7.15
0.25±0.05
2.3
H
5.00
4.75
7.94
3
Pin 5
5.20
0.65
2.60
75
Plating:
Underplating: Nickel 50µ" min.
Contact Area: 30µ" Gold plating
Solder Tails: Gold Flash
Metallic Shell: Nickel 50-100µ"
1.35
3.50
A
1.00
Pin 1
4
1.00
2
5
0.28
1
Materials:
Plastic Housing: LCP, UL94V-0, Black
Contact Terminal: Copper Alloy
Metallic Shell: Stainless Steel SUS304-1/2H T=0.25mm
R0
.1
. 40
0.35
0.8
1.85
A
Specifications:
Ø0
6.20
E
7.15
0.22 (min.)
6.90
0.78
F
Designed to comply with physical, electrical and environmental
requirements of Micro USB Standard (USB2.0)
A/B types support USB On-The-GO (OTG) interface.
0.6 (ref.)
G
Recommended PCB Layout
D
As viewed from component side General Tolerance: ±0.05
0.60
Electrical:
Voltage Rating: 30V
Current Rating: Signal (Pins 2,3,4):1.0 A
Power (Pins 1,5):1.8 A
Operating Temperature : -55°C to +85°C
Contact Resistance: 30 mΩ max.
Insulating Resistance: 1000 MΩ min.
Dielectric Withstand Voltage: 100V AC for 1 minute
Ordering Grid
3.50
2.70
C
Component Outline
USB3131
30
0230
Contact Plating
30 = 30µ" Gold
Request Samples
and Quotation
A
Packing Options
A = Tape & Reel
(1,500 Pieces per Reel)
Shell Stake Length "S"
0230 = 2.30mm
Mechanical & Environmental
Mating Force: 35N max.
Unmating Force: Initial 10N min.
Final 8N min after durability test.
Durability: 10,000 Cycles
(recommended for 1.6mm PCB thickness)
0.25
Section A:A
2.9
2.35
2.60
1.91
1.30
1.00
0.74
0.80
0.15
B
Part Number
Product Description
USB3131
Micro USB Receptacle, Type B, Through-Hole,
Vertical, With 2.30mm (Standard) Shell Stakes
Drawing Date
A
28th October 2013
By
Detail
1
2
3
4
Revision
Date
5
CC
USB3131
B PCN
B5
07/10/20
Tolerances (Except as Noted)
Length
Angle
X.X ± 0.35
X.XX ± 0.25
Units:
Metric (mm)
C
3rd Angle Projection
6
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
1/2
120
1.75±0.10
7.50±0.10
H
18036
12.00±0.10
4.00±0.10
2.00±0.10
First approximately
10pcs empty carrier
+0 .00
-0
Ø1
264
100
First approximately
22pcs empty carrier
Cover tape is empty
Round Sprocket Hole
16.0
13.3
G
Direction of Unreeling
16.5mm
F
120
Ø2
3
I/O Direction
Cover Tape
Ø13.5
Products P/N
E
Carrier Tape
Ø330mm
ø330
USB3131
120°
PCS/Reel Reels/Carton PCS/Carton
1,500
10
15,000
Detail F
6
PS
D
Detail F
Reel
Carton
Waterproof bag
Triangle Liner
Protection Tape
Label
230mm
C
1,500 Pieces/Reel
B
Product Description
USB3131
28th October 2013
By
Detail
Revision
Date
3
4
m
0m
35
Part Number
Drawing Date
A
2
Green Product Label
35
0m
m
10 Reels
1
Label
C/N
O
P/N .
5
CC
USB3131
B PCN
B5
07/10/20
Length
Angle
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
2/2
很抱歉,暂时无法提供与“USB3131-30-0230-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1500+3.560381500+0.43073
- 3000+3.441733000+0.41637
- 7500+3.323037500+0.40201
- 10500+3.1568810500+0.38191
- 15000+3.0856715000+0.37330
