102110137
    SEEED(矽递科技)
102110137 数据手册
        ROCK960 Board ‐ RK3399 solution 2G Version SKU 102110137 Description   Vamrs is a 96boards contract Manufacturing Partner. ROCK960 is the first 96board based on Rockchip processor. Featuring RK3399 with Dual A72 plus Quad A53 cores and Mali T860MP4 makes it one of the most powerful 96boards Features: RK3399(A72x2+A53x4), 2G/16G, 4G/32G Mali T860MP4, OpenGL 3.2, OpenCL 1.2 HDMI 2.0 4K@60 USB type C with DP 1.2 + USB 3.0 4 lanes PCIE 2.1 2x2 MIMO 802.11 AC Wi-Fi, BT 4.1 96boards Low speed/Hight speed expansion Expansion: 1x 40 pin low speed expansion connector – UART, SPI, I2C, GPIO, I2S 1x 60 pin high speed expansion connector – MIPI DSI, USB, MIPI CSI, HSIC, SDIO 1x M.2 key M PCIe connector with support for up to 4-lane PCIe 2.1 (max bandwidth: 2.0 GB) Misc – Power & u-boot buttons. 6 LEDS (4x user, 1x Wifi, 1x Bluetooth) Power Supply – 8 to 18V DC input (12V typical) as per 96Boards CE specs; Battery header Technical Details   Dimensions 85mm x 54mm x 15mm  Weight  G.W 120g    N.W 120g  Battery  Exclude  SoC  Rochchip RK3399 hexa‐core, ARM Cortex A72 cores up to 1.8/2.0 GHz, four Cortex A53  cores @ 1.4 GHz  Support  ARM Mali‐T860 MP4 GPU with OpenGL ES 1.1 to 3.2 support, OpenVG1.1, OpenCL 1.2  and DX 11 support  System  Memory  2G RAM  Storage  16 GB eMMC flash + micro SD card  Video Output  1x HDMI 2.0 up to 4K@60 Hz with CEC and HDCP  Connectivity  WiFi 802.11ac 2×2 MIMO up to 867 Mbps, and Bluetooth 4.1 LE (AP6356S module) with  two on‐board antennas, two u.FL antenna connectors  USB  1x USB 2.0 host port, 1x USB 3.0 port, 1x USB 3.0 type C port with DP 1.2 support  Part List   Rock 960 Board 1                               https://www.seeedstudio.com/Rock‐960‐Board‐‐‐RK3399‐solution‐2G‐Version‐p‐3036.html 4‐12‐18
102110137 价格&库存
很抱歉,暂时无法提供与“102110137”相匹配的价格&库存,您可以联系我们找货
