ISP1807-LR-RS
ISP1807-LR-RS
    INSIGHTSIP(Insight SiP)
    ISP1807-LR-RS
ISP1807-LR-RS 数据手册
ISP1807 Data Sheet Built-in Antenna Low Energy Module BT 5 Long Range, Zigbee, Thread, ANT+ This ultra-small LGA module, 8 x 8 x 1 mm, is based on the nRF52840 Chip. Its powerful Cortex™ M4 CPU, flash and RAM memory combined with an optimized antenna offers the perfect solution for Bluetooth connectivity. The solution is best in class for RF performance and low power consumption. Long range and multiple digital and analogue interfaces give optimum flexibility for sensor integration. Key Features Applications ▪ 2.4GHz Ultra Low Power RF Transceiver ▪ Full Bluetooth 5 – long range stack ANT/ANT+ stack 2.4 GHz proprietary stack ▪ Advanced Wearables: watches, fitness devices, wireless payment wearables, connected health, augmented reality applications … ▪ BT Mesh, Zigbee, Thread stacks available ▪ Smart Home sensors and controllers ▪ NFC-A Tag for OOB pairing ▪ Industrial IoT sensors and controllers ▪ Fully integrated RF matching and Antenna ▪ Advanced remote controls ▪ Integrated 32 MHz& 32kHZ Clock ▪ Remote &Gaming controllers ▪ DC/DC converter with loading circuit ▪ Beacons ▪ Based on Nordic Semiconductor nRF52 ▪ 32-bit ARM Cortex M4F CPU ▪ ARM CryptoCell 310 Certifications ▪ 1 MB Flash / 256 kB SRAM ▪ Configurable 46 GPIOs including 8 ADC ▪ Bluetooth SIG certified ▪ Many interfaces USB, SPI, UART, PDM, I2C ▪ CE certified ▪ Power supply 1.7 to 3.6V, USB supply 5V ▪ FCC, IC certified ▪ Very small size 8.0 x 8.0 x 1.0 mm ▪ TELEC, KCC certified ▪ Temperature -40 to +85 °C ▪ RoHS and Reach compliant ▪ Pin to Pin compatible with ISP1507 ▪ Conflict Mineral Declaration www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 1/25 ISP1807 Data Sheet Revision History Revision Date Ref Change Description R0 23/11/2017 cr pg Preliminary release R1 12/12/2017 cr pg Engineering samples release R2 20/04/2018 cr pg Section 5.2 – FW tool correction and update Section 6.5 – Extension name change R3 22/08/2018 cr pg Section 3 – Typo error correction R4 12/12/2018 cr pg Section 2.9 – Schematic updated R5 18/02/2019 cr pg Definitive release R6 14/03/2019 cr pg Correction VCC / VCCH No High-Power Mode availability R7 06/06/2019 mm pg Change to MSL3 R8 08/11/2019 mm pg Section 4.1 – Mechanical dimension precision Section 8 – Certification list update R9 17/04/2020 cb pg Section 4.2 – Assembly guideline precisions Section 8 – Certification list update R10 03/05/2021 Vn pg Section 8 – Certification list update R11 29/04/2022 pd pg Document layout update www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 2/25 ISP1807 Data Sheet Contents 1. Block Diagram ............................................................................................................................................ 4 2. 2.1. 2.2. 2.3. 2.4. 2.5. 2.6. 2.7. 2.8. 2.9. Specifications ............................................................................................................................................. 5 Important Notice................................................................................................................................. 5 Absolute Maximum Ratings ............................................................................................................... 5 Operating Conditions ......................................................................................................................... 5 Power Consumption........................................................................................................................... 6 Clock Sources .................................................................................................................................... 6 Radio Specifications .......................................................................................................................... 6 Range Measurement ......................................................................................................................... 7 Antenna Performance ........................................................................................................................ 7 Electrical Schematic........................................................................................................................... 9 3. Pin Description ......................................................................................................................................... 10 4. 4.1. 4.2. 4.3. Mechanical Outlines ................................................................................................................................ 13 Mechanical Dimensions ................................................................................................................... 