraded/downgraded without any additional hardware, and we can even do that right in Arduino IDE without at risk of typos or common user errors. Close the Serial Monitor before you click "Burn Bootloader". Afterwards, you shouldn't close the Arduino IDE, unplug the Feather, launch Serial Monitor etc ... ©Adafruit Industries Page 35 of 177 to abort the process. There is a high chance it will brick your device! Do this with care and caution.  First select the Bootloader version that you want to upgrade under Tools>Bootloader Then select "Bootloader DFU for Bluefruit nRF52" for Tools->Programmer Double check all of the following: Board, Bootloader Version, Programmer... Select Tools->Burn Bootloader to start the upgrade. ©Adafruit Industries Page 36 of 177 After receiving the new Bootloader over the serial connection, the old Bootloader will erase itself! The new bootloader will then be flashed. The process typically takes 30-60 seconds to complete. Make sure you see the "Device programmed" in the output log before launching Serial monitor or uploadinga new sketch. In case you wonder, the command that IDE uses to upgrade bootloader is as follows (bootloader zip file is different for boards and version). $ adafruit-nrfutil --verbose dfu serial --package feather_nrf52832_bootloader-0.2.8_s132_6.1.1.zip -p /dev/ttyACM0 -b 115200 --singlebank --touch 1200 Flashing the Bootloader All Adafruit nRF52 boards chip with the bootloader pre-flashed. This page is provided for information purposes only! All Bluefruit nRF52 Feather boards and Bluefruit nRF52 modules ship with the serial bootloader pre-flashed, so this page is normally not required when setting your device and system up. The information provided here is only intended for for rare cases where you may want or need to reflash the bootloader yourself, and have access to the HW required to do so. 1. Updating the Bootloader with a Segger JLink and Arduino IDE To burn the bootloader from within the Arduino IDE using a Segger J-Link, you will need the following tools installed on your system and available in the system path: ©Adafruit Industries Page 37 of 177 JLink Drivers and Tools Download and install the JLink Software and Documentation Pack (https://adafru.it/ vaI) from Segger, which will also install a set of command line tools. Burning the Bootloader from the Arduino IDE Once the tools above have been installed and added to your system path, from the Arduino IDE: • Select `Tools > Board > Adafruit Bluefruit Feather52` • Select `Tools > Programmer > J-Link for Feather52` • Select `Tools > Burn Bootloader` with the board and J-Link connected The appropriate Programmer target and Burn Bootloader button can be seen below: You will need a Segger J-Link to flash the bootloader to the nRF52832/ nRF52840 SoC! 2. Manually Burning the Bootloader via nrfjprog You can also manually burn the bootloader from the command line, using `nrfjprog` from Nordic. ©Adafruit Industries Page 38 of 177 You can either download nRF5x-Command-Line-Tools (https://adafru.it/vaJ) for OSX/ Linux/Win32, or use the version that ships with the BSP in the tools/nrf5x-commandline-tools folder. Run the folllwing commands, updating the path to the .hex file as appropriate: $ nrfjprog --program bootloader_binary.hex --chiperase -f nrf52 --reset You should see something similar to the following output, followed by a fast blinky on the status LED to indicate that you are in DFU/bootloader mode since no user sketch was found after the device reset: All commands below were run from 'tools/nrf5x-command-line-tools/osx/nrfjprog' $ ./nrfjprog -e -f nrf52 Erasing code and UICR flash areas. Applying system reset. $ ./nrfjprog --program ../../../../bin/bootloader/bootloader_v050_s132_v201.hex -f nrf52 Parsing hex file. Reading flash area to program to guarantee it is erased. Checking that the area to write is not protected. Programing device. $ ./nrfjprog --reset -f nrf52 Applying system reset. Run. OS X Note: You may need to create a symlink in `/usr/local/bin` to the `nrfjprog` tool wherever you have added it. You can run the following command, for example: $ ln -s $HOME/prog/nordic/nrfjprog/nrfjprog /usr/local/bin/nrfjprog 3. Manually Burning the Bootloader via AdaLink Alternatively, you can use AdaLink (https://adafru.it/fPq) to flash the bootloader with a Segger J-Link: # First erase the device's flash contents $ adalink nrf52832 -p jlink -w # Then flash the bootloader and SoftDevice .hex file $ adalink nrf52832 -p jlink -h feather52_bootloader_v050_s132_v201.hex ©Adafruit Industries Page 39 of 177 Arduino BLE Examples There are numerous examples available for the Bluefruit nRF52/nRF52840 Feathers in the Examples menu of the nRF52 BSP, and these are always up to date. You're first stop looking for example code should be there: Example Source Code The latest example source code is always available and visible on Github, and the public git repository should be considered the definitive source of example code for this board. Click here to browse the example source code on Github https://adafru.it/vaK Documented Examples To help explain some common use cases for the nRF52 BLE API, feel free to consult the example documentation in this section of the learning guide: • Advertising: Beacon - Shows how to use the BLEBeacon helper class to configure your Bleufruit nRF52 Feather as a beacon • BLE UART: Controller - Shows how to use the Controller utility in our Bluefruit LE Connect apps to send basic data between your peripheral and your phone or tablet. • Custom: HRM - Shows how to defined and work with a custom GATT Service and Characteristic, using the officially adopted Heart Rate Monitor (HRM) service as an example. ©Adafruit Industries Page 40 of 177 • BLE Pin I/O (StandardFirmataBLE) Shows how to control Pin I/O of nRF52 with Firmata protocol For more information on the Arduino nRF52 API, check out this page (https://adafru.it/ IIa). Advertising: Beacon This example shows how you can use the BLEBeacon helper class and advertising API to configure your Bluefruit nRF52 board as a 'Beacon'. Complete Code /********************************************************************* This is an example for our nRF52 based Bluefruit LE modules Pick one up today in the adafruit shop! Adafruit invests time and resources providing this open source code, please support Adafruit and open-source hardware by purchasing products from Adafruit! MIT license, check LICENSE for more information All text above, and the splash screen below must be included in any redistribution *********************************************************************/ #include // Beacon uses the Manufacturer Specific Data field in the advertising // packet, which means you must provide a valid Manufacturer ID. Update // the field below to an appropriate value. For a list of valid IDs see: // https://www.bluetooth.com/specifications/assigned-numbers/company-identifiers // 0x004C is Apple // 0x0822 is Adafruit // 0x0059 is Nordic #define MANUFACTURER_ID 0x0059 // "nRF uint8_t { 0x01, 0x89, }; Connect" app can be used to detect beacon beaconUuid[16] = 0x12, 0x23, 0x34, 0x45, 0x56, 0x67, 0x78, 0x9a, 0xab, 0xbc, 0xcd, 0xde, 0xef, 0xf0 // A valid Beacon packet consists of the following information: // UUID, Major, Minor, RSSI @ 1M BLEBeacon beacon(beaconUuid, 0x0102, 0x0304, -54); void setup() { Serial.begin(115200); // Uncomment to blocking wait for Serial connection // while ( !Serial ) delay(10); Serial.println("Bluefruit52 Beacon Example"); Serial.println("--------------------------\n"); ©Adafruit Industries Page 41 of 177 Bluefruit.begin(); // off Blue LED for lowest power consumption Bluefruit.autoConnLed(false); Bluefruit.setTxPower(0); // Check bluefruit.h for supported values // Manufacturer ID is required for Manufacturer Specific Data beacon.setManufacturer(MANUFACTURER_ID); // Setup the advertising packet startAdv(); Serial.println("Broadcasting beacon, open your beacon app to test"); // Suspend Loop() to save power, since we didn't have any code there suspendLoop(); } void startAdv(void) { // Advertising packet // Set the beacon payload using the BLEBeacon class populated // earlier in this example Bluefruit.Advertising.setBeacon(beacon); // Secondary Scan Response packet (optional) // Since there is no room for 'Name' in Advertising packet Bluefruit.ScanResponse.addName(); /* Start Advertising * - Enable auto advertising if disconnected * - Timeout for fast mode is 30 seconds * - Start(timeout) with timeout = 0 will advertise forever (until connected) * * Apple Beacon specs * - Type: Non connectable, undirected * - Fixed interval: 100 ms -> fast = slow = 100 ms */ //Bluefruit.Advertising.setType(BLE_GAP_ADV_TYPE_ADV_NONCONN_IND); Bluefruit.Advertising.restartOnDisconnect(true); Bluefruit.Advertising.setInterval(160, 160); // in unit of 0.625 ms Bluefruit.Advertising.setFastTimeout(30); // number of seconds in fast mode Bluefruit.Advertising.start(0); // 0 = Don't stop advertising after n seconds } void loop() { // loop is already suspended, CPU will not run loop() at all } Output You can use the nRF Beacons application from Nordic Semiconductors to test this sketch: • nRF Beacons for iOS (https://adafru.it/vaC) • nRF Beacons for Android (https://adafru.it/vaD) ©Adafruit Industries Page 42 of 177 Make sure that you set the UUID, Major and Minor values to match the sketch above, and then run the sketch at the same time as the nRF Beacons application. With the default setup you should see a Mona Lisa icon when the beacon is detected. If you don't see this, double check the UUID, Major and Minor values to be sure they match exactly. BLE UART: Controller This examples shows you you can use the BLEUart helper class and the Bluefruit LE Connect applications to send based keypad and sensor data to your nRF52. Setup In order to use this sketch, you will need to open Bluefruit LE Connect on your mobile device using our free iOS (https://adafru.it/f4H), Android (https://adafru.it/f4G) or OS X  (https://adafru.it/o9F) applications. • Load the Controller example sketch (https://adafru.it/vaN) in the Arduino IDE • Compile the sketch and flash it to your nRF52 based Feather • Once you are done uploading, open the Serial Monitor (Tools > Serial Monitor) • Open the Bluefruit LE Connect application on your mobile device ©Adafruit Industries Page 43 of 177 • Connect to the appropriate target (probably 'Bluefruit52') • Once connected switch to the Controller application inside the app • Enable an appropriate control surface. The Color Picker control surface is shown below, for example (screen shot taken from the iOS application): As you change the color (or as other data becomes available) you should receive the data on the nRF52, and see it in the Serial Monitor output: ©Adafruit Industries Page 44 of 177 Complete Code   /********************************************************************* This is an example for our nRF52 based Bluefruit LE modules Pick one up today in the adafruit shop! Adafruit invests time and resources providing this open source code, please support Adafruit and open-source hardware by purchasing products from Adafruit! MIT license, check LICENSE for more information All text above, and the splash screen below must be included in any redistribution *********************************************************************/ #include // OTA DFU service BLEDfu bledfu; // Uart over BLE service BLEUart bleuart; // Function prototypes for packetparser.cpp uint8_t readPacket (BLEUart *ble_uart, uint16_t timeout); float parsefloat (uint8_t *buffer); void printHex (const uint8_t * data, const uint32_t numBytes); // Packet buffer extern uint8_t packetbuffer[]; void setup(void) { Serial.begin(115200); while ( !Serial ) delay(10); // for nrf52840 with native usb Serial.println(F("Adafruit Bluefruit52 Controller App Example")); Serial.println(F("-------------------------------------------")); Bluefruit.begin(); Bluefruit.setTxPower(4); // Check bluefruit.h for supported values // To be consistent OTA DFU should be added first if it exists bledfu.begin(); // Configure and start the BLE Uart service bleuart.begin(); // Set up and start advertising startAdv(); ©Adafruit Industries Page 45 of 177 Serial.println(F("Please use Adafruit Bluefruit LE app to connect in Controller mode")); Serial.println(F("Then activate/use the sensors, color picker, game controller, etc!")); Serial.println(); } void startAdv(void) { // Advertising packet Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE); Bluefruit.Advertising.addTxPower(); // Include the BLE UART (AKA 'NUS') 128-bit UUID Bluefruit.Advertising.addService(bleuart); // Secondary Scan Response packet (optional) // Since there is no room for 'Name' in Advertising packet Bluefruit.ScanResponse.addName(); /* Start Advertising * - Enable auto advertising if disconnected * - Interval: fast mode = 20 ms, slow mode = 152.5 ms * - Timeout for fast mode is 30 seconds * - Start(timeout) with timeout = 0 will advertise forever (until connected) * * For recommended advertising interval * https://developer.apple.com/library/content/qa/qa1931/_index.html */ Bluefruit.Advertising.restartOnDisconnect(true); Bluefruit.Advertising.setInterval(32, 244); // in unit of 0.625 ms Bluefruit.Advertising.setFastTimeout(30); // number of seconds in fast mode Bluefruit.Advertising.start(0); // 0 = Don't stop advertising after n seconds } /**************************************************************************/ /*! @brief Constantly poll for new command or response data */ /**************************************************************************/ void loop(void) { // Wait for new data to arrive uint8_t len = readPacket(&bleuart, 500); if (len == 0) return; // Got a packet! // printHex(packetbuffer, len); // Color if (packetbuffer[1] == 'C') { uint8_t red = packetbuffer[2]; uint8_t green = packetbuffer[3]; uint8_t blue = packetbuffer[4]; Serial.print ("RGB #"); if (red < 0x10) Serial.print("0"); Serial.print(red, HEX); if (green < 0x10) Serial.print("0"); Serial.print(green, HEX); if (blue < 0x10) Serial.print("0"); Serial.println(blue, HEX); } // Buttons if (packetbuffer[1] == 'B') { uint8_t buttnum = packetbuffer[2] - '0'; boolean pressed = packetbuffer[3] - '0'; Serial.print ("Button "); Serial.print(buttnum); ©Adafruit Industries Page 46 of 177 if (pressed) { Serial.println(" pressed"); } else { Serial.println(" released"); } } // GPS Location if (packetbuffer[1] == 'L') { float lat, lon, alt; lat = parsefloat(packetbuffer+2); lon = parsefloat(packetbuffer+6); alt = parsefloat(packetbuffer+10); Serial.print("GPS Location\t"); Serial.print("Lat: "); Serial.print(lat, 4); // 4 digits of precision! Serial.print('\t'); Serial.print("Lon: "); Serial.print(lon, 4); // 4 digits of precision! Serial.print('\t'); Serial.print(alt, 4); Serial.println(" meters"); } // Accelerometer if (packetbuffer[1] == 'A') { float x, y, z; x = parsefloat(packetbuffer+2); y = parsefloat(packetbuffer+6); z = parsefloat(packetbuffer+10); Serial.print("Accel\t"); Serial.print(x); Serial.print('\t'); Serial.print(y); Serial.print('\t'); Serial.print(z); Serial.println(); } // Magnetometer if (packetbuffer[1] == 'M') { float x, y, z; x = parsefloat(packetbuffer+2); y = parsefloat(packetbuffer+6); z = parsefloat(packetbuffer+10); Serial.print("Mag\t"); Serial.print(x); Serial.print('\t'); Serial.print(y); Serial.print('\t'); Serial.print(z); Serial.println(); } // Gyroscope if (packetbuffer[1] == 'G') { float x, y, z; x = parsefloat(packetbuffer+2); y = parsefloat(packetbuffer+6); z = parsefloat(packetbuffer+10); Serial.print("Gyro\t"); Serial.print(x); Serial.print('\t'); Serial.print(y); Serial.print('\t'); Serial.print(z); Serial.println(); } // Quaternions if (packetbuffer[1] == 'Q') { float x, y, z, w; x = parsefloat(packetbuffer+2); y = parsefloat(packetbuffer+6); z = parsefloat(packetbuffer+10); w = parsefloat(packetbuffer+14); Serial.print("Quat\t"); Serial.print(x); Serial.print('\t'); Serial.print(y); Serial.print('\t'); Serial.print(z); Serial.print('\t'); Serial.print(w); Serial.println(); ©Adafruit