SB350-LOCKOUT
SB350-LOCKOUT
    ANDERSON
    SB350-LOCKOUT
SB350-LOCKOUT 数据手册
SB® 350 Connectors Up to 500 Amps The SB® 350 is the largest connector in the series with power capabilities up to 500 amps with a 350 mcm wire. Wires ranging from 1/0 to 350 mcm (53.5 to 185 mm²) fit into the one piece housing available in standard PC or a chemical resistant PBT/PC blend. Silver plated wire or busbar contacts minimize electrical resistance while offering supreme durability and reliability. • Up to 350 mcm (185 mm²) Wires Allows UL rated currents up to 500 amps • Chemical Resistant Housing Option Extends temperature range down to -40°C, while offering enhanced UV and chemical resistance • Same Housings Used for Wire and Busbar Contacts SB 350 ORDERING INFORMATION ® Enables color-coded mechanically keyed wire to busbar connections SB® 350 SB® 350 Standard Housings The largest SB® housings work with wire contacts up to 350 mcm (150 mm²) as well as busbar contacts. Genderless design mates with itself. Mechanical keys are color-coded. NOTE: SB® 350 Black and Blue Housings have the same keying features and can be intermated. Description Part Numbers [ 107.9 ] Minimum Quantity 50 25 4.25 Yellow 914-BK 914 Orange 932-BK 932 Red 913-BK 913 [ 69.9 ] Gray 906-BK 906 2.75 Blue 912-BK 912 Green 931-BK 931 Black 2-7250G8 [ 28.6 ] [ 34.9 ] 1.38 1.13 SB® 350 Chemical Resistant Housings Same features as the Standard SB® 350 but molded in a chemical resistant PBT/ PC blend. Suitable for use to -40°C. Description Part Numbers Minimum Quantity 50 25 Red P913-BK P913 Gray P906-BK P906 Bottom View [ 6.6 ] Ø 0.26 (2) PLC’S MATERIAL ID P = Chemical Resistant [ 182.6 ] 7.19 [ 33.3 ] 1.31 Mated Length SB® 350 Silver Plated Wire Contacts Silver plated contacts offer superior electrical performance and durability up to 10,000 mating cycles. See reducing bushings in accessory section for smaller wires. Dimensions Mating -A- - B - -CAWG mm² Force Loose Piece Part Numbers inches mm inches mm inches mm Minimum Quantity 200 150 50 350 mcm 185 High - 910-BK 910 * 0.75 19.05 0.87 22.10 3.04 77.2 300 mcm 152 High - 910-BK 910 * 0.75 19.05 0.87 22.10 3.04 77.2 4/0 107.2 High 908-BK - 908 * 0.64 16.26 0.75 19.05 3.03 77.0 3/0 85 High 916-BK - 916 * 0.58 14.73 0.70 17.78 3.00 76.2 2/0 67.4 High 907-BK - 907 * 0.49 12.45 0.64 16.26 2.96 75.2 1/0 53.5 High 917-BK - 917 * 0.44 11.18 0.51 12.95 2.91 73.9 [ 32.8 ] 1.29 MIN [ C ± 2.0 ] C ± 0.08 A B [ 20.6 ] 0.81 * Sold as pairs. 2 parts shipped for every 1 part ordered. - 96 - www.andersonpower.com All Data Subject To Change Without Notice SB® 350 Silver Plated Busbar Contacts [ 131.7 ] 5.19 Use 2 busbar contacts per housing to provide a quick disconnect input or output busbar connection. Busbar contacts are for mating with wire contacts only. Part number 350BBS includes lock nuts. Locknuts must be ordered separately for B01998P1. # 3/8 - 16 THD B [ 17.0 ] 0.67 Mating Type Thread Force Loose Piece Part Numbers Minimum Quantity 50 10 3/8-16 High B01998P1 350BBS Busbar Lock Nut 3/8-16 - H1216P9 110G73 See Busbar contact drawing on website for further detail. [ 22.3 ] 0.88 [ 2.5 ] 0.10 NOTE: Has not been tested by UL. SB® 350 CONNECTOR TEMPERATURE CHARTS - Temperature rise charts are based on a 25°C ambient temperature. Current - Temperature Derating per IEC 60512-5-2 Test 5B SB® 350 Temperature Rise at Constant Current Ambient Temperature (°C) 125 50 40 30 20 10 0 100 75 50 25 0 50 100 150 200 250 300 350 400 450 500 Amperes Applied 350 MCM 300 MCM 3/0 AWG 2/0 AWG 4/0 AWG 1/0 AWG SB® 350 Temperature Rise Above Ambient (°C) 60 SB® 350 Derating vs. Ambient Temperature 0 50 100 150 200 250 300 350 400 450 500 550 350 MCM 3/0 AWG Amperes Applied 300 MCM 2/0 AWG 4/0 AWG 1/0 AWG SB® 350 CONNECTOR SPECIFICATIONS ELECTRICAL Current Rating Amperes MECHANICAL 1 Wire-to-Wire (350 mcm) UL 1977 CSA 500 325 AWG Wire Contacts with Bushings UL 1977 1/0 to 350 mcm 53.5 to 185 mm 1.100 27.900 °F °C Standard -4° to 221° -20° to 105° Chemical Resistant -40 to 221° -40° to 105° 600 Operating Temperature ² Dielectric Withstanding Voltage Volts AC 2,200 1 2 1/2” of 300 mcm Wire 0.050 Hot Plug Current Rating Amperes - Wire & Busbar 250 cycles at 120V DC 100A mm² in. Max. Wire Insulation Diameter Voltage Rating AC/DC Avg. Mated Contact Resistance Milliohms Wire Size Range Mating Cycles No Load by Plating Wire and Busbar Contacts Silver (Ag) 10,000 Avg. Mating / Unmating Force 2 Pole Min. Contact / Spring Retention Force Lbf. N 30 133 Lbf. N 150 667 Specifications continued on next page All Data Subject To Change Without Notice www.andersonpower.com - 97 - MATERIALS Housing Standard Plastic Resin Polycarbonate Chem. Resistant Resin Polycarbonate / PBT blend Contact Retention Spring Stainless Steel Housing Flammability Rating UL94 V-0 Glow Wire 960°C (GWFI) / 800°C GWIT) Wire & Busbar Contacts 4 Base Copper Alloy Plating Silver NOTE 1: See IEC 60664-1 for working voltage. 1 - Based on: 105°C rated or better cable of the largest size. Properly calibrated APP® recommended tooling, and a 25°C ambient temperature. UL rating not to exceed the maximum operating temperature. CSA rating below a 30°C temperature rise. 2 - Limited by the thermal properties of the connector plastic housing. 3 - Use APP® recommended tooling only. Alternate tools may adversely affect the performance of our connectors along with UL and CSA recognition. 4 - Has not been tested by UL. Contact Termination Methods Crimp ³ Wire Contacts Hand Solder Wire Contacts Wrench / Socket Busbar Contacts SB® 350 IEC INFORMATION Connector Series SB® 350 Creepage / Configurations Clearance per IEC 60950-1 Unmated 5.66 mm Mated 5.66 mm PROTECTION Touch Safety with Wire Contacts IEC 60529 IP10 unmated Material Group IIIa ATTRIBUTES SB® 350 AMP Rating AC/DC 350 Voltage Rating AC/DC (Steady State) 500 V AC/DC (Operational) Breaking Capacity - AMP Rating / Cycles 100 Amp / 10 cycles Voltage Rating (Breaking Capacity) 125 VDC Finger Safety - Mated Only IEC 60529 - IP20 Wire Size Tested 120 mm² Contact Series Tested 908 Climatic Testing (Cold, Heat & MFG) IEC 60512 Test -11j, 11i & 11g Cycle Life IEC 60512 Test 9a - 5,000 Cycles Mechanical Strength Impact IEC 60512-5 @ 29.5 Inches Dropped 8 Times Temperature Range -20 °C to 105 °C -4 °F to 221 °F - 98 - www.andersonpower.com All Data Subject To Change Without Notice SB® 350 ACCESSORIES Cable Clamps * Durable metal cable clamps securely hold cables to prevent accidental strain or pulls from dislodging wire or contacts from the housing. Cable clamps are recommended for solder terminated wires. Cable Size Min / Max Min / Max Description Inches O.D. mm O.D. Part Number Minimum Quantity 10 1.00 to 0.35 25.4 to 8.8 996G1 Bolt On for Discrete Conductor 996G1 * Torque value 50 (in - lbs) / 5.6 (Nm) [ 60.5 ] 2.38 NOTE: For assembly of clamp to housing only The given wire O.D. information is an estimate. Cable clamps should be evaluated for performance with the actual wire to be used. [ 65 ] 2.56 [ 76.1 ] 3.00 [ 10.8 ] 0.43 [ 1.5 ] 0.06 [ 2.1 ] 0.08 SB® 350 [ 11.9 ] 0.47 [ 61.9 ] 2.44 Handles * Handles are made out of durable PC plastic. Hardware to attach to connector body included in kits. Description Part Numbers Minimum Quantity 100 25 Gray Handle Kit - 995G2 Red Handle Kit - 995G4 Handle Only, Gray 3-5074P1 Handle Only, Red 3-5074P3 Handle Only, Black 3-5074P5 Hardware Bag - 106G7 * Torque value 50 (in - lbs) / 5.6 (Nm) NOTE: For assembly of clamp to housing only Dust Cover Prevents dust and dirt from entering the mating interface of the connector when unmated. NOTE: Not a Hermetic Seal. Description Minimum Quantity Dust Cover with Lanyard Strap, Red Part Numbers 500 50 113890P3 134G3 Slide cover over mating end. SB® 350 Lockout Works with standard lockout - tagout equipment to prevent access to the mating interface of the connector. Made from durable PC plastic. Description Minimum Quantity Red Lockout - Tagout