13 SMT Assembly Guidelines............................................................................................................... 15 Antenna Keep-Out Zone .................................................................................................................. 15 5. 5.1. 5.2. 5.3. Product Development Tools .................................................................................................................. 16 Hardware .......................................................................................................................................... 16 Firmware .......................................................................................................................................... 16 Development Tools .......................................................................................................................... 17 6. 6.1. 6.2. 6.3. 6.4. 6.5. Packaging & Ordering information ....................................................................................................... 18 Marking ............................................................................................................................................ 18 Prototype Packaging ........................................................................................................................ 18 Jedec Trays...................................................................................................................................... 18 Tape and Reel ................................................................................................................................. 19 Ordering Information ........................................................................................................................ 20 7. 7.1. 7.2. 7.3. Storage & Soldering information .......................................................................................................... 21 Storage and Handling ...................................................................................................................... 21 Moisture Sensitivity .......................................................................................................................... 21 Soldering information ....................................................................................................................... 22 8. 8.1. 8.2. 8.3. 8.4. 8.5. 8.6. 8.7. Quality & User information ..................................................................................................................... 23 Certifications .................................................................................................................................... 23 USA – User information ................................................................................................................... 23 Canada – User information .............................................................................................................. 24 RF Exposure Information ................................................................................................................. 24 Informations concernant l'exposition aux fréquences radio (RF).................................................... 24 Discontinuity ..................................................................................................................................... 24 Disclaimer ........................................................................................................................................ 25 www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 3/25 ISP1807 Data Sheet 1. Block Diagram This module is based on nRF52840 Nordic Semiconductor 2.4GHz wireless System on Chip (SoC) integrating a 2.4 GHz transceiver, an ARM ®Cortex® -M4 32-bit processor with 64 MHz FPU, a 1 MB flash memory, a 256 kB RAM and analog and digital peripherals. It can support BLE, ANT/ANT+ and a range of proprietary 2.4 GHz protocols, such as Gazell from Nordic Semiconductor. Fully qualified BLE stacks for nRF52840 are implemented in the S140 SoftDevices which can be freely downloaded. ISP1807 can then be used in Bluetooth Central, Peripheral, Observer or Broadcaster role with up to 20 connections and for both ends of other proprietary protocols. nRF52840 platform also provides extensive software support for ANT, ZIGBEE and THREAD applications. Ultra-low power consumption and advanced power management enables battery lifetimes up to several years on a coin cell battery. Even though its very small size 8 x 8 x 1.0 mm, the module integrates decoupling capacitors, 32 MHz and 32.768 kHz crystals, load capacitors, DC-DC converter, RF matching circuit and antenna in addition to the wireless SoC. Only the addition of a suitable DC power source is necessary for BLE / ANT / ZIGBEE / THREAD connectivity. Sensor applications require the further addition of appropriate sensors. The antenna was designed to be optimized with several standard ground plane sizes. The NFC tag antenna can be connected externally. www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 4/25 ISP1807 Data Sheet 2. Specifications 2.1. Important Notice The electrical specifications of the module are directly related to the Nordic Semiconductor specifications for the nRF52840 chipset. Bellow information is only a summary of the main parameters. For more detailed information, especially about current consumption, please refer to the up-to-date specification of the chipset available on Nordic Semi website. 