Industries Page 47 of 177 } } You will also need the following helper class in a file called packetParser.cpp: #include #include #include #define #define #define #define #define #define #define PACKET_ACC_LEN PACKET_GYRO_LEN PACKET_MAG_LEN PACKET_QUAT_LEN PACKET_BUTTON_LEN PACKET_COLOR_LEN PACKET_LOCATION_LEN // READ_BUFSIZE #define READ_BUFSIZE (15) (15) (15) (19) (5) (6) (15) Size of the read buffer for incoming packets (20) /* Buffer to hold incoming characters */ uint8_t packetbuffer[READ_BUFSIZE+1]; /**************************************************************************/ /*! @brief Casts the four bytes at the specified address to a float */ /**************************************************************************/ float parsefloat(uint8_t *buffer) { float f; memcpy(&f, buffer, 4); return f; } /**************************************************************************/ /*! @brief Prints a hexadecimal value in plain characters @param data Pointer to the byte data @param numBytes Data length in bytes */ /**************************************************************************/ void printHex(const uint8_t * data, const uint32_t numBytes) { uint32_t szPos; for (szPos=0; szPos < numBytes; szPos++) { Serial.print(F("0x")); // Append leading 0 for small values if (data[szPos] 1) && (szPos != numBytes - 1)) { Serial.print(F(" ")); } } ©Adafruit Industries Page 48 of 177 Serial.println(); } /**************************************************************************/ /*! @brief Waits for incoming data and parses it */ /**************************************************************************/ uint8_t readPacket(BLEUart *ble_uart, uint16_t timeout) { uint16_t origtimeout = timeout, replyidx = 0; memset(packetbuffer, 0, READ_BUFSIZE); while (timeout--) { if (replyidx >= 20) break; if ((packetbuffer[1] == 'A') break; if ((packetbuffer[1] == 'G') break; if ((packetbuffer[1] == 'M') break; if ((packetbuffer[1] == 'Q') break; if ((packetbuffer[1] == 'B') break; if ((packetbuffer[1] == 'C') break; if ((packetbuffer[1] == 'L') break; && (replyidx == PACKET_ACC_LEN)) && (replyidx == PACKET_GYRO_LEN)) && (replyidx == PACKET_MAG_LEN)) && (replyidx == PACKET_QUAT_LEN)) && (replyidx == PACKET_BUTTON_LEN)) && (replyidx == PACKET_COLOR_LEN)) && (replyidx == PACKET_LOCATION_LEN)) while (ble_uart->available()) { char c = ble_uart->read(); if (c == '!') { replyidx = 0; } packetbuffer[replyidx] = c; replyidx++; timeout = origtimeout; } if (timeout == 0) break; delay(1); } packetbuffer[replyidx] = 0; // null term if (!replyidx) // no data or timeout return 0; if (packetbuffer[0] != '!') // doesn't start with '!' packet beginning return 0; // check checksum! uint8_t xsum = 0; uint8_t checksum = packetbuffer[replyidx-1]; for (uint8_t i=0; i 0) { servoCount--; } else if (servoCount > 0) { // keep track of detached servos because we want to reuse their indexes // before incrementing the count of attached servos detachedServoCount++; detachedServos[detachedServoCount - 1] = servoPinMap[pin]; } servoPinMap[pin] = 255; } void enableI2CPins() { byte i; // is there a faster way to do this? would probaby require importing // Arduino.h to get SCL and SDA pins for (i = 0; i < TOTAL_PINS; i++) { if (IS_PIN_I2C(i)) { // mark pins as i2c so they are ignore in non i2c data requests setPinModeCallback(i, PIN_MODE_I2C); } } isI2CEnabled = true; Wire.begin(); } /* disable the i2c pins so they can be used for other functions */ void disableI2CPins() { isI2CEnabled = false; // disable read continuous mode for all devices queryIndex = -1; } void readAndReportData(byte address, int theRegister, byte numBytes, byte stopTX) { // allow I2C requests that don't require a register read // for example, some devices using an interrupt pin to signify new data available // do not always require the register read so upon interrupt you call Wire.requestFrom() if (theRegister != I2C_REGISTER_NOT_SPECIFIED) { Wire.beginTransmission(address); wireWrite((byte)theRegister); Wire.endTransmission(stopTX); // default = true // do not set a value of 0 if (i2cReadDelayTime > 0) { // delay is necessary for some devices such as WiiNunchuck delayMicroseconds(i2cReadDelayTime); } } else { theRegister = 0; // fill the register with a dummy value } Wire.requestFrom(address, numBytes); ©Adafruit Industries // all bytes are returned in requestFrom Page 61 of 177 // check to be sure correct number of bytes were returned by slave if (numBytes < Wire.available()) { Firmata.sendString("I2C: Too many bytes received"); } else if (numBytes > Wire.available()) { Firmata.sendString("I2C: Too few bytes received"); } i2cRxData[0] = address; i2cRxData[1] = theRegister; for (int i = 0; i < numBytes && Wire.available(); i++) { i2cRxData[2 + i] = wireRead(); } // send slave address, register and received bytes Firmata.sendSysex(SYSEX_I2C_REPLY, numBytes + 2, i2cRxData); } void outputPort(byte portNumber, byte portValue, byte forceSend) { // pins not configured as INPUT are cleared to zeros portValue = portValue & portConfigInputs[portNumber]; // only send if the value is different than previously sent if (forceSend || previousPINs[portNumber] != portValue) { Firmata.sendDigitalPort(portNumber, portValue); previousPINs[portNumber] = portValue; } } /* ----------------------------------------------------------------------------* check all the active digital inputs for change of state, then add any events * to the Serial output queue using Serial.print() */ void checkDigitalInputs(void) { /* Using non-looping code allows constants to be given to readPort(). * The compiler will apply substantial optimizations if the inputs * to readPort() are compile-time constants. */ if (TOTAL_PORTS > 0 && reportPINs[0]) outputPort(0, readPort(0, portConfigInputs[0]), false); if (TOTAL_PORTS > 1 && reportPINs[1]) outputPort(1, readPort(1, portConfigInputs[1]), false); if (TOTAL_PORTS > 2 && reportPINs[2]) outputPort(2, readPort(2, portConfigInputs[2]), false); if (TOTAL_PORTS > 3 && reportPINs[3]) outputPort(3, readPort(3, portConfigInputs[3]), false); if (TOTAL_PORTS > 4 && reportPINs[4]) outputPort(4, readPort(4, portConfigInputs[4]), false); if (TOTAL_PORTS > 5 && reportPINs[5]) outputPort(5, readPort(5, portConfigInputs[5]), false); if (TOTAL_PORTS > 6 && reportPINs[6]) outputPort(6, readPort(6, portConfigInputs[6]), false); if (TOTAL_PORTS > 7 && reportPINs[7]) outputPort(7, readPort(7, portConfigInputs[7]), false); if (TOTAL_PORTS > 8 && reportPINs[8]) outputPort(8, readPort(8, portConfigInputs[8]), false); if (TOTAL_PORTS > 9 && reportPINs[9]) outputPort(9, readPort(9, portConfigInputs[9]), false); if (TOTAL_PORTS > 10 && reportPINs[10]) outputPort(10, readPort(10, portConfigInputs[10]), false); if (TOTAL_PORTS > 11 && reportPINs[11]) outputPort(11, readPort(11, portConfigInputs[11]), false); if (TOTAL_PORTS > 12 && reportPINs[12]) outputPort(12, readPort(12, portConfigInputs[12]), false); if (TOTAL_PORTS > 13 && reportPINs[13]) outputPort(13, readPort(13, portConfigInputs[13]), false); if (TOTAL_PORTS > 14 && reportPINs[14]) outputPort(14, readPort(14, portConfigInputs[14]), false); if (TOTAL_PORTS > 15 && reportPINs[15]) outputPort(15, readPort(15, ©Adafruit Industries Page 62 of 177 portConfigInputs[15]), false); } // ----------------------------------------------------------------------------/* sets the pin mode to the correct state and sets the relevant bits in the * two bit-arrays that track Digital I/O and PWM status */ void setPinModeCallback(byte pin, int mode) { if (Firmata.getPinMode(pin) == PIN_MODE_IGNORE) return; if (Firmata.getPinMode(pin) == PIN_MODE_I2C && isI2CEnabled && mode != PIN_MODE_I2C) { // disable i2c so pins can be used for other functions // the following if statements should reconfigure the pins properly disableI2CPins(); } if (IS_PIN_DIGITAL(pin) && mode != PIN_MODE_SERVO) { if (servoPinMap[pin] < MAX_SERVOS && servos[servoPinMap[pin]].attached()) { detachServo(pin); } } if (IS_PIN_ANALOG(pin)) { reportAnalogCallback(PIN_TO_ANALOG(pin), mode == PIN_MODE_ANALOG ? 1 : 0); // turn on/off reporting } if (IS_PIN_DIGITAL(pin)) { if (mode == INPUT || mode == PIN_MODE_PULLUP) { portConfigInputs[pin / 8] |= (1 getPeerName(peer_name, sizeof(peer_name)); Serial.print("[Prph] Connected to "); Serial.println(peer_name); } void prph_disconnect_callback(uint16_t conn_handle, uint8_t reason) { (void) conn_handle; (void) reason; Serial.println(); Serial.println("[Prph] Disconnected"); } void prph_bleuart_rx_callback(uint16_t conn_handle) { (void) conn_handle; // Forward data from Mobile to our peripheral char str[20+1] = { 0 }; bleuart.read(str, 20); Serial.print("[Prph] RX: "); Serial.println(str); if ( clientUart.discovered() ) { clientUart.print(str); }else { bleuart.println("[Prph] Central role not connected"); ©Adafruit Industries Page 83 of 177 } } /*------------------------------------------------------------------*/ /* Central *------------------------------------------------------------------*/ void scan_callback(ble_gap_evt_adv_report_t* report) { // Since we configure the scanner with filterUuid() // Scan callback only invoked for device with bleuart service advertised // Connect to the device with bleuart service in advertising packet Bluefruit.Central.connect(report); } void cent_connect_callback(uint16_t conn_handle) { // Get the reference to current connection BLEConnection* connection = Bluefruit.Connection(conn_handle); char peer_name[32] = { 0 }; connection->getPeerName(peer_name, sizeof(peer_name)); Serial.print("[Cent] Connected to "); Serial.println(peer_name);; if ( clientUart.discover(conn_handle) ) { // Enable TXD's notify clientUart.enableTXD(); }else { // disconnect since we couldn't find bleuart service Bluefruit.disconnect(conn_handle); } } void cent_disconnect_callback(uint16_t conn_handle, uint8_t reason) { (void) conn_handle; (void) reason; Serial.println("[Cent] Disconnected"); } /** * Callback invoked when uart received data * @param cent_uart Reference object to the service where the data * arrived. In this example it is clientUart */ void cent_bleuart_rx_callback(BLEClientUart& cent_uart) { char str[20+1] = { 0 }; cent_uart.read(str, 20); Serial.print("[Cent] RX: "); Serial.println(str); if ( bleuart.notifyEnabled() ) { // Forward data from our peripheral to Mobile bleuart.print( str ); }else { // response with no prph message clientUart.println("[Cent] Peripheral role not connected"); } } ©Adafruit Industries Page 84 of 177 Custom: Central HRM The BLEClientService and BLEClientCharacteristic classes can be used to implement any custom or officially adopted BLE service of characteristic on the client side (most often is Central) using a set of basic properties and callback handlers. The example below shows how to use these classes to implement the Heart Rate Monitor (https://adafru.it/vaO) service, as defined by the Bluetooth SIG. To run this example, you will need an extra nRF52 running peripheral HRM sketch (https:// adafru.it/Cnf) HRM Service Definition UUID: 0x180D (https://adafru.it/vaO) Only the first characteristic is mandatory, but we will also implement the optional Body Sensor Location characteristic. Heart Rate Control Point won't be used in this example to keep things simple. Implementing the HRM Service and Characteristics The core service and the first two characteristics can be implemented with the following code: First, define the BLEService and BLECharacteristic variables that will be used in your project: /* HRM Service Definitions * Heart Rate Monitor Service: 0x180D * Heart Rate Measurement Char: 0x2A37 (Mandatory) * Body Sensor Location Char: 0x2A38 (Optional) */ BLEClientService hrms(UUID16_SVC_HEART_RATE); BLEClientCharacteristic hrmc(UUID16_CHR_HEART_RATE_MEASUREMENT); BLEClientCharacteristic bslc(UUID16_CHR_BODY_SENSOR_LOCATION); Then you need to initialize those variables by calling their begin(). // Initialize HRM client hrms.begin(); ©Adafruit Industries Page 85 of 177 // Initialize client characteristics of HRM. // Note: Client Char will be added to the last service that is begin()ed. bslc.begin(); // set up callback for receiving measurement hrmc.setNotifyCallback(hrm_notify_callback); hrmc.begin(); Client Service + Characteristic Code Analysis 1. The first thing to do is to call .begin() on the BLEClientService (hrms above). Since the UUID is set in the object declaration at the top of the sketch, there is normally nothing else to do with the BLEClientService instance. You MUST call .begin() on the BLEClientService before adding any BLEClientCharacteristics. Any BLEClientCharacteristic will automatically be added to the last BLEClientService that was `begin()'ed! 2. Since Heart Rate Measurement characteristic (clientMeasurement above) is notifiab le. You need to set up callback for it • ' hrmc.setNotifyCallback(hrm_notify_callback); ' This sets the callback that will be fired when we receive a Notify message from peripheral. This is needed to handle notifiable characteristic since callback allow us to response to the message in timely manner. For this example is just simply printing out value to Serial. • ' hrmc.begin(); ' Once all of the properties have been set, you must call .begin () which will add the characteristic definition to the last BLEClientService that was '.begin()ed'. Note for characteristic that does not support notify e.g body sensor location , we can simply use .read() to retrieve its value. 3. Next, we can start to scan and connect to peripheral that advertises HRM service. Once connected, we need to go through peripheral GATT table to find out the Gatt handle for our interest. In this example they are handle for hrms, hrmc and bslc. This looking up process for interested service/characteristic is called Discovery.  Note: Gatt handle (or just handle) is required to perform any operations at all such as read, write, enable notify. It is required that a client characteristic must be discovered before we could doing anything with it. ©Adafruit Industries Page 86 of 177 The service should be discovered before we could discover its characteristic. This can be done by calling  hrms.discover(conn_handle)  . Where conn_handle is the connection ID i.e peripheral that we want to discover since it is possible for Bluefruit nRF52 to connect to multiple peripherals concurrently. If the service is found, the function will return true, otherwise false. // Connect Callback Part 1 void connect_callback(uint16_t conn_handle) { Serial.println("Connected"); Serial.print("Discovering HRM Service ... "); // If HRM is not found, disconnect and return if ( !hrms.discover(conn_handle) ) { Serial.println("Found NONE"); // disconect since we couldn't find HRM service Bluefruit.Central.disconnect(conn_handle); return; } // Once HRM service is found, we continue to discover its characteristic Serial.println("Found it"); ............. } 4. Afterwards, we continue to discover all the interested characteristics within the service by calling  .discover() . The function return true if characteristics is found, and false otherwise. You could also check with  .discovered()  function. A service could contain more characteristics but we don't need to discover them all, only those that we want to interact with. Advanced: Alternatively, you could discover all the interested characteristics of a service within a  function call by using Bluefruit.Discovery.discoverCharacteristic()  (not used in the example). The API can take up to 5 characteristics, if you need more, the variant with passing array of characteristics is also available. The function will return the number of characteristic it found. Note: when a characteristic is discovered by above API, all necessarily meta data such as handles, properties ( read,write, notify etc ...), cccd handle  will be updated automatically. You can then use BLECLientCharacteristic (https://adafru.it/Cng) API such as read(), write(), enableNotify() on it provided that its properties support such as operation.  // Connect Callback Part 2 void connect_callback(uint16_t conn_handle) { ©Adafruit Industries Page 87 of 177 Serial.print("Discovering Measurement characteristic ... "); if ( !hrmc.discover() ) { // Measurement chr is mandatory, if it is not found (valid), then disconnect Serial.println("not found !!!"); Serial.println("Measurement characteristic is mandatory but not found"); Bluefruit.Central.disconnect(conn_handle); return; } Serial.println("Found it"); // Measurement is found, continue to look for option Body Sensor Location // https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.characteristic.body_sensor_location.xml // Body Sensor Location is optional, print out the location in text if present Serial.print("Discovering Body Sensor Location characteristic ... "); if ( bslc.discover() ) { Serial.println("Found it"); // Body sensor location value is 8 bit const char* body_str[] = { "Other", "Chest", "Wrist", "Finger", "Hand", "Ear Lobe", "Foot" }; // Read 8-bit BSLC value from peripheral uint8_t loc_value = bslc.read8(); Serial.print("Body Location Sensor: "); Serial.println(body_str[loc_value]); }else { Serial.println("Found NONE"); } ............... } 5. Once hrmc is discovered, you should enable its notification by calling hrmc.enableNotify() . If this succeeded (return true), peripheral can now send data to us using notify message. Which will trigger the callback that we setup earlier to handle incoming data. // Connect Callback Part 3 void connect_callback(uint16_t conn_handle) { ....... // Reaching here means we are ready to go, let's enable notification on measurement chr if ( hrmc.enableNotify() ) { Serial.println("Ready to receive HRM Measurement value"); }else { Serial.println("Couldn't enable notify for HRM Measurement. Increase DEBUG LEVEL for troubleshooting"); } } /** * Hooked callback that triggered when a measurement value is sent from peripheral * @param chr Pointer to client characteristic that even occurred, * in this example it should be hrmc ©Adafruit Industries Page 88 of 177 * @param data Pointer to received data * @param len Length of received data */ void hrm_notify_callback(BLEClientCharacteristic* chr, uint8_t* data, uint16_t len) { // https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.characteristic.heart_rate_measurement.xml // Measurement contains of control byte0 and measurement (8 or 16 bit) + optional field // if byte0's bit0 is 0 --> measurement is 8 bit, otherwise 16 bit. Serial.print("HRM Measurement: "); if ( data[0] & bit(0) ) { uint16_t value; memcpy(&value, data+1, 2); Serial.println(value); } else { Serial.println(data[1]); } } Full Sample Code The full sample code for this example can be seen below: /********************************************************************* This is an example for our nRF52 based Bluefruit LE modules Pick one up today in the adafruit shop! Adafruit invests time and resources providing this open source code, please support Adafruit and open-source hardware by purchasing products from Adafruit! MIT license, check LICENSE for more information All text above, and the splash screen below must be included in any redistribution *********************************************************************/ #include /* HRM Service Definitions * Heart Rate Monitor Service: 0x180D * Heart Rate Measurement Char: 0x2A37 * Body Sensor Location Char: 0x2A38 */ BLEService hrms = BLEService(UUID16_SVC_HEART_RATE); BLECharacteristic hrmc = BLECharacteristic(UUID16_CHR_HEART_RATE_MEASUREMENT); BLECharacteristic bslc = BLECharacteristic(UUID16_CHR_BODY_SENSOR_LOCATION); BLEDis bledis; BLEBas blebas; uint8_t // DIS (Device Information Service) helper class instance // BAS (Battery Service) helper class instance bps = 0; void setup() { Serial.begin(115200); while ( !Serial ) delay(10); ©Adafruit Industries // for nrf52840 with native usb Page 89 of 177 Serial.println("Bluefruit52 HRM Example"); Serial.println("-----------------------\n"); // Initialise the Bluefruit module Serial.println("Initialise the Bluefruit nRF52 module"); Bluefruit.begin(); // Set the connect/disconnect callback handlers Bluefruit.Periph.setConnectCallback(connect_callback); Bluefruit.Periph.setDisconnectCallback(disconnect_callback); // Configure and Start the Device Information Service Serial.println("Configuring the Device Information Service"); bledis.setManufacturer("Adafruit Industries"); bledis.setModel("Bluefruit Feather52"); bledis.begin(); // Start the BLE Battery Service and set it to 100% Serial.println("Configuring the Battery Service"); blebas.begin(); blebas.write(100); // Setup the Heart Rate Monitor service using // BLEService and BLECharacteristic classes Serial.println("Configuring the Heart Rate Monitor Service"); setupHRM(); // Setup the advertising packet(s) Serial.println("Setting up the advertising payload(s)"); startAdv(); Serial.println("Ready Player One!!!"); Serial.println("\nAdvertising"); } void startAdv(void) { // Advertising packet Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE); Bluefruit.Advertising.addTxPower(); // Include HRM Service UUID Bluefruit.Advertising.addService(hrms); // Include Name Bluefruit.Advertising.addName(); /* Start Advertising * - Enable auto advertising if disconnected * - Interval: fast mode = 20 ms, slow mode = 152.5 ms * - Timeout for fast mode is 30 seconds * - Start(timeout) with timeout = 0 will advertise forever (until connected) * * For recommended advertising interval * https://developer.apple.com/library/content/qa/qa1931/_index.html */ Bluefruit.Advertising.restartOnDisconnect(true); Bluefruit.Advertising.setInterval(32, 244); // in unit of 0.625 ms Bluefruit.Advertising.setFastTimeout(30); // number of seconds in fast mode Bluefruit.Advertising.start(0); // 0 = Don't stop advertising after n seconds } void setupHRM(void) { // Configure the Heart Rate Monitor service // See: https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.service.heart_rate.xml ©Adafruit Industries Page 90 of 177 // Supported Characteristics: // Name // ---------------------------// Heart Rate Measurement // Body Sensor Location // Heart Rate Control Point hrms.begin(); // // // // UUID -----0x2A37 0x2A38 0x2A39 Requirement ----------Mandatory Optional Conditional Properties ---------Notify Read Write getPeerName(central_name, sizeof(central_name)); ©Adafruit Industries Page 91 of 177 Serial.print("Connected to "); Serial.println(central_name); } /** * Callback invoked when a connection is dropped * @param conn_handle connection where this event happens * @param reason is a BLE_HCI_STATUS_CODE which can be found in ble_hci.h */ void disconnect_callback(uint16_t conn_handle, uint8_t reason) { (void) conn_handle; (void) reason; Serial.print("Disconnected, reason = 0x"); Serial.println(reason, HEX); Serial.println("Advertising!"); } void cccd_callback(uint16_t conn_hdl, BLECharacteristic* chr, uint16_t cccd_value) { // Display the raw request packet Serial.print("CCCD Updated: "); //Serial.printBuffer(request->data, request->len); Serial.print(cccd_value); Serial.println(""); // Check the characteristic this CCCD update is associated with in case // this handler is used for multiple CCCD records. if (chr->uuid == hrmc.uuid) { if (chr->notifyEnabled(conn_hdl)) { Serial.println("Heart Rate Measurement 'Notify' enabled"); } else { Serial.println("Heart Rate Measurement 'Notify' disabled"); } } } void loop() { digitalToggle(LED_RED); if ( Bluefruit.connected() ) { uint8_t hrmdata[2] = { 0b00000110, bps++ }; increment BPS value // Sensor connected, // // // if Note: We use .notify instead of .write! If it is connected but CCCD is not enabled The characteristic's value is still updated although notification is not sent ( hrmc.notify(hrmdata, sizeof(hrmdata)) ){ Serial.print("Heart Rate Measurement updated to: "); Serial.println(bps); }else{ Serial.println("ERROR: Notify not set in the CCCD or not connected!"); } } // Only send update once per second delay(1000); } Arduino Bluefruit nRF52 API The Adafruit nRF52 core defines a number of custom classes that aim to make it easy to work with BLE in your projects. ©Adafruit Industries Page 92 of 177 The key classes are listed below, and examined in more detail elsewhere in this learning guide: • AdafruitBluefruit is the main entry point to the Adafruit Bluefruit nRF52 API. This class exposes a number of essential functions and classes, such as advertising, the list of GATT services and characteristics defined on your device, and connection status. • BLEService is a wrapper class for BLE GATT service records, and can be used to define custom service definitions, or acts as the base class for any service helper classes. • BLECharacteristic is a wrapper class for a BLE GATT characteristic record, and can be used to define custom characteristics, or acts as  the base class for any characteristic helper classes. • BLEDis is a helper class for the DIS or 'Device Information Service'. • BLEUart is a helper class for the NUS or 'Nordic UART Service'. • BLEBeacon is a helper class to configure your nRF52 as a beacon using the advertising packet to send out properly formatted beacon data. • BLEMidi is a helper class to work with MIDI data over BLE. • BLEHidAdafruit is a helper class to emulate an HID mouse or keyboard over BLE. Details on each of these helper classes are found further in this learning guide. AdafruitBluefruit Adafruit's nRF52 BSP codebase is still undergoing active development based on customer feedback and testing. As such, the class documentation here may be incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 This base class is the main entry point to the Adafruit Bluefruit nRF52 API, and exposes most of the helper classes and functions that you use to configure your device. API AdafruitBluefruit has the following public API: ©Adafruit Industries Page 93 of 177 // Constructor AdafruitBluefruit(void); /*------------------------------------------------------------------*/ /* Lower Level Classes (Bluefruit.Advertising.*, etc.) *------------------------------------------------------------------*/ BLEGap Gap; BLEGatt Gatt; BLEAdvertising BLEAdvertisingData BLEScanner BLECentral BLEDiscovery Advertising; ScanResponse; Scanner; Central; Discovery; /*------------------------------------------------------------------*/ /* SoftDevice Configure Functions, must call before begin(). * These function affect the SRAM consumed by SoftDevice. *------------------------------------------------------------------*/ void configServiceChanged (bool changed); void configUuid128Count (uint8_t uuid128_max); void configAttrTableSize (uint32_t attr_table_size); // Config Bandwidth for connections void configPrphConn (uint16_t mtu_max, uint8_t event_len, uint8_t hvn_qsize, uint8_t wrcmd_qsize); void configCentralConn (uint16_t mtu_max, uint8_t event_len, uint8_t hvn_qsize, uint8_t wrcmd_qsize); // Convenient function to config connection void configPrphBandwidth (uint8_t bw); void configCentralBandwidth(uint8_t bw); err_t begin(uint8_t prph_count = 1, uint8_t central_count = 0); /*------------------------------------------------------------------*/ /* General Functions *------------------------------------------------------------------*/ void setName (const char* str); uint8_t getName (char* name, uint16_t bufsize); bool int8_t setTxPower getTxPower bool setApperance uint16_t getApperance void void (int8_t power); (void); (uint16_t appear); (void); autoConnLed (bool enabled); setConnLedInterval (uint32_t ms); /*------------------------------------------------------------------*/ /* GAP, Connections and Bonding *------------------------------------------------------------------*/ bool connected (void); bool disconnect (void); bool bool setConnInterval (uint16_t min, uint16_t max); setConnIntervalMS (uint16_t min_ms, uint16_t max_ms); uint16_t connHandle bool connPaired uint16_t connInterval (void); (void); (void); bool void (void); (void); requestPairing clearBonds ble_gap_addr_t getPeerAddr (void); uint8_t getPeerAddr (uint8_t addr[6]); ©Adafruit Industries Page 94 of 177 void printInfo(void); /*------------------------------------------------------------------*/ /* Callbacks *------------------------------------------------------------------*/ void setConnectCallback ( BLEGap::connect_callback_t fp); void setDisconnectCallback( BLEGap::disconnect_callback_t fp); These functions are generally available via 'Bluefruit.*'. For example, to check the connection status in your sketch you could run ' if (Bluefruit.connected()) { ... } '. Examples For examples of how to work with the parent Bluefruit class, see the Examples section later in this guide. It's better to examine this class in the context of a real world use case. You can also browse the latest example code online via Github: Browse the latest example code on Github https://adafru.it/vaK BLEGap This page is a work in progress as the API is changing as we migrate to S132v5 (nRF52832) and S140 (nRF52840) and add better Central mode support. This GAP API for Bluefruit is accessible via  Bluefruit.Gap.***  and has the following public functions: typedef void (*connect_callback_t ) (uint16_t conn_handle); typedef void (*disconnect_callback_t ) (uint16_t conn_handle, uint8_t reason); uint8_t bool getAddr setAddr bool connected (uint16_t conn_handle); uint8_t getRole (uint16_t conn_handle); uint8_t getPeerAddr ble_gap_addr_t getPeerAddr uint16_t getPeerName bufsize); ©Adafruit Industries (uint8_t mac[6]); (uint8_t mac[6], uint8_t type); (uint16_t conn_handle, uint8_t addr[6]); (uint16_t conn_handle); (uint16_t conn_handle, char* buf, uint16_t Page 95 of 177 uint16_t uint16_t uint16_t getMTU getMaxMtuByConnCfg getMaxMtu (uint16_t conn_handle); (uint8_t conn_cfg); (uint8_t conn_handle); BLEAdvertising The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 'Advertising' is what makes your Bluetooth Low Energy devices visible to other devices in listening range. The radio sends out specially formatter advertising packets that contain information like the device name, whether you can connect to the device (or if it only advertises), etc. You can also include custom data in the advertising packet, which is essential how beacons work. The BLEAdvertisingData and BLEAdvertising classes exposes a number of helper functions to make it easier to create well-formatted advertising packets, as well as to use the Scan Response option, which is an optional secondary advertising packet that can be requested by a Central device. (This gives you another 27 bytes of advertising data, but isn't sent out automatically like the main advertising packet.). This two advertising packets are accessible via the parent AdafruitBluefruit class, calling ' Bluefruit.Advertising.* ' and ' Bluefruit.ScanResponse.