Pressure-Sensitive Conductive Sheet
(Velostat/Linqstat) PRODUCT ID: 1361
Description
This conductive material (also known as "Velostat" or "Linqstat") is a nice addition for your
wearable/sensor hacking toolkit. It's pressure-sensitive: squeezing it will reduce the resistance, so it's handy
for making flexible sensors. And it's a lot less expensive than off-the-shelf pressure or bend sensors too!
Each order comes with a 11"x11" (28cm x 28cm) 4mil (0.1mm) thick piece. We may fold the sheet into
quarters to ship it to you. To remove any hard creases, simply lay flat on a table and put a heavy book on
top to flatten it out.
This presentation from Hannah Perner-Wilson (plusea) has a lot of great ideas for how to use this material.
https://cdn-shop.adafruit.com/datasheets/HandcraftingSensors.pdf
Technical Details
o
o
o
o
o
o
o
Dimensions: 11" x 11" (280mm x 280mm)
4 mil / 0.1mm thick
Weight: 18.66g
Temperature Limits : -45°C to 65°C (-50°F to 150°F)
Heat Sealable : Yes
Volume Resistivity :
很抱歉,暂时无法提供与“1361”相匹配的价格&库存,您可以联系我们找货