2.2. Absolute Maximum Ratings Parameter Min Main Supply Voltage respect to ground – VCC_nRF Max Unit -0.3 3.9 V USB Supply Voltage respect to ground – VBUS -0.3 5.8 V IO Pin Voltage -0.3 3.9 V RF Input Level 10 dBm NFC Antenna pin current 80 mA +125 °C Moisture Sensitivity Level 5 - ESD Human Body Model 4000 V ESD Charged Device Model 750 V 10000 cycles Storage Temperature Typ -40 Flash Endurance ATTENTION CONSERVE PRECAUTIONFOR HANDLING ELECTROSTATIC SENSITIVE DEVICES Human Body Model Class 3A 2.3. Operating Conditions Parameter Min Typ Max Unit VCC_nRF Supply Voltage, independent of DCDC enable 1.7 3.0 3.6 V VBUS Supply Voltage 4.35 5.0 5.5 V Extended Industrial Operating Temperature Range -40 +25 +85 °C www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 5/25 ISP1807 Data Sheet 2.4. Power Consumption Parameter Min Typ Max Unit Peak Current, Transmitter +8 dBm, VCC 3V + DCDC 16.4 mA Peak Current, Transmitter 0 dBm, VCC 3V + DCDC 6.4 mA Peak Current, Receiver 1 Mbps, VCC 3V + DCDC 6.26 mA System OFF, no RAM retention 0.4 µA System ON, no RAM retention, wake on RTC 1.5 µA Additional RAM retention current per 4 KB block 30 N nA Typ Max Unit Internal High Frequency Clock for RF Stability: 32 MHz Crystal Frequency Tolerance (1) +/- 40 ppm Internal Low Frequency Clock for BLE Synchronization: 32.768 kHz Crystal Frequency Tolerance (1) +/- 40 ppm Internal Low Frequency Clock for BLE Synchronization: RC Oscillator (2) +/- 250 ppm RF Frequency Tolerance for BLE Operation +/- 40 ppm Max Unit 2480 Mhz +8.5 dBm 2.5. Clock Sources Parameter (1) (2) Min including initial tolerance, drift, aging, and frequency pulling Frequency tolerance after calibration 2.6. Radio Specifications Parameter Min Frequency Range 2402 Typ Maximum Output Power +8 Rx Sensitivity Level, BLE1 Mbps -95 dBm Rx Sensitivity Level, BLE Long Range 125 kbps -103 dBm Antenna Gain 0.6 dBi EIRP Data Rate www.insightsip.com -19.4 8.6 dBm 125 2000 kbps The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 6/25 ISP1807 Data Sheet 2.7. Range Measurement Range measurement between ISP1807-LR test board (configured as Central) and ISP1807-LR test board (configured as Peripheral). Parameter Min Typ Max Unit Range Open field @1m height (0 dBm, 1 Mbps) 150 m Range Open field @1m height (0 dBm, 125 Kbps) 175 m Range Open field @1m height (8 dBm, 1 Mbps) 230 m Range Open field @1m height (8 dBm, 125 Kbps) 450 m 2.8. Antenna Performance Typical Antenna Return Loss Module mounted on a USB dongle ground plane Radiation Pattern in 3 planes Module mounted on a USB dongle ground plane Gain measurement in dBi in the BLE band from 2.4 to 2.5 GHz. www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 7/25 ISP1807 Data Sheet Ground Plane Effect Simulation USB dongle ground plane (size: 18 x 30 mm²) Cell phone config 1 ground plane (size: 40 x 100 mm²) Cell phone config 2 with side ground plane (size: 40 x 100 mm²) www.insightsip.com Cell phone config 1 with side ground plane (size: 40 x 100 mm²) Cell phone config 3 with side ground plane (size: 40 x 100 mm²) The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 8/25 ISP1807 Data Sheet 2.9. Electrical Schematic Electrical schematic showing ISP1807 module connections www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 9/25 ISP1807 Data Sheet 3. Pin Description The module uses an LGA format with a double row of pads on a 0.65 mm pitch. The pad layout follows the QFN Jedec standard for 2 row LGA parts. The NC pads are to be connected to isolated metal pads on the application PCB for mechanical stability and reliability (drop test). Pin Name Pin function Description 1 2 Ground Digital I/O NFC Input Digital I/O 14 15 16 17 18 19 20 VSS P0_09 NFC1 P0_12 TRACEDATA1 P0_10 NFC2 P0_14 P0_26 VSS D+ P0_16 DP0_21 VBUS P0_18 RESET VSS P0_20 VSS P0_22 VSS P0_24 OUT_ANT 21 22 VSS OUT_MOD Ground Antenna I/O 23 24 25 26 27 28 29 30 31 32 33 VSS VSS VSS VCC_nRF P0_17 SWDIO P0_13 SWDCLK VSS P0_08 P0_07 TRACECLK Ground Ground Ground Power Digital I/O Digital I/O Digital I/O Digital Input Ground Digital I/O Digital I/O Should be connected to ground plane on application PCB General purpose I/O pin NFC antenna