* ' from your user sketches. For examples of using these helper classes, see any of the examples later on in this guide, since all devices will advertise as part of the startup process. API The BLEAdvertisingData class has the following public API: /*------------- Adv Data -------------*/ bool addData(uint8_t type, const void* data, uint8_t len); bool addFlags(uint8_t flags); bool addTxPower(void); bool addName(void); bool addAppearance(uint16_t appearance); bool addManufacturerData(const void* data, uint8_t count); ©Adafruit Industries Page 96 of 177 /*------------- UUID bool addUuid(BLEUuid bool addUuid(BLEUuid bool addUuid(BLEUuid bool addUuid(BLEUuid bleuuid4); -------------*/ bleuuid); bleuuid1, BLEUuid bleuuid2); bleuuid1, BLEUuid bleuuid2, BLEUuid bleuuid3); bleuuid1, BLEUuid bleuuid2, BLEUuid bleuuid3, BLEUuid bool addUuid(BLEUuid bleuuid[], uint8_t count); /*------------- Service -------------*/ bool addService(BLEService& service); bool addService(BLEService& service1, BLEService& service2); bool addService(BLEService& service1, BLEService& service2, BLEService& service3); bool addService(BLEService& service1, BLEService& service2, BLEService& service3, BLEService& service4); /*------------- Client Service -------------*/ bool addService(BLEClientService& service); // Functions to work with the raw advertising packet uint8_t count(void); uint8_t* getData(void); bool setData(const uint8_t* data, uint8_t count); void clearData(void); bool setData(Advertisable& adv_able) { return adv_able.setAdv(*this); } In addition to API from BLEAdvertisingData, The BLEAdvertising class also has functions that dictate the behavior of advertising such as slow/fast timeout, adv intervals, and callbacks etc...    typedef void (*stop_callback_t) (void); typedef void (*slow_callback_t) (void); void setType(uint8_t adv_type); void setFastTimeout(uint16_t sec); void setSlowCallback(slow_callback_t fp); void setStopCallback(stop_callback_t fp); void setInterval (uint16_t fast, uint16_t slow); void setIntervalMS(uint16_t fast, uint16_t slow); uint16_t getInterval(void); bool setBeacon(BLEBeacon& beacon); bool setBeacon(EddyStoneUrl& eddy_url); bool isRunning(void); void restartOnDisconnect(bool enable); bool start(uint16_t timeout = 0); bool stop (void); Related Information • Generic Access Profile (https://adafru.it/vaL): This page contains the official list of assigned numbers for the 'Data' type field. Data is inserted into the ©Adafruit Industries Page 97 of 177 advertising packet by supplying a valid 'data' type, optionally followed by a properly formatted payload corresponding to the selected value. Example For practical example code, see the Examples section later on in this guide. The snippet below is provided for illustration purposes, but advertising should be examined in the context of a real use case since it varies from one setup to the next! void setup(void) { // Other startup code here // ... // Set up Advertising Packet setupAdv(); // Start Advertising Bluefruit.Advertising.start(); } void startAdv(void) { // Advertising packet Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE); Bluefruit.Advertising.addTxPower(); // Include bleuart 128-bit uuid Bluefruit.Advertising.addService(bleuart); // Secondary Scan Response packet (optional) // Since there is no room for 'Name' in Advertising packet Bluefruit.ScanResponse.addName(); /* Start Advertising * - Enable auto advertising if disconnected * - Interval: fast mode = 20 ms, slow mode = 152.5 ms * - Timeout for fast mode is 30 seconds * - Start(timeout) with timeout = 0 will advertise forever (until connected) * * For recommended advertising interval * https://developer.apple.com/library/content/qa/qa1931/_index.html */ Bluefruit.Advertising.restartOnDisconnect(true); Bluefruit.Advertising.setInterval(32, 244); // in unit of 0.625 ms Bluefruit.Advertising.setFastTimeout(30); // number of seconds in fast mode Bluefruit.Advertising.start(0); // 0 = Don't stop advertising after n seconds } BLEScanner The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is ©Adafruit Industries Page 98 of 177 incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 This documentation is based on BSP 0.7.0 and higher. Please make sure you have an up to date version before using the code below. The BLEScanner class is used in Central Mode, and facilitates scanning for BLE peripherals in range and parsing the advertising data that is being sent out by the peripherals. The BLEScanner class is normally accessed via the Bluefruit class (instantiated at startup), as shown below: /* Start Central Scanning * - Enable auto scan if disconnected * - Filter for devices with a min RSSI of -80 dBm * - Interval = 100 ms, window = 50 ms * - Use active scan (requests the optional scan response packet) * - Start(0) = will scan forever since no timeout is given */ Bluefruit.Scanner.setRxCallback(scan_callback); Bluefruit.Scanner.restartOnDisconnect(true); Bluefruit.Scanner.filterRssi(-80); // Only invoke callback when RSSI >= -80 dBm Bluefruit.Scanner.setInterval(160, 80); // in units of 0.625 ms Bluefruit.Scanner.useActiveScan(true); // Request scan response data Bluefruit.Scanner.start(0); // 0 = Don't stop scanning after n seconds API BLEScanner has the following public API: typedef void (*rx_callback_t) (ble_gap_evt_adv_report_t*); typedef void (*stop_callback_t) (void); BLEScanner(void); ble_gap_scan_params_t* getParams(void); bool isRunning(void); void void void void useActiveScan(bool enable); setInterval(uint16_t interval, uint16_t window); setIntervalMS(uint16_t interval, uint16_t window); restartOnDisconnect(bool enable); void filterRssi(int8_t min_rssi); void filterMSD(uint16_t manuf_id); void void void void filterUuid(BLEUuid filterUuid(BLEUuid filterUuid(BLEUuid filterUuid(BLEUuid ©Adafruit Industries ble_uuid); ble_uuid1, BLEUuid ble_uuid2); ble_uuid1, BLEUuid ble_uuid2, BLEUuid ble_uuid3); ble_uuid1, BLEUuid ble_uuid2, BLEUuid ble_uuid3, BLEUuid Page 99 of 177 ble_uuid4); void filterUuid(BLEUuid ble_uuid[], uint8_t count); void clearFilters(void); bool start(uint16_t timeout = 0); bool stop(void); /*------------- Callbacks -------------*/ void setRxCallback(rx_callback_t fp); void setStopCallback(stop_callback_t fp); /*------------- Data Parser -------------*/ uint8_t parseReportByType(const uint8_t* scandata, uint8_t scanlen, uint8_t type, uint8_t* buf, uint8_t bufsize = 0); uint8_t parseReportByType(const ble_gap_evt_adv_report_t* report, uint8_t type, uint8_t* buf, uint8_t bufsize = 0); bool checkReportForUuid(const ble_gap_evt_adv_report_t* report, BLEUuid ble_uuid); bool checkReportForService(const ble_gap_evt_adv_report_t* report, BLEClientService svc); bool checkReportForService(const ble_gap_evt_adv_report_t* report, BLEService svc); setRxCallback(rx_callback_t fp) Whenever a valid advertising packet is detected (based on any optional filters that are applied in the BLEScanner class), a dedicated callback function (see rx_callback_t ) will be called. The callback function has the following signature: NOTE: ble_gap_evt_adv_report_t is part of the Nordic nRF52 SD and is defined in ble_gap.h void scan_callback(ble_gap_evt_adv_report_t* report) { /* Display the timestamp and device address */ if (report->scan_rsp) { /* This is a Scan Response packet */ Serial.printf("[SR%10d] Packet received from ", millis()); } else { /* This is a normal advertising packet */ Serial.printf("[ADV%9d] Packet received from ", millis()); } Serial.printBuffer(report->peer_addr.addr, 6, ':'); Serial.print("\n"); /* Raw buffer contents */ Serial.printf("%14s %d bytes\n", "PAYLOAD", report->dlen); if (report->dlen) { Serial.printf("%15s", " "); Serial.printBuffer(report->data, report->dlen, '-'); Serial.println(); ©Adafruit Industries Page 100 of 177 } /* RSSI value */ Serial.printf("%14s %d dBm\n", "RSSI", report->rssi); /* Adv Type */ Serial.printf("%14s ", "ADV TYPE"); switch (report->type) { case BLE_GAP_ADV_TYPE_ADV_IND: Serial.printf("Connectable undirected\n"); break; case BLE_GAP_ADV_TYPE_ADV_DIRECT_IND: Serial.printf("Connectable directed\n"); break; case BLE_GAP_ADV_TYPE_ADV_SCAN_IND: Serial.printf("Scannable undirected\n"); break; case BLE_GAP_ADV_TYPE_ADV_NONCONN_IND: Serial.printf("Non-connectable undirected\n"); break; } /* Check for BLE UART UUID */ if ( Bluefruit.Scanner.checkReportForUuid(report, BLEUART_UUID_SERVICE) ) { Serial.printf("%14s %s\n", "BLE UART", "UUID Found!"); } /* Check for DIS UUID */ if ( Bluefruit.Scanner.checkReportForUuid(report, UUID16_SVC_DEVICE_INFORMATION) ) { Serial.printf("%14s %s\n", "DIS", "UUID Found!"); } Serial.println(); } void useActiveScan(bool enable); Enabling 'Active Scan' by setting the enable  parameter to 1 will cause the device to request the optional Scan Response advertising packet, which is a second 31 byte advertising packet that can be used to transmit additional information. By default active scanning is disabled, so no Scan Response packets will be received by BLEScanner unless this function is called and set to 1 before calling Bluefruit.Scanner.start(0) . ©Adafruit Industries Page 101 of 177 void filterRssi(int8_t min_rssi); void filterMSD(uint16_t manuf_id); void filterUuid(BLEUuid ble_uuid); void filterUuid(BLEUuid ble_uuid1, BLEUuid ble_uuid2); void filterUuid(BLEUuid ble_uuid1, BLEUuid ble_uuid2, BLEUuid ble_uuid3); void filterUuid(BLEUuid ble_uuid1, BLEUuid ble_uuid2, BLEUuid ble_uuid3, BLEUuid ble_uuid4); void filterUuid(BLEUuid ble_uuid[], uint8_t count); Filters can be applied to BLEScanner to narrow down the data sent to the callback handler, and make processing advertising packets easier for you. As of BSP 0.7.0 the following three filters are present: • filterRssi(int8_t min_rssi) : Filters advertising results to devices with at least the specified RSSI value, which allows you to ignore devices that are too far away or whose signal is too weak. The higher the number, the strong the signal so -90 is a very weak signal, and -60 is a much stronger one. • filterUuid(BLEUuid ble_uuid) : Filters advertising results to devices that advertise themselves as having the specified service UUID. If multiple UUIDs are entered, they will be filtered with boolean OR logic, meaning any single UUID present will be considered a match. • void filterMSD(uint16_t manuf_id) : Fitlers advertising results to devices that contain a Manufacturer Specific Data data type, and who use the specifed Bluetooth Customer ID ( manuf_id) . This can be useful to filter iBeacon versus Eddystone devices, for example, which both used the MSD field, or to look for custom MSD data matching your own CID. When multiple UUIDs are added via one of the .filterUuid(...) functions, they UUIDs will be filtered using boolean 'OR' logic, meaning that the callback will fire when ANY of the specified UUIDs are detected in the advertising packet. void clearFilters(void); This function clears and filter values set using the functions above. ©Adafruit Industries Page 102 of 177 bool start(uint16_t timeout = 0); bool stop(void); The .start and .stop functions can be used to start and stop scanning, and should be called after all of the main parameters (timing, filters, etc.) have been set. The .start function has a single parameter called timeout, which sets the number of seconds to scan for advertising packets. Setting this to '0' (the default value) will cause the device to scan forever. Make sure you set any filters of BLEScanner parameters before calling .start! void restartOnDisconnect(bool enable); Setting this function to '1' will cause the scanning process to start again as soon as you disconnect from a peripheral device. The default behaviour is to automatically restart scanning on disconnect. Examples For an example that uses almost all of the BLEScanner and advertising API in Central mode, see central_scan_advanced.ino (https://adafru.it/y5a) in the Central examples folder. central_scan_advanced.ino on Github https://adafru.it/y5a This example is only available in BSP 0.7.0 and higher! BLEService The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 ©Adafruit Industries Page 103 of 177 This base class is used when defining custom BLE Gatt Services, such as the various service helper classes that make up the Adafruit Bluefruit nRF52 API described here. Unless you are implementing a custom GATT service and characteristic, you normally won't use this base class directly, and would instantiate and call a higher level helper service or characteristic included in the Bluefruit nRF52 API. Basic Usage There are normally only two operation required to use the BLEService class: You need to declare and instantiate the class with an appropriate 16-bit or 128-bit UUID in the constructor: BLEService myService = BLEService(0x1234); You then need to call the .begin() method on the instance before adding any BLECharacteristics to it (via the BLECharacteristic's respective .begin() function call): myService.begin(); Order of Operations (Important!) One very important thing to take into consideration when working with BLEService and BLECharacteristic, is that any BLECharacteristic will automatically be added to the last BLEService that had it's `.begin()` function called. As such, you must call yourService.begin() before adding any characteristics! See the example at the bottom of this page for a concrete example of how this works in practice. API BLEService has the following overall class structure: ©Adafruit Industries Page 104 of 177 This documentation may be slightly out of date as bugs are fixed, and the API develops. You should always consult the Github repo for the definitive latest code release and class definitions! BLEUuid uuid; static BLEService* lastService; BLEService(void); BLEService(uint16_t uuid16); BLEService(uint8_t const uuid128[]); void setUuid(uint16_t uuid16); void setUuid(uint8_t const uuid128[]); virtual err_t begin(void); Example The following example declares a HRM (Heart Rate Monitor) service, and assigns some characteristics to it: Note that this example code is incomplete. For the full example open the 'custom_hrm' example that is part of the nRF52 BSP! The code below is for illustration purposes only. /* HRM Service Definitions * Heart Rate Monitor Service: 0x180D * Heart Rate Measurement Char: 0x2A37 * Body Sensor Location Char: 0x2A38 */ BLEService hrms = BLEService(UUID16_SVC_HEART_RATE); BLECharacteristic hrmc = BLECharacteristic(UUID16_CHR_HEART_RATE_MEASUREMENT); BLECharacteristic bslc = BLECharacteristic(UUID16_CHR_BODY_SENSOR_LOCATION); void setupHRM(void) { // Configure the Heart Rate Monitor service // See: https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.service.heart_rate.xml // Supported Characteristics: // Name UUID Requirement Properties // ---------------------------- ------ ----------- ---------// Heart Rate Measurement 0x2A37 Mandatory Notify // Body Sensor Location 0x2A38 Optional Read // Heart Rate Control Point 0x2A39 Conditional Write here hrms.begin(); // // // // <-- Not used Note: You must call .begin() on the BLEService before calling .begin() on any characteristic(s) within that service definition.. Calling .begin() on a BLECharacteristic will cause it to be added to the last BLEService that was 'begin()'ed! // Configure the Heart Rate Measurement characteristic ©Adafruit Industries Page 105 of 177 // See: https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.characteristic.heart_rate_measurement.xml // Permission = Notify // Min Len = 1 // Max Len = 8 // B0 = UINT8 - Flag (MANDATORY) // b5:7 = Reserved // b4 = RR-Internal (0 = Not present, 1 = Present) // b3 = Energy expended status (0 = Not present, 1 = Present) // b1:2 = Sensor contact status (0+1 = Not supported, 2 = Supported but contact not detected, 3 = Supported and detected) // b0 = Value format (0 = UINT8, 1 = UINT16) // B1 = UINT8 - 8-bit heart rate measurement value in BPM // B2:3 = UINT16 - 16-bit heart rate measurement value in BPM // B4:5 = UINT16 - Energy expended in joules // B6:7 = UINT16 - RR Internal (1/1024 second resolution) hrmc.setProperties(CHR_PROPS_NOTIFY); hrmc.setPermission(SECMODE_OPEN, SECMODE_NO_ACCESS); hrmc.setFixedLen(2); hrmc.setCccdWriteCallback(cccd_callback); // Optionally capture CCCD updates hrmc.begin(); uint8_t hrmdata[2] = { 0b00000110, 0x40 }; // Set the characteristic to use 8-bit values, with the sensor connected and detected hrmc.notify(hrmdata, 2); // Use .notify instead of .write! // Configure the Body Sensor Location characteristic // See: https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.characteristic.body_sensor_location.xml // Permission = Read // Min Len = 1 // Max Len = 1 // B0 = UINT8 - Body Sensor Location // 0 = Other // 1 = Chest // 2 = Wrist // 3 = Finger // 4 = Hand // 5 = Ear Lobe // 6 = Foot // 7:255 = Reserved bslc.setProperties(CHR_PROPS_READ); bslc.setPermission(SECMODE_OPEN, SECMODE_NO_ACCESS); bslc.setFixedLen(1); bslc.begin(); bslc.write8(2); // Set the characteristic to 'Wrist' (2) } void cccd_callback(BLECharacteristic& chr, uint16_t cccd_value) { // Display the raw request packet Serial.print("CCCD Updated: "); //Serial.printBuffer(request->data, request->len); Serial.print(cccd_value); Serial.println(""); // Check