7.15
H
1.30
1.87+0.06
-0.04
6.90+0.06
-0.02
3.5max
0.65
Ø
Ø0
A
3
2
.40
5
4
A
Pin 5
5.40±0.05
Material 物料
Plastic Housing 塑胶外壳: LCP, UL94V-0, Black
Contact Terminal 接触端子: Copper Alloy
Metallic Shell 金属外壳: Stainless Steel (T=0.25mm)
1.11
0.35
Pin 1
Specification 规格
1.00
1
1.15
1.55
G
1.10±0.05
80
0.
0.75
Recommended P.C.B Layout
F
Viewed from component side General Tolerance: ±0.05
Mating Entry Face
Solder Area
Plating 电镀
Metallic Shell 金属外壳: Matte Tin
Underplating 底层电镀: 50µ" Nickel
Contact Area 接触面积: 30µ" Gold plating
Solder Tails 焊接末端: Gold Flash
Component Outline
4.75±0.10
2.77
7.80
0.60±0.05
3.50±0.10
Electrical 电气
Voltage Rating 电压额定值: 30 V AC
Current Rating 电流额定值: Signal (Pins 2,3,4):1.0 A.
Power (Pins1,5):1.8A.
Operating Temperature 工作温度: -30°C to +85°C.
Contact Resistance 接触电阻值: 30mΩ max.
Insulating Resistance 绝缘电阻值: 1000MΩ min.
Dielectric Withstand Voltage 耐电压: 500V AC/minute
8.30
6.00
2.70+0.05
-0.08
0.50
E
1.00
D
2.30
Mechanical & Environmental 机械 & 环境
Mating Force 插入力: 35N max.
Unmating Force 拨出力: 8N min.
Durability 耐久性: 10,000 Cycles
0.25
0.65±0.05
2.60±0.05
C
0.80
0.15
0.25
1.11±0.10
0.75
1.00
0.36
7.15
Product Description
USB3145
Micro USB Receptacle, Type B, Through Hole,
Vertical, With Through Hole Shell Stakes
By
Detail
3
4
Packing Options
A = Tape & Reel
Part Number
2nd April 2013
2
Request Samples
and Quotation
(1300 per reel)
Drawing Date
1
A
Mating Entry Face
1 = With Mating Entry Face (Standard)
0 = Without Mating Entry Face (MOQ = 7800)
1.1
A
X
Contact Plating
30 = 30µ" Gold
Note: Recommended for 1.6mm PCB thickness,
for thinner PCB's choose USB3130 (B) or USB3105 (A/B).
5.6
30
USB3145
Section A-A
Designed to comply with physical, electrical and environmental
requirements of Micro USB Standard (USB2.0)
4.00
B
Ordering Grid
0.25
Revision
Date
5
CC
Tolerances (Except as Noted)
USB3145
B PCN
B2
17/01/17
X.X ± 0.30
X.X° ± 2°
X.XX ± 0.20
X.XX° ± 1°
X.XXX ± 0.10 X.XXX° ± 0.5°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
ASE
8
Sheet No.
1/2
G
12.0
4.0
Ø
START OF REEL APPROXIMATELY
26PCS EMPTY CARRIER
5
1.
200mm min.
24.0
1.75
END OF REEL APPROXIMATELY
26PCS EMPTY CARRIER
0.4
21.3
H
Cover Tape
I/O Direction
卷盘绕逆时针方向转动
PCS/Reel Reels/Carton PCS/Carton
Products P/N
F
Peel off Angle
剥离角度
0°
12
Ø2
3
ø330
1300
3
3900
10°
Cover Tape
盖带
USB3145
Notes注意:
Peeling off force of top tape: 0.1-1.3N
(Peeling direction as shown)
Ø13.5
Carrier Tape
载带
Materials材料:
Carrier Tape: Polystyrene (PS)
Top Tape: PE
Reel Tape: Polystyrene (PS)
E
Detail F
6
PS
Cardboard
纸板
D
Detail F
Reel
卷筒
Waterproof bag
防水袋
Triangle Liner
三角形班轮
Protection Tape
保护胶带
Carton
纸箱
Label
Label
标签
标签
160mm
C
1300 pieces/reel
1300 件/卷
3 Reels
3 卷轴
B
35
0m
m
700x600x0.05
3900 pieces/carton
3900 件/纸箱
Part Number
Product Description
USB3145
Drawing Date
A
2nd April 2013
By
Detail
1
2
3
m
0m
35
4
Revision
Date
5
CC
USB3145
B PCN
B2
17/01/17
X.X ± 0.30
X.X° ± 2°
X.XX ± 0.20
X.XX° ± 1°
Length
Angle
6
Units:
Metric (mm)
C
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
ASE
8
Sheet No.
2/2
很抱歉,暂时无法提供与“USB3145-30-1-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.902671+0.83444
- 10+5.8200410+0.70356
- 25+5.5835925+0.67498
- 50+5.4642250+0.66055
- 100+5.22641100+0.63180
- 250+4.75107250+0.57434
- 500+4.27590500+0.51690
- 国内价格 香港价格
- 1300+3.800861300+0.45947
- 2600+3.444552600+0.41640
- 6500+3.325766500+0.40204
- 9100+3.159479100+0.38194
- 13000+3.0882113000+0.37332
