ISP1507-AX-RS
ISP1507-AX-RS
    INSIGHTSIP(Insight SiP)
    Module
    ISP1507-AX-RS
ISP1507-AX-RS 数据手册
ISP1507 Data Sheet Bluetooth 5.0 Low Energy Module Supporting Mesh, ANT, NFC With built-in MCU & Antenna This ultra-small LGA module, 8 x 8 x 1 mm, is based on the nRF52 Chip. Its powerful Cortex™ M4 CPU, flash and RAM memory combined with an optimized antenna offers the perfect solution for Bluetooth connectivity. The solution is best in class for RF performance and low power consumption. Multiple digital and analogue interfaces give optimum flexibility for sensor integration. Key Features Applications ▪ Multi-protocol 2.4GHz Ultra Low Power RF Transceiver based on Nordic Semiconductor nRF52 ▪ Bluetooth 5.0 & Mesh ANT 2.4 GHz proprietary protocol ▪ Connected sensors for medical devices, healthcare, sport, fitness, industrial … ▪ NFC-A Tag for OOB pairing in option ▪ IoT applications, connected objects ▪ Wearable technology ▪ Home automation ▪ Beacons ▪ Fully integrated RF matching and Antenna ▪ Integrated 32 MHz & 32kHZ Clock in option ▪ DC/DC converter with loading circuit ▪ 32-bit ARM Cortex M4 CPU ▪ 512 kB Flash and 64 kB SRAM or 192 kB Flash and 24 kB SRAM variants ▪ From 10 to 30 configurable GPIOs including from 2 to 8 ADCs ▪ Interfaces SPI, I2C, UART, PWM, PDM ▪ Single 1.7 to 3.6 V supply ▪ Very small size 8.0 x 8.0 x 0.95 mm ▪ Temperature -40 to +85 °C www.insightsip.com Certifications ▪ Fully FCC certified module ▪ Fully CE certified module ▪ Fully IC certified module ▪ Fully TELEC certified module ▪ Bluetooth SIG certified QDL listing ▪ RoHS compliant The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1507_R18.docx Page 1/31 ISP1507 Data Sheet Document Revision History Revision Date Ref Change Description R0 15/02/2016 cr pg Preliminary release R1 16/06/2016 cr pg RF specification update R2 19/10/2016 cr pg Marking update + schematic CIAA R3 17/11/2016 cr pg Marking update + RF exposure for FCC/IC R4 24/11/2016 cr pg Pin description update R5 04/01/2017 cr pg Current consumption update R6 16/01/2017 cr pg Bluetooth version update R7 05/10/2017 cr pg Reference design addition R8 22/01/2018 cr pg Max capacitance & inductance specification R9 12/05/2018 cr pg Addition of AL variant R10 09/07/2018 cr pg AL variant specification update R11 19/10/2018 cr pg Supply voltage update R12 14/12/2018 cr pg Electrical spec update + new reference design R13 16/10/2019 mm pg Upgrade to MSL 3 R14 15/10/2020 ys pg Addition of AC variant + Power consumption update R15 26/01/2022 cb pg Certification list update R16 18/02/2022 ys pg Marking evolution R17 13/04/2022 cb pg Removal of AC variant + Certification list update R18 29/04/2022 pd pg Document layout update www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1507_R18.docx Page 2/31 ISP1507 Data Sheet Contents 1. 2. 2.1. 2.2. 2.3. 2.4. 2.5. 2.6. 2.7. 3. 4. 4.1. 4.2. 4.3. 5. 5.1. 5.2. 5.3. 6. 6.1. 6.2. 7. 7.1. 7.2. 7.3. 7.4. 7.5. 8. 8.1. 8.2. 8.3. 9. 9.1. 9.2. 9.3. 9.4. 9.5. 9.6. 9.7. Block Diagram & Features................................................................................................................................... 4 Specifications........................................................................................................................................................ 6 General Notice ............................................................................................................................................ 6 Absolute Maximum Ratings......................................................................................................................... 6 Operating Conditions................................................................................................................................... 6 Power Consumption .................................................................................................................................... 7 Clock Sources ............................................................................................................................................. 7 Radio Specifications .................................................................................................................................... 7 Electrical Schematic .................................................................................................................................. 10 Pin Description.................................................................................................................................................... 13 Mechanical Outlines ........................................................................................................................................... 