connection General purpose I/O pin Trace port output General purpose I/O pin NFC antenna connection General purpose I/O pin General purpose I/O pin Should be connected to ground plane on application PCB USB D+ General purpose I/O pin USB DGeneral purpose I/O pin 5V input for USB 3.3V regulator General purpose I/O pin Configurable as system RESET pin Should be connected to ground plane on application PCB General purpose I/O pin Should be connected to ground plane on application PCB General purpose I/O pin Should be connected to ground plane on application PCB General purpose I/O pin This pin is connected to the internal antenna It should be connected to Pin 22 OUT_MOD for normal operation Should be connected to ground plane on application PCB This pin is the RF I/O pin of the BLE module It should be connected to Pin 20 OUT_ANT for normal operation Should be connected to ground plane on application PCB Should be connected to ground plane on application PCB Should be connected to ground plane on application PCB Power supply (1.7 – 3.6V) General purpose I/O pin Serial Wire Debug I/O for debug and programming General purpose I/O pin Serial Wire Debug clock input for debug and programming Should be connected to ground plane on application PCB General purpose I/O pin General purpose I/O pin Trace port clock output 3 4 5 6 7 8 9 10 11 12 13 Digital I/O NFC Input Digital I/O Digital I/O Ground Digital I/O Digital I/O Digital I/O Digital I/O Power Digital I/O Ground Digital I/O Ground Digital I/O Ground Digital I/O Antenna I/O www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 10/25 ISP1807 Data Sheet Pin Name Pin function Description 34 35 P0_06 P0_04 AIN2 P0_05 AIN3 P0_15 P0_03 AIN1 P0_27 P0_02 AIN0 P0_25 P0_31 AIN7 P0_11 TRACEDATA2 P0_30 AIN6 P0_19 P0_29 AIN5 P0_23 P0_28 AIN4 P1_02 P1_06 P1_15 P1_14 P1_13 P1_05 P1_08 P1_09 TRACEDATA3 P1_00 TRACEDATA0 P1_03 P1_12 P1_10 P1_11 P1_07 P1_04 P1_01 NC Digital I/O Digital I/O Analog Input Digital I/O Analog Input Digital I/O Digital I/O Analog Input Digital I/O Digital I/O Analog Input Digital I/O Digital I/O Analog Input Digital I/O General purpose I/O pin General purpose I/O pin SAADC/COMP/LPCOMP input General purpose I/O pin SAADC/COMP/LPCOMP input General purpose I/O pin General purpose I/O pin SAADC/COMP/LPCOMP input General purpose I/O pin General purpose I/O pin SAADC/COMP/LPCOMP input General purpose I/O pin General purpose I/O pin SAADC/COMP/LPCOMP input General purpose I/O pin Trace port output General purpose I/O pin SAADC/COMP/LPCOMP input General purpose I/O pin General purpose I/O pin SAADC/COMP/LPCOMP input General purpose I/O pin General purpose I/O pin SAADC/COMP/LPCOMP input General purpose I/O pin General purpose I/O pin General purpose I/O pin General purpose I/O pin General purpose I/O pin General purpose I/O pin General purpose I/O pin General purpose I/O pin Trace port output General purpose I/O pin Trace port output General purpose I/O pin General purpose I/O pin General purpose I/O pin General purpose I/O pin General purpose I/O pin General purpose I/O pin General purpose I/O pin Isolated pad on application PCB for mechanical stability 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 to 78 Digital I/O Analog Input Digital I/O Digital I/O Analog Input Digital I/O Digital I/O Analog Input Digital I/O Digital I/O Digital I/O Digital I/O Digital I/O Digital I/O Digital I/O Digital I/O Digital I/O Digital I/O Digital I/O Digital I/O Digital I/O Digital I/O Digital I/O Digital I/O Not Connected www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 11/25 ISP1807 Data Sheet ISP1807 pad placement and pin assignment for the LGA QFN package TOP VIEW www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 12/25 ISP1807 Data Sheet 4. Mechanical Outlines 4.1. Mechanical Dimensions Package dimensions www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 13/25 ISP1807 Data Sheet Dimensional drawing for 62-Pad LGA Package www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 14/25 ISP1807 Data Sheet 4.2. SMT Assembly Guidelines For PCB Land Patterns and Solder Mask layout, Insight SiP recommends using the same dimensions as module pads, ie 0.4 x 0.4 mm for standard pads and 0.8 x 0.8 mm for corner pads. For implementations in which most or all of the inner pads are used Insight SiP recommends the use of capped vias placed in the centre of each pad. For standard PCB types (no micro vias - all vias are top to bottom): we use nominal 0.4mm catch pads with 0.2mm vias. The vias should be plugged and capped to avoid solder wicking. For HDI PCB types having micro vias on a layer by layer basis: we use 0.25mm catch pads and 0.1mm copper filled laser vias. Ideally the via is centered in the pad. For reduced pinout implementations we recommend using external pads only. The use of a small number of internal pads can be accommodated by placing normal vias in the centre of the device. In this case only the required pads should be Solder Mask opened and the vias tented with solder mask to prevent short circuits. In general, we recommend NSMD solder mask with 50µm SM extension. 