the characteristic this CCCD update is associated with in case // this handler is used for multiple CCCD records. if (chr.uuid == hrmc.uuid) { if (chr.notifyEnabled()) { Serial.println("Heart Rate Measurement 'Notify' enabled"); } else { Serial.println("Heart Rate Measurement 'Notify' disabled"); } } } ©Adafruit Industries Page 106 of 177 BLECharacteristic The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 This base class is used when defining custom BLE GATT characteristics, and is used throughput the Adafruit Bluefruit nRF52 API and helper classes. Unless you are implementing a custom GATT service and characteristic, you normally won't use this base class directly, and would instantiate and call a higher level helper service or characteristic included in the Bluefruit nRF52 API. Basic Usage There are two main steps to using the BLECharacteristic class. First, you need to declare and instantiate your BLECharacteristic class with a 16-bit or 128-bit UUID: BLECharacteristic myChar = BLECharacteristic(0xABCD); Then you need to set the relevant properties for the characteristic, with the following values at minimum: myChar.setProperties(CHR_PROPS_READ); myChar.setPermission(SECMODE_OPEN, SECMODE_NO_ACCESS); myChar.setFixedLen(1); // Alternatively .setMaxLen(uint16_t len) myChar.begin(); • .setProperties can be set to one or more of the following macros, which correspond to a single bit in the eight bit 'properties' field for the characteristic definition: ◦ CHR_PROPS_BROADCAST = bit(0), ◦ CHR_PROPS_READ = bit(1), ◦ CHR_PROPS_WRITE_WO_RESP = bit(2), ◦ CHR_PROPS_WRITE = bit(3), ◦ CHR_PROPS_NOTIFY = bit(4), ©Adafruit Industries Page 107 of 177 ◦ CHR_PROPS_INDICATE = bit(5) • .setPermission sets the security level for the characteristic, where the first value sets the read permissions, and the second value sets the write permissions, where both fields can have one of the following values: ◦ SECMODE_NO_ACCESS = 0x00, ◦ SECMODE_OPEN = 0x11, ◦ SECMODE_ENC_NO_MITM = 0x21, ◦ SECMODE_ENC_WITH_MITM = 0x31, ◦ SECMODE_SIGNED_NO_MITM = 0x12, ◦ SECMODE_SIGNED_WITH_MITM = 0x22 • .setFixedLen() indicates how many bytes this characteristic has. For characteristics that use 'notify' or 'indicate' this value can be from 1..20, other characteristic types can be set from 1..512 and values >20 bytes will be sent across multiple 20 byte packets. If the characteristic has a variable len, you set the .setMaxLen() value to the maximum value it will hold (up to 20 bytes). • .begin() will cause this characteristic to be added to the last BLEService that had it's .begin() method called. Order of Operations (Important!) One very important thing to take into consideration when working with BLEService and BLECharacteristic, is that any BLECharacteristic will automatically be added to the last BLEService that had it's `.begin()` function called. As such, you must call yourService.begin() before adding any characteristics! See the example at the bottom of this page for a concrete example of how this works in practice. API BLECharacteristic has the following overall class structure: This documentation may be slightly out of date as bugs are fixed, and the API develops. You should always consult the Github repo for the definitive latest code release and class definitions! /*--------- Callback Signatures ----------*/ typedef void (*read_authorize_cb_t) (BLECharacteristic& chr, ble_gatts_evt_read_t * request); ©Adafruit Industries Page 108 of 177 typedef void (*write_authorize_cb_t) (BLECharacteristic& chr, ble_gatts_evt_write_t* request); typedef void (*write_cb_t) (BLECharacteristic& chr, uint8_t* data, uint16_t len, uint16_t offset); typedef void (*write_cccd_cb_t) (BLECharacteristic& chr, uint16_t value); BLEUuid uuid; // Constructors BLECharacteristic(void); BLECharacteristic(BLEUuid bleuuid); // Destructor virtual ~BLECharacteristic(); BLEService& parentService(void); void setTempMemory(void); /*------------- Configure -------------*/ void setUuid(BLEUuid bleuuid); void setProperties(uint8_t prop); void setPermission(BleSecurityMode read_perm, BleSecurityMode write_perm); void setMaxLen(uint16_t max_len); void setFixedLen(uint16_t fixed_len); /*------------- Descriptors -------------*/ void setUserDescriptor(const char* descriptor); // aka user descriptor void setReportRefDescriptor(uint8_t id, uint8_t type); // TODO refactor to use addDescriptor() void setPresentationFormatDescriptor(uint8_t type, int8_t exponent, uint16_t unit, uint8_t name_space = 1, uint16_t descritpor = 0); /*------------- Callbacks -------------*/ void setWriteCallback (write_cb_t fp); void setCccdWriteCallback (write_cccd_cb_t fp); void setReadAuthorizeCallback(read_authorize_cb_t fp); void setWriteAuthorizeCallbak(write_authorize_cb_t fp); virtual err_t begin(void); // Add Descriptor function must be called right after begin() err_t addDescriptor(BLEUuid bleuuid, void const * content, uint16_t len, BleSecurityMode read_perm = SECMODE_OPEN, BleSecurityMode write_perm = SECMODE_NO_ACCESS); ble_gatts_char_handles_t handles(void); /*------------- Write -------------*/ uint16_t write(const void* data, uint16_t len); uint16_t write(const char* str); uint16_t uint16_t uint16_t uint16_t write8 write16 write32 write32 (uint8_t (uint16_t (uint32_t (int num); num); num); num); /*------------- Read -------------*/ uint16_t read(void* buffer, uint16_t bufsize); uint8_t read8 (void); uint16_t read16(void); uint32_t read32(void); /*------------- Notify -------------*/ uint16_t getCccd(void); bool notifyEnabled(void); ©Adafruit Industries Page 109 of 177 bool notify(const void* data, uint16_t len); bool notify(const char* str); bool bool bool bool notify8 notify16 notify32 notify32 (uint8_t (uint16_t (uint32_t (int num); num); num); num); /*------------- Indicate -------------*/ bool indicateEnabled(void); bool indicate(const void* data, uint16_t len); bool indicate(const char* str); bool bool bool bool indicate8 indicate16 indicate32 indicate32 (uint8_t (uint16_t (uint32_t (int num); num); num); num); Example The following example configures an instance of the Heart Rate Monitor (HRM) Service and it's related characteristics: Note that this example code is incomplete. For the full example open the 'custom_hrm' example that is part of the nRF52 BSP! The code below is for illustration purposes only. /* HRM Service Definitions * Heart Rate Monitor Service: 0x180D * Heart Rate Measurement Char: 0x2A37 * Body Sensor Location Char: 0x2A38 */ BLEService hrms = BLEService(UUID16_SVC_HEART_RATE); BLECharacteristic hrmc = BLECharacteristic(UUID16_CHR_HEART_RATE_MEASUREMENT); BLECharacteristic bslc = BLECharacteristic(UUID16_CHR_BODY_SENSOR_LOCATION); void setupHRM(void) { // Configure the Heart Rate Monitor service // See: https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.service.heart_rate.xml // Supported Characteristics: // Name UUID Requirement Properties // ---------------------------- ------ ----------- ---------// Heart Rate Measurement 0x2A37 Mandatory Notify // Body Sensor Location 0x2A38 Optional Read // Heart Rate Control Point 0x2A39 Conditional Write here hrms.begin(); // // // // <-- Not used Note: You must call .begin() on the BLEService before calling .begin() on any characteristic(s) within that service definition.. Calling .begin() on a BLECharacteristic will cause it to be added to the last BLEService that was 'begin()'ed! // Configure the Heart Rate Measurement characteristic // See: https://www.bluetooth.com/specifications/gatt/viewer? ©Adafruit Industries Page 110 of 177 attributeXmlFile=org.bluetooth.characteristic.heart_rate_measurement.xml // Permission = Notify // Min Len = 1 // Max Len = 8 // B0 = UINT8 - Flag (MANDATORY) // b5:7 = Reserved // b4 = RR-Internal (0 = Not present, 1 = Present) // b3 = Energy expended status (0 = Not present, 1 = Present) // b1:2 = Sensor contact status (0+1 = Not supported, 2 = Supported but contact not detected, 3 = Supported and detected) // b0 = Value format (0 = UINT8, 1 = UINT16) // B1 = UINT8 - 8-bit heart rate measurement value in BPM // B2:3 = UINT16 - 16-bit heart rate measurement value in BPM // B4:5 = UINT16 - Energy expended in joules // B6:7 = UINT16 - RR Internal (1/1024 second resolution) hrmc.setProperties(CHR_PROPS_NOTIFY); hrmc.setPermission(SECMODE_OPEN, SECMODE_NO_ACCESS); hrmc.setFixedLen(2); hrmc.setCccdWriteCallback(cccd_callback); // Optionally capture CCCD updates hrmc.begin(); uint8_t hrmdata[2] = { 0b00000110, 0x40 }; // Set the characteristic to use 8-bit values, with the sensor connected and detected hrmc.notify(hrmdata, 2); // Use .notify instead of .write! // Configure the Body Sensor Location characteristic // See: https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.characteristic.body_sensor_location.xml // Permission = Read // Min Len = 1 // Max Len = 1 // B0 = UINT8 - Body Sensor Location // 0 = Other // 1 = Chest // 2 = Wrist // 3 = Finger // 4 = Hand // 5 = Ear Lobe // 6 = Foot // 7:255 = Reserved bslc.setProperties(CHR_PROPS_READ); bslc.setPermission(SECMODE_OPEN, SECMODE_NO_ACCESS); bslc.setFixedLen(1); bslc.begin(); bslc.write8(2); // Set the characteristic to 'Wrist' (2) } void cccd_callback(BLECharacteristic& chr, uint16_t cccd_value) { // Display the raw request packet Serial.print("CCCD Updated: "); //Serial.printBuffer(request->data, request->len); Serial.print(cccd_value); Serial.println(""); // Check the characteristic this CCCD update is associated with in case // this handler is used for multiple CCCD records. if (chr.uuid == hrmc.uuid) { if (chr.notifyEnabled()) { Serial.println("Heart Rate Measurement 'Notify' enabled"); } else { Serial.println("Heart Rate Measurement 'Notify' disabled"); } } } ©Adafruit Industries Page 111 of 177 BLEClientService The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 This base class is used when defining custom BLE Gatt Clients. Unless you are implementing a custom GATT client service and characteristic, you normally won't use this base class directly, and would instantiate and call a higher level helper service or characteristic included in the Bluefruit nRF52 API. Basic Usage There are normally only threes operations required to use the BLEClientService class: 1.) You need to declare and instantiate the class with an appropriate 16-bit or 128-bit UUID in the constructor: BLEClientService myService = BLEService(0x1234); 2.) You then need to call the .begin() method on the instance before adding any BLEClientCharacteristics to it (via the BLEClientCharacteristic's respective .begin() function call): myService.begin(); 3) When connected e.g in connect callback, you should call .discover() to discover the service myService.discover(); API BLEClientService has the following overall class structure: ©Adafruit Industries Page 112 of 177 This documentation may be slightly out of date as bugs are fixed, and the API develops. You should always consult the Github repo for the definitive latest code release and class definitions! BLEUuid uuid; // Constructors BLEClientService(void); BLEClientService(BLEUuid bleuuid); virtual bool begin(void); virtual bool bool discover (uint16_t conn_handle); discovered(void); uint16_t connHandle(void); void setHandleRange(ble_gattc_handle_range_t handle_range); ble_gattc_handle_range_t getHandleRange(void); Example The following example declares a HRM (Heart Rate Monitor) service, and assigns some characteristics to it: /********************************************************************* This is an example for our nRF52 based Bluefruit LE modules Pick one up today in the adafruit shop! Adafruit invests time and resources providing this open source code, please support Adafruit and open-source hardware by purchasing products from Adafruit! MIT license, check LICENSE for more information All text above, and the splash screen below must be included in any redistribution *********************************************************************/ /* This sketch show how to use BLEClientService and BLEClientCharacteristic * to implement a custom client that is used to talk with Gatt server on * peripheral. * * Note: you will need another feather52 running peripheral/custom_HRM sketch * to test with. */ #include <bluefruit.h> /* HRM Service Definitions * Heart Rate Monitor Service: 0x180D * Heart Rate Measurement Char: 0x2A37 (Mandatory) * Body Sensor Location Char: 0x2A38 (Optional) */ BLEClientService hrms(UUID16_SVC_HEART_RATE); BLEClientCharacteristic hrmc(UUID16_CHR_HEART_RATE_MEASUREMENT); BLEClientCharacteristic bslc(UUID16_CHR_BODY_SENSOR_LOCATION); ©Adafruit Industries Page 113 of 177 void setup() { Serial.begin(115200); Serial.println("Bluefruit52 Central Custom HRM Example"); Serial.println("--------------------------------------\n"); // Initialize Bluefruit with maximum connections as Peripheral = 0, Central = 1 // SRAM usage required by SoftDevice will increase dramatically with number of connections Bluefruit.begin(0, 1); Bluefruit.setName("Bluefruit52 Central"); // Initialize HRM client hrms.begin(); // Initialize client characteristics of HRM. // Note: Client Char will be added to the last service that is begin()ed. bslc.begin(); // set up callback for receiving measurement hrmc.setNotifyCallback(hrm_notify_callback); hrmc.begin(); // Increase Blink rate to different from PrPh advertising mode Bluefruit.setConnLedInterval(250); // Callbacks for Central Bluefruit.Central.setDisconnectCallback(disconnect_callback); Bluefruit.Central.setConnectCallback(connect_callback); /* Start Central Scanning * - Enable auto scan if disconnected * - Interval = 100 ms, window = 80 ms * - Don't use active scan * - Filter only accept HRM service * - Start(timeout) with timeout = 0 will scan forever (until connected) */ Bluefruit.Scanner.setRxCallback(scan_callback); Bluefruit.Scanner.restartOnDisconnect(true); Bluefruit.Scanner.setInterval(160, 80); // in unit of 0.625 ms Bluefruit.Scanner.filterUuid(hrms.uuid); Bluefruit.Scanner.useActiveScan(false); Bluefruit.Scanner.start(0); // // 0 = Don't stop scanning after n seconds } void loop() { // do nothing } /** * Callback invoked when scanner pick up an advertising data * @param report Structural advertising data */ void scan_callback(ble_gap_evt_adv_report_t* report) { // Connect to device with HRM service in advertising Bluefruit.Central.connect(report); } /** * Callback invoked when an connection is established * @param conn_handle */ void connect_callback(uint16_t conn_handle) ©Adafruit Industries Page 114 of 177 { Serial.println("Connected"); Serial.print("Discovering HRM Service ... "); // If HRM is not found, disconnect and return if ( !hrms.discover(conn_handle) ) { Serial.println("Found NONE"); // disconect since we couldn't find HRM service Bluefruit.Central.disconnect(conn_handle); return; } // Once HRM service is found, we continue to discover its characteristic Serial.println("Found it"); Serial.print("Discovering Measurement characteristic ... "); if ( !hrmc.discover() ) { // Measurement chr is mandatory, if it is not found (valid), then disconnect Serial.println("not found !!!"); Serial.println("Measurement characteristic is mandatory but not found"); Bluefruit.Central.disconnect(conn_handle); return; } Serial.println("Found it"); // Measurement is found, continue to look for option Body Sensor Location // https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.characteristic.body_sensor_location.xml // Body Sensor Location is optional, print out the location in text if present Serial.print("Discovering Body Sensor Location characteristic ... "); if ( bslc.discover() ) { Serial.println("Found it"); // Body sensor location value is 8 bit const char* body_str[] = { "Other", "Chest", "Wrist", "Finger", "Hand", "Ear Lobe", "Foot" }; // Read 8-bit BSLC value from peripheral uint8_t loc_value = bslc.read8(); Serial.print("Body Location Sensor: "); Serial.println(body_str[loc_value]); }else { Serial.println("Found NONE"); } // Reaching here means we are ready to go, let's enable notification on measurement chr if ( hrmc.enableNotify() ) { Serial.println("Ready to receive HRM Measurement value"); }else { Serial.println("Couldn't enable notify for HRM Measurement. Increase DEBUG LEVEL for troubleshooting"); } } /** * Callback invoked when a connection is dropped * @param conn_handle * @param reason ©Adafruit Industries Page 115 of 177 */ void disconnect_callback(uint16_t conn_handle, uint8_t reason) { (void) conn_handle; (void) reason; Serial.println("Disconnected"); } /** * Hooked callback that triggered when a measurement value is sent from peripheral * @param chr Pointer client characteristic that even occurred, * in this example it should be hrmc * @param data Pointer to received data * @param len Length of received data */ void hrm_notify_callback(BLEClientCharacteristic* chr, uint8_t* data, uint16_t len) { // https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.characteristic.heart_rate_measurement.xml // Measurement contains of control byte0 and measurement (8 or 16 bit) + optional field // if byte0's bit0 is 0 --> measurement is 8 bit, otherwise 16 bit. Serial.print("HRM Measurement: "); if ( data[0] & bit(0) ) { uint16_t value; memcpy(&value, data+1, 2); Serial.println(value); } else { Serial.println(data[1]); } } BLEClientCharacteristic The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 This base class is used when defining custom client for BLE GATT characteristics, and is used throughout the Adafruit Bluefruit nRF52 API and helper classes. Unless you are implementing a custom client for GATT service and characteristic, you normally won't use this base class directly, and would instantiate and call a higher level helper service or characteristic included in the Bluefruit nRF52 API. ©Adafruit Industries Page 116 of 177 Basic Usage There are three main steps to using the BLECharacteristic class. 