SKV606014-AL
SKV606014-AL
    WAKEFIELD-VETTE
    SKV606014-AL
SKV606014-AL 数据手册
Copper & Aluminum Skived Fin Heat Sink SKV Series Skived Fin heat sinks can be an alternative to extruded heat sinks when looking for a fin density which can’t be achieved by extrusion technology. Skived heat sinks can be manufactured from either copper or aluminum and usually have 0.5 (0.020”) thick fins. Skived heat sinks are produced using a series of sharp knives that, as they pass over the material, curl up a small thickness of metal which is then bent vertically to form the fin. Skived fins are produced from a bar of material which is approximately 16 feet in length and then cut to length as required by the final application. The final heat sink can be machined using normal fabrication techniques. Because of the thin fins, care must be taken in handling to prevent damage. It is suggested that a shroud be placed over the fins to help prevent damage. Wakefield- Vette SKV Series offers standard off the shelf solutions for customer applications in addition to custom solutions utilizing a plastic pin attachment. Features: • Plastic push pin attachment for easy insertion • Plastic pins ensure integrity of the PCB Board • High fin densities in comparison to extrusion • No interface between fins and base • Minimal tooling cost for non-standards • Improved thermal performance WKV Part Attachment Height Off Base Thermal Resistance Number Description Method Length Width (Height of Fin) @ Forced Air Flow SKV38538514-CU COPPER HEATSINK 38.5X37.6X14MM Plastic Push Pin 1.480" (37.59mm) 1.516" (38.50mm) 0.551" (14.00mm) 2.60°C/W @ 200 LFM SKV38538514-AL ALUMINUM HEATSINK 38.5X37.6X14MM Plastic Push Pin 1.480" (37.59mm) 1.516" (38.50mm) 0.551" (14.00mm) 2.70°C/W @ 200 LFM SKV4545225-CU COPPER HEATSINK 45X44X22.5MM Plastic Push Pin 1.732" (44.00mm) 1.772" (45.00mm) 0.886" (22.50mm) 1.65°C/W @ 200 LFM SKV4545225-AL ALUMINUM HEATSINK 45X44X22.5MM Plastic Push Pin 1.732" (44.00mm) 1.772" (45.00mm) 0.886" (22.50mm) 1.75°C/W @ 200 LFM SKV505014-CU COPPER HEATSINK 50X50X14MM Plastic Push Pin 1.969" (50.00mm) 1.969" (50.00mm) 0.551" (14.00mm) 2.10°C/W @ 200 LFM SKV505014-AL ALUMINUM HEATSINK 50X50X14MM Plastic Push Pin 1.969" (50.00mm) 1.969" (50.00mm) 0.551" (14.00mm) 2.20°C/W @ 200 LFM SKV585811-CU COPPER HEATSINK 57.9X59X11MM Plastic Push Pin 2.323" (59.00mm) 2.280" (57.91mm) 0.433" (11.00mm) 1.90°C/W @ 200 LFM SKV585811-AL ALUMINUM HEATSINK 57.9X59X11MM Plastic Push Pin 2.323" (59.00mm) 2.280" (57.91mm) 0.433" (11.00mm) 2.00°C/W @ 200 LFM SKV606014-CU COPPER HEATSINK 60X60X14MM Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.551" (14.00mm) 1.70°C/W @ 200 LFM SKV606014-AL ALUMINUM HEATSINK 60X60X14MM Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.551" (14.00mm) 1.80°C/W @ 200 LFM SKV606021-CU COPPER HEATSINK 