SK33
SK33
    SMCDIODESOLUTIONS(桑德斯)
    SMB
    SK33
SK33 数据手册
SK32 THRU SK310 Technical Data Data Sheet N0101, Rev. A SK32 THRU SK310 SCHOTTKY RECTIFIER Features Schottky Barrier Chip Guard Ring Die Construction for Transient Protection High Current Capability Low Power Loss, High Efficiency High Surge Current Capability For Use in Low Voltage, High Frequency Inventers, Free Wheeling, and Polarity Protection Applications This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request          SMC Circuit Diagram Mechanical Data       Case: Low Profile Molded plastic Terminals: Plated leads solderable per MIL-STD-750, Method 2026 guaranteed Polarity: Color band or cathode Notch Mounting Position: Any Weight: 0.21grams(approx) Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristic Symbol SK32 SK33 SK34 SK35 SK36 SK38 SK39 SK310 Units Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Maximum RMS voltage VRRM VRWM VR VRMS Average Rectified Output Current @TL= 75°C IO 3.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 100 A Forward Voltage @ IF= 3.0 A VF Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 100°C IRM Typical Thermal Resistance Junction to Ambient (Note 1) RθJA 55 °C/W Operating Temperature Range TJ -65 to +125 °C Storage Temperature Range TSTG -65 to +150 °C 20 30 40 50 60 80 90 100 V 14 21 28 35 42 56 64 71 V 0.55 0.75 0.5 20 Note: 1. mounted on P.C. Board with 8.0mm2 copper pad areas.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  0.85 V mA SK32 THRU SK310 Technical Data Data Sheet N0101, Rev. A Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SK32 THRU SK310 Technical Data Data Sheet N0101, Rev. A Mechanical Dimensions SMC SYMBOL Ordering Information Device SK32 THRU SK310 Millimeters Inches Min. Max. Min. Max. A 5.59 6.22 0.220 0.245 B 6.60 7.11 0.260 0.280 C 2.75 3.25 0.108 0.128 D 0.152 0.305 0.006 0.012 E 7.75 8.25 0.305 0.325 F 2.00 2.95 0.079 0.116 G 0.051 0.203 0.002 0.008 H 0.76 1.60 0.030 0.063 Marking Diagram Package Shipping SMC (Pb-Free) 3000pcs / reel Where XXXXX is YYWWL First row: Part Number (SK32, SK33, SK34, SK35, SK36, SK38, SK39, SK310) Second row: YYWWL YY is the manufacture year, WW is the manufacture week code, L is the wafer’s Lot Number For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. Carrier Tape Specification SMC SYMBOL A B C d E F P P0 P1 T W Millimeters Min. Max. 5.90 8.20 2.40 1.40 1.40 7.60 7.90 3.90 3.90 15.80  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  6.10 8.40 2.60 1.60 1.60 7.70 8.10 4.10 4.10 0.600 16.20 SK32 THRU SK310 Technical Data Data Sheet N0101, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
很抱歉,暂时无法提供与“SK33”相匹配的价格&库存,您可以联系我们找货