4.3. Antenna Keep-Out Zone For optimal antenna performance, it is recommended to respect a metal exclusion zone to the edge of the board: no metal, no traces and no components on any application PCB layer except mechanical LGA pads. www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 15/25 ISP1807 Data Sheet 5. Product Development Tools 5.1. Hardware In order to assist clients in developing their Bluetooth Smart solutions based on the ISP1807, Insight SIP offers a Development Kit containing: One Interface Board J-Link Lite CortexM-9 JTAG/SWD Emulator One Test Board A Development Dongle 5 ISP1807 module samples Cables, power supply and coin battery holder Using this development kit, product developers can use a working solution as starting point to develop their own products. Time to market is saved by avoiding starting from a blank sheet of paper. In addition, there may be some applications that use the hardware as is. Please refer to the documentation for more information: http://www.insightsip.com/fichiers_insightsip/pdf/ble/ISP1807/isp_ble_DS1807_DK.pdf 5.2. Firmware ISP1807supports Bluetooth Low Energy protocol stacks. It also provides extensive software support for ANT, ZIGBEE and THREAD applications as well as 2.4 GHz protocol stacks, including Gazell. All are available as downloads at www.nordicsemi.com. The S140 SoftDevice is a Bluetooth low energy (BLE) Central and Peripheral protocol stack solution. The S140 SoftDevice supports up to twenty connections with an additional observer and a broadcaster role all running concurrently. The S140 SoftDevice integrates a Bluetooth low energy Controller and Host, and provides a full and flexible API for building Bluetooth low energy nRF52 System on Chip (SoC) solutions: - Bluetooth 5.0 compliant low energy single-mode protocol stack suitable for Bluetooth low energy products. - Concurrent central, observer, peripheral, and broadcaster roles with up to 20 concurrent connections along with one Observer and one Broadcaster. - Link layer supporting LE 1M PHY and LE 2M PHY. - LL Privacy. - LE Data Packet Length Extension. - LE Secure Connections pairing model www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 16/25 ISP1807 Data Sheet 5.3. Development Tools The following development tools and software are recommended for using and testing ISP1807 module: Nordic Semiconductor nRFgo Studio: Downloadable after registering at www.nordicsemi.com. Nordic Semiconductor Master Control Panel: Downloadable after registering at www.nordicsemi.com. Keil MDK-ARM Lite: Downloadable from https://www.keil.com/demo/eval/arm.htm. Segger J-Link Lite: Downloadable from http://www.segger.com/jlink-software.html. nRF52 Software Development Kit (SDK): nRF52 SDK can be downloaded after registering at www.nordicsemi.com. It contains example of source codes applications (C language): - Precompiled HEX files - Source code - Keil ARM project files - IAR project files www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 17/25 ISP1807 Data Sheet 6. Packaging & Ordering information 6.1. Marking M /N : I S P 1 8 0 7 T T Y Y W W R ISP1807 YY Part Number 2 letters Module Type (see section 6.5) 2 digits year number WW 2 digits week number R 1 letter Hardware revision TT 6.2. Prototype Packaging For engineering samples and prototype quantities up to 99 units, deliveries are provided in thermoformed trays or cut tapes. They are delivered in sealed pack with desiccant pack and humidity sensors. Please see section 7.2 for more information on moisture sensitivity. Please order with “ST” code packaging suffix. 6.3. Jedec Trays For pre-production volumes, ISP1807 are available in Jedec trays. They are delivered in sealed pack with desiccant pack and humidity sensors. These Jedec trays are also suitable for further baking. Please see section 7.2 for more information on moisture sensitivity. Please order with “JT” code packaging suffix. Refer to tray sizes below. Complete information on Jedec trays is available on request. www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 18/25 ISP1807 Data Sheet Top view position of modules within the tray. 6.4. Tape and Reel ISP1807 are also available in Tape & Reel. They are delivered in sealed pack with desiccant pack and humidity sensors. Reels are proposed in standard quantities of 500 units (180mm / 7” reel) or 2000 units (330mm / 13” reel) only. Please order with “RS” code packaging suffix for 500-unit reels and “R2” for 2000-unit reels. www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 19/25 ISP1807 Data