503
    MGCHEMICALS
503 数据手册
Copper Clad Boards 500 Series Technical Data Sheet 500 Series Description The 500 Series Copper Clad Boards are made of a laminate consisting of continuous woven glass cloth impregnated with epoxy resin. The boards are made of FR4 which is a flame retardant version of G-10 material. Applications & Usages The boards are ideal for prototyping and small production runs. It is used by PCB manufacturers, design engineers, hobbyists, and students. Benefits and Features • Complies with UL (file number E214381) and IPC-4101C/21 • DICY (dicyandiamide) Cured System • Easy to cut with no specialized equipment required • UV blocking • Available in 1 oz (1.37 mil, 35 µm) and ½ oz (0.67 mil, 17 µm) copper cladding • Comes in 1/16" (1.60 mm) and 1/32" (0.80 mm) laminate thicknesses Properties Physical Properties Moisture Absorption Flammability Method IPC-TM-650 2.6.2.1 UL-94 Specification 6 lb/in 10-12 lb/in 9-12 lb/in IPC-TM-650 2.4.4 " >415 MPa >345 MPa 600 MPa 500 MPa Note: Data shown are typical values for reference only. Storage Store at around room temperature 18 to 27 °C [65 to 80 °F] and protect from direct heat or sunlight. Keep sealed in an air tight container, away from humidity. Health and Safety Please see the 500 Series Copper Clad Boards Safety Data Sheet (SDS) for more details on transportation, storage, handling and other security guidelines. Environmental Impact: This product doesn’t have any known environmental toxicity. This product meets the European Directive 2011/65/EU Annex II (ROHS); recasting 2002/95/EC. Health and Safety: This product is not considered to be hazardous for human health under normal use. It is widely used in the packing and food industry. Page 2 of 4 Date: 16 March 2017 / Ver. 2.01 Copper Clad Boards 500 Series Technical Data Sheet 500 Series HMIS® RATING NFPA® 704 CODES HEALTH: 0 FLAMMABILITY: 1 PHYSICAL HAZARD: 0 1 0 0 PERSONAL PROTECTION: Approximate HMIS and NFPA Risk Ratings Legend: 0 (Low or none); 1 (Slight); 2 (Moderate); 3 (Serious); 4 (Severe) Packaging and Supporting Products 1 oz Copper Claddings FR4 1/16" (1.60 mm), single sided Cat. No. 503 506 509 512 515 521 575 580 Metric 76 x 127 mm 101 x 152 mm 152 x 152 mm 152 x 228 mm 203 x 254 mm 304 x 304 mm 609 x 914 mm 914 x 1219 mm FR4 1/16" (1.60 mm), double sided Imperial a) 3" x 5" 4" x 6" 6" x 6" 6" x 9" 8" x 10" 12" x 12" 24" x 36" 36" x 48" FR4 1/32" (0.80 mm), single sided Cat. No. 586 588 Metric 101 x 152 mm 152 x 228 mm Cat. No. 540 550 555 Imperial a) 3" x 5" 6" x 6" 12" x 12" FR4 1/32" (0.80 mm), double sided Imperial a) 4" x 6" 6" x 9" Cat. No. 587 589 a) Sizes are approximate Page 3 of 4 Date: 16 March 2017 / Ver. 2.01 Metric 76 x 127 mm 152 x 152 mm 304 x 304 mm Metric 101 x 152 mm 152 x mm Imperial a) 3" x 5" 4" x 6" Copper Clad Boards 500 Series Technical Data Sheet 500 Series ½ oz Copper Claddings FR4 1/16" (1.60 mm), single sided Cat. No. 510 516 Metric 152 x 152 mm 203 x 254 mm FR4 1/16" (1.60 mm), double sided Imperial a) 6" x 6" 8" x 10" Cat. No. 551 Metric 152 x 152 mm Imperial a) 6" x 6" b) Sizes are approximate Supporting Products • Positive Presensitized Copper Clad Boards, 600 Series Technical Support Contact us regarding any questions, improvement suggestions, or problems with this product. Application notes, instructions, and FAQs are located at www.mgchemicals.com. Email: support@mgchemicals.com Phone: +(1) 800-340-0772 (Canada, Mexico & USA) +(1) 905-331-1396 (International) Fax: +(1) 905-331-2862 or +(1) 800-340-0773 Mailing address: Manufacturing & Support 1210 Corporate Drive Burlington, Ontario, Canada L7L 5R6 Head Office 9347–193rd Street Surrey, British Columbia, Canada V4N 4E7 Warranty M.G. Chemicals Ltd. warranties this product for 12 months from the date of purchase by the end user. M.G. Chemicals Ltd. makes no claims as to shelf life of this product for the warranty. The liability of M.G. Chemicals Ltd. whether based on its warranty, contracts, or otherwise shall in no case include incidental or consequential damage. Disclaimer This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. M.G. Chemicals Ltd. does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. Page 4 of 4 Date: 16 March 2017 / Ver. 2.01
很抱歉,暂时无法提供与“503”相匹配的价格&库存,您可以联系我们找货