15 Mechanical Dimensions ............................................................................................................................ 15 SMT Assembly Guidelines ........................................................................................................................ 16 Antenna Keep-Out Zone ........................................................................................................................... 16 Product Development Tools.............................................................................................................................. 17 Hardware................................................................................................................................................... 17 Firmware ................................................................................................................................................... 17 Development Tools ................................................................................................................................... 19 Reference Designs ............................................................................................................................................. 20 Beacon Design .......................................................................................................................................... 20 Sensor Board Design ................................................................................................................................ 21 Packaging & Ordering information................................................................................................................... 24 Marking ..................................................................................................................................................... 24 Prototype Packaging ................................................................................................................................. 24 Jedec Trays............................................................................................................................................... 24 Tape and Reel........................................................................................................................................... 25 Ordering Information ................................................................................................................................. 26 Storage & Soldering information ...................................................................................................................... 27 Storage and Handling................................................................................................................................ 27 Moisture Sensitivity ................................................................................................................................... 27 Soldering information ................................................................................................................................ 28 Quality & User information ................................................................................................................................ 29 Certifications ............................................................................................................................................. 29 USA – User information............................................................................................................................. 29 Canada – User information ....................................................................................................................... 30 RF Exposure Information .......................................................................................................................... 30 Informations concernant l'exposition aux fréquences radio (RF) ............................................................... 30 Discontinuity .............................................................................................................................................. 30 Disclaimer ................................................................................................................................................. 