Sheet Top view position of modules within the reel. 6.5. Ordering Information I S P 1 8 0 7 - T ▼ ▼ ▼ T - Z Z ▼ ▼ ▼ ▼ ▼ ▼ ▼ ▼ ▼ I S P 1 8 0 7 Part Number - L R Long range version - E B Evaluation Board(1) - T B Test board (1) - S T Standard Tray or Cut Tape - Jedec Tray Packaging J T - R S Reel of 500 units - R 2 Reel of 2000 units (1) Please see section 5.1 and refer to the following documentation for more information on development kit and test board: http://www.insightsip.com/fichiers_insightsip/pdf/ble/ISP1807/isp_ble_DS1807_DK.pdf http://www.insightsip.com/fichiers_insightsip/pdf/ble/ISP1807/isp_ble_ANXXXXX.pdf www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 20/25 ISP1807 Data Sheet 7. Storage & Soldering information 7.1. Storage and Handling Keep this product away from other high frequency devices which may interfere with operation such as other transmitters and devices generating high frequencies. Do not expose the module to the following conditions: - Corrosive gasses such as Cl2, H2S, NH3, SO2, or NOX - Extreme humidity or salty air - Prolonged exposure to direct Sunlight - Temperatures beyond those specified for storage Do not apply mechanical stress Do not drop or shock the module Avoid static electricity, ESD and high voltage as these may damage the module ATTENTION CONSERVE PRECAUTIONFOR HANDLING ELECTROSTATIC SENSITIVE DEVICES 7.2. Moisture Sensitivity All plastic packages absorb moisture. During typical solder reflow operations when SMDs are mounted onto a PCB, the entire PCB and device population are exposed to a rapid change in ambient temperature. Any absorbed moisture is quickly turned into superheated steam. This sudden change in vapor pressure can cause the package to swell. If the pressure exerted exceeds the flexural strength of the plastic mold compound, then it is possible to crack the package. Even if the package does not crack, interfacial delamination can occur. Since the device package is sensitive to moisture absorption, it is recommended to bake the product before assembly. The baking process for dry packing is 24 hours at 125°C. ISP1807 has been tested MSL-3 according to standards. After baking, modules can be exposed to ambient room conditions (approximately 30 °C/60%RH) during 168 hours before assembly on the PCB. CAUTION MOISTURE SENSITIVE DEVICES www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 21/25 ISP1807 Data Sheet 7.3. Soldering information Recommendation for RoHS reflow process is according to Jedec J–STD-020 and 033 standard profiles. Preheat/Soak Temperature Min (Tsmin) Temperature Max (Tsmax) Time (ts) from (Tsmin to Tsmax) Ramp-up rate (TL to Tp) Liquidous temperature (TL) Time (tL) maintained above TL www.insightsip.com 150 °C 200 °C 60-120 sec 3 °C/sec max 217 °C 60-150 sec Peak package body temperature (T p) Classification Temperature (Tc) Time (tp) maintained above TC-5 °C Ramp-down rate (Tp to TL) Time 25 °C to peak temperature The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. 260°C (+0/-5°C) 260 °C 30 sec 6 °C/sec max 8 mn max Document reference isp_ble_DS1807_R11.docx Page 22/25 ISP1807 Data Sheet 8. Quality & User information 8.1. Certifications All below certificates can be downloaded on the website: Bluetooth SIG Declaration ID n° D046560 CE Certified, DoC Insight SiP Ref TR201105 TELEC Certified, n° 020-200037 KCC Certification n° R-C-iNs-ISP1807 FCC Certification n° 2AAQS-ISP1807 IC Certification n° 11306A-ISP1807 RoHS3 and Reach compliant, Ref TR200301 and TR191101 Conflict Mineral Declaration available, Ref TR180701 To support customers in their application certification, Insight SiP can provide test reports on request. 8.2. EC – CE Certification This device can be operated in at least one Member State without infringing applicable requirements on the use of radio spectrum. 8.3. USA – User information This intends to inform how to specify the FCC ID of our module “ISP1807” on the product. Based on the Public Notice from FCC, the host device should have a label which indicates that it contains our module. The label should use below example wording or any similar wording that expresses the same meaning: “Contains FCC ID: 2AAQS-ISP1807” The label of the host device should also include the below FCC Statement. When it is not possible, this information should be included in the User Manual of the host device: “This device complies with part 15 of the FCC rules. Operation is subject to the following two conditions. (1) This device may not cause harmful interference (2) This device must accept any interference received, including interference that may cause undesired operation. Caution: Any Changes or modifications not expressly approved by the party responsible for compliance could void the user’s authority to operate the equipment.” www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 