1.) First, you need to declare and instantiate your BLECharacteristic class with a 16-bit or 128-bit UUID: BLEClientCharacteristic myChar = BLEClientCharacteristic(0xABCD); 2.) Then you need to set the relevant callback for the characteristic if it supports notify or indicate. myChar.setNotifyCallback(notify_callback); myChar.begin(); • .setNotifyCallback This sets the callback that will be fired when we receive a Notify message from peripheral. This is needed to handle notifiable characteristic since callback allow us to response to the message in timely manner • .begin() will cause this characteristic to be added to the last BLEClientService that had it's .begin() method called. 3) Discover the characteristic after connected to peripheral by calling  .discover()  I t is a must in order to perform any operation such as .read(), .write(), .enableNotify(). if ( myChar.discover() ) { uint32_t value = myChar.read32(); } API BLEClientCharacteristic has the following overall class structure: This documentation may be slightly out of date as bugs are fixed, and the API develops. You should always consult the Github repo for the definitive latest code release and class definitions! /*--------- Callback Signatures ----------*/ typedef void (*notify_cb_t ) (BLEClientCharacteristic* chr, uint8_t* data, ©Adafruit Industries Page 117 of 177 uint16_t len); typedef void (*indicate_cb_t) (BLEClientCharacteristic* chr, uint8_t* data, uint16_t len); BLEUuid uuid; // Constructors BLEClientCharacteristic(void); BLEClientCharacteristic(BLEUuid bleuuid); // Destructor virtual ~BLEClientCharacteristic(); void begin(BLEClientService* parent_svc = NULL); bool bool discover(void); discovered(void); uint16_t connHandle(void); uint16_t valueHandle(void); uint8_t properties(void); BLEClientService& parentService(void); /*------------- Read -------------*/ uint16_t read(void* buffer, uint16_t bufsize); uint8_t read8 (void); uint16_t read16(void); uint32_t read32(void); /*------------- Write without Response-------------*/ uint16_t write (const void* data, uint16_t len); uint16_t write8 (uint8_t value); uint16_t write16 (uint16_t value); uint16_t write32 (uint32_t value); /*------------- Write with Response-------------*/ uint16_t write_resp(const void* data, uint16_t len); uint16_t write8_resp (uint8_t value); uint16_t write16_resp (uint16_t value); uint16_t write32_resp (uint32_t value); /*------------- Notify -------------*/ bool writeCCCD (uint16_t value); bool bool enableNotify disableNotify (void); (void); bool bool enableIndicate (void); disableIndicate (void); /*------------- Callbacks -------------*/ void setNotifyCallback(notify_cb_t fp, bool useAdaCallback = true); void setIndicateCallback(indicate_cb_t fp, bool useAdaCallback = true); Example The following example configures an instance of the Heart Rate Monitor (HRM) Service and it's related characteristics: /********************************************************************* This is an example for our nRF52 based Bluefruit LE modules ©Adafruit Industries Page 118 of 177 Pick one up today in the adafruit shop! Adafruit invests time and resources providing this open source code, please support Adafruit and open-source hardware by purchasing products from Adafruit! MIT license, check LICENSE for more information All text above, and the splash screen below must be included in any redistribution *********************************************************************/ /* This sketch show how to use BLEClientService and BLEClientCharacteristic * to implement a custom client that is used to talk with Gatt server on * peripheral. * * Note: you will need another feather52 running peripheral/custom_HRM sketch * to test with. */ #include <bluefruit.h> /* HRM Service Definitions * Heart Rate Monitor Service: 0x180D * Heart Rate Measurement Char: 0x2A37 (Mandatory) * Body Sensor Location Char: 0x2A38 (Optional) */ BLEClientService hrms(UUID16_SVC_HEART_RATE); BLEClientCharacteristic hrmc(UUID16_CHR_HEART_RATE_MEASUREMENT); BLEClientCharacteristic bslc(UUID16_CHR_BODY_SENSOR_LOCATION); void setup() { Serial.begin(115200); Serial.println("Bluefruit52 Central Custom HRM Example"); Serial.println("--------------------------------------\n"); // Initialize Bluefruit with maximum connections as Peripheral = 0, Central = 1 // SRAM usage required by SoftDevice will increase dramatically with number of connections Bluefruit.begin(0, 1); Bluefruit.setName("Bluefruit52 Central"); // Initialize HRM client hrms.begin(); // Initialize client characteristics of HRM. // Note: Client Char will be added to the last service that is begin()ed. bslc.begin(); // set up callback for receiving measurement hrmc.setNotifyCallback(hrm_notify_callback); hrmc.begin(); // Increase Blink rate to different from PrPh advertising mode Bluefruit.setConnLedInterval(250); // Callbacks for Central Bluefruit.Central.setDisconnectCallback(disconnect_callback); Bluefruit.Central.setConnectCallback(connect_callback); /* * * * * * Start Central Scanning - Enable auto scan if disconnected - Interval = 100 ms, window = 80 ms - Don't use active scan - Filter only accept HRM service - Start(timeout) with timeout = 0 will scan forever (until connected) ©Adafruit Industries Page 119 of 177 */ Bluefruit.Scanner.setRxCallback(scan_callback); Bluefruit.Scanner.restartOnDisconnect(true); Bluefruit.Scanner.setInterval(160, 80); // in unit of 0.625 ms Bluefruit.Scanner.filterUuid(hrms.uuid); Bluefruit.Scanner.useActiveScan(false); Bluefruit.Scanner.start(0); // // 0 = Don't stop scanning after n seconds } void loop() { // do nothing } /** * Callback invoked when scanner pick up an advertising data * @param report Structural advertising data */ void scan_callback(ble_gap_evt_adv_report_t* report) { // Connect to device with HRM service in advertising Bluefruit.Central.connect(report); } /** * Callback invoked when an connection is established * @param conn_handle */ void connect_callback(uint16_t conn_handle) { Serial.println("Connected"); Serial.print("Discovering HRM Service ... "); // If HRM is not found, disconnect and return if ( !hrms.discover(conn_handle) ) { Serial.println("Found NONE"); // disconect since we couldn't find HRM service Bluefruit.Central.disconnect(conn_handle); return; } // Once HRM service is found, we continue to discover its characteristic Serial.println("Found it"); Serial.print("Discovering Measurement characteristic ... "); if ( !hrmc.discover() ) { // Measurement chr is mandatory, if it is not found (valid), then disconnect Serial.println("not found !!!"); Serial.println("Measurement characteristic is mandatory but not found"); Bluefruit.Central.disconnect(conn_handle); return; } Serial.println("Found it"); // Measurement is found, continue to look for option Body Sensor Location // https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.characteristic.body_sensor_location.xml // Body Sensor Location is optional, print out the location in text if present Serial.print("Discovering Body Sensor Location characteristic ... "); if ( bslc.discover() ) { Serial.println("Found it"); ©Adafruit Industries Page 120 of 177 // Body sensor location value is 8 bit const char* body_str[] = { "Other", "Chest", "Wrist", "Finger", "Hand", "Ear Lobe", "Foot" }; // Read 8-bit BSLC value from peripheral uint8_t loc_value = bslc.read8(); Serial.print("Body Location Sensor: "); Serial.println(body_str[loc_value]); }else { Serial.println("Found NONE"); } // Reaching here means we are ready to go, let's enable notification on measurement chr if ( hrmc.enableNotify() ) { Serial.println("Ready to receive HRM Measurement value"); }else { Serial.println("Couldn't enable notify for HRM Measurement. Increase DEBUG LEVEL for troubleshooting"); } } /** * Callback invoked when a connection is dropped * @param conn_handle * @param reason */ void disconnect_callback(uint16_t conn_handle, uint8_t reason) { (void) conn_handle; (void) reason; Serial.println("Disconnected"); } /** * Hooked callback that triggered when a measurement value is sent from peripheral * @param chr Pointer client characteristic that even occurred, * in this example it should be hrmc * @param data Pointer to received data * @param len Length of received data */ void hrm_notify_callback(BLEClientCharacteristic* chr, uint8_t* data, uint16_t len) { // https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.characteristic.heart_rate_measurement.xml // Measurement contains of control byte0 and measurement (8 or 16 bit) + optional field // if byte0's bit0 is 0 --> measurement is 8 bit, otherwise 16 bit. Serial.print("HRM Measurement: "); if ( data[0] & bit(0) ) { uint16_t value; memcpy(&value, data+1, 2); Serial.println(value); } else { Serial.println(data[1]); } } ©Adafruit Industries Page 121 of 177 BLEDiscovery This page is a work in progress as the API is changing as we migrate to S132v5 (nRF52832) and S140 (nRF52840) and add better Central mode support. BLEDiscovery is a helper class to make finding characteristics on a Gatt server (hosted on a BLE peripheral) easier. For service discovery, the BLEClientService's dis cover() API must be used, as shown below: API BLEDiscovery(void); // Constructor void bool begin(void); begun(void); void setHandleRange(ble_gattc_handle_range_t handle_range); ble_gattc_handle_range_t getHandleRange(void); uint8_t discoverCharacteristic(uint16_t conn_handle, BLEClientCharacteristic* chr[], uint8_t count); uint8_t discoverCharacteristic(uint16_t conn_handle, BLEClientCharacteristic& chr1); uint8_t discoverCharacteristic(uint16_t conn_handle, BLEClientCharacteristic& chr1, BLEClientCharacteristic& chr2); uint8_t discoverCharacteristic(uint16_t conn_handle, BLEClientCharacteristic& chr1, BLEClientCharacteristic& chr2, BLEClientCharacteristic& chr3); uint8_t discoverCharacteristic(uint16_t conn_handle, BLEClientCharacteristic& chr1, BLEClientCharacteristic& chr2, BLEClientCharacteristic& chr3, BLEClientCharacteristic& chr4); uint8_t discoverCharacteristic(uint16_t conn_handle, BLEClientCharacteristic& chr1, BLEClientCharacteristic& chr2, BLEClientCharacteristic& chr3, BLEClientCharacteristic& chr4, BLEClientCharacteristic& chr5); For concrete examples of how to use this API see the 'Central' folder in the examples that are part of the BSP. BLEDis The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 ©Adafruit Industries Page 122 of 177 This helper class acts as a wrapper for the Bluetooth Device Information Service (http s://adafru.it/q9E) (0x180A). This official GATT service allows you to publish basic information about your device in a generic manner. The Bluefruit BLEDis helper class exposes the following characteristics: • Model Number String (https://adafru.it/vav) (0x2A24), exposed via .setModel(con st char*) • Serial Number String (https://adafru.it/vaw) (0x2A25), private • Firmware Revision String (https://adafru.it/vax) (0x2A26), private • Hardware Revision String (https://adafru.it/vay) (0x2A27), exposed via .setHardw areRev(const char*) • Software Revision String (https://adafru.it/vaz) (0x2A28), exposed via .setSoftwar eRev(const char*) • Manufacturer Name String (https://adafru.it/vaA) (0x2A29), exposed via .setManu facturer(const char*) The Serial Number String is private and is populated with a unique device ID that nRF52832 SoCs are programmed with during manufacturing. The Firmware Revision String is also private and is populated with the following fields (to help us track issues and offer better feedback in the support forums): ◦ Softdevice Name (Sxxx) ◦ Softdevice Version (x.x.x) ◦ Bootloader Version (x.x.x) Note: The Softdevice and Bootloader fields are separated by a single comma, meaning the final output will resemble the following string: 'S132 2.0.1, 0.5.0' The remaining characteristics are all public and can be set to an value (up to 20 chars in length) using the appropriate helper function, but they have the following default values (for the nRF52832): • Model Number String: Bluefruit Feather 52 • Hardware Revision String: NULL • Software Revision String: The nRF52 BSP version number • Manufacturer Name String: Adafruit Industries ©Adafruit Industries Page 123 of 177 Setting a public value to NULL will prevent the characteristic from being present in the DIS service. API The following functions and constructors are defined in the BLEDis class: BLEDis(void); void void void void setModel(const char* model); setHardwareRev(const char* hw_rev); setSoftwareRev(const char* sw_rev); setManufacturer(const char* manufacturer); err_t begin(void); The individual characteristic values are set via the .set*() functions above, and when all values have been set you call the .begin() function to add the service to the device's internal GATT registry. Example The following bare bones examples show how to setup the device information service with user-configurable strings for values: #include <bluefruit.h> BLEDis bledis; void setup() { Serial.begin(115200); Serial.println("Bluefruit52 DIS Example"); Bluefruit.begin(); Bluefruit.setName("Bluefruit52"); // Configure and Start Device Information Service bledis.setManufacturer("Adafruit Industries"); bledis.setModel("Bluefruit Feather52"); bledis.begin(); // Set up Advertising Packet setupAdv(); // Start Advertising Bluefruit.Advertising.start(); } void setupAdv(void) { Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE); ©Adafruit Industries Page 124 of 177 Bluefruit.Advertising.addTxPower(); // There isn't enough room in the advertising packet for the // name so we'll place it on the secondary Scan Response packet Bluefruit.ScanResponse.addName(); } void loop() { } Output If you examine the device using the Bluefruit LE Connect app on iOS, Android or OS X you should see something resembling the following output: BLEUart The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 BLEUart is a wrapper class for NUS (Nordic UART Service), which is a proprietary service defined by Nordic Semiconductors that we use as a baseline transport mechanism between Bluefruit modules and our mobile and desktop Bluefruit LE Connect applications. You can use it to easily send ASCII or binary data in both directions, between