410-135
    DIGILENT(迪芝伦)
410-135 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com PmodTPH2™ Reference Manual Revised May 24, 2016 This manual applies to the PmodTPH2 rev. A Overview The PmodTPH2 is a 12 point test header, giving users easy access to any signals passing through the Pmod. Features include:      12 external test point headers Easily access and test signals passing through Small PCB size for flexible designs 1.3“ × 0.8” (3.3 cm × 2.0 cm) 12-pin Pmod connector with GPIO interface Follows Digilent Pmod Interface Specification Type 1 The PmodTPH2. 1 Functional Description Offering 12 isolated pass through connectors, this module is able to easily able to be placed between two pieces of hardware allowing the user to observe and debug their circuit. 2 Interfacing with the Pmod Attach your multimeter or oscilliscope (such as the Analog Discovery) to the vertical test point headers and measure away! DOC#: 502-081 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 2 PmodTPH2™ Reference Manual Pin 1 2 3 4 5 6 Signal 1 2 3 4 5 6 Header J1 Description Pin Pass through #1 7 Pass through #2 8 Pass through #3 9 Pass through #4 10 Pass through #5 11 Pass through #6 12 Signal 7 8 9 10 11 12 Description Pass through #7 Pass through #8 Pass through #9 Pass through #10 Pass through #11 Pass through #12 Table 1. Pinout description table. Any external power applied to the PmodTPH2 must be able to be handled by your two pieces of hardware on either side of the Pmod. 3 Physical Dimenions The pins on the pin header are spaced 100 mil apart. The PCB is 2 inches long on the sides parallel to the pins on the pin header and 0.8 inches long on the sides perpendicular to the pin header. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 2
410-135 价格&库存
很抱歉,暂时无法提供与“410-135”相匹配的价格&库存,您可以联系我们找货
    • 1+40.75976
    • 5+39.94748
    库存:38