60X60X21MM Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.866" (21.00mm) 0.80°C/W @ 300 LFM SKV606021-AL ALUMINUM HEATSINK 60X60X21MM Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.866" (21.00mm) 0.90°C/W @ 200 LFM SKV707014-CU COPPER HEATSINK 70X70X14MM Plastic Push Pin 2.717" (69.00mm) 2.756" (70.00mm) 0.551" (14.00mm) 1.40°C/W @ 200 LFM SKV707014_AL ALUMINUM HEATSINK 70X70X14MM Plastic Push Pin 2.717" (69.00mm) 2.756" (70.00mm) 0.551" (14.00mm) 1.50°C/W @ 200 LFM SKV808012-CU COPPER HEATSINK 80X80X12MM Plastic Push Pin 3.150" (80.00mm) 3.150" (80.00mm) 0.472" (12.00mm) 1.20°C/W @ 200 LFM SKV808012-AL ALUMINUM HEATSINK 80X80X12MM Plastic Push Pin 3.150" (80.00mm) 3.150" (80.00mm) 0.472" (12.00mm) 1.30°C/W @ 200 LFM SKV909010-CU COPPER HEATSINK 90X90X10MM Plastic Push Pin 3.543" (90.00mm) 3.543" (90.00mm) 0.394" (10.00mm) 1.30°C/W @ 200 LFM SKV909010-AL ALUMINUM HEATSINK 90X90X10MM Plastic Push Pin 3.543" (90.00mm) 3.543" (90.00mm) 0.394" (10.00mm) 1.40°C/W @ 200 LFM www.wakefield-vette.com Thermal Resistance @ Natural 15.90°C/W 17.20°C/W 8.00°C/W 8.70°C/W 8.90°C/W 9.90°C/W 7.70°C/W 8.40°C/W 7.00°C/W 7.60°C/W 7.20°C/W 7.90°C/W 5.60°C/W 6.30°C/W 5.10°C/W 5.70°C/W 4.50°C/W 5.00°C/W Material Copper Aluminum Copper Aluminum Copper Aluminum Copper Aluminum Copper Aluminum Copper Aluminum Copper Aluminum Copper Aluminum Copper Aluminum Copper & Aluminum Skived Fin Heat Sink SKV Series Attachment Height Off Base Thermal Resistance @ Thermal Resistance WKV Part Number Description Method Length Width (Height of Fin) Forced Air Flow @ Natural SKV38538514-CU COPPER HEATSINK 38.5X37.6X14MM Plastic Push Pin 1.480" (37.59mm) 1.516" (38.50mm) 0.551" (14.00mm) 2.60°C/W @ 200 LFM 15.90°C/W SKV38538514-AL ALUMINUM HEATSINK 38.5X37.6X14MM Plastic Push Pin 1.480" (37.59mm) 1.516" (38.50mm) 0.551" (14.00mm) 2.70°C/W @ 200 LFM 17.20°C/W WKV Part Number SKV4545225-CU SKV4545225-AL WKV Part Number SKV505014-CU SKV505014-AL Attachment Height Off Base Thermal Resistance @ Thermal Resistance Description Method Length Width (Height of Fin) Forced Air Flow @ Natural Material COPPER HEATSINK 45X44X22.5MM Plastic Push Pin 1.732" (44.00mm) 1.772" (45.00mm) 0.886" (22.50mm) 1.65°C/W @ 200 LFM 8.00°C/W Copper ALUMINUM HEATSINK 45X44X22.5MM Plastic Push Pin 1.732" (44.00mm) 1.772" (45.00mm) 0.886" (22.50mm) 1.75°C/W @ 200 LFM 8.70°C/W Aluminum Attachment Height Off Base Thermal Resistance @ Thermal Resistance Description Method Length Width (Height of Fin) Forced Air Flow @ Natural Material COPPER HEATSINK 50X50X14MM Plastic Push Pin 1.969" (50.00mm) 1.969" (50.00mm) 0.551" (14.00mm) 2.10°C/W @ 200 LFM 8.90°C/W Copper ALUMINUM HEATSINK 50X50X14MM Plastic Push Pin 1.969" (50.00mm) 1.969" (50.00mm) 0.551" (14.00mm) 2.20°C/W @ 200 LFM 9.90°C/W Aluminum Copper & Aluminum Skived Fin Heat Sink SKV Series WKV Part Number SKV585811-CU