31 www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1507_R18.docx Page 3/31 ISP1507 Data Sheet 1. Block Diagram & Features This module is based on nRF52 Nordic Semiconductor 2.4GHz wireless System on Chip (SoC) integrating a 2.4 GHz transceiver, a 32-bit ARM Cortex™-M4 CPU, flash and RAM memory, and analog and digital peripherals. It can support BLE, Mesh, ANT and a range of proprietary 2.4 GHz protocols, such as ShockBurst. Fully qualified stacks for nRF52 are freely available for operating in Central role, Peripheral role, Scanning and Advertising. Ultra-low power consumption and advanced power management enables battery lifetimes up to several years on a coin cell battery. Even though its very small size 8 x 8 x 0.95 mm, the module integrates, in addition to the wireless SoC, all required decoupling and load capacitors, DC-DC converter, 32 MHz crystal, 32.768 kHz optional crystal , RF matching circuit and antenna. Only the addition of a suitable DC power source is necessary for module connectivity. Sensor applications require the further addition of appropriate sensors. The antenna was designed to be optimized with several standard ground plane sizes. When NFC function is available, the NFC tag antenna can be connected externally. www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1507_R18.docx Page 4/31 ISP1507 Data Sheet The main features versus the different variants are described in the table below. Module Type iSP1507-AC iSP1507-AL iSP1507-AX Specification Features Other protocol Tx Power Data rate SoftDevice Processor Flash / RAM GPIOs ADCs SPI NFC tag USB Other Power Supply Crystals Size (mm) Temperature BT 5.0 BLE +4 dBm 2 Mbps S112/S113 32-bit ARM Cortex M4 192 kB / 24 kB 10 2 Yes No No UART, PWM, PDM 1.7-3.6 V + LDO/DCDC 32 MHz 8 x 8 x 0.95 85°C BT 5.0 BLE ANT +4 dBm 2 Mbps S112/S113 32-bit ARM Cortex M4 192 kB / 24 kB 13 3 Yes No No UART, PWM, PDM 1.7-3.6 V + LDO/DCDC 32 MHz & 32 kHz 8 x 8 x 0.95 85°C BT 5.0 BLE & Mesh ANT +4 dBm 2 Mbps S112/S113/S132 32-bit ARM Cortex M4F 512 kB / 64 kB 30 8 Yes Yes No UART, PWM, PDM 1.7-3.6 V + LDO/DCDC 32 MHz & 32 kHz 8 x 8 x 0.95 85°C www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1507_R18.docx Page 5/31 ISP1507 Data Sheet 2. Specifications 2.1. General Notice The electrical specifications of the module are directly related to the Nordic Semiconductor specifications for nRF52 chipset series. Bellow information is only a summary of the main parameters. For more detailed information, especially about current consumption, please refer to the up-to-date specification of the chipset available on Nordic Semi website. 2.2. Absolute Maximum Ratings Parameter Min Supply Voltage respect to ground - VCC IO Pin Voltage Max Unit -0.3 3.9 V -0.3 3.9 V RF Input Level 10 dBm NFC Antenna pin current 80 mA Module Total Capacity 2.5 µF Module Total Inductance 15 µH +125 °C Moisture Sensitivity Level 5 - ESD Human Body Model 4000 V ESD Charged Device Model 750 V 10000 cycles Storage Temperature Typ -40 Flash Endurance ATTENTION CONSERVE PRECAUTIONFOR HANDLING ELECTROSTATIC SENSITIVE DEVICES Human Body Model Class 3A 2.3. Operating Conditions Parameter Min Typ Max Unit Operating Supply Voltage, independent of DCDC enable 1.7 3.0 3.6 V Extended Industrial Operating Temperature Range -40 +25 +85 °C www.insightsip.com The information contained in this document is the property of Insight SiP and should not be disclosed to any third party without written permission. Specification subject to change without notice. Document reference isp_ble_DS1507_R18.docx Page 6/31 ISP1507 Data Sheet 2.4. Power Consumption Typ AC variant Typ AL variant Typ AX variant Unit 6.1 6.1 6.5 mA 3.4 3.4 4.1 mA 5.8 5.8 7.1 mA System OFF, no RAM retention, wake on reset 0.3 0.3 0.3 µA System ON, full RAM retention, wake on any event 0.8 0.8 1.5 µA Additional RAM retention current per 4 KB block 40 40 40 nA Parameter Peak current, Receiver active (1) Peak current, Transmitter active -40 dBm Output Power (2) Peak current, Transmitter active 0 dBm Output Power (1) (2) (2) DCDC enable, Power supply 3V, 1 Mbps DCDC enable, Power supply 3V 2.5. Clock Sources Parameter Max Unit Internal High Frequency Clock for RF Stability: 32 MHz Crystal Frequency Tolerance (1) +/- 40 ppm Internal Low Frequency Clock for BLE Synchronization: 32.768 kHz Crystal Frequency Tolerance (1) (3) +/- 40 ppm Internal Low Frequency Clock for BLE Synchronization: RC Oscillator (2) +/- 250 ppm RF Frequency tolerance: For BLE operation Channels 0 to 39 +/- 40 ppm (1) (2) (3) Including initial tolerance, drift, aging, and frequency pulling Frequency tolerance after calibration The Low Frequency Clock 32.768 kHz is not present in AC variant 2.6. Radio Specifications Parameter Min Frequency Range 2402 Typ Channel 0 to 39 Spacing -20 Rx sensitivity Level for BER
ISP1507-AX-RS 价格&库存
很抱歉,暂时无法提供与“ISP1507-AX-RS”相匹配的价格&库存,您可以联系我们找货
ISP1507-AX-RS
  • 1+76.089731+9.20831
  • 50+75.7335550+9.16521
  • 100+74.27876100+8.98915
库存:36378
ISP1507-AX-RS
  • 500+74.27874500+8.98915
库存:36378