Kit Part Number 25 SB350-LOCKOUT SB® 350 Connector not included. All Data Subject To Change Without Notice www.andersonpower.com - 99 - Manual Release Bracket - Mounting Side * Works with the Locking Side to ease mating and unmating connectors. Part Numbers Description Minimum Quantity Bracket and Hardware Kit Bracket Only Hardware Bag 66 - B00229P1 - 25 - - 106G6 10 922G1 - * Torque value 50 (in - lbs) / 5.6 (Nm) NOTE: For assembly of brackets to housing only Mounting Plate Hardware Manual Release Bracket - Locking Side with Cable Clamp * Works with the Mounting Side to ease mating and unmating connectors. Cable Size Min / Max Min / Max Description Inches O.D. Minimum Quantity Bracket and Hardware Kit w/ Clamp Kit 0.94 to 0.61 mm O.D. Part Number 23.7 to 15.5 10 919 * Torque value 50 (in - lbs) / 5.6 (Nm) NOTE: For assembly of bracket to housing only The given wire O.D. information is an estimate. Cable clamps should be evaluated for SB® 350 performance with the actual wire to be used. Manual Release Bracket - Locking Side no Cable Clamp * Works with the Battery side to ease mating and unmating connectors. Description Part Number Minimum Quantity Bracket and Hardware Kit No Clamp Kit 10 919G1 * Torque value 50 (in lbs) / 5.6 (N - M) NOTE: For assembly of bracket to housing only Reducing Bushings: for Use with Contact Part Number 907 Use with contact part number 907-BK to allow a smaller wire to be used with the connector. Electrical capability is derated with smaller wire. Contact Barrel Size Wire Size AWG mm AWG Minimum Quantity 2/0 67.4 1/0 mm² Part Numbers 53.5 500 5918-BK 100 5918 [ 28.4 ] 1.12 [ 11.1 ] 0.44 Wire Entrance - 100 - www.andersonpower.com All Data Subject To Change Without Notice SB® Tooling Information Wire Size AWG mm² Loose Piece Part Number Silver Plating Loose Piece Contact Crimp Tools Hand Tool OR Pneumatic Tool + Die + Locator Number of Crimps SB® 50 6 13.3 8 8.4 1307 5900 5952 1388G6 1309G4 1387G1 Single 5953 10 to 12 5.3 to 3.3 1 42.4 1323G1 2 33.6 1319 4 21.2 1319G4 6 13.3 1319G6 1389G6 1388G7 5915 1389G7 SB® 120 1388G3 1368 Series 1387G1 1388G4 1389G4 Single SB® TOOLING SB® 175 1/0 53.5 1382 1 42.4 1347 2 33.6 1383 4 21.1 1384 6 13.3 1348 1368 Series 1387G2 1303G13 1304G32 Double 1387G1 1388G4 1389G3 Single SB® 350 350 mcm 185 910 300 mcm 152 910 4/0 107.2 908 3/0 85 916 2/0 67.4 907 1/0 53.5 917 N/A 1303G3 1368 Series 1387G2 Double 1304G31 1303G12 NOTE: See website for the most current information. SB® 2/0 Tooling Information Wire Size Loose Piece Part Number Loose Piece Contact Crimp Tools AWG mm² Silver Plating Hand Tool 2/0 53.5 1328G1 1368 OR Pneumatic Tool 1387G2 + Die 1303G12 + Locator Number of Crimps 1304G32 Double NOTE: See website for the most current information. Your Best Connection™ 2020-0055 DS-SB350 REV C7 Anderson™ will use reasonable efforts to include accurate and up-to-date content in the data sheet. All product information contained in the data sheet including ordering information, illustrations, specifications, and dimensions, are believed to be reliable as of the date of publishing, but is subject to change without notice. Anderson™ makes no warranty or representation as to its accuracy. Content in the data sheet may contain technical inaccuracies, typographical errors and may be changed or updated without notice. Anderson™ may also make improvements and/or changes to the products and/or to the programs described in the content at any time without notice. Current sales drawings and specifications are available upon request. ©2020 Anderson Power Products, Inc. All rights reserved. APP®, A®, Anderson Power Products®, SB® and the APP Logo are registered trademarks of Anderson Power Products, Inc. Anderson™ and Your Best Connection™ are trademarks of Anderson Power Products, Inc. All Data Subject To Change Without Notice www.andersonpower.com - 101 -
SB350-LOCKOUT 价格&库存
很抱歉,暂时无法提供与“SB350-LOCKOUT”相匹配的价格&库存,您可以联系我们找货
SB350-LOCKOUT
    库存:25