SKV585811-AL Attachment Height Off Base Thermal Resistance @ Thermal Resistance Description Method Length Width (Height of Fin) Forced Air Flow @ Natural Material COPPER HEATSINK 57.9X59X11MM Plastic Push Pin 2.323" (59.00mm) 2.280" (57.91mm) 0.433" (11.00mm) 1.90°C/W @ 200 LFM 7.70°C/W Copper ALUMINUM HEATSINK 57.9X59X11MM Plastic Push Pin 2.323" (59.00mm) 2.280" (57.91mm) 0.433" (11.00mm) 2.00°C/W @ 200 LFM 8.40°C/W Aluminum WKV Part Number SKV606014-CU SKV606014-AL WKV Part Number SKV606021-CU SKV606021-AL Description COPPER HEATSINK 60X60X14MM ALUMINUM HEATSINK 60X60X14MM Attachment Height Off Base Thermal Resistance @ Thermal Resistance Method Length Width (Height of Fin) Forced Air Flow @ Natural Material Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.551" (14.00mm) 1.70°C/W @ 200 LFM 7.00°C/W Copper Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.551" (14.00mm) 1.80°C/W @ 200 LFM 7.60°C/W Aluminum Attachment Height Off Base Thermal Resistance @ Thermal Resistance Description Method Length Width (Height of Fin) Forced Air Flow @ Natural Material COPPER HEATSINK 60X60X21MM Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.866" (21.00mm) 0.80°C/W @ 300 LFM 7.20°C/W Copper ALUMINUM HEATSINK 60X60X21MM Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.866" (21.00mm) 0.90°C/W @ 200 LFM 7.90°C/W Aluminum Copper & Aluminum Skived Fin Heat Sink SKV Series WKV Part Number SKV707014-CU SKV707014_AL Attachment Height Off Base Thermal Resistance @ Thermal Resistance Description Method Length Width (Height of Fin) Forced Air Flow @ Natural Material COPPER HEATSINK 70X70X14MM Plastic Push Pin 2.717" (69.00mm) 2.756" (70.00mm) 0.551" (14.00mm) 1.40°C/W @ 200 LFM 5.60°C/W Copper ALUMINUM HEATSINK 70X70X14MM Plastic Push Pin 2.717" (69.00mm) 2.756" (70.00mm) 0.551" (14.00mm) 1.50°C/W @ 200 LFM 6.30°C/W Aluminum WKV Part Number SKV808012-CU SKV808012-AL Attachment Height Off Base Thermal Resistance @ Thermal Resistance Description Method Length Width (Height of Fin) Forced Air Flow @ Natural Material COPPER HEATSINK 80X80X12MM Plastic Push Pin 3.150" (80.00mm) 3.150" (80.00mm) 0.472" (12.00mm) 1.20°C/W @ 200 LFM 5.10°C/W Copper ALUMINUM HEATSINK 80X80X12MM Plastic Push Pin 3.150" (80.00mm) 3.150" (80.00mm) 0.472" (12.00mm) 1.30°C/W @ 200 LFM 5.70°C/W Aluminum WKV Part Number SKV909010-CU SKV909010-AL Attachment Height Off Base Thermal Resistance @ Thermal Resistance Description Method Length Width (Height of Fin) Forced Air Flow @ Natural Material COPPER HEATSINK 90X90X10MM Plastic Push Pin 3.543" (90.00mm) 3.543" (90.00mm) 0.394" (10.00mm) 1.30°C/W @ 200 LFM 4.50°C/W Copper ALUMINUM HEATSINK 90X90X10MM Plastic Push Pin 3.543" (90.00mm) 3.543" (90.00mm) 0.394" (10.00mm) 1.40°C/W @ 200 LFM 5.00°C/W Aluminum
SKV606014-AL 价格&库存
很抱歉,暂时无法提供与“SKV606014-AL”相匹配的价格&库存,您可以联系我们找货
SKV606014-AL
    • 1+80.90070