the peripheral and the central device. API BLEUart has the following public API: // RX Callback signature (fires when data was written by the central) typedef void (*rx_callback_t) (void); ©Adafruit Industries Page 125 of 177 // Constructor BLEUart(uint16_t fifo_depth = BLE_UART_DEFAULT_FIFO_DEPTH); virtual err_t begin(void); bool notifyEnabled(void); void setRxCallback( rx_callback_t fp); // Stream API virtual int virtual int virtual size_t virtual size_t virtual int virtual int virtual void read read write write available peek flush ( ( ( ( ( ( ( void ); uint8_t * buf, size_t size ); uint8_t b ); const uint8_t *content, size_t len ); void ); void ); void ); // Pull in write(str) and write(buf, size) from Print using Print::write; Example The following example shows how to use the BLEUart helper class. This example may be out of date, and you should always consult the latest example code in the nRF52 BSP! #include <bluefruit.h> BLEDis bledis; BLEUart bleuart; BLEBas blebas; #define STATUS_LED #define BLINKY_MS (17) (2000) uint32_t blinkyms; void setup() { Serial.begin(115200); Serial.println("Bluefruit52 BLEUART Example"); // Setup LED pins and reset blinky counter pinMode(STATUS_LED, OUTPUT); blinkyms = millis(); // Setup the BLE LED to be enabled on CONNECT // Note: This is actually the default behaviour, but provided // here in case you want to control this manually via PIN 19 Bluefruit.autoConnLed(true); Bluefruit.begin(); Bluefruit.setName("Bluefruit52"); Bluefruit.setConnectCallback(connect_callback); Bluefruit.setDisconnectCallback(disconnect_callback); // Configure and Start Device Information Service bledis.setManufacturer("Adafruit Industries"); ©Adafruit Industries Page 126 of 177 bledis.setModel("Bluefruit Feather52"); bledis.begin(); // Configure and Start BLE Uart Service bleuart.begin(); // Start BLE Battery Service blebas.begin(); blebas.update(100); // Set up Advertising Packet setupAdv(); // Start Advertising Bluefruit.Advertising.start(); } void setupAdv(void) { Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE); Bluefruit.Advertising.addTxPower(); // Include bleuart 128-bit uuid Bluefruit.Advertising.addService(bleuart); // There is no room for Name in Advertising packet // Use Scan response for Name Bluefruit.ScanResponse.addName(); } void loop() { // Blinky! if (blinkyms+BLINKY_MS < millis()) { blinkyms = millis(); digitalToggle(STATUS_LED); } // Forward from Serial to BLEUART if (Serial.available()) { // Delay to get enough input data since we have a // limited amount of space in the transmit buffer delay(2); uint8_t buf[64]; int count = Serial.readBytes(buf, sizeof(buf)); bleuart.write( buf, count ); } // Forward from BLEUART to Serial if ( bleuart.available() ) { uint8_t ch; ch = (uint8_t) bleuart.read(); Serial.write(ch); } } void connect_callback(void) { Serial.println("Connected"); } void disconnect_callback(uint8_t reason) { (void) reason; Serial.println(); ©Adafruit Industries Page 127 of 177 Serial.println("Disconnected"); Serial.println("Bluefruit will start advertising again"); } BLEClientUart The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 BLEClientUart is a wrapper class for the client side of the NUS or 'Nordic UART Service' (aka 'BLE UART'). It is only required when your Bluefruit nRF52 board is acting as Central communicating to other BLE peripherals that expose the BLEUart (ht tps://adafru.it/yud) service. API BLEClientUart has the following public API: // Callback Signatures typedef void (*rx_callback_t) (BLEClientUart& svc); BLEClientUart(uint16_t fifo_depth = BLE_UART_DEFAULT_FIFO_DEPTH); virtual bool virtual bool begin(void); discover(uint16_t conn_handle); void setRxCallback( rx_callback_t fp); bool enableTXD(void); bool disableTXD(void); // Stream API virtual int read virtual int read int read read( (uint8_t*) buf, size); virtual size_t write virtual size_t write virtual int available virtual int peek virtual void flush ( ( ( } ( ( ( ( ( void ); uint8_t * buf, size_t size ); char * buf, size_t size ) { return uint8_t b ); const uint8_t *content, size_t len ); void ); void ); void ); Examples The following example shows how to use the BLEClientUart helper class. ©Adafruit Industries Page 128 of 177 #include <bluefruit.h> BLEClientDis clientDis; BLEClientUart clientUart; void setup() { Serial.begin(115200); Serial.println("Bluefruit52 Central BLEUART Example"); Serial.println("-----------------------------------\n"); // Initialize Bluefruit with maximum connections as Peripheral = 0, Central = 1 // SRAM usage required by SoftDevice will increase dramatically with number of connections Bluefruit.begin(0, 1); Bluefruit.setName("Bluefruit52 Central"); // Configure DIS client clientDis.begin(); // Init BLE Central Uart Serivce clientUart.begin(); clientUart.setRxCallback(bleuart_rx_callback); // Increase Blink rate to different from PrPh advertising mode Bluefruit.setConnLedInterval(250); // Callbacks for Central Bluefruit.Central.setConnectCallback(connect_callback); Bluefruit.Central.setDisconnectCallback(disconnect_callback); /* Start Central Scanning * - Enable auto scan if disconnected * - Interval = 100 ms, window = 80 ms * - Don't use active scan * - Start(timeout) with timeout = 0 will scan forever (until connected) */ Bluefruit.Scanner.setRxCallback(scan_callback); Bluefruit.Scanner.restartOnDisconnect(true); Bluefruit.Scanner.setInterval(160, 80); // in unit of 0.625 ms Bluefruit.Scanner.useActiveScan(false); Bluefruit.Scanner.start(0); // // 0 = Don't stop scanning after n seconds } /** * Callback invoked when scanner pick up an advertising data * @param report Structural advertising data */ void scan_callback(ble_gap_evt_adv_report_t* report) { // Check if advertising contain BleUart service if ( Bluefruit.Scanner.checkReportForService(report, clientUart) ) { Serial.print("BLE UART service detected. Connecting ... "); // Connect to device with bleuart service in advertising Bluefruit.Central.connect(report); } } /** * Callback invoked when an connection is established * @param conn_handle */ void connect_callback(uint16_t conn_handle) ©Adafruit Industries Page 129 of 177 { Serial.println("Connected"); Serial.print("Dicovering DIS ... "); if ( clientDis.discover(conn_handle) ) { Serial.println("Found it"); char buffer[32+1]; // read and print out Manufacturer memset(buffer, 0, sizeof(buffer)); if ( clientDis.getManufacturer(buffer, sizeof(buffer)) ) { Serial.print("Manufacturer: "); Serial.println(buffer); } // read and print out Model Number memset(buffer, 0, sizeof(buffer)); if ( clientDis.getModel(buffer, sizeof(buffer)) ) { Serial.print("Model: "); Serial.println(buffer); } Serial.println(); } Serial.print("Discovering BLE Uart Service ... "); if ( clientUart.discover(conn_handle) ) { Serial.println("Found it"); Serial.println("Enable TXD's notify"); clientUart.enableTXD(); Serial.println("Ready to receive from peripheral"); }else { Serial.println("Found NONE"); // disconect since we couldn't find bleuart service Bluefruit.Central.disconnect(conn_handle); } } /** * Callback invoked when a connection is dropped * @param conn_handle * @param reason */ void disconnect_callback(uint16_t conn_handle, uint8_t reason) { (void) conn_handle; (void) reason; Serial.println("Disconnected"); } /** * Callback invoked when uart received data * @param uart_svc Reference object to the service where the data * arrived. In this example it is clientUart */ void bleuart_rx_callback(BLEClientUart& uart_svc) { Serial.print("[RX]: "); ©Adafruit Industries Page 130 of 177 while ( uart_svc.available() ) { Serial.print( (char) uart_svc.read() ); } Serial.println(); } void loop() { if ( Bluefruit.Central.connected() ) { // Not discovered yet if ( clientUart.discovered() ) { // Discovered means in working state // Get Serial input and send to Peripheral if ( Serial.available() ) { delay(2); // delay a bit for all characters to arrive char str[20+1] = { 0 }; Serial.readBytes(str, 20); clientUart.print( str ); } } } } BLEBeacon The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 The BLEBeacon helper class allows you to easily configure the nRF52 as a 'Beacon', which uses the advertising packet to send out a specifically format chunk of data to any devices in listening range. The following values must be set in order to generate a valid 'Beacon' packet: • Manufacturer ID: A 16-bit value (registered with the Bluetooth SIG (https:// adafru.it/vaB)!) that identifies the manufacturer. • Major: A 16-bit 'Major' number, used to differentiate beacon nodes. • Minor: A 16-bit 'Minor' number, used to differentiate beacon nodes. • RSSI @ 1M: A signed 8-bit value (int8_t) indicating the RSSI measurement at 1m distance from the node, used to estimate distance to the beacon itself. ©Adafruit Industries Page 131 of 177 These values can either be set in the constructor, or via the individual functions exposed as part of this helper class. API BLEBeacon has the following public API: // Constructors BLEBeacon(void); BLEBeacon(uint8_t const uuid128[16]); BLEBeacon(uint8_t const uuid128[16], uint16_t major, uint16_t minor, int8_t rssi); // Set the beacon payload values void setManufacturer(uint16_t manfacturer); void setUuid(uint8_t const uuid128[16]); void setMajorMinor(uint16_t major, uint16_t minor); void setRssiAt1m(int8_t rssi); // Start advertising bool start(void); bool start(BLEAdvertising& adv); In addition to these functions, the BLEAdvertising class (accessible via `Bluefruit.Advertising.*`) exposes the following function to assign Beacon payload to the advertising payload: bool setBeacon(BLEBeacon& beacon); See the example below for a concrete usage example. Example The following example will configure the nRF52 to advertise a 'Beacon' payload: #include <bluefruit.h> // Beacon uses the Manufacturer Specific Data field in the advertising // packet, which means you must provide a valid Manufacturer ID. Update // the field below to an appropriate value. For a list of valid IDs see: // https://www.bluetooth.com/specifications/assigned-numbers/company-identifiers // 0x004C is Apple (for example) #define MANUFACTURER_ID 0x004C // AirLocate UUID: E2C56DB5-DFFB-48D2-B060-D0F5A71096E0 uint8_t beaconUuid[16] = { 0xE2, 0xC5, 0x6D, 0xB5, 0xDF, 0xFB, 0x48, 0xD2, 0xB0, 0x60, 0xD0, 0xF5, 0xA7, 0x10, 0x96, 0xE0, }; // A valid Beacon packet consists of the following information: ©Adafruit Industries Page 132 of 177 // UUID, Major, Minor, RSSI @ 1M BLEBeacon beacon(beaconUuid, 0x0001, 0x0000, -54); void setup() { Serial.begin(115200); Serial.println("Bluefruit52 Beacon Example"); Bluefruit.begin(); Bluefruit.setName("Bluefruit52"); // Manufacturer ID is required for Manufacturer Specific Data beacon.setManufacturer(MANUFACTURER_ID); // Setup the advertising packet setupAdv(); // Start advertising Bluefruit.Advertising.start(); } void setupAdv(void) { // Set the beacon payload using the BLEBeacon class populated // earlier in this example Bluefruit.Advertising.setBeacon(beacon); // char* adv = Bluefruit.Advertising.getData(); // There is no room left for 'Name' in the advertising packet // Use the optinal secondary Scan Response packet for 'Name' instead Bluefruit.ScanResponse.addName(); } void loop() { // Toggle both LEDs every second digitalToggle(LED_BUILTIN); delay(1000); } Testing If you test with the nRF Beacons application (iOS (https://adafru.it/vaC) or Android (htt ps://adafru.it/vaD)) you can configure the app to look for the UUID, Manufacturer ID, Major and Minor values you provided, and you should be able to see the beacon, as shown in the two screenshots below: Make sure that the UUID, Major and Minor values match or the application won't detect your beacon node! ©Adafruit Industries Page 133 of 177 BLEMidi The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 BLEMidi is a helper class that adds support for sending and receiving MIDI Messages using the MIDI over Bluetooth LE specification. BLEMidi supports the full standard MIDI protocol (including SysEx messages), and it also can act as the hardware interface for the Arduino MIDI Library. API BLEMidi has the following public API. // Constructor BLEMidi(uint16_t fifo_depth = 128); err_t bool begin (void); notifyEnabled (void); // Stream API for Arduino MIDI Library Interface int read (void); size_t write (uint8_t b); ©Adafruit Industries Page 134 of 177 int int void available peek flush (void); (void); (void); size_t size_t write write (const char *str); (const uint8_t *buffer, size_t size); Installing the Arduino MIDI Library BLEMidi is easiest to use when combined with the Arduino MIDI Library by Francois Best, lathoub. You will need version 4.3.1 installed before continuing with the example code. Next, select Communication from the topic dropdown, and enter MIDI Library into the search box. Click the Install button to install version 4.3.0 or higher of the MIDI Library. Example The blemidi example demonstrates how to use the BLEMidi helper class with the Ardu ino MIDI Library. The example sends a looping arpeggio, and prints any incoming MIDI note on and note off messages to the Arduino Serial Monitor. ©Adafruit Industries Page 135 of 177 This example may be out of date, and you should always consult the latest example code in the Bluefruit52 example folder! /********************************************************************* This is an example for our nRF52 based Bluefruit LE modules Pick one up today in the adafruit shop! Adafruit invests time and resources providing this open source code, please support Adafruit and open-source hardware by purchasing products from Adafruit! MIT license, check LICENSE for more information All text above, and the splash screen below must be included in any redistribution *********************************************************************/ #include <bluefruit.h> #include <MIDI.h> BLEDis bledis; BLEMidi blemidi; // Create a new instance of the Arduino MIDI Library, // and attach BluefruitLE MIDI as the transport. MIDI_CREATE_BLE_INSTANCE(blemidi); // Variable that holds the current position in the sequence. int position = 0; // Store example melody as an array of note values byte note_sequence[] = { 74,78,81,86,90,93,98,102,57,61,66,69,73,78,81,85,88,92,97,100,97,92,88,85,81,78, 74,69,66,62,57,62,66,69,74,78,81,86,90,93,97,102,97,93,90,85,81,78,73,68,64,61, 56,61,64,68,74,78,81,86,90,93,98,102 }; void setup() { Serial.begin(115200); Serial.println("Adafruit Bluefruit52 MIDI over Bluetooth LE Example"); Bluefruit.begin(); Bluefruit.setName("Bluefruit52 MIDI"); // Setup the on board blue LED to be enabled on CONNECT Bluefruit.autoConnLed(true); // Configure and Start Device Information Service bledis.setManufacturer("Adafruit Industries"); bledis.setModel("Bluefruit Feather52"); bledis.begin(); // Initialize MIDI, and listen to all MIDI channels // This will also call blemidi service's begin() MIDI.begin(MIDI_CHANNEL_OMNI); // Attach the handleNoteOn function to the MIDI Library. It will // be called whenever the Bluefruit receives MIDI Note On messages. MIDI.setHandleNoteOn(handleNoteOn); ©Adafruit Industries Page 136 of 177 // Do the same for MIDI Note Off messages. MIDI.setHandleNoteOff(handleNoteOff); // Set General Discoverable Mode flag Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE); // Advertise TX Power Bluefruit.Advertising.addTxPower(); // Advertise BLE MIDI Service Bluefruit.Advertising.addService(blemidi); // Advertise device name in the Scan Response Bluefruit.ScanResponse.addName(); // Start Advertising Bluefruit.Advertising.start(); // Start MIDI read loop Scheduler.startLoop(midiRead); } void handleNoteOn(byte channel, byte pitch, byte velocity) { // Log when a note is pressed. Serial.printf("Note on: channel = %d, pitch = %d, velocity - %d", channel, pitch, velocity); Serial.println(); } void handleNoteOff(byte channel, byte pitch, byte velocity) { // Log when a note is released. Serial.printf("Note off: channel = %d, pitch = %d, velocity - %d", channel, pitch, velocity); Serial.println(); } void loop() { // Don't