23/25 ISP1807 Data Sheet 8.4. Canada – User information This intends to inform how to specify the IC ID of our module “ISP1807” on the product. According to Canadian standards “RSS-210” and “RSS-Gen”, the host device should have a label which indicates that it contains our module. The label should use below example wording or any similar wording that expresses the same meaning: “Contains IC: 11306A-ISP1807” The label of the host device should also include the below IC Statement. When it is not possible, this information should be included in the User Manual of the host device: “This device complies with Industry Canada license-exempt RSS standard(s). Operation is subject to the following two conditions: (1) this device may not cause interference, and (2) this device must accept any interference, including interference that may cause undesired operation of the device. Le présent appareil est conforme aux CNR d'Industrie Canada applicables aux appareils radio exempts de licence. L'exploitation est autorisée aux deux conditions suivantes : (1) l'appareil ne doit pas produire de brouillage, et (2) l'utilisateur de l'appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d'en compromettre le fonctionnement.” 8.5. RF Exposure Information This equipment complies with FCC/IC radiation exposure limits set forth for an uncontrolled environment and meets the FCC radio frequency (RF)Exposure Guidelines in Supplement C toOET65 and RSS-102 of the IC radio frequency (RF) Exposure rules. This equipment has very low levels of RF energy that it deemed to comply without maximum permissive exposure evaluation (MPE). 8.6. Informations concernant l'exposition aux fréquences radio (RF) La puissance de sortie émise par l’appareil de sans-fil est inférieure à la limite d'exposition aux fréquences radio d'Industry Canada (IC). Ce module a également été évalué et démontré conforme aux limites d'exposition aux RF d'IC dans des conditions d'exposition à des appareils mobiles et/ou portables. 8.7. Discontinuity Normally a product will continue to be manufactured as long as all of the following are true: - The manufacturing method is still available. - There are no replacement products. - There is demand for it in the market. www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 24/25 ISP1807 Data Sheet In case of obsolescence, Insight SiP will follow Jedec Standard JSD-48. A Product Discontinuation Notice (PDN) will be sent to all distributors and made available on our website. After this, the procedure goes as follows: - Last Order Date will be 6 months after the PDN was published. - Last Shipment Date will be 6 months after Last Order Date, i.e. 12 months after PDN. 8.8. Disclaimer Insight SiP’s products are designed and manufactured for general consumer applications, so testing and use of the product shall be conducted at customer’s own risk and responsibility. Please conduct validation and verification and sufficient reliability evaluation of the products in actual condition of mounting and operating environment before commercial shipment of the equipment. Please also pay attention (i) to apply soldering method that don’t deteriorate reliability, (ii) to minimize any mechanical vibration, shock, exposure to any static electricity, (iii) not to overstress the product during and after the soldering process. The products are not designed for use in any application which requires especially high reliability where malfunction of these products can reasonably be expected to result in personal injury or damage to the third party's life, body or property, including and not limited to (i) aircraft equipment, (ii) aerospace equipment, (iii) undersea equipment, (iv) power plant control equipment, (v) medical equipment, (vi) transportation equipment, (vii) traffic signal equipment, (viii) disaster prevention / crime prevention equipment. The only warranty that Insight SiP provides regarding the products is its conformance to specifications provided in datasheets. Insight SiP hereby disclaims all other warranties regarding the products, express or implied, including without limitation any warranty of fitness for a particular purpose, that they are defectfree, or against infringement of intellectual property rights. Insight SiP customers agree to indemnify and defend Insight SiP against all claims, damages, costs and expenses that may be incurred, including without any limitation, attorney fees and costs, due to the use of products. www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1807_R11.docx Page 25/25
ISP1807-LR-RS 价格&库存
很抱歉,暂时无法提供与“ISP1807-LR-RS”相匹配的价格&库存,您可以联系我们找货
ISP1807-LR-RS
  • 50+95.4822450+11.55517
  • 100+94.86520100+11.48050
  • 200+94.07257200+11.38458
库存:6350
ISP1807-LR-RS
  • 500+93.19042500+11.27782
  • 1000+92.793321000+11.22976
库存:6350