continue if we aren't connected. if (! Bluefruit.connected()) { return; } // Don't continue if the connected device isn't ready to receive messages. if (! blemidi.notifyEnabled()) { return; } // Setup variables for the current and previous // positions in the note sequence. int current = position; int previous = position - 1; // If we currently are at position 0, set the // previous position to the last note in the sequence. if (previous < 0) { previous = sizeof(note_sequence) - 1; } // Send Note On for current position at full velocity (127) on channel 1. MIDI.sendNoteOn(note_sequence[current], 127, 1); // Send Note Off for previous note. MIDI.sendNoteOff(note_sequence[previous], 0, 1); // Increment position ©Adafruit Industries Page 137 of 177 position++; // If we are at the end of the sequence, start over. if (position >= sizeof(note_sequence)) { position = 0; } delay(286); } void midiRead() { // Don't continue if we aren't connected. if (! Bluefruit.connected()) { return; } // Don't continue if the connected device isn't ready to receive messages. if (! blemidi.notifyEnabled()) { return; } // read any new MIDI messages MIDI.read(); } Usage You will need to do a small bit of setup on your selected platform to connect to the BLE MIDI enabled Bluefruit52. Click on a platform below to view BLE MIDI setup instructions for your device: • macOS (OS X) • iOS • Android • Windows The arpeggio should automatically play once the Bluefruit52 is connected to your software synth. The video below shows the Bluefruit52 connected to Moog's Animoog on iOS. Note: The board used in the video was a pre-release prototype. The production boards are standard Adafruit Black. ©Adafruit Industries Page 138 of 177 BLEHidAdafruit The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 BLEHidAdafruit allows you to simulate a mouse or keyboard using the HID (Human Interface Device) profile that is part of the Bluetooth Low Energy standard. Most modern mobile devices with Bluetooth Low Energy support, and the latest operating systems generally support Bluetooth Low Energy mice and keyboards out of the box, once you pair your Bluefruit nRF52/nRF52840 Feather and run an appropriate sketch. API The BLEHidAdafruit helper class has the following public API: // Constructor BLEHidAdafruit(void); // Call this once to start the HID service virtual err_t begin(void); // Keyboard err_t keyboardReport(hid_keyboard_report_t* report); err_t keyboardReport(uint8_t modifier, uint8_t keycode[6]); err_t keyboardReport(uint8_t modifier, uint8_t keycode0, uint8_t keycode1=0, uint8_t keycode2=0, uint8_t keycode3=0, uint8_t keycode4=0, uint8_t keycode5=0); err_t keyPress(char ch); err_t keyRelease(void); err_t keySequence(const char* str, int interal=5); // Consumer Media Keys err_t consumerReport(uint16_t usage_code); err_t consumerKeyPress(uint16_t usage_code); err_t consumerKeyRelease(void); // Mouse err_t mouseReport(hid_mouse_report_t* report); err_t mouseReport(uint8_t buttons, int8_t x, int8_t y, int8_t wheel=0, int8_t pan=0); err_t mouseButtonPress(uint8_t buttons); err_t mouseButtonRelease(void); err_t mouseMove(int8_t x, int8_t y); err_t mouseScroll(int8_t scroll); err_t mousePan(int8_t pan); ©Adafruit Industries Page 139 of 177 Example Sketches There are a variety of example sketches showing how to use the BLEHidAdafruit class. You can browse the latest source code on Github with the following links: • hid_keyboard (https://adafru.it/vb8): This example will simulate an HID keyboard, waiting for data to arrive via the nRF52's serial port (via USB serial), and send that data over the air to the bonded Central device. • hid_mouse (https://adafru.it/vb9): This example will simulate an HID mouse. To use it run the sketch and open the Serial Monitor, then enter the appropriate characters to move the mouse or trigger/release the mouse buttons. Bonding HID Devices In order to use your HID mouse or keyboard, you will first need to bond the two devices. The bonding process involves the following steps: • The two devices will connect to each other normally • A set of security keys are exchanged between the two devices, and stores in non-volatile memory on each side. This is to ensure that each side is reasonably confident it is talking to the device it thinks it is for future connections, and to encrypt over the air communication between the devices (so that people can 'sniff' your keyboard data, etc.). • On the nRF52 side this key data will be stored in a section of flash memory reserved for this purpose using an internal file system. • The process of storing these security keys is referred to as bonding, and allows bonded devices to securely communicate without user interaction in the future. • To cancel the bonding agreement, you can simply delete the keys on the nRF52 via the clearbonds (https://adafru.it/vba) sketch, or delete the bonding data on your mobile device of computer. If you run into any bonding problems, try running the clearbonds sketch to remove and old bonding data from local non-volatile memory! ©Adafruit Industries Page 140 of 177 Setting up your Bluefruit device for bonding To bond an device, run an appropriate HID sketch on the nRF52 to emulate either an HID mouse or an HID keyboard. In the event that you use the HID mouse example you may need to open the Serial Monitor to use it. In this example we'll run the hid_keyboard example sketch, flashing it to the nRF52, which should give you the following results: Opening the Serial Monitor will give you the following output (though it may differ depending on the debug level you have selected): ©Adafruit Industries Page 141 of 177 Bonding on iOS To bond to an iOS device, make sure the sketch is running (as described above) and go into your Settings app and Select Bluetooth. You should see a device at the bottom of this page called Bluefruit52 (this may vary depending on the version of the sketch you are using!): Click the device, and you will get a pairing request like this: Click the Pair button, and the devices will be paired and bonded, and will automatically connect to each other in the future. If everything went will, you will see the device in your MY DEVICES list, as follows: ©Adafruit Industries Page 142 of 177 Testing the HID Keyboard and Bonding To test the HID keyboard sketch and bonding process, open the Serial Monitor (or your favorite terminal emulator), enter some text, and if you are using the Serial Monitor click the Send button. This will send some text over the air to whatever textbox or text control has focus in your app. The text will then appear in your mobile app or bonded device. If the characters don't match exactly what you send, be sure to check your keyboard language settings, since you may be sending data to a device with a different keyboard setup! BLEAncs The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 BLEAncs is a helper class that enables you to receive notifications from the Apple Notification Center Service (https://adafru.it/ErH) from devices such as an iPhone or iPad. It can be used to receive alerts such as incoming or missed calls, email messages, or most alerts that appear on the mobile device's screen when locked. API Because the BLEAncs class is a work in progress, the latest public API for the BLEAncs helper class should be viewed here (https://adafru.it/xen). ©Adafruit Industries Page 143 of 177 ANCS OLED Example The ancs_oled (https://adafru.it/xeo) example uses the Adafruit FeatherWing OLED (ht tps://adafru.it/sao) to display any incoming alerts. Sketch Requirements In order to use this example sketch the following libraries must be installed on your system: • Adafruit_GFX (https://adafru.it/xep) (Github source (https://adafru.it/aJa)) • Adafruit_SSD1306 (https://adafru.it/xep) (Github source (https://adafru.it/aHq)) • Version 0.6.0 or higher of the Bluefruit nRF52 BSP Loading the Sketch The ancs_oled sketch can be loaded via the examples menu under Peripheral > ancs_oled: With the sketch loaded, you can build the firmware and then flash it to your device via the Upload button or menu option: ©Adafruit Industries Page 144 of 177 Make sure that the Adafruit_SSD1306.h file has the 'SSD1306_128_32' macro enabled. Running the sketch with 'SSD1306_128_64' set will cause corrupted data to appear on the OLED display. Once the sketch is running on the nRF52 Feather you can proceed with the onetime pairing process, described below. Pairing to your Mobile Device Before you can start receiving notifications, you will need to 'pair' the nRF52 Feather and the mobile device. The pairing process causes a set of keys to be exchanged and stored on the two devices so that each side knows it is talking to the same device it originally bonded with, and preventing any devices in the middle from eavesdropping on potentially sensitive data. The one-time pairing process is described below, and assumes you are already running the ancs_oled sketch on your nRF52 device. 1. In the Settings app go to Bluetooth: ©Adafruit Industries Page 145 of 177 2. Scroll to the bottom of the list of 'My Devices' and click on Bluefruit52 under Other Devices: 3. When the pairing dialog box comes up, click the Pair button: 4. Wait for the pairing process to complete, at which point Bluefruit52 should appear in the My Devices list with the Connected status: ©Adafruit Industries Page 146 of 177 Once two devices have been paired, they will automatically reconnect to each other whenever they are in range and have their Bluetooth radios enabled. Wait for Alerts At this point, any alerts that the mobile device generates will be displayed on the OLED display along with the notification category and date: Certain alerts (such as incoming calls) can also have actions associated with them, making use of the three buttons on the left-hand side of the display to decide which action to take. In the ancs_oled example, we have a special section of code for incoming calls where you can accept or decline a call with an appropriate button press: // Check buttons uint32_t presedButtons = readPressedButtons(); if ( myNotifs[activeIndex].ntf.categoryID == ANCS_CAT_INCOMING_CALL ) { /* Incoming call event * - Button A to accept call * - Button C to decline call */ if ( presedButtons & bit(BUTTON_A) ) { bleancs.actPositive(myNotifs[activeIndex].ntf.uid); } if ( presedButtons & bit(BUTTON_C) ) { bleancs.actNegative(myNotifs[activeIndex].ntf.uid); } } ©Adafruit Industries Page 147 of 177 BLEClientCts The Bluefruit nRF52 BSP codebase is undergoing active development based on customer feedback and testing. As such, the class documentation here is incomplete, and you should consult the Github repo for the latest code and API developments: https://goo.gl/LdEx62 BLEClientCts is a helper class that implements adopted Current Time Service (https:// adafru.it/BiT) , which enables you to receive time from devices such as an iPhone or iPad. API // Callback Signatures typedef void (*adjust_callback_t) (uint8_t reason); BLEClientCts(void); virtual bool virtual bool begin(void); discover(uint16_t conn_handle); bool getCurrentTime(void); bool getLocalTimeInfo(void); bool enableAdjust(void); void setAdjustCallback(adjust_callback_t fp); // https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.characteristic.current_time.xml struct ATTR_PACKED { uint16_t year; uint8_t month; uint8_t day; uint8_t hour; uint8_t minute; uint8_t second; uint8_t weekday; uint8_t subsecond; uint8_t adjust_reason; } Time; // https://www.bluetooth.com/specifications/gatt/viewer? attributeXmlFile=org.bluetooth.characteristic.local_time_information.xml struct ATTR_PACKED { int8_t timezone; uint8_t dst_offset; }LocalInfo; ©Adafruit Industries Page 148 of 177 Client CTS OLED Example The client_cts_oled (https://adafru.it/BiU) example uses the Adafruit FeatherWing OLED (https://adafru.it/sao) to display received time. Sketch Requirements In order to use this example sketch the following libraries must be installed on your system: • Adafruit_GFX (https://adafru.it/xep) (Github source (https://adafru.it/aJa)) • Adafruit_SSD1306 (https://adafru.it/xep) (Github source (https://adafru.it/aHq)) Loading the Sketch The client_cts_oled sketch can be loaded via the examples menu under Peripheral > client_cts_oled: With the sketch loaded, you can build the firmware and then flash it to your device via the Upload button or menu option. Once the sketch is running on the nRF52 Feather you can proceed with the one-time pairing process, described below. Make sure that the Adafruit_SSD1306.h file has the 'SSD1306_128_32' macro enabled. Running the sketch with 'SSD1306_128_64' set will cause corrupted data to appear on the OLED display. ©Adafruit Industries Page 149 of 177 Pairing to your Mobile Device Before you can start receiving notifications, you will need to 'pair' the nRF52 Feather and the mobile device. The pairing process causes a set of keys to be exchanged and stored on the two devices so that each side knows it is talking to the same device it originally bonded with, and preventing any devices in the middle from eavesdropping on potentially sensitive data. The one-time pairing process is described below, and assumes you are already running the ancs_oled sketch on your nRF52 device. 1. In the Settings app go to Bluetooth: 2. Scroll to the bottom of the list of 'My Devices' and click on Bluefruit52 under Other Devices: 3. When the pairing dialog box comes up, click the Pair button: ©Adafruit Industries Page 150 of 177 4. Wait for the pairing process to complete, at which point Bluefruit52 should appear in the My Devices list with the Connected status: Once two devices have been paired, they will automatically reconnect to each other whenever they are in range and have their Bluetooth radios enabled. Wait for Time Data At this point,  time data from the mobile device will be read and display on the the OLED. For demo purpose the sketch will read time data from mobile once every second. However, in reality, nRF52 should have an internal timer that keep track of second, and only read/sync with mobile after several hours or days, similar to how IP device got time from NTP server. ©Adafruit Industries Page 151 of 177 BLECentral This page is a work in progress as the API is changing as we migrate to S132v5 (nRF52832) and S140 (nRF52840) and add better Central mode support. The Central mode API is accessible via  Bluefruit.Central.*  and has the following public functions: void begin(void); /*------------------------------------------------------------------*/ /* GAP *------------------------------------------------------------------*/ bool setConnInterval(uint16_t min, uint16_t max); bool setConnIntervalMS (uint16_t min_ms, uint16_t max_ms); bool bool bool connect(const ble_gap_evt_adv_report_t* adv_report); connect(const ble_gap_addr_t *peer_addr); disconnect(uint16_t conn_handle); bool bool connected (uint16_t conn_handle); // If connected to a specific peripheral connected (void); // If connected to any peripherals /*------------- Callbacks -------------*/ void setConnectCallback ( BLEGap::connect_callback_t fp); void setDisconnectCallback( BLEGap::disconnect_callback_t fp); For examples of how to use the Central mode API, see the Central examples folder (ht tps://adafru.it/BiV). ©Adafruit Industries Page 152 of 177 nRF52 ADC The nRF52 family includes an adjustable 'successive-approximation ADC' which can be configured to convert data with up to 14-bit resolution (0..16383), and the reference voltage can be adjusted up to 3.6V internally. The default values for the ADC are 10-bit resolution (0..1023) with a 3.6V reference voltage, meaning every digit returned from the ADC = 3600mV/1024 = 3.515625mV. Analog Reference Voltage The internal reference voltage is 0.6V with a variable gain setting, and can be adjust via the analogReference(...) function, providing one of the following values: • AR_INTERNAL (0.6V Ref * 6 = 0..3.6V)
很抱歉,暂时无法提供与“3406”相匹配的价格&库存,您可以联系我们找货
    • 1+260.42116
    • 10+257.97342
